#4201 | Link | |
SLOVEHEART
1) the international (usa) BD50 used anydvdhd to rip to hard drive 2)bd rebuilder, I have installed all tools that come with bd rebuilder, the latest ffdshow, markosi splitter, avi snth latest. I used one pass encoding (high speed encoding (for bd25)) kept hd for bd25, didn't use trellis encoding, didn't downmix dts to ac3, kept all languages and subtitles. 3)the green lettering may be due to checking verbose status reporting? it starts after loading during trailers, then stops and restarts when movie begins to play. it seems to be file and settings information, the beginnings of the lines are cut off on my panasonic viera 46 pz85u 1080p tv, so I will post what is legable: xx.xx% ? size:1920x1080 ? size:1920x1080 ? description: AVC(libavcodec h264) ?:libavcodec h264 FPS:23.976 ? file name: 00011.m2ts ?file:C:\jeff's documents\anydvdhd\volume id\bdmv\stream\00011.m2ts ? aspect ratio SAR:1/1, DAR:16/9 /size and aspect ratio: 1920x1080 SAR:1/1, DAR 16/9 how does one get encoding w/o these details in upper lefthand corner? ![]()
ROSE... |
#4202 | Link | |
Webmaster
![]() Last edited by tekmobile; 27th July 2009 at 20:08. |
#4203 | Link | |
SLOVEHEART
YES I did have it selected, I am not very knowledgable about ffdshow, do you think this is the reason it showed up in the output? I thought it meant that ffdshow would show on desktop when in use. the items selected in the second window seem to correspond to the green lettering that showed up on the output...should i uncheck both OSD boxes??? Thanks for the help...
ROSE... |
#4204 | Link | |
Webmaster
#4205 | Link |
SLOVEHEART
thanks for the help w/ffdshow problem
okay great, I learned something, I know ffdshow is used when i use moviemaker to encode dvr-ms files to dvd output, however the tray icon is blue rather than red, i guess that means it is the audio encoder rather than the video encoder... anyway thanks for your help - i appreciate the effort and time to assess a fairly stupid mistake. thanks again...
ROSE... |
#4206 | Link | |
Webmaster
We all make mistakes thats how you learn |
#4207 | Link | |
I am checking Beowulf, Region A, NTSC, but not sure which column to look for it. BDMV, Playlist or Clipinf do not show IG, so maybe this disc does not have it. EDIT: Is it just me, or does BDEdit's values not align/fit within the display boxes? Last edited by Capsbackup; 28th July 2009 at 00:07. |
#4208 | Link |
Using BDRebuild 0.25.04, can't encode AVP2.
[23:29:17] BD Rebuilder v0.25.04 (beta) - Source: AVP2 - Input BD size: 25.25 GB - Approximate total content: [01:41:05.016] - Target BD size: 4.27 GB - MOVIE-ONLY mode enabled [23:29:17] PHASE ONE, Encoding - [23:29:17] Extracting A/V streams [VID_00010] - Error in attempt to extract audio/subs. - Can't create output file H:\WORKFILES\00010+00050+00011+00051+00012+00052+00013+00053+00014+00054+00015+00055+00016+00056+00017+00057+00018+00058+00019+00059+00020+00060+00021+00061+00022+00062+00023+00063+00024+00064+00025+00065+00026+00066+00027+00067+00028+00068+00029+00069.track_4352.dts [23:29:17] - Failed to retrieve audio, aborted The problem is likely the fact that it's trying to create a file that is 268 characters long (including the path). Vista only allows full path/file lengths of 260 characters. I specified the root of a drive as the working path so I can't make the path any smaller. |
#4209 | Link | |
Programmer (or just 教务长)
![]() ![]() Go to Playlist tab, select the movie playlist (you may need to click 'read') then take a look on the right where you see the "STN" groupbox: Vid/Aud/PGs/IGs/sVid/sAud/pid Video, Audio, Presentation graphics (subtitles), Interactive graphics (menu), Secondary video, Secondary audio... Dean |
#4211 | Link |
![]() Join Date: Oct 2001
That's a little odd. That means there is no audio -- which probably means you aren't looking at the main-movie. I'm not sure if you are familiar with BDEdit, but there is a dropdown box under xxxxx.mpls that lets you select from all the playlists. You have to step through them until you find the one that represents the movie w/PiP. Each time you select an MPLS the attributes change.
#4212 | Link | |
BDEdit should be for .00006.mpls: Vi=1, Au=3, PG=7, IG=0, sV=1, sA=0, PIP=0. BDEdit for .00008.mpls: Vi=1, Au=3, PG=6, IG=0, sV=1, sA=0, PIP=0. I can't blame my eyes for this mistake!! ![]() |
#4213 | Link |
Pardon Me,but does anyone here have to use AVCHD Patcher. The first few BD_RBLD movies I did refused to play on my ancient DMP-BD30 unless I ran the patcher on the index.bmmv. I still use it but I don't think it does anything anymore because it doesn't create a index.bdmv.bkup. It used to say patch completed and create a bkup, I think now it just checks the index.bdmv and if it is ok leaves it alone. Does anyone know if this is the case or if it needs to be used anymore? Does it create the chapter play issues I keep having with my full disk backups. Watchmen BD-25 movie only plays but if you hit chapter seek or FF it freezes up the player. I took it to BB and tried multiple players and all freeze up, I have a friend with a PS3and he has the same problem. Is it my Vista OS or the software I have installed or what? Does anyone else have this problem? I have made lots of playable BD-9 movies but for some reason this Watchmen movie only in BD-25 is really a big pain, I have spent 48 Hrs of encoding time and still no love. Ay Carrumba! Please help, I want to move on from this disaster, I can hope when I watch it that it's worth all the hassle. Any help will be greatly appreciated.
#4214 | Link |
@worknstiff:
If you're using BD-25 as media and full-movie backup you don't need avchd patcher, because you're using blu-ray disc media. If you're creating movie-only backup then it is different. You can try to use strict avchd mode and remove folders like auxdata and certificate before burning. Did you try to play the output folder with a software player? |
#4217 | Link |
I may have missed this, but I'm having a problem with a few discs, I'm trying to shrink 'Dr Who Planet of the Dead' and Torchwood Season 2 and 3 to BD25 as full discs, but I can't get it to work, as soon as I choose the BD25 option the main large video files disappear, it works fine with the other 100 plus discs I've done including other TV series discs but not with these.
One thing I have noticed is that when it lists them before I choose the BD 25 option it tells me that the files are '29.97**' with the two asterisks after the frame rate |
#4219 | Link | |
Webmaster
#4220 | Link |
hey jdobbs on this lastest beta i had tried like 3 or 4 blurays withhigh speed encode to bd-25 and noticed some blockiness i hadnt notice before! maybe something its wrong with the lastest x264 codec or something? im redoing those blurays with default settings!
