#6201 | Link | |
![]() Join Date: Oct 2001
#6203 | Link |
Well, re-ripped and tried again.
failed again at a different point this time: - [16:59:05] Reencoding: VID_00085 (22 of 29) - Error in attempt to multiplex: MUX_00085.meta - [17:02:31] - Failed to build structure, aborted I'm at a loss now... cwh |
#6205 | Link |
You really can't because you're demuxing several streams at once and aren't given the opportunity to provide an output name (only a folder). You can only name them if you are doing one at a time. That could take hours. The alternative would be to output them (contatenated) to an intermediate M2TS -- but even that would take twice as long and require twice as much space.
#6207 | Link | |
![]() But since there does not seem to be any help from SmartLabs on this, it gets added to your "to do list". ![]() It would be nice if you could implement your own "remuxer", as you did with DVD Rebuilder, making it the best DVD backup program! (IMHO) ![]() |
#6208 | Link | |
#6212 | Link | |
I'm also adding a hidden option to the next version that will allow you to use non-patched versions. The difference is that without the patch you are relying on TSMUXER's insertion during muxing -- which very likely isn't as compliant. But, with that said, I highly recommend that people stick with the version included in the BD-RB zip. It will have been tested, is always very close to the latest release, and is much less likely to be the source of problems. Last edited by jdobbs; 7th December 2009 at 16:08. |
#6213 | Link | |
That way you at least rule out if it is anyDVD, Your Disc, and then or your system or even worse BD REbuilder |
#6214 | Link |
FYI for anyone doing SW Clone Wars Vol.1: I finally figured out why BD_RB was crashing.
IE: STAR_WARS_CLONE_WARS_S1_BOX\BDMV\STREAM\00096.M2TS already exists. [21:04:07] - Failed to retrieve audio, aborted The afore mentioned 00096.m2ts is just a static screen that shows up for 5 seconds in the end credits. This m2ts is only about 20 MB but being it is an episodic disk it calls for this 00096.m2ts about 7 times. BD_RB would always choke on it because it was trying to encode the same file over and over in the audio stream. If you leave it out and try to combine the other m2ts files it gets out of sync progressively worse as it plays. I was able to remove 00096.m2ts and use ClownBD to get everything synced back up and am now encoding movie only BD9. I was able to do a full backup with BD_RD to BD-25 but really wanted it to work as DVD_DL. Seems AnyDVD_HD misses things every now and then. You win some you lose some. Have Fun, worknstiff |
#6215 | Link |
buffer for parse
I've completed several movies without any issues. I've recently come accross this one a few times. I ripped it first with anydvd and then with dvdfab6. Any idea's?
----------------------- [12:33:10] BD Rebuilder v0.31.01 (beta) - Source: NIGHT_AT_THE_MUSEUM2 - Input BD size: 19.80 GB - Approximate total content: [01:44:43.277] - Target BD size: 4.27 GB - Windows Version: 6.0 [6002] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [12:33:11] PHASE ONE, Encoding - [12:33:11] Extracting A/V streams [VID_00308] - Error in attempt to extract audio/subs. - Not enought buffer for parse video stream. Current frame num 34460 [12:34:19] - Failed to retrieve audio, aborted |
#6216 | Link | |
#6220 | Link | |
Looks to me like you have keep HD Audio ticked and you are trying to encode a BD_5 disk and not enough room for the video. |
