#61 | Link |
brainless
no! you should have read the AVISynth documentation.
FixBrokenChromaUpsampling() will correct a progressively upsampled to interlaced upsampling. But that is NOT the case with the canopus decoder. it upsamples correctly in relation with interlacing.
Don't forget the 'c'! Don't PM me for technical support, please. |
#62 | Link | |
From your advice, as my target is YV12 (MPEG1 or WMV actually), I think I should either: 1) grab the YVY2 output of Canopus and then point-sample (reducetoyv12) it to YV12; or 2) try the YV12 output of ffdshow's VFW module. I am particularly interested if ffdshow will deliver both PAL and NTSC outputs correctly. Last edited by henryho_hk; 12th December 2004 at 12:37. |
#63 | Link |
brainless
if your chroma look coarse interlaced instead of being fine combed, you will need fixbrokenchromaupsampling().
otherwise you won't need it. my canopus decoder is working correctly! PAL can be used with ffdshow's YV12 output. but for NTSC it is a mess, cause it puts out the 4:1:1 samples chroma as YV12 data, which is handled by AVISynth as 4:2:0 sampled chroma. Just use normal NTSC-DV decoding as it is. maybe use reinterpolate411() afterwards. you will not gain anything by working with YV12 output here.
Don't forget the 'c'! Don't PM me for technical support, please. Last edited by scharfis_brain; 12th December 2004 at 14:59. |
#64 | Link | |
Super Moderator
![]() Join Date: Nov 2001
@scharfis_brain
function translation(clip clip, clip "LClip", int "start_frame", int "beginX", int "beginY", int "end_frame", \ int "endX", int "endY") { return Animate(start_frame, end_frame, "layer", clip, LClip, "Add", 255, beginX, beginY, \ clip, LClip, "Add", 255, endX, endY) } c = BlankClip(width=720,height=576,pixel_type="YUY2") c2 = ImageSource("F:\411_vs_420\1-720-pal.bmp",0,250,25,false).ConvertToYUY2() ct = translation(c, c2, 0, 0, 0, 99, 720, 288) cf = ct.SeparateFields.SelectEven cf.Weave AssumeFPS(25) c1 = last.KillAudio c2 = DirectShowSource("F:\411_vs_420\mc_int.avi", fps=25) # interlaced YV12 #ConvertToYUY2(interlaced=true) c1 = c1.ConvertToYV12(interlaced=true) #Subtract(c1,c2) StackVertical(c1,c2) 2) mc_int.avi is the script (forming the clip "c1") encoded with MainConcept (also in pal.zip). If mc_int.avi would have been upsampled to YV12 using MPEG-2 sampling, the clips c1 and c2 would be identical. As you can see, they are not. |
#65 | Link |
sorry to intefere in your discussion.. i wonder if there is a possibility to only display one of the color channels a time. not in interpolated fullscreened size, but with ie the red pixels in just the position they are stored:
l1:x x x l2: blank l3:x x x would be interesting to see, dont you think? |
#66 | Link | |
Is the following script correct? <<deleted>> Last edited by henryho_hk; 6th September 2005 at 16:13. |
#67 | Link |
Senior Member
Sorry for the late reply, but better late then never.
Its not a question of which better, but which format you use, PAL or NTSC, which depends on what county you live in. Yes, I would recommend using the ReInterpolate411 filter if you are encoding NTSC DV into MPEG-2. It does a great job. |
#68 | Link | |
Reclusive fart. Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers |
#69 | Link | |
Super Moderator
Still waiting for your screenshots
![]() edit: oops sorry ![]() Quote:
#70 | Link | |
#73 | Link |
AviSynth plugger
I updated ReInterpolate420 plugin a little:
v3, 22 July 2006 - color tint decreasing in progressive mode; speed increasing in both modes by integer processing
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 25th July 2006 at 21:34. |
#74 | Link |
So, now i m trying to use Canopus Dv codec 4.60 from Grass Valley Codec Option package. And im confused about necessary of using Reinterpolate420. Because last testing was done for Canopus DV 1.0.0.0. I made testing by myself with last canopus version but cant understand if its needed...sorry.
P.S. So for now i see. With new version of canopud DV (4.60) You dont need to use FixBrokenChromaUpsampling, but its preferable to use Reinterpolate420. Correct me please if i made wrong conclusion. Last edited by romangal; 21st June 2021 at 18:34. |
