#5181 | Link |
![]() Join Date: Oct 2001
BD Rebuilder v0.29.04
I have just updated the link of the first page of this thread to a new version of BD-RB (v0.29.04). Changes for this version:
- Made one more adjustment to prevent "GUI Issue, no hWnd returned". I think this may be gone for good now. It finally became clear as to what was causing this to randomly occur. - Fixed an error in which progressive output could under some circumstances be created at an illegal (29.97fps, 25fps) framerate. - Changed the default processing for interlaced sources. All sources that are interlaced now are kept interlaced in the output. This means the "KEEP_INTERLACING" INI setting has been removed (as unnecessary) - Added a "DEINTERLACING=" hidden option, see the description in HIDDENOPTS.TXT for details. - Changed the type of AVISYNTH preprocessing used to ensure comb-free deinterlacing. Interlaced sources should be more crisp, and free of jagged edges now. - Corrected a "Selected source is not BD format" error that could happen on very small sources. - Added a "quick search" function to identify sources that are Bottom Field First (BFF) interlaced. - Added code to scan all M2TS files and find audio streams that have delayed PTS times (for correction). - Other minor corrections and cosmetic fixes. |
#5182 | Link | |
#5183 | Link | |
Thanks for the excellent work! |
#5184 | Link | |
Interestingly, this is pretty rare -- I could only find one other disc of my standard working/test set that had an offset, and it wasn't enough to matter (about 6ms). But you have to cover all scenarios. The new scan will probably add a couple of seconds to the initial scan of most discs when you select the source path. As long as I was scanning anyway -- I also added code that looks for the TFF flag on video streams -- so I can sense when a source was BFF (but not pulldown)... which, by the way, turned out to be part of the the issue with the "Making Of" extras on "The Matrix". Last edited by jdobbs; 13th September 2009 at 23:18. |
#5185 | Link | |
If the original .mpls/m2ts shows a delay, for example Batman Begins 83ms, should BD-RB's backup also show a delay in the same mpls/m2ts? If one chooses to keep HD audio and do not reencode ac3, will this delay be maintained per example above? Or is there another method for you to correct/address the delay? I guess I am just curious how to determine that the delay is correct besides the visual check I always perform anyway. ![]() |
#5186 | Link | |
#5187 | Link | |
My experiment with Batman Begins, doing just this and remuxing it back into BD-RB would still not bring the audio in sync. Only after editing the BD-RB meta file for this m2ts file to "time shift=250",( 83ms was not enough) then rebuilding that m2ts thru the command line, and then substituting this new m2ts into the BD-RB rebuild was I able to get the audio in sync. I noticed that when checking this new mpls/m2ts created with BD-RB with tsMuxeR, it now also showed the 250ms delay. This worked for me for this disc, be it cumbersome, audio was now in sync. So, not to be a bother, but this method of timeshift within the BD-RB meta file also works, and seems to reflect the original mpls/m2ts as well. |
#5188 | Link | |
#5189 | Link | |
However, just editing and saving this meta file inside the Workfiles folder was not working. Upon rebuild, BD-RB would change/correct my edits to back to the original meta. I had to run that edited meta from the command line, and then substitute this new m2ts/clpi into the BD-RB Workfiles folder for a new rebuild. ( Using a creative rebuild, canceling the rebuild just after the final m2ts is created, substituting the new m2ts/clpi for the ones BD-RB just rebuilt, and then selecting rebuild again and letting BD-RB just integrate all those m2ts/clpi/mpls files into the new BluRay structure. ![]() EDIT: I will be curious if you have audio sync this first time try. Though 83ms is the original delay, this was not enough to correct the async for me. Only after several tests/burns to BD-RE did I finally get audio sync, but it took 250ms. Definately an odd disc! Last edited by Capsbackup; 14th September 2009 at 00:59. |
#5190 | Link | |
I've corrected it for the next release. Luckily there aren't very many discs out there that need it. |
#5191 | Link | |
#5192 | Link | |
Thanks for checking and generally for your awsome program ![]() |
#5194 | Link |
It means that all the audio and subtitle selections you have made combined are already too big to fit on the output disc size you've chosen -- even without the video. The only way you can fix it is to either choose a bigger output size or select fewer audio/subs to keep. FORCE_ENCODE won't help becaus you can't reencode to a negative size... this is most likely seen when LPCM or lossless tracks exist and you're trying to output to BD-5/9.
#5195 | Link | |
#5196 | Link | |
#5197 | Link |
This bug is called "The Case Of The Missing Menu Text". But I don't think it's really a bug!
I've had 3 rebuilds that have ended up "stuck in an endless loop" on the top menu, because the "button text" is not there. I'm talking about the "Play", "Audio Select", "Special Features"....., etc "buttons". On one of them (Elton 60), I'm able to use my player's "Go-To" button & then manually select the main title & then the disc takes off & plays fine. Even the pop up menu works to navigate chapter to chapter. The other two, (Dave Matthews Radio City & Baraka) wont allow me to do that. On the latest one to fail, (Baraka) I did a little investigation With BD Info & found the culprit. The "interactive graphics stream (IGS)" is missing from the rebuilt menu video's remux. Here's the Original: Name_________Time In_______Length 00012.M2TS___0:00:00.000___0:08:45.525 STREAM DIAGNOSTICS: File___________PID___________Type___Codec 00012.M2TS___4113 (0x1011)___0xEA___VC-1 00012.M2TS___4352 (0x1100)___0x81___AC3 00012.M2TS___4353 (0x1101)___0x81___AC3 00012.M2TS___5120 (0x1400)___0x91___IGS ======================================= Here's the Rebuild: Name_________Time In_______Length 00012.M2TS___0:00:00.000___0:08:45.525 STREAM DIAGNOSTICS: File___________PID___________Type___Codec 00012.M2TS___4113 (0x1011)___0xEA___VC-1 00012.M2TS___4352 (0x1100)___0x81___AC3 ======================================= So then I reopened the project in BD-RB & discovered that it's not really a "bug"! I have my config setup to keep all English subs only. That IGS (for whatever reason???) had 3 "languages", 2 English & 1 Spanish. With my config, Spanish is eliminated which eliminated the WHOLE IGS! Unfortunately, I dumped my workfiles, so for the helluvit, & rebuilt that menu vid again, this time with all the audio & all the sub languages. I then replaced those "corrected" m2ts & clpi files in the structure. I burned it to RE & it appears that I "saved" the project! The menu now comes up & functions & it appears all is good now! Is what I did there really a "good" fix jdobbs? I think the moral of this story is "keep ALL your subs"!!! |
#5198 | Link | |
#5199 | Link | |
I'm having problems with Tomb Raider 1 Region B
- VID_00006.AVS - VID_00006.AVS.MKV - VID_00006.AVS.MKV.stats The main movie is: VID_00004.AVS.264 and this was created properly and completely together with the two sound streams. Muxing video + audio streams woorked fine via tsmuxer, so the goal was achieved: a movie only backup but i have no idea why bd rebuilder got stuck with two different versions and slightly different settings: 1pass with version 0.28.03 and 2 passes with 0.29.04 |
