#5581 | Link |
@Persecutor;
What are you trying to play the movie back with? Standalone or PC, PowerDVD, etc... Also, if you play the BD-RB encoded file 00000.m2ts with MediaPlayer Classic, do you hear the audio? If you open the 00000.m2ts file with tsMuxeR, does it show an audio file present? |
#5582 | Link |
jdobbs i need an advice, like you know, i commented before about some problems with music blurays (like foo fighters, elton john), after bd rebuilder works its done, no letters on option are displayed on the menu, i was wondering, if i do a movie only and use that 00000.m2ts on the original bluray, and burn it, maybe it should work as normal? cause i had only compressed the main movie, and everything else would be untouched, or it isnt so easy as i say? hope you can answer me, thx
#5583 | Link |
late audio sync issues
hey JD.
Still trying to figure out the best way to correct an audio offset. Basically, after rebuild , a feature length movie remains in sync for the first 1/3rd. then the sync drifts further and fyrther out. Is there a one time fix, or does eash file require tweaking/ Thanks. |
#5585 | Link | |
![]() Join Date: Oct 2001
#5586 | Link | |
#5589 | Link | |||
Frankly I would be content if you set high quality settings (only setting I use for final results) back to how they were originally or just allow a few changeable options through ini. With the latter I can see users coming back saying there settings weren't used even though they are fully compliant. Also I did another full backup with 2 pass extras and output was again within 1000 KB if 1 MB = 1000 KB. I notice with CRF extras the more extras there are the more it goes over. Have you been able to look into seeing if 1 MB = 1000 KB? Last edited by turbojet; 13th October 2009 at 08:47. |
#5590 | Link |
@jdobbs:
Are there any plans for feature enhancements in the near future? One that I'm personally waiting for is the ability to "blank" certain m2ts's (trailers, fbi warning, etc..) on full-disc backups (in a similar way that VOBBlanker does it for DVD). Do you think that would happen soon? |
#5591 | Link |
Short encoding question:
Is it qualitywise *absolutely safe* to use One-Pass CRF encoding (HQ) for BD-25 Movie-Only? Or would it be better to use Two-Pass encoding even at those high bitrates? I suspect there would be no benefits except for an more exact output size, right? Last edited by samtroy; 13th October 2009 at 12:04. |
#5592 | Link | |
#5593 | Link |
1 pass CRF and 2 pass use the same mechanics in x264 so for equal file size the quality is almost identical. Of course if your CRF encode is smaller, you'll get less quality. But I'll doubt that you'll notice any difference for 50-100kbit/s (if the CRF encode is slightly smaller) at these high bitrates so it should be safe to use the CRF mode.
It would be best to use a hard to encode sample (e.g. a very long action movie) and try both ways and compare the quality. |
#5595 | Link | |
#5596 | Link |
True. But CRF has been optimized very well, and the difference isn't as great as some think.
Hmmm.... I wonder if there is a graph around anywhere in which the bit distribution has been analyzed for comparison between the two. I'm sure sombody has done that by now. |
#5597 | Link | |
To me, this sounds like a bad thing for quality fanatics, and a good thing for not very perceptive people. I'll admit, however, that I don't fully understand the way it operates so I could be wrong. If there's a tool to analyze h264 streams, I'll make two encodes and compare the graphs. |
#5598 | Link | |
x264 developer
