#81 | Link | |
Software Developer
![]() Join Date: Jun 2005
And if you take a look at the x264 commandline, you will notice that my x264 launcher tool won't even involve the "--preset" switch, if "Medium" is selected in the "Preset" combo box ![]() (BTW: In a C or C++ program /* and */ surround comments, so the code I quoted really doesn't do anything)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th July 2009 at 01:01. |
#82 | Link | |
Hardware Aspirin
Stream video on web in your quality |
#83 | Link |
Software Developer
Updated x264 to r1184 (JEEB's builds). Download link updated.
#84 | Link | |
Software Developer
Not sure whether there were other problems as well. Anyway, JEEB has fixed his built environment and provided fresh r1184 builds. Download link in first post updated. I highly recommend to updated again, if you downloaded the update earlier this day!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st July 2009 at 19:31. |
#85 | Link | |
Hardware Aspirin
#86 | Link |
encoder enthusiast
Core 2 Duo E7200 overclocked to 3.02GHz, 2GB DDR2, P43 Chipset, Windows 7 Ultimate RC1 X64
500 frame clip from "A Love Song for Bobby Long" PAL R2 avisynth: DGDecode_mpeg2source("C:\work\bobbylong.d2v", info=3) ColorMatrix(hints=true, threads=0) crop( 2, 0, 0, 0) LanczosResize(720,576) trim(15500,16000) Code:
Source: C:\work\bobbylong.avs Preset: Fast Tuning: None Profile: High Params: [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 51.95 fps, 936.46 kb/s encoded 501 frames, 51.88 fps, 936.46 kb/s encoded 501 frames, 51.93 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 52.54 fps, 936.46 kb/s encoded 501 frames, 51.89 fps, 936.46 kb/s encoded 501 frames, 52.64 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 501 frames, 52.80 fps, 936.46 kb/s encoded 501 frames, 53.04 fps, 936.46 kb/s encoded 501 frames, 52.98 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 501 frames, 52.85 fps, 936.46 kb/s encoded 501 frames, 51.61 fps, 936.46 kb/s encoded 501 frames, 52.94 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 501 frames, 51.70 fps, 936.46 kb/s encoded 501 frames, 46.54 fps, 936.46 kb/s <- window auto-lost focus here encoded 501 frames, 51.18 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 501 frames, 47.61 fps, 936.46 kb/s <- and here encoded 501 frames, 51.55 fps, 936.46 kb/s encoded 501 frames, 51.09 fps, 936.46 kb/s Code:
Source: C:\work\bobbylong.avs Preset: Fast Tuning: None Profile: High Params: [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 48.28 fps, 936.46 kb/s encoded 501 frames, 47.73 fps, 936.46 kb/s encoded 501 frames, 48.42 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 52.88 fps, 936.46 kb/s encoded 501 frames, 53.65 fps, 936.46 kb/s encoded 501 frames, 53.75 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 501 frames, 54.02 fps, 936.46 kb/s encoded 501 frames, 54.34 fps, 936.46 kb/s encoded 501 frames, 54.41 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 501 frames, 54.24 fps, 936.46 kb/s encoded 501 frames, 54.31 fps, 936.46 kb/s encoded 501 frames, 54.35 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 501 frames, 52.69 fps, 936.46 kb/s encoded 501 frames, 53.74 fps, 936.46 kb/s encoded 501 frames, 53.81 fps, 936.46 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 501 frames, 52.66 fps, 936.46 kb/s encoded 501 frames, 52.64 fps, 936.46 kb/s encoded 501 frames, 52.64 fps, 936.46 kb/s |
#87 | Link |
Software Developer
Updated x264 to r1189 (JEEB's builds). Also allow the Quantizer for CRF mode to be a Float. Download link updated.
#89 | Link | |
Software Developer
[EDIT] Updated x264 to r1190 (JEEB's builds). Download link in first post updated.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 28th July 2009 at 02:07. |
#90 | Link |
Software Developer
Updated x264 to r1193 (JEEB's builds). Download link in first post updated.
#91 | Link |
encoder enthusiast
some fast tests again, now with akira r2 remastered special edition, jeeb's 1193 and imk.cx icc 1193.
- quick conclusion would be that icc builds are faster on x64 - 1mb/2mb/4mb buffers are the fastest Code:
DGDecode_mpeg2source("C:\work\akira.d2v", info=3) ColorMatrix(hints=true, threads=0) crop( 2, 0, 0, 0) BilinearResize(720,576) trim(29000,29500) Code:
Source: C:\work\test.avs Preset: Veryfast Tuning: Animation Profile: High Params: [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 80.81 fps, 1459.69 kb/s encoded 501 frames, 80.82 fps, 1459.69 kb/s encoded 501 frames, 79.33 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 74.55 fps, 1459.69 kb/s encoded 501 frames, 73.29 fps, 1459.69 kb/s encoded 501 frames, 75.20 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 501 frames, 79.32 fps, 1459.69 kb/s encoded 501 frames, 78.93 fps, 1459.69 kb/s encoded 501 frames, 78.72 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 501 frames, 78.89 fps, 1459.69 kb/s encoded 501 frames, 78.58 fps, 1459.69 kb/s encoded 501 frames, 78.59 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 501 frames, 76.33 fps, 1459.69 kb/s encoded 501 frames, 78.84 fps, 1459.69 kb/s encoded 501 frames, 78.10 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 501 frames, 76.09 fps, 1459.69 kb/s encoded 501 frames, 77.47 fps, 1459.69 kb/s encoded 501 frames, 76.61 fps, 1459.69 kb/s Code:
Source: C:\work\test.avs Preset: Veryfast Tuning: Animation Profile: High Params: [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 66.30 fps, 1459.69 kb/s encoded 501 frames, 67.84 fps, 1459.69 kb/s encoded 501 frames, 67.15 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 501 frames, 79.41 fps, 1459.69 kb/s encoded 501 frames, 79.35 fps, 1459.69 kb/s encoded 501 frames, 79.78 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 501 frames, 80.90 fps, 1459.69 kb/s encoded 501 frames, 81.16 fps, 1459.69 kb/s encoded 501 frames, 80.95 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 501 frames, 79.56 fps, 1459.69 kb/s encoded 501 frames, 81.33 fps, 1459.69 kb/s encoded 501 frames, 80.59 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 501 frames, 80.51 fps, 1459.69 kb/s encoded 501 frames, 80.42 fps, 1459.69 kb/s encoded 501 frames, 80.68 fps, 1459.69 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 501 frames, 78.20 fps, 1459.69 kb/s encoded 501 frames, 78.91 fps, 1459.69 kb/s encoded 501 frames, 77.73 fps, 1459.69 kb/s |
#92 | Link |
Software Developer
Updated x264 to r1195 (Techouse builds). I recommend updating, QPRD was borked in previous builds. Download link in first post updated.
#94 | Link |
Software Developer
It means that if (and only if) you used QPRD (aka SubME=10), then your output wasn't as the developers had intended, because there was a bug in QPRD.
But by chance the GCC builds still gave "reasonable" output, while ICC builds would simply have crashed. The problem is fixed now ![]() http://forum.doom9.org/showthread.ph...15#post1309515
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 29th July 2009 at 15:48. |
#96 | Link |
Software Developer
#97 | Link |
Software Developer
Updated x264 to r1203 (x264.nl builds). Also added support for the new presets. Download link in first post updated.
#98 | Link |
Software Developer
Updated x264 to r1206 (Komisar's builds). Download link in first post updated.
#100 | Link | |
Software Developer
