Old 4th September 2020, 23:27   #641  |  Link
manolito
manolito's Avatar
What is going on with this 3.6.2 test 2 build???
The first post of this thread still lists test1 as the latest test version. And when using the real.finder link for test 2 Google tells me that the file is infected with a virus and can only be downloaded by the owner...
@ StainlessS
AFAIk all the pinterf files only test versions are XP compatible.
Old 5th September 2020, 00:43   #642  |  Link
kedautinh12
@ StainlessS
Try link: https://mega.nz/file/w5w3RBDB#bYXUC8...OOXbJn6fvHx7qY
kedautinh12 is online now   Reply With Quote
Old 5th September 2020, 01:45   #643  |  Link
StainlessS
StainlessS's Avatar
thankx, did not know that.
kedautinh12,
Thank ked, I got it from real.finder Pinterf link via linux.
I sometimes post sober.
Old 5th September 2020, 06:17   #644  |  Link
real.finder
@ StainlessS
it's from https://github.com/AviSynth/AviSynth...ment-683817906
edit: seems you right there are problem with google drive, anyway it's only one https://www.virustotal.com/gui/file/...4610/detection so it's false positive
also seems you didn't note https://forum.doom9.org/showthread.p...91#post1922691
See My Avisynth Stuff
Old 8th September 2020, 04:52   #645  |  Link
manolito
manolito's Avatar
No wonder that the unofficial 3.6.2 test2 build is not featured, because I found that it is thoroughly broken...
During a few tests with interlaced sample clips this one crashed reliably using the test2 build:
http://www.nepadigital.com/reencode/avidv.avi
First of all the SSRC audio filter seems to be missing. Plus the encode crashes because a VC++ redistributable is missing. The missing file is VCRUNTIME140D.dll, and this redistributable is not included in the very latest Abbodi VC++ AIO package. Reverting to version 3.6.2 test1 fixed the problems.
Old 8th September 2020, 06:23   #646  |  Link
kedautinh12
I think you need update all vc runtime c++ 2005-2019 last version
Old 8th September 2020, 09:11   #647  |  Link
StainlessS
StainlessS's Avatar
VCRUNTIME140D.dl looks to be a debug version of VCRUNTIME140.dl from Visual Studio 2015.
[you will not have it without the compiler, but dont seem to cause me problem and I dont have it]
Old 8th September 2020, 10:21   #648  |  Link
real.finder
try this one https://www.sendspace.com/file/qooa40 I made it not as debug
Old 8th September 2020, 11:43   #649  |  Link
tormento
Acid fr0g
tormento's Avatar
did you tried with test 2
Questo file infettato da un virus
Solo il proprietario pu scaricare i file contenenti virus.
I.e. Drive complains about a virus and doesn't download it.
Any mirror available, please?
@turment on Telegram
Old 8th September 2020, 13:07   #650  |  Link
real.finder
for x86 see my post in #648
for x64 see kedautinh12 #642
Old 9th September 2020, 10:44   #651  |  Link
tormento
Acid fr0g
tormento's Avatar
LOL
I should open my eyes wider when reading.
10x
Old 12th September 2020, 04:50   #652  |  Link
kedautinh12
I check vcredist downloaded from there errors with some softwares only support visual c++ 2015, 2017, i checked and package from there only name visual c++ 2019 after install
https://github.com/abbodi1406/vcredist/releases
When i downloaded from there, visual c++ full name 2015-2019 after install and softwares work correctly and don't crash anymore
https://downloadly.net/2020/13/3230/...013094212.html
Old 17th September 2020, 07:34   #653  |  Link
kedautinh12
your built and pinterf can't use with megui 32bit
Edit: i know what wrong, just download this file and copy all file from library folder, after paste to windows/system32 if you use win x86 or windows/sysWow64 if you use win x64
Edit2: https://drive.google.com/file/d/13O9...w?usp=drivesdk
Old 18th September 2020, 13:27   #654  |  Link
kedautinh12
Everyone can try 3.6.2 test 2b: https://github.com/AviSynth/AviSynth...ment-694731296
Old 18th September 2020, 14:35   #655  |  Link
pinterf
Previous not-so-public test2 version contained debug builds of the x86 bundled plugins so people with no VS development environment had bad luck.
pinterf is offline   Reply With Quote
Old 20th September 2020, 01:52   #656  |  Link
real.finder
I did update those old posts with this Reply (note the colors)
ok, so I will mention what not has HBD yet
1st is plugins that has VS ports with HBD:-
1 - EEDI3 (no HBD yet)
2 - Dither_resize16/fmtconv (no yet) here https://github.com/EleonoreMizo/fmtconv the vs port
3 - SangNom2/SangNomMod (done by Asd)
4 - TTempSmooth (done by Asd)
5 - EEDI2 (done by Asd)
6 - TCanny (there are TCannymod by chikuzen but I think with no HBD) (done by Asd)
7 - Yadifmod (there are Yadifmod2 by chikuzen with not completed HBD) (done by Asd)
8 - DeblockPP7 (done by Asd)
9 - median (not yet) here https://github.com/dubhater/vapoursynth-median the VS port
10 - tbilateral (done by Asd)
11 - tedgemask (done by Asd but no HBD yet) here https://github.com/dubhater/vapoursynth-tedgemask the vs port
12 - MSmooth (done by Asd)
13 - ASharp (no yet) here https://github.com/dubhater/vapoursynth-asharp the VS port
14 - degrainmedian (no yet) here https://github.com/dubhater/vapoursynth-degrainmedian the VS port
15 - TDeint (done by pinterf)
plugins that has VS ports but no HBD:-
1 - scxvid (there are no x64 in avs yet)
2 - hqdn3d (there are avs port but with 16bit hack)
3 - ssiq (there are no x64 in avs yet)
and there are some filters seems has no VS ports
1 - VariableBlur (it was planed by tp7)
2 - frfun7 (useful for Dot Crawl Removal, used in DDComb)
3 - GradFun2db (maybe it can be replaced with f3kdb?)
4 - LGhost (HolyWu Recently did the VS port, avs+ done by Asd)
so a lot of those are done now by Asd here https://github.com/Asd-g?tab=repositories and there are some that I didn't mention like https://github.com/Asd-g/AviSynth-CAS and https://github.com/Asd-g/AviSynth-FillBorders and https://github.com/Asd-g/AviSynth-vsTMM and https://github.com/Asd-g/AviSynth-BWDIF and https://github.com/Asd-g/AviSynth-JincResize and https://github.com/Asd-g/RawSource_2.6x and https://github.com/Asd-g/MTCombMask and https://github.com/Asd-g/ReduceFlicker and there are many others!
note: the ones that has "vs" in their names because they are not same as old avs one (Missing things from avs old one or different parameters)
Old 20th September 2020, 02:31   #657  |  Link
kedautinh12
I think FFT3dGPU (no HBD yet) and add more plugins work very good but only have in vapoursynth: BM3D (https://github.com/HomeOfVapourSynth...pourSynth-BM3D) and CUDA-accelerated implementation of BM3D image denoising method (https://github.com/DawyD/bm3d-gpu), fvsfunc (https://github.com/Irrational-Encoding-Wizardry/fvsfunc) have AutoDeblock function (trying to detect blocked frames and won’t touch non-blocked frames. It’s recommended for MPEG2 input, but also works with h264 input. You can use it on the whole clip)
Old 20th September 2020, 03:38   #658  |  Link
real.finder
Originally Posted by kedautinh12 View Post
I think FFT3dGPU (no HBD yet) and add more plugins work very good but only have in vapoursynth: BM3D (https://github.com/HomeOfVapourSynth...pourSynth-BM3D) and CUDA-accelerated implementation of BM3D image denoising method (https://github.com/DawyD/bm3d-gpu), fvsfunc (https://github.com/Irrational-Encoding-Wizardry/fvsfunc) have AutoDeblock function (trying to detect blocked frames and wont touch non-blocked frames. Its recommended for MPEG2 input, but also works with h264 input. You can use it on the whole clip)
seems there are AutoDeblock2 for avs but I can't find it, it will be easier for me to update it instead of read python code and back port it
Old 20th September 2020, 06:07   #659  |  Link
kedautinh12
I only find out here related avisynh
https://pastebin.com/JqBvNp32
Edit: Script related
vweakdeblock = Deblock_QED().dfttest(sigma=1 ,y=true,u=true,v=true,tbsize=1).smdegrain(blksize=16,tr=2,pel=1,subpixel=3,prefilter=2,thsad=50,thsadc=25,refinemotion=true)
weakdeblock = Deblock_QED().dfttest(sigma=5 ,y=true,u=true,v=true,tbsize=1).smdegrain(blksize=16,tr=2,pel=1,subpixel=3,prefilter=2,thsad=100,thsadc=50,refinemotion=true)
mediumdeblock = Deblock_QED().dfttest(sigma=9 ,y=true,u=true,v=true,tbsize=1).smdegrain(blksize=16,tr=2,pel=1,subpixel=3,prefilter=2,thsad=150,thsadc=75,refinemotion=true)
strongdeblock = Deblock_QED().dfttest(sigma=13,y=true,u=true,v=true,tbsize=1).smdegrain(blksize=16,tr=2,pel=1,subpixel=3,prefilter=2,thsad=200,thsadc=100,refinemotion=true)
vstrongdeblock = Deblock_QED().dfttest(sigma=17,y=true,u=true,v=true,tbsize=1).smdegrain(blksize=16,tr=2,pel=1,subpixel=3,prefilter=2,thsad=200,thsadc=100,refinemotion=true)
Old 22nd September 2020, 02:06   #660  |  Link
real.finder
I got AutoDeblock2 from a friend, and did add HBD, you can got it from Thread in my signature
