#10021 | Link |
Support for Super Resolution appeared after the implementation in Chromium. The file swap_chain_presenter.cc contains the functions ToggleIntelVpSuperResolution and ToggleNvidiaVpSuperResolution. There is no solution for AMD.
MPC-BE 1.6.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#10022 | Link |
For Nvidia Video SuperResolution, there has been an Nvidia blog post and very mixed user reviews. For Intel, there was just some press coverage of the chromium commit.
bShaders: realtime Effects/filters for video players |
#10023 | Link |
Using mpc-be with mpc-vr dx11, I've noticed that when I open the shader combiner interface "Shaders > Select Shaders..." the combo-box always starts on dx9. However, the user would need to use dx11 shaders in this case. Would it be possible to modify so that the selector is set to the display mode currently in use (ie dx11) ?
#10024 | Link | |
In commit 9643c21 I made it so that the choice of DX9/DX11 depends on the renderer selected in the settings and the Windows version. This will close the issue on typical configurations.
#10026 | Link |
Is there a way to play HLG files in HDR10 or HLG passthrough? Tried a couple of HLG files that Kodi handles well and they played back in SDR.
LG 77C1 - Windows 10 Pro 21H1 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - GTX 3070 FE - Ryzen 5 3600 - 16GB RAM |
#10027 | Link |
Yes - use MPC VR.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#10028 | Link |
Right. I had tried but I made a dumb mistake... it works. Thanks a lot.
#10029 | Link |
Hmmm... it works with some files and not with other files. I uploaded here two very small videos, one working, the other not working. Meaning one activates HDR and the other doesn't. Both work fine in Kodi 20.1.
https://easyupload.io/zai05t Let me know if any other info is needed to help solving this.
#10030 | Link |
one file is not HLG it is BT 2020 (what ever that means for transfer).
https://en.wikipedia.org/wiki/Rec._2...haracteristics do not forget wikipedia is not reliable for video specs. |
#10031 | Link | |
Color range : Limited Color primaries : BT.2020 Transfer characteristics : BT.2020 (10-bit) transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant Mediainfo for "working" file states: Color range : Limited Color primaries : BT.2020 Transfer characteristics : HLG transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant Now, I have zero knowledge about the implications but the "non working" file is displayed in HDR through Kodi and it's quite clear that HDR picture information is there. So, maybe the "transfer_characteristics_Original" value is the correct one, I don't know. One extra question, on MPC VR: I don't see where to set range output. I need limited range, that's how I have calibrated my display. But MPC VR is outputting full range and I don't see where I could change that. In madVR I have set "The display expects the following RGB output levels:" to TV levels (16-235) and colors are correct.
LG 77C1 - Windows 10 Pro 21H1 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - GTX 3070 FE - Ryzen 5 3600 - 16GB RAM Last edited by ashlar42; 5th June 2023 at 13:08. |
#10032 | Link |
i get this for not working:
Color range : Limited Color primaries : BT.2020 Transfer characteristics : BT.2020 (10-bit) transfer_characteristics_Origi : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant and this is not HLG the mpcVR is also seeing this as none linear bt 2020 (pretty much means ~gamma). mpcVR doesn't have a range option(and i support this). you can still do this using shaders. should be the first one under shader make sure you match the DX version. |
#10033 | Link | ||
If the shader approach is correct, I'll use that (I discovered it after writing the previous message).
#10034 | Link | |||
under the current information on the wiki it is plain SDR. Quote:
#10035 | Link | |
Which leads me to believe the problem was probably just in the muxing process for whomever encoded those files.
#10037 | Link |
Hi guys!
Has anyone seeing a non linear stretch shader like this https://www.heimkinoverein.de/forum/...inear-stretch/ For MPC? Thanks Last edited by shaolin95; 12th June 2023 at 03:58. |
#10038 | Link |
@shaolin95
MPC shaders do not change the frame size.
