#15382 | Link | |
- Playing the extracted DTS (00506.track_4352.dts): plays OK, audible ![]() - Playing the derivated AVS (AUD_00506_4352.AVS): plays with no sound and an error message (MTAudioDTSDsource: unable to open file "00506.track_4352.mts" ) ![]() Does this imply that my issue with failing to encode to AC3 is not due to AFTEN but rather to AviSynth? ![]() |
#15384 | Link | |
![]() Join Date: Oct 2001
1. Is DTS encoding enabled in your FFDSHOW audio configuration? 2. Do you have some other DTS decoder that is interfering with DirectshowSource()? Codec packs installed? It's significant that MPC can play the source but DirectshowSource() can't. Last edited by jdobbs; 22nd July 2012 at 14:49. |
#15386 | Link | ||||
Mmmmh. That's a tough one. ![]() ![]() So my next move will be to multi-boot this computer with a fresh XP install, so to determine for sure if the problem lies with the config/software or with the hardware (which is still a possibility...) |
#15387 | Link | ||
![]() Fresh bd-rb install on a fresh XP SP3 partition: Quote:
![]() MSI 770-C45 (AM3) Phenom II X4 965 4GB RAM (checked) I'm not knowledgable enough to know if an extension card (or its drivers) may interfere with audio decoding/encoding? Is it worth it to even try removing some PCI cards? (I have and IDE extension card and a Parallel port extension card). ![]() - |
#15388 | Link | |
Like I said, not a high probability of success, but easy enough to try. |
#15389 | Link | |
![]() Sadly, I'm always using the same BD rips (external HD) on both machines. Nice try, though. ![]() |
#15390 | Link | |
![]() Curiosity is awesome. JDobbs, Okay.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 22nd July 2012 at 20:22. |
#15391 | Link |
Having an issue with "ALIENS". It's 87% complete, then suddenly:
---------------------- [07/22/12] BD Rebuilder v0.40.11 (beta) [13:39:59] Source: ALIENS - Input BD size: 44.51 GB - Approximate total content: [03:22:30.636] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [13:40:01] PHASE ONE, Encoding - [13:40:01] Processing: VID_01136 (27 of 42) - [13:40:01] Reencoding video [VID_01136] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,768 frames - Bitrate: 11,997 Kbs - [13:40:01] Reencoding: VID_01136, Pass 1 of 2 - Encode failed. Aborting. - BD-Rebuilder v0.40.11 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [13:40:01] - Failed video encode, aborted ---------------------------------------------- Says everything is "OK", but fails anyway. Any thoughts? |
#15393 | Link |
JDobbs,
I have encountered a problem using version 40.11. I saw the posts about a Matrix backup that failed, and I had recently done a backup of the Matrix which gave me odd sized results, so I thought I'd look at that again. My first attempt at backing up The Matrix worked, using 40.10, but the file size ended up being too big for a BD-25. Eh, oh well, it happens. So I decided to try again with a custom size of 21500, but since 40.11 was now out I figured I'd use it as well. It failed with this error - Error in attempt to multiplex: MUX_00000.meta - Can't open file: D:\BD REBUILDER\WORKFILES\VID_00000_2.AVS.1.264 So I rolled back to 40.10 and it works fine. Since 40.10 worked, I once again tried 40.11. Same error. In summary, the backup completes with 40.10 and fails with 40.11. I have done it twice with each version, failed twice with 40.11 and succeeded twice with 40.10. I don't want to clutter up the posts with a ton of info if you don't need it, but I do have the output text files and config file if you need them. What info would you like? |
#15394 | Link | |
That filename references the secondary video track. It looks like it was never created. The ".1." means you are using multiprocessing mode... you might try turning it off to see what happens. Last edited by jdobbs; 23rd July 2012 at 01:46. |
#15395 | Link | |
#15396 | Link |
JDobbs, the "The Matrix" - Bonus, In-Movie Experience also play correctly for you? Not just the movie..? With 40.11?
#15397 | Link | |
#15398 | Link | |
[Edit] Never mind, I see it. Yes it is working correctly. I'm playing it right now. Last edited by jdobbs; 23rd July 2012 at 02:05. |
#15399 | Link | |
If this one fails as well I will try a movie only backup. Or whatever you want for a next step. ![]() EDIT: I tried a Movie Only backup with 40.11 and it works. So my guess would be that something related to that Secondary Video stream is behaving differently in .11 than it was in .10. (Also, is there any way to blank secondary streams? The only way I can seem to get it blanked is with the Movie Only option, but that loses the menus too, right?) Edit 2: I tried a Full Backup, changed the setting back to a target size of BD-25 and the encoding to Highest (just to shake things up a bit) and it still fails. The only way I can complete a backup of the Matrix with 40.11 is if I do a Movie Only backup. So far all of these attempts have been with multiple processors active. I will start another backup without the multi support and see what that does. Last edited by Chuckwagon; 23rd July 2012 at 08:29. |
#15400 | Link |
Sweet! I put a # before the MULTIPROCESS=4 and tried it with High Speed Option for testing. Nice. It functions well. I was wondering about the audio in some parts, as I didn't remember it "cutting" in and out like that in between images. I checked it with the original and same. They could have made that a bit smoother, but...Meh...it's cool. Now I'll do it at Very Slow soon. This is with 40.11.
Thanks J! I'll test "The Incredibles" tonight the same way. Another donation coming. I haven't forgotten.
