12th June 2009, 00:01 | #3261 | Link |
@jdobbs
Hi! Regarding (not) having to defend/explain yourself: I must say that, in addition to your wonderful skills at program development, if nothing else, you're the most tolerant MODERATOR I've ever come across! Without mentioning names, I'm sure you know as well as I, that there are other moderators that would have "climbed all over" "turbojet" quite some time ago. Therefore, I'd like to take this opportunity to unofficially welcome you as a member of my unofficial "Thick Skin Club" ;>} |
12th June 2009, 01:49 | #3263 | Link | |
Anyways, the TSMuxer appended BD went fine through BD-RB 0.22.02, and the resulting BD-9 looks incredible... no audio sync issues, nor any video gliches...absolutely perfect. As I mentioned, this is the only time I've recieved that failure to retrieve audio error... so I'll chalk it up as an exception and not a rule...Thanks.
MBK |
12th June 2009, 12:49 | #3264 | Link |
If im doing a movie only back up to a dvd9, should the output folder contain a CERTIFICATE folder or not.
All of my previous backups worked fine with a CERTIFICATE folder. the latest version does not make a CERTIFICATE folder. sorry if this has been answered before there's too many pages to read through. |
12th June 2009, 13:12 | #3265 | Link |
Generally for movie-only it should not. Most players will play it fine with or without, but I have been told there are some that look for the CERTIFICATE and will not play AVCHD if it exists. I'm not aware of any that require it for movie-only.
12th June 2009, 13:53 | #3266 | Link | |
12th June 2009, 14:40 | #3268 | Link |
Regarding movie only backups on DVD9, I'm afraid that my Denon 2500BT will only play these if the full Blu-ray structure is there. I have to manually add the missing folders e.g. CERTIFICATE once the BD rebuild has completed. I have to do the same with AVCHDs authored from my Sony HD camcorder using Nero. Pinnacle 12 Ultimate, however, makes AVCHDs that contain the full Blu-ray structure and these play fine on the Denon.
I have an older Sony BDP-S300 that will play more or less any disc I load. |
12th June 2009, 15:40 | #3269 | Link | ||
If enabled, ImgBurn creates the missing CERTIFICATE folder for you.
12th June 2009, 16:31 | #3270 | Link | |
Programmer (or just 教务长)
Because there is no accepted standard and rules for Blu-ray content (among hardware manufacturers) when content is written to DVD5/DVD9 (also called BD5/BD9), I believe it is better for everyone to do a simple test and see what works for their players. There are 100's of brands and 1000's of models and all handle DVD media with BD/AVCHD content differently. I think it is not a good idea to request any folder presence or absence in BD-RB's movie only output (for BD5/BD9). Also, having ImgBurn adding folders (by default) when they're not wanted is another issue. I asked ImgBurn's author to remove this 'feature', because it is always better to be sure that your DVD/BD-R disc will contain only the folders you added. There is no need of AI when it comes to this. Dean |
12th June 2009, 17:18 | #3271 | Link |
Just to let you know, I also had the stuck at 50% problem with both passes including muxing.
Windows 7 RC1 X64 x264 that came with build 22.02 It's my first disc with this build INI: Code:
[Options] RESIZE=0 MODE=1 ENCODE_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=10150 TARGET_SIZE=10150 [Paths] SOURCE_PATH=I:\TRANSFORMERS\TRANSFORMERS_D1_EU\ WORKING_PATH=I:\TRANSFORMERS\BDREBUILDER\ Last edited by spida_singh; 12th June 2009 at 17:25. |
12th June 2009, 19:08 | #3272 | Link |
I have just tried to load in the mummy 3 tomb of the dragon emperor on version 22.02 on full backup and i am recieving this error (the selected path length exceeds current limits. cannot process)The size of the disk is 45.8 GB any ideas?
12th June 2009, 19:12 | #3273 | Link | |
I should be able to make some determinations as to whether it is 23.976 pulldown and correct for it. Just as a point of reference... WMP also plays that stream off the original commercial disc out-of-sync. Apparently it ignores pulldown as well (which explains why the frame serving only created enough frames for 23.976). Last edited by jdobbs; 12th June 2009 at 19:36. |
12th June 2009, 19:18 | #3274 | Link | |
Make a new directory mummy3 in the root and copy all of the sub-directories (e.g BMDV, Certificate etc) to it then try again. |
12th June 2009, 19:22 | #3275 | Link | |
That's one of those things I've been meaning to correct (by using a newer call) but have never gotten around to it (because it so rarely happens). [edit] Guess I'm too slow on the trigger. drmih beat me to the answer. |
12th June 2009, 22:36 | #3277 | Link |
just got a x264 appcrash. x264.exe has stopped working here is the details.
Problem Event Name: APPCRASH Application Name: x264.exe Application Version: 0.0.0.0 Application Timestamp: 4a1eb070 Fault Module Name: wmvdecod.dll Fault Module Version: 11.0.6001.7000 Fault Module Timestamp: 4791a820 Exception Code: c0000005 Exception Offset: 000cdf7d OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 2057 Additional Information 1: fd00 Additional Information 2: ea6f5fe8924aaa756324d57f87834160 Additional Information 3: fd00 Additional Information 4: ea6f5fe8924aaa756324d57f87834160 |
12th June 2009, 22:45 | #3280 | Link |
Banned
jdobbs? will there ever be a resume / pause from the last current progress / overall progress available in the future?
and i love the program best ive used, so far only stable version for me is 20.09 |
