Old 16th June 2022, 10:48   #21  |  Link
Fador
uvg266 v0.3.0 was released fixing many small bugs:
https://github.com/ultravideo/uvg266...ses/tag/v0.3.0
Fador is offline   Reply With Quote
Old 16th June 2022, 17:27   #22  |  Link
Barough
Barough's Avatar
uvg266 VVC v0.3.0-e758624
Built on June 16, 2022, GCC 12.1.0
https://github.com/ultravideo/uvg266/commits/master
DL:
https://www.mediafire.com/file/5364qlchfr5hpy4/
Old 17th June 2022, 09:49   #23  |  Link
They may need someone using Linux to update the man page. The shell script in /tools did not work under MSYS2, seems to be unable to redirect the output of the Windows application executed in backticks.
Ah, someone did.
Old 20th June 2022, 08:23   #24  |  Link
Fador
Ah, someone did.
Yes I actually had to fix something in the script, but Windows Subsystem for Linux also works nicely 😁
It's not really a tool you normally need to run so it's not that big of a problem if it's not working in MSYS2, but I might take a look later.
Old 30th June 2022, 19:15   #25  |  Link
Barough
Barough's Avatar
uvg266 VVC v0.4.0-456f69f
Built on June 30, 2022, GCC 12.1.0
https://github.com/ultravideo/uvg266...ses/tag/v0.4.0
DL :
https://www.mediafire.com/file/ctiylmf17c4c6zi/
Old 8th July 2022, 19:46   #26  |  Link
Barough
Barough's Avatar
uvg266 VVC v0.4.1-7213465
Built on July 08, 2022, GCC 12.1.0
https://github.com/ultravideo/uvg266...ses/tag/v0.4.1
DL :
https://www.mediafire.com/file/29bxahjkrlnqvl0/
Old 15th July 2022, 15:18   #27  |  Link
vjs
There seems to be an issue with too many threads with uvg266. While testing uvg266 I noticed that contrary to expectations encoding the same file with exactly the same parameters does not produce the same output file. Even the file sizes differ.
I used the newest 0.4.1 release and on linux and macos I did compile it myself, but on windows I used @Barough's precompiled binary. However specifying "--threads 8" does fix this issue and then uvg does produce same bitstream every time. Seems that 32 threads with Ryzen 5950x is too many for uvg, this should be fixed. If you need help, I can provide some time & effort for testing.
vjs is offline   Reply With Quote
Old 26th July 2022, 10:19   #28  |  Link
MartinEesmaa
Windows MPV Player (libvvdec build)
I built Windows MPV Player (libvvdec support), it works on AMD and Intel to play VVC, even mp4 file too.
See documentation: https://github.com/MartinEesmaa/VVCE...ibvvdec-plugin
See top-left information of the image:
- Martin Eesmaa
MartinEesmaa is offline   Reply With Quote
Old 27th July 2022, 20:40   #29  |  Link
and welcome on the doom9 board.
Just the generic VVC thread is that one, this here is for the uvg266 encoder, specifically.
Old 28th July 2022, 19:12   #30  |  Link
Barough
Barough's Avatar
uvg266 VVC v0.4.1-cd2d406
Built on July 28, 2022, GCC 12.1.0
DL :
https://www.mediafire.com/file/amq91nol18rxthq/
Old 30th July 2022, 21:22   #31  |  Link
New upload:
uvg266 0.4.1-cd2d406 [GNU 12.1.0] 2022-07-30
Old 9th September 2022, 07:13   #32  |  Link
edison
- Martin Eesmaa
"On Windows, you can copy mpv-2.dll, mpv-vvceasy and mpv-vvceasy of DLL to mpv.net of https://github.com/stax76/mpv.net"
Where is the .dll files can I find ?
edison is offline   Reply With Quote
Old 10th September 2022, 02:47   #33  |  Link
MartinEesmaa
Hi, edison. Sorry, I forgot to add libmpv.dll on it, but I need static link with my Visual Studio, because my MSYS2 static links only file type with .a. Visual Studio links with .dll. I'll might try as possible to build libmpv.dll static.
EDIT: It worked with --enable-libmpv-shared with --enable-static-build, but it did not link of two files containing: libgcc_s_seh-1.dll & libwinpthread-1.dll.
- Martin Eesmaa
Old 10th September 2022, 06:48   #34  |  Link
MartinEesmaa
edison, I released my mpv.net latest build to include mpv-2.dll of VVC + xHE-AAC support.
https://github.com/MartinEesmaa/VVCE...d0509fbd6c3806
Old 10th September 2022, 11:41   #35  |  Link
Again:
This is the thread for the uvg266 VVC encoder only.
For general VVC content, please use this thread.
Old 10th September 2022, 13:55   #36  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
Again:
I guess EasyVVC warrants a separate topic.
The existing H.266 topic is about the codec issues/development/future in general.
Old 29th September 2022, 20:59   #37  |  Link
Barough
Barough's Avatar
uvg266 VVC v0.4.1-c6764df
Built on September 29, 2022, GCC 12.2.0
DL :
https://www.mediafire.com/file/d1gpm4q748gj50d
Old 1st October 2022, 04:19   #38  |  Link
benwaggoner
Any changelog?
Ben Waggoner
My Compression Book
Old 1st October 2022, 15:43   #39  |  Link
Only few new commits in commits/master (sufficient to read for me).
Old 23rd February 2023, 01:05   #40  |  Link
New upload:
uvg266 0.4.1-c6764df [GNU 12.2.0]
No panic, I am just late
video encoder, vvc
Copyright ©2000 - 2023, vBulletin Solutions Inc.
