Old 30th September 2012, 11:27   #15881  |  Link
Scorpio1
To Wakko79
I have noticed you get this behaviour if you copy the new version of BD Rebuilder over the old one, you need to completely delete the old version first, then put the new version in the directory (folder), this works for me, I get exactly the same error as you if I copy the new one over the old one. Hope that makes sense to you.
Scorpio1 is offline   Reply With Quote
Old 30th September 2012, 19:03   #15882  |  Link
dfsooner
I always copy the new over the old, but I'm careful to make sure ALL files and folders in the new version replace their predecessors. I don't remember ever having a problem that resulted from that practice.
dfsooner is offline   Reply With Quote
Old 30th September 2012, 21:12   #15883  |  Link
AmigaFuture
AmigaFuture's Avatar
I use BD-RB from the Desktop, and once I confirm the contents are the same (Giggling at jdobbs for a moment), I then extract the archive replacing the older. Then I move the archive to an archival directory until no longer needed. There should not be a challenge with replacing the older files unless a program/directory are "locked" from being used in some way. I've never deleted the older files or directories first; if the system is functioning correctly with respect to updating, it'll go smooth.
Old 2nd October 2012, 02:15   #15884  |  Link
abbadon
When using the new "Import" feature, and subsequently fully processing, will a video be "uncropped" to restore the compliant resolution (by adding black boarders) if necessary, or simply vertically stretched?
Win7x64...I had to...
RIP WinXP
abbadon is offline   Reply With Quote
Old 2nd October 2012, 05:48   #15885  |  Link
omegaman7
omegaman7's Avatar
I ran a cropped video recently. Clearly black borders were added in. It came out perfectly
Old 2nd October 2012, 10:07   #15886  |  Link
abbadon
hmmm, that's what I figured was SUPPOSED to happen, but for some reason I keep getting stretch video instead of borders . It's just import and process, right? No extra/hidden options? I'm sure I'm missing something...
RIP WinXP
Old 2nd October 2012, 12:30   #15887  |  Link
Borders are added to make it compliant. But it isn't done during the import, it is done when processing the imported source. If you look in the BDMV/STREAM folder of the import (the pseudo-BD source) you'll see a file with the extension .ADJ. This holds any adjustments that needs to be made to the source. It is a text file and is made up of AVISYNTH functions (like AddBorders()).
Old 2nd October 2012, 23:53   #15888  |  Link
CanuckGod
Just noticed that the newest BD Rebuilder (0.42.03) seems not to process what I have selected to blank or not to blank in Edit Mode when I save it in a batch queue; the BLANKED variable seems to have the correct 1's and 0's for what I'm editing, but BD Rebuilder uses the default auto-selected streams instead. Normal 'non-batch' mode works fine, however; wonder if anyone else has this problem or not.
CanuckGod is offline   Reply With Quote
Old 3rd October 2012, 00:33   #15889  |  Link
soneca
Hi Jdobbs,
How to properly process this unusual title?
Bd Rebuilder does not accept the inclusion of the line "--bff".
[09/28/12] BD Rebuilder v0.42.03 (beta)
[11:02:17] Source:  SUPER_SPEEDWAY_PLAYLIST_00000
  - Input BD size: 12,45 GB
  - Approximate total content: [00:49:41.978]
  - Target BD size: 4,38 GB
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY mode enabled
  - Quality: Better (Faster), Two Pass
  - X264 Tweak(s) enabled
  - Decoding/Frame serving: DGDecNV [2-way]
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
  - Subtitle [1] is defaulted ON.
[11:02:20] PHASE ONE, Encoding
 - [11:02:20] Processing: VID_00000 (1 of 1)
 - [11:02:20] Extracting A/V streams [VID_00000]
 - [11:05:03] Reencoding video [VID_00000]
   - Rate/Length: 29,970fps, 89.370 frames
   - Bitrate: 11.189 Kbs
 - [11:05:03] Reencoding: VID_00000, Pass 1 of 2
 - [11:26:05] Reencoding: VID_00000, Pass 2 of 2
  - Encode failed.  Aborting.
- BD-Rebuilder v0.42.03 (beta)
  - HAALI Splitter:  Isn't recommended version
  - FFDSHOW: 4422, not recommended version
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
General
Complete name                            : D:\BLU_RAY\SUPER_SPEEDWAY\BDMV\STREAM\00000.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 12.5 GiB
Duration                                 : 49mn 42s
Overall bit rate mode                    : Variable
Overall bit rate                         : 35.9 Mbps
Maximum Overall bit rate                 : 48.0 Mbps
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Format settings, GOP                     : M=3, N=18
Codec ID                                 : 27
Duration                                 : 49mn 41s
Bit rate                                 : 31.4 Mbps
Maximum bit rate                         : 35.0 Mbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 29.970 fps
Standard                                 : NTSC
Scan type                                : Interlaced
Scan order                               : Bottom Field First
Bits/(Pixel*Frame)                       : 0.505
Stream size                              : 10.9 GiB (87%)
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 49mn 41s
Bit rate                                 : 1 765 Kbps / 1 510 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : 129
Duration                                 : 49mn 41s
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Stream size                              : 228 MiB (2%)
Audio #3
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Duration                                 : 49mn 41s
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Old 3rd October 2012, 00:51   #15890  |  Link
When, where, how? What makes you think that is the issue? I notice that the first pass completed successfully -- and it also would use the "--bff" parameter.
Just a reminder... I don't accept bug reports that don't use the recommended versions of the helper software.
Old 3rd October 2012, 04:03   #15891  |  Link
soneca
Ok, I'll do some more tests and figure out what's going on.
It is difficult to harmonize the only software that I always use.
BD Rebuilder vs. RipBot264
As I recall, I never had problems because of that.
But it can happen...
Old 3rd October 2012, 04:24   #15892  |  Link
abbadon
I figured it out. there is a conflict with the MULTIPROCESS option
my config had MULTIPROCESS=1 but once removed no problem. tried changing it to 2 but no luck
separate, unless the source is oversized or FORCE_ENCODE is used, it doesn't process
RIP WinXP
Old 3rd October 2012, 04:42   #15893  |  Link
AmigaFuture
abbandon: If things fail in any way...Disable MULTIPROCESS and go from there. Once okay, try MP. It's usually fine left active for most movies.
Jdobbs: Any news with Toy Story?
After it's done re-rendering here and rebuilding, I discovered if I click Backup again, it rebuilds shows a longer list of rebuilding text. I'll include logs if you like.
Old 3rd October 2012, 08:59   #15894  |  Link
setarip_old
setarip_old's Avatar
@soneca
Did you notice the following?:
Old 3rd October 2012, 12:59   #15895  |  Link
soneca
Yes, it is easy to solve the issue of Haali Splitter installing the recommended version, but RipBot requires a newer version of ffdshow.
Old 3rd October 2012, 13:23   #15896  |  Link
mercadonegro
mercadonegro
when I want to compress a 25GB Blu Ray. I choose not to keep the original audio. I want to convert or re-encode AC3, I always had errors. Why?.
[10/02/12] BD Rebuilder v0.42.03 (beta)
[11:05:30] Source: SACCO_E_VANZETTI_-_1971
- Input BD size: 30,36 GB
- Approximate total content: [03:08:32.946]
- Target BD size: 22,95 GB
- Quality: High Quality (Default), Two Pass
- Resuming from previously started job.
[11:05:31] PHASE ONE, Encoding
- [11:05:31] Processing: VID_00006 (1 of 6)
- [11:05:31] Reencoding video [VID_00006]
- Source Video: MPEG-2, 720x576
- Rate/Length: 25,000fps, 3.622 frames
- [11:05:31] Reencoding: VID_00006, Pass 1 of 1
- [11:05:52] Video Encode complete
- [11:05:52] Processing audio tracks
- Track 4352 (ita): Keeping original audio
- [11:05:52] Multiplexing M2TS
- [11:05:56] Processing: VID_00005 (2 of 6)
- [11:05:56] Extracting A/V streams [VID_00005]
- [11:06:03] Reencoding video [VID_00005]
- Rate/Length: 25,000fps, 5.317 frames
- [11:06:03] Reencoding: VID_00005, Pass 1 of 1
- [11:06:38] Video Encode complete
- [11:06:38] Processing audio tracks
- [11:06:38] Multiplexing M2TS
- [11:06:45] Processing: VID_00003 (3 of 6)
- [11:06:45] Extracting A/V streams [VID_00003]
- [11:06:53] Reencoding video [VID_00003]
- Rate/Length: 25,000fps, 6.480 frames
- [11:06:53] Reencoding: VID_00003, Pass 1 of 1
- [11:07:33] Video Encode complete
- [11:07:33] Processing audio tracks
- [11:07:33] Multiplexing M2TS
- [11:07:38] Processing: VID_00007 (4 of 6)
- [11:07:38] Extracting A/V streams [VID_00007]
- [11:07:46] Reencoding video [VID_00007]
- Rate/Length: 25,000fps, 6.724 frames
- [11:07:46] Reencoding: VID_00007, Pass 1 of 1
- [11:08:28] Video Encode complete
- [11:08:28] Processing audio tracks
- [11:08:28] Multiplexing M2TS
- [11:08:34] Processing: VID_00002 (5 of 6)
- [11:08:34] Extracting A/V streams [VID_00002]
- [11:09:29] Reencoding video [VID_00002]
- Rate/Length: 25,000fps, 63.661 frames
- [11:09:29] Reencoding: VID_00002, Pass 1 of 1
- [11:15:43] Video Encode complete
- [11:15:43] Processing audio tracks
- [11:15:44] Multiplexing M2TS
- [11:16:30] Processing: VID_00000 (6 of 6)
- [11:16:30] Extracting A/V streams [VID_00000]
- [11:31:43] Reencoding video [VID_00000]
- Rate/Length: 24,000fps, 179.583 frames
- Bitrate: 20.599 Kbs
- [11:31:44] Reencoding: VID_00000, Pass 1 of 2
- [14:17:20] Reencoding: VID_00000, Pass 2 of 2
- [00:37:45] Video Encode complete
- [00:37:46] Processing audio tracks
- Track 4352 (ita): Reencoding audio to AC3...
- [00:37:46] ReencodeAudio() 00070 1801
[02:27:33] - Failed to reencode audio, aborted
help me please!
mercadonegro is offline   Reply With Quote
Old 3rd October 2012, 14:18   #15897  |  Link
Ch3vr0n
Run inspect.executive from inside the bdrb folder and post the results. That kind of behaviour typically indicates something wrong with the helper aps
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
Old 3rd October 2012, 19:13   #15898  |  Link
@mercadonegro
Error 00070 is "Permission Denied" -- you have a permissions issue with either the application or the folder where it is attempting to write.
I'd right-click on the files AFTEN.EXE and WAVI.EXE in the BD-RB tools folder and see if there is some rights issue against one of them.
Old 3rd October 2012, 22:28   #15899  |  Link
jwjohnson
mercadonegro
Do you have BD-RB installed in the Program Files or the Program Files (x86) folders?
Windows 7 doesn't always play nice with BD-RB if you put it there.
jwjohnson is offline   Reply With Quote
Old 4th October 2012, 01:36   #15900  |  Link
Ch3vr0n
there are no issues with running any program like BDRB or another in the program files. I do, well not if u disable that stupid UAC like i did. Thats one of the first things i do after a windows install.
