Old 8th July 2024, 08:37   #31821  |  Link
musiclover
Does anyone know of a program that can join MKV/M2TS files into a single MKV/M2TS? It turns out some of the discs I am working on do not have a play-all type playlist. At the moment that means I have to use VideoReDo to join them, but VRD does not work with sub-titles, so they are lost.
These are the videos that I have upconverting to 2160/25.
MakeMKV doesn't seem to have an option to do so.
MKVToolnix can do that. Right click on the file and choose append
Old 8th July 2024, 08:52   #31822  |  Link
Lathe
Lathe's Avatar
Man... you'd really think someone called 'Mr. Video' would know about this...
Old 8th July 2024, 12:11   #31823  |  Link
gonca
If your audio is THD then you have carry the THD + AC3 core and merge them at the end if you want to create a playable BD disc
Old 8th July 2024, 12:57   #31824  |  Link
MrVideo
MrVideo's Avatar
I never use MKVToolnix. I always use the mkv program via the command line. It'll recompute the chapter marks as well as the subtitle timings?
UPDATE: No need to do a right-click. Just drag all of the files to be merged and go from there.
Old 8th July 2024, 13:00   #31825  |  Link
MrVideo
MrVideo's Avatar
The audio is either plain DD or DTS-MA. All are from the DVDs and/or Blu-rays.
Old 8th July 2024, 17:23   #31826  |  Link
jellyhead1
These are the videos that I have been upconverting to 2160/25.
MKVToolNix (Append) or tsMuxerGUI (Join)
jellyhead1 is offline   Reply With Quote
Old 9th July 2024, 15:52   #31827  |  Link
You can use mkvmerge.exe to create an MKV -- you just add plus signs between the multiple filenames and they will be appended to each other.
Old 9th July 2024, 15:56   #31828  |  Link
Blurayhd
How do you burn to disc those movies that you encode to bd25 with rebuilder? years ago I use IMGburn but I cant remember what options to set i ask this because when I try to play in some rerwritable disc player (in my case Play 3) cant play it
Old 9th July 2024, 16:28   #31829  |  Link
I put a link (shortcut) on my desktop to IMGBURN. Here is what I added to the "Target" area of the properties:
"C:\Program Files (x86)\ImgBurn\ImgBurn.exe" /MODE BUILD /BUILDMODE DEVICE /DEST G: /FILESYSTEM "UDF"/UDFREVISION "2.50"
My burner is drive G:
When it starts, just add the folder that contains the Blu-Ray file (BDMV, etc) and burn.
You can also select "Burn to Disc (with IMGBURN)" from the SETTINGS/OUTPUT OPTIONS menu in BD-RB if you want it to do it automatically at the end of the rebuild. You can tell it which drive to use with a hidden option:
IMGBURN_TARGET_DEVICE=s
s = Drive to use for burning with ImgBurn (ex: e:, f:, etc)
Old 9th July 2024, 20:48   #31830  |  Link
cartman0208
It has been in BETA, free, for about 15 years....
You mean ... almost as long as BD Rebuilder
Sorry, couldn't resist
Old 9th July 2024, 22:30   #31831  |  Link
You have to go for a record in something!
Old 9th July 2024, 22:38   #31832  |  Link
MrVideo
MrVideo's Avatar
Thanks for the info.
Old 10th July 2024, 00:28   #31833  |  Link
Lathe
Lathe's Avatar
After using IMGBurn for many years, I started to have trouble with it. So, I started using BurnAwareFree which I've used to burn probably well over 100 playable Blu-rays, as well as data discs with MKV files and also ISO files. I've never had one issue with it and it is free.
You just drop the BDMV/CERT files or the individual MKV's together or an ISO into the window and click 'Burn' Couldn't be easier...
HIGHLY Recommend it!
Old 10th July 2024, 13:47   #31834  |  Link
cartman0208
From my experience rewritable discs do not play well on BD Players.
Did you try a one-time writable disc for comparison?
Old 10th July 2024, 14:24   #31835  |  Link
MrVideo
MrVideo's Avatar
Interesting. I've never had an issue playing rewritable BD discs in my BD players or my UHD player.
Old 10th July 2024, 15:06   #31836  |  Link
cartman0208
To be more specific ... it was a 100GB rewritable disc.
And of course it depends on the player ... and the writing drive.
Old 10th July 2024, 15:29   #31837  |  Link
I've never had an issue either. But I don't think I've ever used a rewritable that was more than 25GB.
Old 10th July 2024, 17:06   #31838  |  Link
Blurayhd
I dont know why I tried with diferent movies that are 2160p MKV to reencode in 1080p and I always get an error from BDrebuilder, and just for curious I tried with another tool and encode just fine
I so like to encode with Rebuilder but like I sayng when I select as source an 2160p mkv and alternate movie 1080p justs give me an error
Old 10th July 2024, 19:55   #31839  |  Link
This happens during import?
Old 10th July 2024, 21:26   #31840  |  Link
Blurayhd
No, this happens few seconds when reencode starts "Failed video encode", cancel
