Old 2nd September 2021, 19:01   #8801  |  Link
v0lt
Thanks. Translations updated in r6478, r6479, r6482.
v0lt is online now   Reply With Quote
Old 5th September 2021, 09:17   #8802  |  Link
kopija
Greetings,
does MPC-BE have functionality to eliminate motion judder?
Something like MadVR smooth motion?
Is it "sync video to display" under "EVR sync settings"?
Thank you.
kopija is offline   Reply With Quote
Old 7th September 2021, 08:16   #8803  |  Link
It doesn't. Probably not hard to them to add though.
Old 8th September 2021, 00:18   #8804  |  Link
beter
Update for translation of Chinese Traditional and Dutch
https://www.sendspace.com/file/lxrxsr
beter is offline   Reply With Quote
Old 8th September 2021, 16:49   #8805  |  Link
v0lt
@beter
Thanks. Updated in r6506.
Old 12th September 2021, 06:31   #8806  |  Link
Will 1.5.9 be released with some fixes backported from 1.6.0 alpha or is 1.6.0 the next release?
Old 17th September 2021, 21:30   #8807  |  Link
Sunspark
Testing the playing of a YouTube link in MPC-BE I found a bug.
Currently the player is set up to use LAV for the decoding.
With the audio renderer set to MPC Audio Renderer, it will play the video fine from YouTube.
With the audio renderer set to Directsound: Speakers (Realtek(R) Audio), the video from YouTube stutters.
Sunspark is offline   Reply With Quote
Old 18th September 2021, 10:58   #8808  |  Link
v0lt
@Sunspark
1. Try to open with built-in filters and DirectSound.
2. Try not to use LAV Source and LAV Decoders together.
Old 18th September 2021, 22:36   #8809  |  Link
mclingo
Hi, looking for some help with HP elite desktop G3 i5 with Intel 530 graphics. This is supposedly capable of decoding HEVC but I cant seem to get it to use any hardware decoding either using internal or external lav filters, CPU remains at 60-100 rending this machine useless, got latest drivers, any ideas?
EDIT - it actually looks like it might be now but its still still wont play any HDR 4k bluray rips without a slide show, I'm thinking this machine just doesnt have enough grunt for this.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - http://madshi.net/madVRhdrMeasure141.zip
Old 19th September 2021, 01:15   #8810  |  Link
clsid
It only supports 8-bit HEVC. It doesn't do 10-bit HEVC.
MPC-HC 1.9.16
Old 19th September 2021, 06:29   #8811  |  Link
mogli
Minor issue:
Let's say we have a mpcpl with a video 'hello.webm' and explicitly given corresponding audio file 'hello.mka'. Note that in the same folder is also 'hello.m4a'.
Playing the video chooses the right audio file but if we delete the video with shift+delete, MPC-BE deletes 'hello.webm' and 'hello.m4a' even though the latter isn't even in the playlist.
(And no, it wasn't me who named the files or made the playlist.)
mogli is offline   Reply With Quote
Old 19th September 2021, 07:03   #8812  |  Link
v0lt
I was against the functionality of deleting files in the player. But users strongly insisted and it was added. What users wanted is what they got in the end. People need to think not only about momentary desires, but also about the consequences.
Old 19th September 2021, 09:18   #8813  |  Link
mogli
I don't understand.
For playing you use the information in the playlist.
For deleting you don't.
Why?
Old 19th September 2021, 11:25   #8814  |  Link
mclingo
aha, thanks for that, I couldnt find that info anywhere, guessing I need something with the later intel IRIS
Old 19th September 2021, 20:03   #8815  |  Link
mzso
Hello!
Where can I find the latest builds of MPC video renderer?
Old 19th September 2021, 21:15   #8816  |  Link
lvqcl
Currently https://disk.yandex.ru/d/AjAXDDHtHRIELg
Old 19th September 2021, 21:47   #8817  |  Link
mzso
Originally Posted by lvqcl View Post
Old 26th September 2021, 12:57   #8818  |  Link
Klaus1189
Updated german translation based on r6561
Old 27th September 2021, 05:14   #8819  |  Link
Klaus1189
Updated german translation to match changes of 6563
Old 27th September 2021, 10:18   #8820  |  Link
s0meone_new
Hungarian translation updated:
https://www80.zippyshare.com/v/H602dKOd/file.html
s0meone_new is offline   Reply With Quote
