Old 24th March 2012, 08:48   #14881  |  Link
Paddy97
I'm having problems to get the SUP files muxed in when using the latest BDRebuilder that has this hidden option. Is it a problem in the software or is it me?
The SUP gets extracted to the working dir but not muxed in to the final MKV.
[03-23-12] BD Rebuilder v0.40.08 (beta)
[17:28:59] Source:  FIGHT_CLUB
  - Input BD size: 31,82 GB
  - Approximate total content: [02:19:08.381]
  - Windows Version: 6.1 [7601]
  - Mode: MKV Container, 1920x1080, Intact Audio
[17:29:00] PHASE ONE, Encoding
 - [17:29:00] Processing: VID_00349 (1 of 1)
 - [17:29:00] Extracting A/V streams [VID_00349]
 - [17:46:23] Reencoding video [VID_00349]
   - Rate/Length: 23,976fps, 200*161 frames
 - [17:46:23] Reencoding: VID_00349, Pass 1 of 1
 - [19:56:14] Video Encode complete
 - [19:56:14] Processing audio tracks
[19:56:14]PHASE ONE complete
[19:56:14]PHASE TWO - Rebuild Started
 - [19:56:14] Building ALTERNATE OUTPUT Structure
[20:09:57] - Encode and Rebuild complete
[20:09:57] JOB: FIGHT_CLUB finished.
[Status]
LABEL=FIGHT_CLUB
VERSION=v0.40.08 (beta)
SOURCE_SIZE=34166661120
SOURCE_VIDEO_SIZE=34166661120
TARGET_SIZE=4686086144
REDUCTION=.137153763065743
RESIZE_1080=0
AUDIO_TO_KEEP=eng;swe;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;swe;
BACKUP_MODE=1
MOVIEONLY_TYPE=11
USE_LAVF=0
INSTANCES=1
DGDECNV=0
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00349]
AUDIO=100000000
PGS=00000000100000000000000000000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4686086144
SPLITS=1
NSIZE=0
FLINK=0
MLINK=0
[Options]
ALTCRF=n		n = 0-50 - CRF value to use for Alternate Movie-Only encodes (default=20)
ALTERNATE_PAL=n		n = 0/1 - Default=0, setting to "1" converts FILM DVD's to PAL without adding frames
ASSUME_HYBRID=n		n = 0/1 - Default=0, - if set to "1" all MPEG-2 NTSC SD material is assumed hybrid
AUDIO_AMPLIFY=n		n = 0-x - Increase volume of reencoded audio.  Example "1.2" = 20% increase, "2.0" = 2X
AUTO_BIAS=n		n = 0-3 - Def=1, Auto Qual bias, 0=high speed, 1=normal, 2=high quality, 3=highest qual
AUTO_TWOPASSONLY=n      n = 0/1 - 0 (default) allows one-pass ABR via automatic quality, 1 forces two-pass always
B_PYRAMID=n		n = 0/1 - 0 (default) sets option "--b-pyramid none", 1 sets option "--b-pyramid strict"
BDMV_CERT_ONLY=n        n = 0/1 - 0=Off (default) - if set to "1" BD-RB ignores all but BDMV & CERTIFICATE folders
BEEP_SOUNDFILE=s	s = The full path of a WAV file to be played upon completion of each job
COLOR_BOOST=n           n = 0/1 - Default=0, When set to "1" BD-RB will boost color levels by 10% (slow)
DEFAULT_LANG=s		s = language code, sets assumption for "undetermined" languages, example: DEFAULT_LANG=eng
DEINTERLACER_TYPE=n	n = 1-4 - 1=DECOMB w/o blend, 2=DECOMB w/blend, 3=SmoothDeinterlace, 4=Progressive (fake)
DISABLE_SLEEP=n		n = 0/1 - 1=(Default) block system SLEEP mode during encoding, 0=No SLEEP disabling
DISABLE_VIDEO_SLEEP=n	n = 0/1 - 1=Block video SLEEP mode during encoding, 0=(default) No video SLEEP disabling
DVD_SUB_BACKGROUND=n	n = 0-2 - 0=Transparent background (default), 1=Dark Blue background, 2=Black background
DVD_SUB_COLOR=n		n = 0/1/2 - 0=Yellow subtitles, 1=White subtitles (default), 2=Green subtitles
EXTENDED_GOP=n		n = 0/1 - 0=Off (default), 1=Use 48 frame GOPs for BD-5/9 output (rather than 24)
FIX_MOVIEONLY=n		n = 0/1 - 1=ON (default) - If set to "0", BD-RB will not add ExtensionData() to CLPI/MPLS
FIXED_CRF=n		n = 10..50 - force CRF encoding to use this CRF value (output size control disappears)
FORCE_ENCODE=n		n = 0/1 - if set to 1, BD-RB will never check to see if original video will fit
FORCE_NOENCODE=n	n = 0/1 - if set to 1, BD-RB will always use original video (sizing will not be checked)
FREE_PROCESSOR=n	subtract n from the processor count (leaves n processors free for other tasks)
HC_PROFILE=s		s = FAST/NORMAL/BEST - Default=NORMAL, Sets quality level for DVD encoding with HCEncode
HC_ONEPASS=n		n = 0/1 - 0=Normal two pass encoding (default), 1=HC *1PASS (quick first scan) (DVD only)
HDDVD_COMPLIANT=n	n = 0/1 - if set to 1, the output will be compliant with HD-DVD standards
IMGBURN_TARGET_DEVICE=s s = Drive to use for burning with ImgBurn (ex: e:, f:, etc)
INDEX_WITH_EXTRACT=n    n = 0/1 - if set to 1 (default), indexing occurs concurrently with audio extraction
IVTC_480i=n 		n = 0/1 - Default=0, 1=Perform IVTC on all 480i sources (careful -- normally a bad idea)
IVTC_DIRECTSHOW=n	n = 0/1 - Default=1, 1=IVTC is inherently performed by Directshow, 0=Use other (DECOMB)
IVTC_SELECTION=n	n = 0/1 - Default=0, 1=Enables IVTC on dropdown menu, use only for hard telecined sources
IVTC_TELECIDE=n		n = 0/1 - Default=1, 1=Use DECOMB's TELECIDE in Inverse telecining (IVTC) (DECOMB iVTC only).
KEEP_HD_LPCM=n		n = 0/1 - Default=1, When set to "0", BD-RB reencodes LPCM even for "Keep HD Audio"
KEEP_MBTREE=n		n = 0/1 - 0=Off (default), 1=Keep the stats.mbtree file after encode is complete
KEEP_SINGLE_AUDIO=n     n = 0/1 - 1=On (default), 1=Select audio (regardless of lang) when only 1 track exists
MAXIMIZE_REFS=n		n = 0/1 - If set to 0, BD-RB will always limit reference frames to 4. Otherwise, max.
MIN_M2TS_SIZE=n		n = minimum size required for BD-RB processing on BD-25 in MB, default is 100
MIN_PLAYLIST_MINS=n	n = minimum size (in minutes, default=15) for a playlist to a movie-only choice
MKV_INTERMEDIATE=n	n = 0/1 - 0=OFF (default) - if set to "1", .MKV files are used instead of .264
MKV_CHAPTERS=n		n = 0/1 - 1=ON (default) - if set to "0", no chapters will be implementeded in MKV output
MKV_MUXSUPS=n		1 = 0/1 - If set to "1", ALTERNATE/MKV output will include selected .SUP subtitles
MULTIPROCESS=n		n = 0-n - Experimental, see http://www.jdobbs.net/freeware/multiprocessing.html
NO_MBTREE=n		n = 0/1 - if set to 1, BD-RB will disable MBTREE in encodes
PASS_TWO_STATS_UPDATE=n n = 0/1 - 0=OFF (default) - if set to "1", BD-RB uses "--pass 3" for second pass
QUICK_CRF=n		n = 10..50 -- CRF value for "Quick Extras" encoding, defaults are BD5=30,BD9=24,BD25=20
QUICK_USE_QUALITY=n	n = 0/1 - if set to 1, BD-RB will use the current quality selection for CRF encodes
REMOVE_OUTPUT=n		n = 0/1 - 0=OFF (default) - if set to "1", the OUTPUT folder is removed after burning
REMOVE_WORKING=n	n = 0/1 - 0=OFF (default) - if set to "1", the WORKFILES folder is removed after rebuild
RESET_PERMISSION=n	n = 0/1 - Default=1, When set to "1", tells ImgBurn to reset permission flag during burn
SAMPLE_GROUP=n		n = Number of frames in each sample group for CRF estimation
SAMPLE_SIZE=n		n = Number of frames in each sample for CRF estimation (size/group = sample percentage)
SD_PROGRESSIVE=n	n = 0/1 - 0=OFF (default). If set to 1, Keeps IVTC'd 480i sources as 480p (not compliant)
SECONDARY_CRF=n		n = 10..50 - force BD-RB to use the specified CRF value for secondary encodings
SECONDARY_USE_QUALITY=n n = 0/1 - 0=OFF (default) - if set to "0" ultrafast is used, "1" uses standard quality
SHOW_ENCODER=n		n = 0/1 - Default 0.  If set to 1, BD-RB will show the X264 window during encoding
SHUTDOWN_SLEEP=n        n = 0/1 - Default=0, Setting to "1" changes "SHUTDOWN after Rebuild" option to "SLEEP..."
THREADS=n		n represents the number of threads to use in X264, default is "auto"
TWEAK_PASS_ONE=s	s = X264 pass 1 command line tweak(s)(warning -- for experts only, bugs not supported)
TWEAK_PASS_TWO=s	s = X264 pass 2 command line tweak(s)(warning -- for experts only, bugs not supported)
CHECK_FFDSHOW=n		n = 0/1 - 1=ON (default) 1 = Checks for FFDSHOW before running, 0 = Ignore checks
USE_NAL_HRD=n		n = 0/1 - 1=ON (default) 1 = Use "--nal-hrd" in the X264 command line, 0 = Don't use it.
WEIGHTP=n		n = 0/1/2 - Value used by BD-RB in X264 command line "--weightp", default is "1"
WIDE_OFFSET=n		n = .1-2.0 - Adjust start of clipping: 1=centered (default), .75=(y_start_line*.75), etc.
[Paths]
NICAUDIO=		Change the path for NICAUDIO.DLL
TSMUXER=		Change the path for TSMUXER.EXE
WAVI=			Change the path for WAVI.EXE
AFTEN=			Change the path for AFTEN.EXE
DECOMB=			Change the path for DECOMB521.DLL
MKVMERGE=		Change the path for MKVMERGE.EXE
Paddy97 is offline   Reply With Quote
Old 24th March 2012, 12:39   #14882  |  Link
You didn't post your INI file, so I can't tell if you're configured correctly. Do you have MKV_MUXSUPS=1 added to your INI file? It looks like you just changed it in the HIDDENOPTS.TXT file. That file is just there as documentation -- it isn't read by BD-RB. The INI/Config file has to be altered to include any hidden option you decide to use.
Old 24th March 2012, 17:19   #14883  |  Link
Paddy97
Thanks for clarifying. I feel stupid.
I only changed in the hiddenopts and did not transfter the line to the INI file.
Old 24th March 2012, 18:22   #14884  |  Link
Prz
Not related to this post but if you can review my post from Prz March 12th , 15:08 I'd greatly appreciate it as I'm pretty much out of commission using BDRB for a couple of weeks now.
Prz is offline   Reply With Quote
Old 24th March 2012, 19:11   #14885  |  Link
omegaman7
omegaman7's Avatar
You have no post on march 12th...
Old 24th March 2012, 20:33   #14886  |  Link
Don't feel stupid. It's not your fault. Unfortunately the software just hasn't been documented very well (yet). In its entirety this thread pretty much covers everything about the software -- but you'd have to scan through almost 15,000 posts to find it all.
Old 24th March 2012, 21:32   #14887  |  Link
Prz
Yes your correct. Its 18th March 2012, 15:08. However was trying to get to jdobbs but since I'm new to the forum thought I could do this by replying to his reply to you. Sorry for the misdirection but any pointers you can offer would be appreciated.
Old 24th March 2012, 23:07   #14888  |  Link
Capsbackup
Uninstall any / all codec packs, and also uninstall haali, ffdshow and avisynth. Delete the BD-RB folder that you initially unzipped to run the program. Then install only those three programs. (haali, ffdshow and avisynth)
From the same page that you download the latest BD-RB is the Windows 7 installation instructions. Follow that exactly.
Old 25th March 2012, 15:03   #14889  |  Link
Prz
So your saying get ffdshw,avsynth and haali installed with the needed modifications to the codecs in ffdshow then install BDRB? If so, the process is then to extract BDRB then launch it as an admin and allow it to set the Win 7 codecs. Wonder why the pre install of the 3 supporting pgms prior to BDRB? Will try it and let you know and thanks for the suggestion.
Old 25th March 2012, 18:44   #14890  |  Link
Capsbackup
No, I did not say this! This may work, but I only said to install them!
Yes, as the first post states for Windows 7 installation guide. Read the guide, it needs to be followed exactly!
They are necessary for BD-RB to work!
Old 25th March 2012, 20:56   #14891  |  Link
Originally Posted by rpareja View Post
I am having problems to make a FULL DISC copy of disk 5 from the TV Series GAME OF THRONES.
I removed all audio streams except english and removed all subtitles streams except english and spanish. BDRB gets stuck at the 31 of 42 title (at 16.99% overall progress).
Had no problems at all with the first 4 blu-rays.
Any suggestions?
I love this series, so I picked it up. I'll run Disc 5 today and will report back.
Old 25th March 2012, 23:14   #14892  |  Link
drmih
It may not be appropriate to comment but I have read a similar 'fault' elsewhere and it turned out that there is a version on Newsgroups which has corruption on Disc 5 - I have a Region B set and that works fine on all 5 discs with the latest version.
If you look closely at the post you'll see it was edited and I guess it may have been dubious:
"Last edited by neuron2; 21st March 2012 at 12:27. Reason: rule 6"
Old 26th March 2012, 15:07   #14893  |  Link
colinhunt
An observation I made when trying to do a full backup of a disc containing two episodes of a TV series (AVC 1080i/29.97fps):
With LAVF enabled, the output was constantly too large by several gigabytes. I ran several tests, using both custom and regular BD-25 target sizes. Switching to DGDecNV and selecting regular BD-25 target size resulted in an output size of 22.2GB.
Old 26th March 2012, 16:33   #14894  |  Link
drmih
I've also been struggling with something similar compressing to bd-9 with a 1 Gb oversize. Again a tv series with 2 episodes per disc, but a series and have had the same issue with the first two discs of a five disc set. I'll try changing to a machine with DGDecNV capability.
Old 26th March 2012, 18:17   #14895  |  Link
Prz
I followed your directions and those in the Windows 7 installation post exactly and still get the following from the inspect program.
- FFDSHOW: [3882], Ok
- WIN7 preferred AVC CODEC: Not Set correctly
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.40.0.8, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Any other suggestions?
Old 26th March 2012, 18:39   #14896  |  Link
Ch3vr0n
Did you run BDRB as with administrator priviledges?
Old 26th March 2012, 18:52   #14897  |  Link
KarstenS
I got the following error in the movie "Meet Dave" german version (full backup to BD9):
- [11:10:51] Processing: VID_00011 (12 of 35)
- [11:10:51] Extracting A/V streams [VID_00011]
- [11:11:09] Reencoding video [VID_00011]
- Source Video: MPEG-2, 720x576
- Rate/Length: 25,000fps, 3.475 frames
- Bitrate: 1.300 Kbs
- [11:11:09] Reencoding: VID_00011, Pass 1 of 2
- [11:11:50] Reencoding: VID_00011, Pass 2 of 2
- [11:13:38] Video Encode complete
- [11:13:38] Processing audio tracks
- Track 4352 (deu): Keeping original audio
- [11:13:38] Multiplexing M2TS
- [11:13:44] CorrectEPData() 00006 2007
EDIT: BD Rebuilder 0.40.08
KarstenS is offline   Reply With Quote
Old 26th March 2012, 19:00   #14898  |  Link
Prz
Yes, I did. I followed all instructions to the letter.
Old 27th March 2012, 12:51   #14899  |  Link
Ch3vr0n
@KarstenS, where's the rest of the log? We need all data
@Prz: check your system, do you have ANY kind of codec pack installed, kazaa lite, divx, ... ultimate codec pack, ...
Old 27th March 2012, 20:15   #14900  |  Link
busch42
Just tried to shrink the Bluray Movie Extremely Loud & Incredibly Close, Came up Failed video encode, aborted, Don't know why because I wiped my hard drive clean an reinstalled windows 7 with 64 bit and since I did that several weeks ago I have done 2 blurays since with no problem, Here is the report:
[03/27/12] BD Rebuilder v0.40.08 (beta)
[13:46:04] Source: EXTREME_LOUD_INCREDIBLE_CLOSE
- Input BD size: 34.51 GB
- Approximate total content: [03:46:30.576]
- Target BD size: 22.95 GB
[13:46:04] PHASE ONE, Encoding
- [13:46:04] Processing: VID_00001 (1 of 8)
- [13:46:05] Extracting A/V streams [VID_00001]
- [13:46:15] Reencoding video [VID_00001]
- Rate/Length: 23.976fps, 2,627 frames
- Bitrate: 6,157 Kbs
- [13:46:15] Reencoding: VID_00001, Pass 1 of 1
- [13:47:29] Video Encode complete
- [13:47:29] Processing audio tracks
- [13:47:29] Multiplexing M2TS
- [13:47:35] Processing: VID_00015 (2 of 8)
- [13:47:35] Extracting A/V streams [VID_00015]
- [13:47:45] Reencoding video [VID_00015]
- Rate/Length: 23.976fps, 8,159 frames
- Bitrate: 2,582 Kbs
- [13:47:45] Reencoding: VID_00015, Pass 1 of 1
- [13:50:00] Video Encode complete
- [13:50:00] Processing audio tracks
- [13:50:00] Multiplexing M2TS
- [13:50:06] Processing: VID_00023 (3 of 8)
- [13:50:06] Extracting A/V streams [VID_00023]
- [13:50:16] Reencoding video [VID_00023]
- Rate/Length: 23.976fps, 1,849 frames
- Bitrate: 6,228 Kbs
- [13:50:16] Reencoding: VID_00023, Pass 1 of 1
- [13:51:03] Video Encode complete
- [13:51:03] Processing audio tracks
- [13:51:03] Multiplexing M2TS
- [13:51:09] Processing: VID_00054 (4 of 8)
- [13:51:09] Extracting A/V streams [VID_00054]
- [14:12:13] Reencoding video [VID_00054]
- Rate/Length: 23.976fps, 186,265 frames
- Bitrate: 15,050 Kbs
- [14:12:13] Reencoding: VID_00054, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.40.08 (beta)
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[15:04:02] - Failed video encode, aborted
busch42 is offline   Reply With Quote
