#5401 | Link |
jdobbs could you please change non-strict AVCHD movie only on DVD to --avchd? Most players won't play --bluray content on DVD. The only reason according to tsmuxer changelog for --bluray is to allow VC-1 to play on Panasonic players which was probably drjake's issue.
Also with current firmwares of all known players the non-strict AVCHD movie only is fully compatible. However strict AVCHD fails to play in Funai based (Phillips, Insignia, Sylvania, etc.) and Denon players. Strict AVCHD option recent changes are good considering this mode should only be meant for playback in PowerDVD/WinDVD from HDD which only supports AC3/LPCM audio. Maybe you would consider changing the default back to non-strict AVCHD with --avchd as it's the most compliant when output is DVD. Last edited by turbojet; 29th September 2009 at 15:17. |
#5402 | Link | |
![]() Join Date: Oct 2001
L, R, C, LS, cs1, cs2, RS, lfe For 5.1 LPCM the mapping is: L, R, C, LS, RS, lfe So the correct mapping is GetChannel (audio, 1,2,3,4,7,8). On the DTS tracks you're describing the line has no affect at all. It only makes the conversion if there are more than 6 tracks i.e. "(AudioChannels(audio) > 6)". Last edited by jdobbs; 29th September 2009 at 16:15. |
#5404 | Link | |
Yes. The logfile is written to the output directory. |
#5405 | Link | |
Are you positive about the players, even with the new settings? The whole purpose of the new setting was to make it compatible across more players. |
#5406 | Link | |
@jdobbs & turbojet
Although I like the Profile 4.0 encoding *without* slices very much. From what I have read slices only use up bitrate and are not really useful. I know they are needed for 4.1. How bout a checkbox maybe where profiles 4.0/4.1 could be changed? Would that make sense? Last edited by samtroy; 29th September 2009 at 17:04. |
#5407 | Link |
BD Rebuilder v0.30.02 (beta)
I just updated the first post of this thread with a link to a new release of BD-RB (v0.30.02). Changes for this version:
- Fixed a bug in which the AUDIO_AMPLIFY hidden INI setting was not being read properly. - Corrected an error in which non-strict movie-only output to BD-5/9 was being written as "--blu-ray" rather than "--avchd". Also made "no slices" and "--level 4.0" restrictions to BD-5/9 movie-only encodes even when "strict" is not selected. Reversed the v0.30.01 change -- "strict AVCHD" is no longer the default. I'm afraid that change may cause too much confusion for people who have found the "sweet spot" for their particular player (especially the removed directories). - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 29th September 2009 at 17:15. |
#5408 | Link | |
Or does it also apply to custom size that would fit into DL DVD? |
#5409 | Link | |
#5413 | Link |
I'm going to post this again because no one seems to want to answer my question.
Quick question, I encoded a full movie back up of Punisher 2 War Zone to a BD-25. The disc loads up fine and plays in my Sony BDP-S300, but I've noticed the movie is a bit jumpy and choppy in parts, like the frame rate is stuttering. What could cause this? This is not the first time I've encountered this problem. I ended up just taking the largest M2TS file and running it through Ripbot instead and made a 20gb BDMV AVCHD file instead and burned it and it plays beautiful, but I wanted the whole bluray, extras included. What could cause BD-Rebuilder to cause stuttering of the frame rate? |
#5414 | Link | |
![]() Anyway, more info is needed, like the BD-RB log, INI, and if this is a 1080i/p file, etc.. The more info you can provide regarding this disc, the more likely someone could reply. |
#5415 | Link | |
#5416 | Link | ||
I belong to the group of users who still believe that in general a higher bitrate means higher picture quality and therefore hate wasting space on a BD-25. And what can I say - with v030.01 you finally made it! Quote:
I use BD Rebuilder to reencode movie-only to BD-25 and now I am REALLY HAPPY to burn my movies with the maximum possible bitrate. Believe me, on a projector screen size of 98" there are scenes where you can spot the difference between a bitrate of 19,985 kbps with v029.05 and 26,513 kbps with v030.01 @jdobbs: I really appreciate your work very much - have sent you a donation. |
#5417 | Link |
@jdobbs
Do you have any plans for adding an 'Force a particular subtitle to ON' setting in the next versions? So far I did use BDedit for that (which is definately *not* very user-friendly ![]() I know there's already an option like that present in BD Rebuilder's Mode menu but it's greyed out.. Last edited by samtroy; 30th September 2009 at 13:53. |
#5418 | Link | |
#5419 | Link |
Problem with PIP audio
I have a problem with Pic In Pic.
I was doing LABYRINTH that has Pic-In-Pic. As you can see the 2nd audio isn't been selected even if i choose all languages. The result is that i can see the PIP but i no pip sound just the original. I got the same result in the HULK. Am i doing something wrong or missing something? I am attaching the ini file as well. Thanks By the way, Great S/W . ![]() [Options] MODE=0 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 MIN_M2TS_SIZE=20 AUDIO_TO_KEEP=all SUBS_TO_KEEP=ang;eng;enm;heb; TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 SHOW_ENCODER=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=7700 ENCODE_QUALITY=2 TARGET_SIZE=23000 VERBOSE_STATUS=1 KEEP_INTERLACING=1 REMOVE_WORKFILES=0 PROCESS_SECONDARY=1 CRF_ENCODING=0 MKV_INTERMEDIATE=0 ONEPASS_ENCODING=0 SD_CONVERT=0 [Paths] SOURCE_PATH=H:\ WORKING_PATH=D:\ORIG\ |
#5420 | Link | |
only EAC3+ PiP audio tracks are supported. There's no free DTS-Express muxer available yet. Also if you have a Sony SAP then you need to set audio output to "mix" in the system menu of the player. |
