#17701 | Link |
![]() Join Date: Oct 2001
Uninstall any "CODEC packs" you may have installed. Uninstall and reinstall AVISYNTH, FFDSHOW, and HAALI. If there is an issue, it's likely because some other CODEC or software you've installed is interfering with the normal frame-serving process.
#17703 | Link | |
A minor issue: 1440x1080 on BD9 still seems to start with the CRF 11.00 30.50 ... sequence. Just wondering if this is intentional or a leftover from the previous version? |
#17706 | Link |
BD-RB checks to make sure the VC-1 setting is correct in FFDSHOW. But, unfortunately, if some other software intercepts it -- there is no way to detect it. All you can do is uninstall and reinstall so that FFDSHOW becomes the assigned CODEC again.
#17707 | Link |
I'm wondering if anyone else has noticed this when importing a QuickTime (MOV) from iPhone 5? The Framerate is different than what QuickTime, or VLC shows. Any ideas? A Bug? [02:16:38] Importing MOV: IMG_0487 - Preparing MOV for processing... - Collecting audio/video streams from source... - Warning: Framerate [29.94fps] not BD compliant. - Converting audio, Track #2, AAC to AC3... - Building pseudo-BD source structure... [02:17:21] Video import completed successfully. ---------------------- [07/28/13] BD Rebuilder v0.44.15 (beta) [02:17:42] Source: IMG_0487_00000 - Input BD size: 0.51 GB - Approximate total content: [00:04:03.620] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Output folder: H:\!Blu-ray\ - Decoding/Frame serving: DirectShow [4-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [02:17:44] PHASE ONE, Encoding - [02:17:44] Processing: VID_00000 (1 of 1) - [02:17:44] Extracting A/V streams [VID_00000] - [02:18:05] Reencoding video [VID_00000] - Error: Video framerate is illegal/unknown. [02:18:05] - Failed video encode, aborted Thanks.
#17708 | Link |
Amiga, where's the rest of the log? Inspect.exe settings? Don't know if it'll be related but there's an ! in the output path. There have been issues in the past with "weird" signs in the path causing issues, but don't know if that's the case here too.
#17709 | Link | |
I can import from my iPhone 4s with no issues. |
#17710 | Link | |
@ jdobbs Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 498 MiB Duration : 4mn 3s Overall bit rate : 17.2 Mbps Recorded date : 2013-06-29T14:27:45-0800 Encoded date : UTC 2013-06-29 22:27:45 Tagged date : UTC 2013-07-28 09:18:26 Writing application : 6.1.3 Writing library : Apple QuickTime 7.6.6 com.apple.quicktime.make : Apple com.apple.quicktime.creationdate : 2013-06-29T14:27:45-0800 com.apple.quicktime.location.ISO6709 : +61.3094-149.5467+153.729/ com.apple.quicktime.software : 6.1.3 com.apple.quicktime.model : iPhone 5 com.apple.quicktime.player.movie.audio.m : (Binary) Model : iPhone 5 cxyz : +61.3094-149.5467+153.729/ Make : Apple Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 4mn 3s Source duration : 4mn 3s Bit rate : 17.1 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable -- Because of this? Frame rate : 29.970 fps Minimum frame rate : 28.571 fps Maximum frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.275 Stream size : 496 MiB (100%) Source stream size : 496 MiB (100%) Title : Core Media Video Encoded date : UTC 2013-06-29 22:27:45 Tagged date : UTC 2013-06-29 22:27:57 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 4mn 3s Source duration : 4mn 3s Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 1.82 MiB (0%) Source stream size : 1.82 MiB (0%) Title : Core Media Audio Encoded date : UTC 2013-06-29 22:27:45 Tagged date : UTC 2013-07-28 09:18:26 Any suggestions? Edit 1: The file "AUD_00000.meta" contains.. MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "E:\BLU-RAY\REBUILDER\IMPORTS\IMG_0487\BDMV\STREAM\00000.m2ts", fps=23.976, track=4113 A_AC3, "E:\BLU-RAY\REBUILDER\IMPORTS\IMG_0487\BDMV\STREAM\00000.m2ts", track=4352, lang=und The file "VID_00000.AVS" contains.. #Created by BD Rebuilder - v0.44.15 (beta) DirectshowSource("E:\BLU-RAY\REBUILDER\IMPORTS\IMG_0487\BDMV\STREAM\00000.m2ts", fps=, audio=false) ConvertToYV12() Looks like the blank ftp= is at fault? --- Perhaps not... Looked at LASTCMD and noticed the end result: "C:\Users\UserName\Desktop\BD_Rebuilder\tools\x264.exe" "E:\BLU-RAY\REBUILDER\WORKFILES\VID_00000.AVS" --preset medium --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 35000 --level 4.1 --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --fake-interlaced --threads auto --slices 4 --thread-input --stats "E:\BLU-RAY\REBUILDER\WORKFILES\VID_00000.AVS.264.stats" --pass 1 --output NUL avs [error]: Script error: syntax error (E:\BLU-RAY\REBUILDER\WORKFILES\VID_00000.AVS, line 2, column 86) x264 [error]: could not open input file `E:\BLU-RAY\REBUILDER\WORKFILES\VID_00000.AVS' Peculiar, even though the file is there and plays well.. Checking..
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 28th July 2013 at 21:56. |
#17711 | Link | ||
I have no idea why it reads 29.97 now and 29.94 earlier -- but BD-RB simply reports what MEDIAINFO said at the time. Last edited by jdobbs; 29th July 2013 at 13:23. |
#17712 | Link |
Would you like the file that it's doing it with and notice if it happens with your computer? It's a small outdoors clip of Celtica. Maybe your system will process it correctly?
#17714 | Link |
Sorry, I have a stupid question. Are there beta versions for download, or do I just have to wait until the next major update in order to put Taken 2 into mkv?
I'm fine either way, just wanted to know if I was missing something...haha. Can't thank you enough for this amazing program! |
#17715 | Link | |
#17716 | Link |
#17718 | Link |
Having problems converting Dead Man Down to DVD and managing forced subtitles.
Please be advised that I ran this BD title through Clown-BD in order to retain the forced subtitles, since BDRB doesn't handle them correctly for this title. Note that BDRB sees the extracted subtitle stream fine, and converts it, but then cannot integrate it into the output. [07/31/13] BD Rebuilder v0.44.15 (beta) [11:04:42] Source: DEADMANDOWN-BD_00000 - Input BD size: 24.73 GB - Approximate total content: [01:57:47.050] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [1] is defaulted ON. - Audio [1] set to default. [11:04:42] PHASE ONE, Encoding - [11:04:42] Processing: VID_00000 (1 of 1) - [11:04:42] Extracting A/V streams [VID_00000] - [11:10:59] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 169,440 frames - Bitrate: 4,662 Kbs - [11:10:59] Reencoding: VID_00000 - [12:37:11] Video Encode complete - [12:37:11] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [12:41:26]PHASE ONE complete [12:41:26]PHASE TWO - Rebuild Started - [12:41:26] Building ALTERNATE OUTPUT Structure - [12:41:26] Converting 2 subtitles to DVD format. - [12:42:02] Starting MPLEX. - [12:44:41] Multiplexing 2 subtitles into stream. - WARNING: Failed to integrate Subtitle_02 - [12:47:29] Building DVD File Structure. [12:50:23] - Encode and Rebuild complete [12:50:23] JOB: DEADMANDOWN-BD finished. |
#17720 | Link |
There seems to be an issue with the EU release of "Oblivion". (Volume name OBLIVION_G51 barcode 5050582938456) The main title VID_00023, keeps holding on "Completing remainder of DGDecNV indexing...". Can be like that for dozens of minutes till i finally abort the encode. At times resuming then instantly does that, it resumes with encoding (as if the indexing is done). No such issues when swapping to FFDshow
