Old 23rd February 2017, 16:54   #25681  |  Link
HWK
HWK's Avatar
Originally Posted by thekiller View Post
The first is the bluray in x264 and after I re import the mkv obtained in bdrebuilder and I do a reencoding in hevc
You can go from Blu-ray to hevc directly. Yes it will output mkv file.
Old 23rd February 2017, 17:25   #25682  |  Link
thekiller
Not most of the time it works but not on some
thekiller is offline   Reply With Quote
Old 23rd February 2017, 17:27   #25683  |  Link
HWK
HWK's Avatar
Can you share example which doesn't work.
Old 23rd February 2017, 17:30   #25684  |  Link
HWK
HWK's Avatar
@ Jdobbs for alternate output can I request option to have ability to downconvert DTS-HD to DTS.
Currently it only accept ac3, aac, and intact. I was think to add third option dts-hd to dts
Old 23rd February 2017, 18:05   #25685  |  Link
It works every time I've tried it -- and I'm pretty sure I've tried it more than anyone else on the planet.
Old 23rd February 2017, 18:29   #25686  |  Link
HWK
HWK's Avatar
Never mind I found it.
Old 23rd February 2017, 18:51   #25687  |  Link
thekiller
rebelle and the Magnificient seven
Old 23rd February 2017, 18:51   #25688  |  Link
Yeah. You just have to uncheck "Keep HD Audio" in the SETUP dialog.
Old 23rd February 2017, 18:53   #25689  |  Link
thekiller
I did not say that it did not work all the time but on some movies at home I am obliged to do in x264 at first and then redo from x264 to hevc. By cons I just try the automatic cropping and it cuts me part of the video has the vertical
Old 23rd February 2017, 18:54   #25690  |  Link
I'll test it on "The Magnificent Seven" later today -- but I'm pretty sure it will work. I assume you are talking about the 2016 version.
Old 23rd February 2017, 19:08   #25691  |  Link
raul124
raul124's Avatar
hi everyone, what's the different between x264 and HEVC?
raul124 is offline   Reply With Quote
Old 23rd February 2017, 19:13   #25692  |  Link
jfcarbel
Programmer
What is the default AC3 encoder used in BD Rebuilder and can and should it be replaced with something else for highest AQ?
I could only find only and older FAQ that mentioned it used Aften and that encoder had some quality issues.
jfcarbel is offline   Reply With Quote
Old 23rd February 2017, 19:20   #25693  |  Link
The default is Aften. There's always someone who will say something negative about anything. I can only say that IMHO the version of Aften included with BD-RB is a very good AC3 encoder and rivals commercial encoders. The only valid criticism would be that it hasn't been in development for a long while. If someone would point out a better AC3 encoder that is either free or very inexpensive and readily available -- it wouldn't be that hard to implement an alternative.
The funny thing is that I've read comments about other options (that people say are better) that actually use the Aften library as their engine.
Old 23rd February 2017, 19:39   #25694  |  Link
thekiller
Yes version 2016 with cinavia encryption
Old 23rd February 2017, 20:14   #25695  |  Link
MrVideo
MrVideo's Avatar
I personally also use aften. It is a relatively quick encoder. That said, ffmpeg will do AC3 and well as EAC3.
Old 23rd February 2017, 20:14   #25696  |  Link
MrVideo
MrVideo's Avatar
Just to clarify, Cinavia is not any kind of encryption. It is a watermark.
Old 23rd February 2017, 20:19   #25697  |  Link
Yeah, it would be better to call it "copyright protection". Or more accurately: "A way to make you pay for something, but not really be able to use it the way you want".
Old 23rd February 2017, 22:26   #25698  |  Link
LowDead
Elit Amans
Update to the AVCHD problem... By chance I tried today full backup BD5 with Java menus in the old Sony, and guess what... it worked!
I haven't checked yet, but is it done "the old way" when Java menus is located on the disc?
Old 23rd February 2017, 23:21   #25699  |  Link
Yeah. My old Sony would play full backups with Java too. It was much better back before Sony "fixed" all their players.
Yes. It is done the "old way" when there is Java. There isn't a choice, since it can't do a legal AVCHD disc. It's simply a full BD backup. Just a warning, though -- there are fewer and fewer players these days that will play those kinds of discs.
Old 23rd February 2017, 23:57   #25700  |  Link
jfcarbel
Programmer
Thanks, great to know, was just asking, don't have an opinion myself.
