Old 25th October 2021, 15:52   #62161  |  Link
the oppo uses bilinear or worse NN for chroma scaling it would be sad if it doesn't rival it.
Old 25th October 2021, 18:33   #62162  |  Link
chros
chros's Avatar
Originally Posted by oldpainlesskodi View Post
I looked at all the main players, and narrowed it down to Dune, Zappiti, and Ziddo, and ended up choosing the Zidoo Z1000 Pro, and I have to say, I could not be happier (https://www.avforums.com/reviews/zid...x-review.18745), and yes, the picture quality really does rival (read beat) the mighty Oppo 203!
I too found it difficult to look at anything other than a HTPC using MadVR, but, sadly, MadVr has stayed static, whilst the rest of the tech world has moved on.
I understand what you mean, but it's not necessarily madvr's fault but PC.
Unfortunately there's no perfect hardware player today either for everything, otherwise I would have one
E.g. I use madvr for sdr and hdr10, Plex app on LG TV for profile 5/8.1 DoVi and Oppo for profile 7 DoVi 4k BD only. There's no other way around it for now, maybe never will be.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 25th October 2021, 19:20   #62163  |  Link
oldpainlesskodi
Ok...you know I still love you, right?
Sapphire RX 5700 XT (21.6.1) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (20H2), Silverstone LC13B-E, Kodi Dsplayer 17.6 X64, LG OLED55BX6LB, Zidoo Z1000 Pro, Denon AVR-X3300W, Mission M35i speakers.
Old 25th October 2021, 19:26   #62164  |  Link
oldpainlesskodi
Agreed, there will NEVER be a perfect solution, so, there are always comprises - mine is, is the picture good, does it just work, whats the interface like?.....and, is it wife friendly?
Like I said, happy viewing (for the 1st time in years, the wife and I just watched a film, no having to tweak, no if only...the picture quality, well, like watching a movie, and it looked great).
Each to their own, and happy viewing!
K
Old 25th October 2021, 19:28   #62165  |  Link
if someone says it beats an oppo i'm just very easy to convince that it is true.
Old 26th October 2021, 08:06   #62166  |  Link
declain
Originally Posted by zveroboy View Post
I`m using a dual display configuration.
1 - default: Asus VG259QM
2 - extended: Panasonic TX-P55ST60
madVR can switch a modes for default display only, but for extended display it can`t.
Yes, extended display is completely broken, it uses the settings from the main display, even LUT. Since my main monitor cannot switch refresh rates, madVR uses default 60Hz all the time. I changed the LUT of the main display (fortunately, I don't use it for film watching) and for now I manually switch refresh rates on extended display using nvidia driver. It's PITA but it works.
declain is offline   Reply With Quote
Old 28th October 2021, 13:57   #62167  |  Link
tp4tissue
tp4tissue's Avatar
How dare you besmirch Oppo, the darling of the video enthusiast community.
The only thing worse than oppo players are their cellphones.
Ghetto | 2500k 5Ghz
Old 28th October 2021, 14:00   #62168  |  Link
tp4tissue
tp4tissue's Avatar
Madvr is the ONLY good solution on the market. Everything else is plain impractical.
Anything without end to end 3DLut support is also completely worthless.
Ghetto | 2500k 5Ghz
Old 28th October 2021, 17:43   #62169  |  Link
doffen
From what I’ve read it seems MPV is getting closer to being a good substitute, apart from HDR —> SDR tonemapping. It’s already possible to load filters which is equally good or better at chroma upscaling than MadVRs NGU. It also seems MPV supports icc profiles and use it to generate a LUT on the fly. Probably not quite as good as our pre-rendered 3D-LUTs, but closer to that than nothing.
I just searched all of this since I’m planning to buy a new laptop, and was wondering about other solutions. I’m still landing on mpc-hc + MadVR though.
doffen is offline   Reply With Quote
Old 28th October 2021, 22:07   #62170  |  Link
Siso
Siso's Avatar
Can anyone with nvidia and the latest drivers can confirm if windowed overlay is working? I get this error - "the gpu driver does not support overlay." Madvr 0.92.17
Old 29th October 2021, 01:57   #62171  |  Link
Asmodian
I get the same message. no Overlay in Win11 with 496.49.
madVR options explained
Old 29th October 2021, 09:23   #62172  |  Link
Siso
Siso's Avatar
So it seems nvidia stopped it from working with their new drivers...
Old 29th October 2021, 12:31   #62173  |  Link
DMU
What were the advantages of "windowed overlay"?
R3 3200G / Vega8 / Samsung UE40NU7100
Win10Pro 21H1 / 4K RGB 59Hz / AMD last driver
MPC-HC 1.9.16 / madVR 0.92.17 / FSW / 8bit@59Hz
DMU is offline   Reply With Quote
Old 29th October 2021, 12:57   #62174  |  Link
Siso
Siso's Avatar
It is maybe the most stable rendering mode.
Old 29th October 2021, 13:14   #62175  |  Link
LenniePaz
What causes presentation glitches? I've been getting a bunch lately, out of nowhere.
Sent from my SM-N975U using Tapatalk
LenniePaz is online now   Reply With Quote
Old 29th October 2021, 14:05   #62176  |  Link
yiuleungf
After upgrading to Windows 11, mpc-be can no longer enter into Fullscreen Exclusive Mode (8-bit or 10-bit) with Madvr V0.92.17. It is always fullscreen windowed. Previously it was working on Windows 10. Anyone else having the same issue? Thanks.
yiuleungf is offline   Reply With Quote
Old 29th October 2021, 14:11   #62177  |  Link
yiuleungf
Also, I read that madvr V0.92.17 is having issue on Windows 11 getting HDR to display properly. Does it resolve if I use OS HDR instead? Some say no saying the color still looks incorrect but I am not sure as I cannot compare it with the OS HDR picture on Windows 10.
Old 29th October 2021, 15:47   #62178  |  Link
usually composition rate issues or dual screen setups if you are not on win 11 you can try overlay this mode is pretty much totally immune to all of these issues.
this ^^
Old 29th October 2021, 16:09   #62179  |  Link
LenniePaz
this ^^
The presentation glitches only started when I switched from using DSPlayer, to MPC-HC.
Old 30th October 2021, 01:11   #62180  |  Link
tp4tissue
tp4tissue's Avatar
It's not better than nothing, it's most likely WORSE than nothing.
Madvr gives you END TO END, calibration goes through its renderer, You can be 100% confident that the measurements correlate with output. It also dithers, ensuring smooth corrections, which "effectively,sorta,kinda, magics" 8bit panels into 10bit panels..
ANY other method is just winging it. In the case of the interaction between our clandestine free softwares, gpu drivers, windows random updates, gamma ramps, bit depth discrepancies, It's a total nightmare.
There was a windows update not long ago that completely broke windows gamma ramp for months.
Color tweaking outside of Madvr, you're better off using the TV's internal rgb gamma correction, because at least you can count on its consistency when interacting with the software set to default.
Ghetto | 2500k 5Ghz
