Old 18th December 2014, 23:14   #22021  |  Link
Ch3vr0n
no,
the DGDecNV one sais 14.554kb http://forum.doom9.org/showpost.php?...ostcount=21958
the LAVF one sais 13.752 http://forum.doom9.org/showpost.php?...ostcount=22020
Between those 2 is the big difference in size and the fact that that DGDecNV one was run with multiprocess=1 (2 instances fired up)
DGDecNV one 13.757kb one http://forum.doom9.org/showpost.php?...ostcount=21980 is with multiprocess=0
why the difference in size, i have no idea. But it's not the first ISO i see turning out at around 19GB. Prometheus disc 2 (bonus disc) is also such a disc that turns out at 19GB (19.995.904kb exact)
Old 18th December 2014, 23:22   #22022  |  Link
robbie74
Originally Posted by Video Dude View Post
I don't think you needed to uninstall AnyDVD. When you rip the disc the AnyDVD options should not modify the disc, such as Remove Short Titles, Remove Annoying Adverts, and Speed Menus.
It is possible those options can cause a problem for BD-RB. If your source files were originally ripped with those options enabled, you might want to re-rip the disc with the options disabled to determine if that is the cause of the problem.
This may not be a BD-RB problem. I have seen reports on other forums about Guardians of the Galaxy and no audio involving other backup software.
For example:
https://forum.slysoft.com/showthread...-of-The-Galaxy
I have not ripped these as i am waiting for my bluray drive, i have downloaded these from a private site.
Just seems strange that both movies cut off at exactly 6 1/2 minutes.
Once i have my drive i will rip a disc & try again.
just to point out , i have tried both films with dvdfab & it works fine.
Just out of curiosity what convert speeds & time are people getting ?
I have
x4 phenom 970be OC to 4.0ghz
12gb ram
6gb sata hd
My convert speeds seem to be around the 8-9 hour mark with a FPS of .22
Does that seem about right ?
rob
robbie74 is offline   Reply With Quote
Old 19th December 2014, 01:42   #22023  |  Link
@robbie74
1. Your post violates forum rules -- as discussion of downloaded copyrighted material is NOT PERMITTED on Doom9. Please review Rule #6.
2. You have violated BD-RB bug reporting rules -- as the sources have been preprocessed.
#2 above is probably the reason you are having issues. There will be no more discussion related to your posts, any further discussion will result in strikes.
jdobbs.softworks@gmail.com
Old 19th December 2014, 15:48   #22024  |  Link
robbie74
@robbie74
OK, sorry..
Old 19th December 2014, 17:19   #22025  |  Link
Originally Posted by robbie74 View Post
OK, sorry..
BTW, .22fps seems really slow. My system is using an AMD FX-8350. I just did a movie-only disc and I got about 80fps in pass one and 29fps in pass two.
Old 20th December 2014, 04:19   #22026  |  Link
Lathe
Lathe's Avatar
I have
12gb ram
6gb sata hd
rob
Hmmm, are you SURE that that is the correct FPS...? The reason why I ask is because the way I set my encodes usually for any BDs where the size is north of say 27 Gigs or so, is I have it on High: Default, 2 Pass AND I use x264 tweaks that tune for film, set the ME=umh and the SubME=8, and bump up the Psychovisual and Trellis stuff, just to give it a bit more punch (the High: Default usually sets the ME=hex and the SubME=7 and it doesn't tune for film) So, not that it is actually necessary, but I like to get the most sharpness and detail possible with larger encodes (I may not even SEE the bloody difference, but then all these people here who set it to the overkill of Highest:Very Slow go beyond even that )
So, even with all the tweaks and the relatively high setting, at the most my 2nd pass is about 8 hrs or so (the 1st is consistently about 1 - 1 1/2 hrs no matter what my settings)
I have an AMD APU A8-5600 with 8 Gigs of RAM.
When the movie size is smaller, I usually leave it on High: Default 2 Pass and basically only tune - film, so it takes about 4 hrs on the 2nd pass.
When the size is just a couple of Gigs larger than a BD-25, I leave it on 'Auto' with just the tune-film tweaks, and the 2nd pass usually only takes anywhere from 1 to 2 hrs.
The FPS on the 2nd passes are about 4-5 on the really high settings and maybe around 30-70 on the lower settings. That is why I thought .22 sounded REALLY low...
Old 20th December 2014, 11:35   #22027  |  Link
Sharc
Well, yes. But IMHO the real challenge is to relax the settings and still get a (visually) high quality backup, rather than driving everything into the placebo corner. BD-RB "Auto" does a pretty good job in this respect.
Old 20th December 2014, 13:25   #22028  |  Link
KeVe1983
Banned
Hey jdobbs,
have Problems with both Hobbit Desolation of Smaug Extended 3D Discs
[13:14:45] Source: HOBBIT_DOS_EXTENDED_3D_PART2
- Input BD size: 31,42 GB
- Approximate total content: [02:04:26.917]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7601]
- Quality: Good (Very Fast), ABR
- MVC 3D Output Mode enabled
- Decoding/Frame serving: FRIMDecode
- Resuming from previously started job.
[13:14:47] PHASE ONE, Encoding
- [13:14:47] Processing: VID_00006 (1 of 2)
- [13:14:47] Reencoding video [VID_00006]
- Rate/Length: 23,976fps, 130.338 frames
- Bitrate: 27.553 Kbs
- Using FRIMEncoder for MVC encoding
- [13:14:47] Reencoding: VID_00006, Pass 1 of 1
[13:14:51] - Failed video encode, aborted
Got this with both Discs.
Systemcheck is fine and other 3D encodes are working fine.
KeVe1983 is offline   Reply With Quote
Old 20th December 2014, 17:08   #22029  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by KeVe1983 View Post
Hey jdobbs,
I have that. I'll try to run it within the next 24hrs.
Old 20th December 2014, 17:28   #22030  |  Link
whatever_gong82
Having issues with West Side Story 50th Anniversary Blu-ray
I ripped to ISO with AnyDVD HD 7.5.4.0 (Registered lifetime user of the Slysoft program--use same username over at their Forum as well), and while using BD-Rebuilder got this issue that I'm posting below.
I have never seen this before, so I'm stumped.
(I'm removed my personal name from the text.)
[12/20/14] BD Rebuilder v0.50.01
[06:37:07] Source: WEST_SIDE_STORY
- Input BD size: 41.44 GB
- Approximate total content: [03:02:04.036]
- Target BD size: 22.95 GB
- Windows Version: 6.2 [9200]
[06:37:09] PHASE ONE, Encoding
- [08:49:37] Rebuilding stream 00508 [8 of 19]
- [08:49:37] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00508.meta
- Can't create file E:\FILEHISTORY\Username\Username-PC\DATA\C\USERS\Username\VIDEOS\WORKFILES\TMP\BDMV\STREAM\00000.m2ts
- Failed to rebuild BD file(s). Aborted.
[09:48:32] Source: WEST_SIDE_STORY
[09:48:35] PHASE ONE, Encoding
[09:48:35]PHASE ONE complete
[09:48:35]PHASE TWO - Rebuild Started
- [09:48:35] Rebuilding stream 00501 [1 of 19]
- [09:48:35] Multiplexing M2TS
- [09:48:58] Rebuilding stream 00502 [2 of 19]
- [09:48:58] Multiplexing M2TS
- [09:50:34] Rebuilding stream 00503 [3 of 19]
- [09:50:34] Multiplexing M2TS
- [09:51:00] Rebuilding stream 00504 [4 of 19]
- [09:51:00] Multiplexing M2TS
- [09:51:37] Rebuilding stream 00505 [5 of 19]
- [09:51:37] Multiplexing M2TS
- [09:54:42] Rebuilding stream 00506 [6 of 19]
- [09:54:42] Multiplexing M2TS
- [09:55:02] Rebuilding stream 00507 [7 of 19]
- [09:55:02] Multiplexing M2TS
- [09:55:46] Rebuilding stream 00508 [8 of 19]
- [09:55:46] Multiplexing M2TS
- [09:58:03] Rebuilding stream 00511 [9 of 19]
- [09:58:03] Multiplexing M2TS
- [09:58:19] Rebuilding stream 00512 [10 of 19]
- [09:58:19] Multiplexing M2TS
- [09:58:32] Rebuilding stream 00513 [11 of 19]
- [09:58:32] Multiplexing M2TS
- [09:58:42] Rebuilding stream 00514 [12 of 19]
- [09:58:42] Multiplexing M2TS
- [09:58:53] Rebuilding stream 00515 [13 of 19]
- [09:58:53] Multiplexing M2TS
- [09:59:01] Rebuilding stream 00516 [14 of 19]
- [09:59:01] Multiplexing M2TS
- [09:59:10] Rebuilding stream 00517 [15 of 19]
- [09:59:10] Multiplexing M2TS
- [09:59:23] Rebuilding stream 00518 [16 of 19]
- [09:59:23] Multiplexing M2TS
- [09:59:26] Rebuilding stream 00519 [17 of 19]
- [09:59:26] Multiplexing M2TS
- [09:59:30] Rebuilding stream 00520 [18 of 19]
- [09:59:30] Multiplexing M2TS
- [09:59:34] Rebuilding stream 00521 [19 of 19]
- [09:59:34] Multiplexing M2TS
- [09:59:38] Rebuilding BD file Structure
[10:00:19] - Failed to REBUILD
whatever_gong82 is offline   Reply With Quote
Old 20th December 2014, 22:17   #22031  |  Link
Lathe
Lathe's Avatar
You are right, of course. BDRB does an outstanding job on it's own, which generally speaking, is precisely what it is for. But, at least I am not as compulsive as all these guys here using 'Highest Quality' on every encode
SubME-9 is REALLY going over the deep end and it HUGELY impacts the encoding time for likely no real visual gain...
'Auto' is probably just fine for everything. I just personally start getting a little nervous when the disc size starts getting pretty big and BDRB want's to do the encode really fast, although I'm sure the result would be excellent. I mean, shoot... I USED to be perfectly happy with the free DVDFab encodes, and we KNOW JD's program is a heck of a lot better than that!
Old 21st December 2014, 19:15   #22032  |  Link
Hajnal
Hey jdobbs,
[11.07.14] BD Rebuilder v0.49.05 (beta)
[21:32:32] Source: HOBBIT_DOS_EXTENDED_3D_PART1_00100
- Input BD size: 31,53 GB
- Approximate total content: [01:36:05.676]
- Target BD size: 23,73 GB
- MOVIE-ONLY mode enabled
- Quality: Ultra-High (Extremely Slow), ABR
[21:32:32] PHASE ONE, Encoding
- [21:32:32] Processing: VID_00049 (1 of 1)
- [21:32:32] Extracting A/V streams [VID_00049]
- [21:38:32] Reencoding video [VID_00049]
- Rate/Length: 23,976fps, 138*238 frames
- Bitrate: 26*485 Kbs
- [21:38:32] Reencoding: VID_00049, Pass 1 of 1
- [22:18:16] Video Encode complete
- [22:18:16] Processing audio tracks
- Track 4354 (hun): Keeping original audio
[22:18:16]PHASE ONE complete
[22:18:16]PHASE TWO - Rebuild Started
- [22:18:17] Rebuilding BD-3D file Structure
[22:31:33] - Encode and Rebuild complete
[22:31:33] JOB: HOBBIT_DOS_EXTENDED_3D_PART1 finished.
[12.21.14] BD Rebuilder v0.50.01
[18:52:59] Source: GONE GIRL
- Input BD size: 41,71 GB
- Approximate total content: [02:41:27.677]
- Target BD size: 23,93 GB
- Quality: Ultra-High (Extremely Slow), Two Pass
- X264 Tweak(s) enabled
Hajnal is offline   Reply With Quote
Old 22nd December 2014, 03:16   #22033  |  Link
Lathe
Lathe's Avatar
Heh, Ultra-High AND tweaks! WOW!
Old 22nd December 2014, 10:43   #22034  |  Link
KeVe1983
Banned
That was a while ago and you are using an older version, maybe something changed?
[12.22.14] Checking System Settings
  - BD-Rebuilder v0.50.01
  - Working Path Free Space: 42,95GB
  - FFDSHOW: 4504, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[12.22.14] Systems Settings Check complete
Just tried it again:
[12.22.14] BD Rebuilder v0.50.01
[10:40:17] Source:  HOBBIT_DOS_EXTENDED_3D_PART1
  - Input BD size: 35,04 GB
  - Approximate total content: [02:00:51.994]
[10:40:17] PHASE ONE, Encoding
 - [10:40:17] Processing: VID_00031 (1 of 3)
 - [10:40:17] Extracting A/V streams [VID_00031]
 - [10:40:28] Reencoding video [VID_00031]
   - Rate/Length: 23,976fps, 8.159 frames
   - Bitrate: 5.890 Kbs
 - [10:40:28] Reencoding: VID_00031, Pass 1 of 1
[10:40:30] - Failed video encode, aborted
Old 22nd December 2014, 11:18   #22035  |  Link
Hajnal
[/CODE]
Intel HD Graphics Driver?
Old 22nd December 2014, 11:45   #22036  |  Link
Hajnal
.....I USED to be perfectly happy with the free DVDFab encodes, and we KNOW JD's program is a heck of a lot better than that!
edit x264_dp_Standalone-Blu-ray.xml with settings x264
Old 22nd December 2014, 11:49   #22037  |  Link
KeVe1983
Banned
Yes, i just use the Intel GPU, don't have a graphic card.
Other Discs are working fine, just got that with Hobbit DOS.
Hobbit AUJ encode was fine.
Old 22nd December 2014, 12:25   #22038  |  Link
Hajnal
version number?
Old 22nd December 2014, 13:28   #22039  |  Link
KeVe1983
Banned
Originally Posted by hajnal View Post
version number?
10.18.10.3907 - 05.08.2014
Intel HD 4600
Old 22nd December 2014, 13:55   #22040  |  Link
Hajnal
Intel HD 4600
10.18.10.3621
the new version does not work
