Old 20th June 2021, 19:14   #61601  |  Link
SamuriHL
SamuriHL's Avatar
113 doesn't work with smooth motion. Known problem.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
SamuriHL is online now   Reply With Quote
Old 21st June 2021, 00:41   #61602  |  Link
ashlar42
So what's the latest version that works with it and still doesn't expire? My family uses my HTPC, not just me. I can't have them deal with videos not playing because the video renderer has expired :-(
I wonder if I wouldn't be better off staying with the last stable version. I thought about updating madVR in order to better tonemap HDR1000 and, most of all, HDR4000 stuff on my LG C1.
Old 21st June 2021, 01:05   #61603  |  Link
Asmodian
92.17 or do some of the betas not expire?
madVR options explained
Old 21st June 2021, 01:18   #61604  |  Link
ashlar42
http://madshi.net/madVRhdrMeasure113.zip this does not expire and it's still available. But it has the smooth motion bug and 112 is nowhere to be found.
Old 21st June 2021, 01:44   #61605  |  Link
lych_necross
ZZZzzzz...
lych_necross's Avatar
Here is 112b.
https://www.sendspace.com/file/b39q3f
I can upload to a different service if needed.
lych_necross is offline   Reply With Quote
Old 21st June 2021, 01:45   #61606  |  Link
SamuriHL
SamuriHL's Avatar
Anything 113 or prior in the betas don't expire. But because of license changes, madshi removed all prior betas so you will not find them. If 113 doesn't work for you then you either need to live with the betas and keep them up to date (with their limitations) or stick to the latest stable version. There's really not many other choices.
Old 21st June 2021, 06:42   #61607  |  Link
SirMaster
madshi said he would re-upload any beta version people ask for.
113 is hosted because someone asked him to re-upload.
Nobody asked him for 112b.
SirMaster is offline   Reply With Quote
Old 21st June 2021, 13:33   #61608  |  Link
SamuriHL
SamuriHL's Avatar
I know he said that a while back. It gets more complicated when there's the time limit involved. E.g. people requested a new updated time limit version of 128 but so far that's not happened. 112b shouldn't have that issue given the lack of time limit but it'd be interesting to see if he'd post it given the lack of time limit in that build.
Sent from my SM-G998U1 using Tapatalk
Old 21st June 2021, 13:41   #61609  |  Link
ashlar42
Originally Posted by lych_necross View Post
Here is 112b.
Many thanks for this. You're a star!
Old 21st June 2021, 14:05   #61610  |  Link
mclingo
https://www.youtube.com/watch?v=HSseaknEv9Q
the Intel Iris Xe DG1 upcoming cards are looking interesting for passive builds, something to keep an eye on going forward to see how these perform in MADVR.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700
Old 21st June 2021, 22:30   #61611  |  Link
you watched the video and noticed that they only work in a very limited number of boards?
this one is practically just an iGPU so it would work the same as an intel iGPU.
the real different cards come later this year.
Old 24th June 2021, 22:43   #61612  |  Link
Nabukodonosor
Hey guys, I have an issue with madVR. I'm using it with the latest MPC-HC 32bit. I've been using it with my R9 280X 3Gb GPU, and it was working fine, but that GPU was overkill for my machine, too much heat in these hot days, so I've put back my old R7 250 1GB graphics card, which was in my machine for years and was working just fine. But now I have an issue. When I play some video file in fullscreen, I get a choppy video, like the framerate drops. It's an NBA game 60fps video. When I try other renderers, no issue. This was not the case when I used madVR last time with this GPU. Any ideas what can be the issue here? I did try uninstalling it and reinstalling it again. Also tried KMPlayer with madVR, the same thing. The video plays smoothly when I play windowed.
Nabukodonosor is offline   Reply With Quote
Old 25th June 2021, 01:37   #61613  |  Link
a screen of the OSD could help (control+j).
this sounds like your GPU simply can't display 60 FPS with the settings you are using at fullscreen.
Old 25th June 2021, 11:39   #61614  |  Link
Nabukodonosor
The situation i much better with 1080p video files. I get 1 dropped frame every 4-5 seconds. But with a 720p the situation is quite bad. I get around 25 dropped frames every second. Screenshot attached.
Attachments Pending Approval
File Type: jpg NBA-2021-06-22_LAC@PHX.720pier.ru.mkv_snapshot_00.22.44_[2021.06.25_12.37.25].jpg
Old 25th June 2021, 12:07   #61615  |  Link
please upload the image somewhere else uploads on this forum need admin approval.
Old 25th June 2021, 12:59   #61616  |  Link
Nabukodonosor
Here:
http://prntscr.com/16q4tzs
Old 25th June 2021, 13:32   #61617  |  Link
can you check GPU-z for Vram usages and others stats a R7 250 should be able to do bilinear and much better for 720p-1080p 60 FPS but it's not even close here in this case.
Old 25th June 2021, 15:09   #61618  |  Link
Nabukodonosor
Here's the log file. Is that ok?
File Type: txt GPU-Z Sensor Log.txt
Old 25th June 2021, 15:13   #61619  |  Link
Klaus1189
Please use Google drive or similar, we can not open it. -> "Attachments Pending Approval"
Old 25th June 2021, 15:22   #61620  |  Link
a screen of the sensor page should give me an idea.
in playback when the issues happens.
