#22122 | Link |
![]() Join Date: Oct 2001
What are you using to install them? They aren't showing as installed in the system registry. Use the link on the first page of this thread for installation.
If it is installed correctly you will see "- LAVFILTERS: Ok" in INSPECT, and none of the FFDSHOW settings will be checked. |
#22123 | Link | |
I'm using the install link supplied on this forum link, v0.63. What's really bizzare is I have run successful backups on another PC with the exact same source, exact same setup (LAV only) and exact same output settings and the mkv output file plays perfectly on any machine on my LAN. AND the INSPECT output does NOT show any reading on LAV filters as you state above. Here is the INSPECT output on the PC producing a correctly playing output - - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: Not installed - FFDSHOW doesn't appear to be installed - FFDSHOW Audio doesn't appear to be installed - WIN7 preferred AVC CODEC: Not Set correctly - WIN7 preferred VC-1 CODEC: Not Set correctly - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set incorrectly: [0] - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set incorrectly: [0] - AnyDVD settings check: Ok. - BD-RB v0.50.0.2, not current and yet HKEY_CURRENT_USER in the registry clearly shows a LAV entry. What the hell???? |
#22125 | Link | |
#22127 | Link | |
[01/18/15] Checking System Settings - BD-Rebuilder v0.50.02 - Windows Version: 6.1 [7601] - Working Path Free Space: 100.82GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01/18/15] Systems Settings Check complete On the PC not behaving and - [01/18/15] Checking System Settings - BD-Rebuilder v0.50.02 - Windows Version: 6.1 [7601] - Working Path Free Space: 632.08GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01/18/15] Systems Settings Check complete On the one that does. So now what??? ![]() |
#22128 | Link |
Hello,
since version 0.50.0.2 alternate output doesn't work for me. I tried to encode mp4-1280*720-acc by setting 2 pass encoding with a fixed size (third option). When I start encoding a pop up appears telling me that the audio is too big to fit into the fixed size and suggests crf. The same happens if i choose the 2 pass encoding with fixed bitrate (second option). In the moment I use version 0.50.01 for alternate encoding. additionally if i tried to upscale an imported dvd and encode it to mp4-1280*720-acc a pop up appears telling me about an h.264 error. Is it possible that's because the imported format is interlaced? |
#22129 | Link | |
#22131 | Link |
Just finished a quick test
[01/18/15] BD Rebuilder v0.50.02 [16:50:39] Source: 00800_00000 - Input BD size: 7.62 GB - Approximate total content: [00:30:00.590] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [16:50:39] PHASE ONE, Encoding - [16:50:39] Processing: VID_00000 (1 of 1) - [16:50:39] Extracting A/V streams [VID_00000] - [16:51:13] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 43,171 frames - [16:51:14] Reencoding: VID_00000, Pass 1 of 1 - [16:55:56] Video Encode complete - [16:55:56] Processing audio tracks - Track 4352 (eng): Keeping original audio [16:55:56]PHASE ONE complete [16:55:56]PHASE TWO - Rebuild Started - [16:55:56] Building ALTERNATE OUTPUT Structure [16:56:12] - Encode and Rebuild complete [16:56:12] JOB: 00800 finished. |
#22132 | Link |
Having an issue with BD Rebuilder v0.50.02 it think?
I rip my own disc of The Equalizer using DVDFab 9.1.7.1 I will start by saying when I installed BD v0.50.02 id said my set up was not correct and it could correct it. So I let it? Now running Inspect shows this: - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, not recommended version - HAALI Splitter: Ok - FFDSHOW: 4504, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD-RB vUNKNOWN, not current I haven't even gone into my issue yet Just trying to get my set up correct ? What AVISYNTH version is recommended? And what about FFDshow ? And I don't remember BD version ever showing as unknown and not current? All my issue just might be do to the above setup? I am experiencing video freezing and video was not touched? Movie only mode converting DTS MA to AC3 [Status] LABEL=THE_EQUALIZER VERSION=v0.50.02 SOURCE_SIZE=26777235456 SOURCE_VIDEO_SIZE=26777235456 TARGET_SIZE=25690112000 REDUCTION=.959401206379712 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=10 REBUILD_COMPLETE=1 [00002] AUDIO=1 PGS=01 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=275281894 USE_ORIGINAL=1 NSIZE=0 FLINK=-1 MLINK=0 [00003] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=374505039 USE_ORIGINAL=1 ---------------------- [01/17/15] BD Rebuilder v0.50.02 [18:58:00] Source: THE_EQUALIZER_00000 - Input BD size: 24.94 GB - Approximate total content: [02:12:02.914] - Target BD size: 23.93 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [18:58:01] PHASE ONE, Encoding - [18:58:01] Processing: VID_00002 (1 of 10) - [18:58:01] Extracting A/V streams [VID_00002] - [19:12:53] Reencoding video [VID_00002] - [19:12:53] Keeping original video (no reencode) - [19:12:53] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [19:18:21] Processing: VID_00003 (2 of 10) - [19:18:21] Extracting A/V streams [VID_00003] - [19:18:49] Reencoding video [VID_00003] - [19:18:49] Keeping original video (no reencode) - [19:18:49] Processing: VID_00004 (3 of 10) - [19:18:49] Extracting A/V streams [VID_00004] - [19:21:07] Reencoding video [VID_00004] - [19:21:07] Keeping original video (no reencode) - [19:21:07] Processing: VID_00005 (4 of 10) - [19:21:07] Extracting A/V streams [VID_00005] - [19:23:46] Reencoding video [VID_00005] - [19:23:46] Keeping original video (no reencode) - [19:23:46] Processing: VID_00006 (5 of 10) - [19:23:46] Extracting A/V streams [VID_00006] - [19:28:19] Reencoding video [VID_00006] - [19:28:19] Keeping original video (no reencode) - [19:28:19] Processing: VID_00007 (6 of 10) - [19:28:19] Extracting A/V streams [VID_00007] - [19:29:55] Reencoding video [VID_00007] - [19:29:55] Keeping original video (no reencode) - [19:29:55] Processing: VID_00008 (7 of 10) - [19:29:55] Extracting A/V streams [VID_00008] - [19:31:40] Reencoding video [VID_00008] - [19:31:40] Keeping original video (no reencode) - [19:31:40] Processing: VID_00009 (8 of 10) - [19:31:40] Extracting A/V streams [VID_00009] - [19:37:11] Reencoding video [VID_00009] - [19:37:11] Keeping original video (no reencode) - [19:37:11] Processing: VID_00010 (9 of 10) - [19:37:11] Extracting A/V streams [VID_00010] - [19:39:58] Reencoding video [VID_00010] - [19:39:58] Keeping original video (no reencode) - [19:39:58] Processing: VID_00011 (10 of 10) - [19:39:58] Extracting A/V streams [VID_00011] - [19:45:35] Reencoding video [VID_00011] - [19:45:35] Keeping original video (no reencode) [19:45:35]PHASE ONE complete [19:45:35]PHASE TWO - Rebuild Started - [19:45:35] Rebuilding BD file Structure [20:11:10] - Encode and Rebuild complete [20:11:10] JOB: THE_EQUALIZER finished. The weird part burned Movie to a dual Layer BD 50GB and no freezing. Burned BD single layer after just converting Audio and have the freezing. That why think it a BDRD issue. |
#22136 | Link | |
- Windows Version: 6.1 [7601] - AVISYNTH Version: 2.6.0.5, not recommended version - HAALI Splitter: Ok - FFDSHOW: 4504, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD-RB vUNKNOWN, not current |
#22137 | Link |
Are you sure you're executing the EXE you think you are? It's pretty hard for BD-RB to find the wrong version of itself. You'll need to uninstall AVISYNTH and FFDSHOW first, then then install the versions linked in the first post. Somehow the system isn't seeing the new install.
#22138 | Link | |
#22139 | Link |
We'll there's likely your problem, 2.6.0.5 is not the official recommended version. As such bug reports with unsupported versions are not accepted, to the disc again with the supported versions. If you will have the same problem, then come back.
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
#22140 | Link | |
Won't know if it cause Video to freeze untill I redo again tomorrow. - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, not recommended version |
