Old 31st August 2015, 04:33   #1241  |  Link
Reel.Deel
r1774 (c4972da) is definitely the culprit; it even had this comment:
// TODO: Figure out why uncommenting this line causes problems
Tested using the Groucho's script above.
r1773:
r1774:
I believe this is the issue that spawned that/those commit(s).
Edit: old commit that might be relevant to this issue: https://github.com/AviSynth/AviSynth...f5af7dfab2c1a5
Reel.Deel is offline
Old 31st August 2015, 17:21   #1242  |  Link
Thunderbolt8
I'd like to request the addition of Rec. 2020 support for UHD Blu-rays & corresponding conversion options to compare UHD screenshots with normal Blu-ray screenshots. Otherwise we'd have to do it all manually.
Would be nice if the developers could add this in the future.
Thunderbolt8 is offline
Old 31st August 2015, 17:24   #1243  |  Link
This would certainly mean that all probable decoder plugins need to be able to signal source colorimetry metadata to the AviSynth+ kernel as well.
LigH is offline
Old 1st September 2015, 05:14   #1244  |  Link
Elegant
r1773:
r1774:
I did a whole bunch of comparisons between the AVS 2.6 and AVS+ regarding this. Could you test this build and see if the issue still occurs? I'll test it myself later when I have access to my PC with my plugins.
Elegant is offline
Old 1st September 2015, 05:30   #1245  |  Link
Reel.Deel
I get this error with AVSMeter:
Exception 0xC0000005
STATUS_ACCESS_VIOLATION
Edit: tried another time with AVSMeter and this time it ran for about 500 frames and then I got the error above. Using VirtualDub to run an analysis pass, the fps drop is very obvious, it goes from 100fps to 2 within 500 frames and then I got this error:
Avisynth read error:
Could not allocate video frame. Out of memory.
Old 1st September 2015, 14:01   #1246  |  Link
Elegant
Thanks, looking back at the change I made, that makes sense since I actually forgot to apply it to the rest of file and only fixated on the lines listed in that commit mentioned earlier and assumed the rest of it would work itself out (bad idea!). I'll test it fully at home and hopefully my idea pans out.
I found this comment very interesting as AVS 2.6 utilizes it in the "troubled" area:
// Hack note :- Use of SubFrame will require an "InterlockedDecrement(&retval->refcount);" after
// assignement to a PVideoFrame, the same as for a "New VideoFrame" to keep the refcount consistant.
This comment is made in both AVS 2.6 and AVS+ but AVS+ never utilizes InterlockedDecrement yet we use the refcount with AVS+ as well as InterlockedIncrement. More importantly we use refcount while going through the FrameRegistry list mentioned in the commit where frame is a value in the FrameRegistry:
if (0 == frame->refcount)
    delete frame;
At a glance this looks like a problem. I can't say for certain but I do not like that we never decrement a counter and yet have a condition for when it's 0 to delete it. I thought simply adding that comment to the "troubled" area would fix the problem but I think there are more areas that need an visiting in order for that to work.
EDIT: I did do a build where I reverted that commit and it does rectify the issue but it doesn't seem right to be using it as is...
Elegant is offline
Old 6th September 2015, 00:36   #1247  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
AviSynth+_v0.1.0_r1779.exe
http://avisynth.nl/index.php/AviSynth%2B#Downloads
Colorbars(pixel_type="YV12")
return Histogram("audiolevels")
==> "Integer Divide by Zero"
ConvertAudioTo16bit does not help.
v2.60 Jan 14 2013 is OK.
raffriff42 is offline
Old 6th September 2015, 02:38   #1248  |  Link
qyot27
qyot27's Avatar
That seems to be an issue with the tone ColorBars generates. If you kill the audio and replace it with the output of Tone(), Histogram works fine.
qyot27 is offline
Old 6th September 2015, 03:29   #1249  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
It's not only ColorBars:
#[[ choose a source
  A=WAVSource("pinknoise.wav") ## mono
  A=MonoToStereo(A, A)
  ## 2 ch, 16 bit, 44100
#  A=Tone
#  ## 2 ch, float, 48000
AudioDub(A)
#[[ choose one or more -  any of these causes divide-by-zero
#  ConvertAudioToFloat
#  ConvertAudioTo32bit
#  ConvertAudioTo16bit
Info
return Last
Old 20th September 2015, 11:13   #1250  |  Link
burfadel
So... Any new post 1825 test builds? I'm particularly interested in the 64-bit version.
burfadel is offline
Old 20th September 2015, 17:49   #1251  |  Link
qyot27
qyot27's Avatar
Development has entered a hiatus again, so there's nothing past r1825 to build (pull requests notwithstanding, but aside from #64 those wouldn't add very much to the end-user's experience).
I nearly start having an anxiety attack when I try to jump back into working on the SIMD splitting necessary for the Linux (or generally GCC, really) branch. The RC1 integration majorly sidetracked it.
qyot27 is offline
Old 21st September 2015, 02:29   #1252  |  Link
burfadel
Ah ok, all good! Has anyone attempted merging the latest Avisynth branch with Avisynth+ recently?
burfadel is offline
Old 21st September 2015, 05:09   #1253  |  Link
qyot27
qyot27's Avatar
There is amazingly little that changed between 2.6 RC1 (which was already merged into AviSynth+ in the early 1700s revision range) and 2.6.0 Final that were a concern to avsplus, or otherwise. The changes that do apply to avsplus are in the RC2 integrate branch/pending pull request - which AFAICT, along the whatever the resolution of the QTGMC slowdown issue a few posts back happens to be, are really all that are blocking 0.2 being tagged and released.
If classic's CVS isn't beyond the state of 2.6.0, then there's nothing else to merge from classic at the moment. Finding that out basically requires running a full cvsimport and doing a commit comparison unless you want to wander aimlessly through Sourceforge's CVS webviewer. The last time I did that was just after 2.6.0 was released.
qyot27 is offline
Old 23rd September 2015, 10:56   #1254  |  Link
tormento
Acid fr0g
tormento's Avatar
I have tried to search and read the wiki but can't find:
- which is the criteria to put a plugin inside plugin or plugin+?
- is there a list of tested plugins that fill that criteria?
@turment on Telegram
tormento is offline
Old 23rd September 2015, 11:09   #1255  |  Link
Groucho2004
Most plugins that work with 2.6 should work with AVS+.
However, AVS+ r1576 (the "official" stable version) supports only interface version 5. There are already a few plugins that are based on interface version 6 (KNLMeansCL for example), so these won't work. Also, the latest builds of ffmpeg require interface version 6. A workaround would be to install r1576 and then replace the DLLs with r1825.
Groucho2004 is offline
Old 23rd September 2015, 11:21   #1256  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your reply and I still haven't understood which is the difference between plugin and plugin+ directory.
tormento is offline
Old 23rd September 2015, 11:22   #1257  |  Link
I really wish development of this would start up again soon.. getting this is a fully workable state to finally replace AvisynthMT would be great.
ryrynz is offline
Old 23rd September 2015, 11:31   #1258  |  Link
tormento
Acid fr0g
tormento's Avatar
I am playing back and forth between Avisynth 2.6.0MT and AviSynth+ 1825 MT, testing speed and image quality.
I went thru the following image corruption.
AviSynth output:
from script:
PHP Code:
SetMTMode(3)
SetMemoryMax(2048)
LoadPlugin("D:\eseguibili\media\DGDecIM\DGDecodeIM.dll")
DGSourceIM("E:\in\2_01 favoloso mondo di Amelie, Il\amelie.dgi",engine=1)
SetMTMode(2)
CompTest(1)
ChangeFPS(last,last,true)
Crop(0,132,0,-140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6
AviSynth+ output:
from script:
PHP Code:
SetFilterMTMode("DEFAULT_MT_MODE"2)
SetFilterMTMode("DGSourceIM"3)
SetMemoryMax(2048)
CompTest(1)
Crop(0,132,0,-140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(4
Any idea?
tormento is offline
Old 23rd September 2015, 11:32   #1259  |  Link
Groucho2004
All you need to know is here, including the auto-load priorities.
Old 23rd September 2015, 11:35   #1260  |  Link
Groucho2004
What happens if you comment out the Prefetch() statement?
