Old 20th March 2021, 18:40   #881  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Thanks pinterf!
Old 21st March 2021, 15:06   #882  |  Link
wonkey_monkey
VideoInfo.GetPlaneWidthSubsampling and VideoInfo.GetPlaneHeightSubsampling both throw exceptions if called with a parameter of 0. Since "0" is the default parameter for GetReadPtr, etc, and so is effectively the plane ID for interleaved RGB video, could those functions be updated to return 0 if called with 0, rather than throwing an exception?
Also edit: could IsY(), IsYUV() and IsYUVA() be updated/replaced to be consistent and intuitive?
Old 21st March 2021, 18:43   #883  |  Link
StainlessS
StainlessS's Avatar
Maybe one of em should be VideoInfo.GetPlaneHeightSubsampling.
EDIT:
Function X_IsY(clip c)  {
    # True=Single Plane
    #     (!IsRGB)=True = Any type with Y, YUY2/YUVA/Y8 etc.
    #     BEWARE Y8_Clip.IsYUV returns True
    c
    IsAvsPlus ? IsY : IsAvs26 ? IsY8 : False
I sometimes post sober.
Old 25th March 2021, 18:21   #884  |  Link
StainlessS
StainlessS's Avatar
From here [Internal functions]:- http://avisynth.nl/index.php/Interna...ons#propSetInt
Not sure if this lot is correct,
propSetInt
propSetInt(clip, string key_name, function func_obj [, integer "mode"]) AVS+
propSetFloat
propSetFloat(clip, string key_name, function func_obj [, integer "mode"]) AVS+
propSetString
propSetString(clip, string key_name, function func_obj [, integer "mode"]) AVS+
propSetArray
propSetArray(clip, string key_name, function func_obj [, integer "mode"]) AVS+
these setters accept only the specific type
Should it be more like this
propSetInt
    propSetInt(clip, string key_name, integer value [, integer "mode"])   AVS+
propSetFloat
    propSetFloat(clip, string key_name, float value  [, integer "mode"])   AVS+
propSetString
    propSetString(clip, string key_name, string value  [, integer "mode"])   AVS+
propSetArray
    propSetArray(clip, string key_name, array value  [, integer "mode"])   AVS+
Also, something seems a bit messed up here,
propGetAsArray
propGetAsArray(clip, string key_name[, integer "index", integer "offset"]) AVS+
returns an array. For a single property array size will be 1. (only in array-aware AviSynth+ versions)
propGetAll
propGetAsArray(clip [, integer "offset"]) AVS+
Returns all frame properties in an array of [key-value] pairs. Array size will be 'numProps'
Each key-value pair is contained in a two dimensional subarray.
If the property value for a given key is an array again then "value" will be an array as well.
Once you have the array with all properties you can access them with the "associative" feature of AviSynth array access
Extracting from C prototypes I see this, [can only extract single C prototype]
propGetAsArray "cs[offset]i"
EDIT: And
propGetAll "c[offset]i"
Old 26th March 2021, 16:47   #885  |  Link
pinterf
propSetInt
propSetFloat
propSetString
propSetArray
They are O.K. These names are different only for parameter lists with function object.
Other plain propSet versions can establish the property type from the type of the provided value.
More on function objects:
http://avisynth.nl/index.php/Function_objects
EDIT: the mess with propGetAll is quick-fixed, thanks for the report.
pinterf is offline   Reply With Quote
Old 26th March 2021, 21:42   #886  |  Link
wonkey_monkey
There's something very odd going on...
I was getting a crash with this script and version 3.6.1 (edit: also with 3.7.0):
Colorbars
ResampleAudio(48000) # any value
It would play back from any frame other than frame 0, but if played back (in VirtualDub) from frame 0, it would crash. It would also crash using AVSMeter (I wrote a simple plugin to GetAudio within GetFrame, so that I could benchmark audio using AVSMeter).
So I updated to 3.7.0. The good news is, no more crash (EDIT: scratch that: it still crashes from frame 0. Not if you add trim(1,0), though). The bad news is, when I playback a simple Colorbars clip (even without ResampleAudio) in VirtualDub2, the sound is all messed up, like it's clicking on and off at (very rough guess) 25Hz. EDIT: It seems to be almost exactly 40Hz. Here's an Audacity screenshot of a recording of VirtualDub2 playback:
Using my waveform plugin, the waveform looks okay, but I guess something about how VirtualDub is getting the audio is getting things messed up. Sound generated by the Tone function is similarly messed up. A Wavsource, though, is fine.
Edit: ffmpeg encoding to a file seems fine. Maybe it's a VirtualDub2 thing, but it wasn't doing it under 3.6.1.
Old 26th March 2021, 22:57   #887  |  Link
Richard1485
AviSynth monkey
Richard1485's Avatar
It's not VirtualDub2, though I can hear it in VirtualDub2. I can also reproduce it in ffplay on the Linux build of AviSynth+ (latest version). It seems to me to be related to bit depth.
Colorbars
ConvertAudioTo16bit() # any bit depth
It's not audible in ffplay if I comment out the second line, but it is in VirtualDub2. VirtualDub never used to like playing back audio at anything other than 16-bit (though VirtualDub2 was an improvement), so maybe VirtualDub2 converts the audio as it comes in.
Richard1485 is offline   Reply With Quote
Old 27th March 2021, 00:02   #888  |  Link
wonkey_monkey
Same with ffplay on Windows.
Old 27th March 2021, 09:24   #889  |  Link
pinterf
Colorbars
Did it crash for you even at 48000? Because in this case the filter does nothing, no conversion occurs, just calls the child (colorbars) GetAudio. Anyway, I could not make it crash, neither from avsmeter not from vdub2.
Old 27th March 2021, 13:53   #890  |  Link
wonkey_monkey
I could have sworn it did yesterday, but it's not doing it now.
Rates other than 48000 are still causing it to crash on the first frame.
ColorBars
ResampleAudio(44100)
# ^ crashes
ColorBars
Trim(1,0)
# ^ does not crash
Both of these are true for 3.6.1 and 3.7.0. Garbled VirtualdDub2/ffplay audio only occurs with 3.7.0 (and on ffplay only if ConvertAudioTo16Bit() or ConvertAudioTo8Bit() is used).
I removed all plugins just in case but it didn't make any difference.
EDIT: Adding a call to Amplify - even with a value of 1 - before ResampleAudio stops the crash occuring.
Old 27th March 2021, 14:19   #891  |  Link
wonkey_monkey
Re the glitch, my previous screenshot was taken while I had my laptop's audio processing enabled which I think gave a misleading impression. Here's a closeup with processing disabled:
It happens at the positive peak every 11 positive peaks. I'm guessing some change in the code or perhaps floating point mode when compiling is causing the generated sample to go just over 1.0, which makes the glitch audible when it's converted to integer samples before sending to the sound card. Adding:
Amplify(0.99)
stops the playback glitch.
Old 27th March 2021, 15:49   #892  |  Link
Richard1485
AviSynth monkey
On my end, it occurs in ffplay with ConvertAudioTo24Bit() and ConvertAudioTo32Bit() as well.
Old 29th March 2021, 09:00   #893  |  Link
pinterf
ColorBars
# ^ crashes
ColorBars
Trim(1,0)
# ^ does not crash
No crash for me. Now to get any further: 32 or 64 bit Avisynth? Does it happen with SetMaxCPU("none") at the start of the script?
Which version of Virtualdub2 you are using (I'm at 44282). What are you exactly doing when vdub2 is crashing? Just load the script and press reload F2? Or File|Save audio.
I can see that after ResampleAudio, some samples can be more than 1.0, e.g. 1.00000023 but it cannot be a problem.
Old 29th March 2021, 12:29   #894  |  Link
wonkey_monkey
It seems to affect 64 bit Avisynth only. SetMaxCPU("none") has no effect. I'm using 44282 as well but the crash happens with ffplay.exe, as well as avsmeter64.exe and my own AVS viewer (when using a plugin that forces the fetching of audio with video - my original Waveform plugin and a completely new purpose-written one that just calls GetAudio within GetFrame). I also added a call to GetAudio to my own viewer and that let me narrow it down a little:
With the following script:
SetMaxCPU("none")
ColorBars
, the crash occurs if I attempt
clip->GetAudio(buffer, X, 1, env);
, where X is between 0 and 41. For x=42 and above, no crash.
If I change the new sample rate to 34100, it crashes with X between 0 and 39.
If I change the new sample rate to 10000, it crashes with X between 0 and 34.
I thought >1.0 samples might be the cause of the garbled playback with VirtualDub and ffplay, but may be entirely unrelated to the crash.
Old 29th March 2021, 13:59   #895  |  Link
pinterf
SetMaxCPU("none")
ColorBars
Filter can request data for negative audio sample points in this case when we are in the very first frame. Resample is using overlapping buffers. Providing proper zeroified-samples for negative sample points is handled however when GetAudio is passing through "audio cache", so ColorBars is seeing only n>=0 audio sample requests.
EDIT: from 48000 to 44100 conversion, there is a -45 as the start parameter of GetAudio
Old 30th March 2021, 16:46   #896  |  Link
StainlessS
StainlessS's Avatar
Bit more audio weirdness, StackVertical audio should be from first clip.
# Stack filters should produce audio from first clip.
CHANNELS = 2        # Try with 2 and 1
V=Colorbars.KillAudio
A1=Tone (length=30.0, frequency=440, samplerate=44100, channels=2,        type="Sine",  level=1.0)
A2=Tone (length=30.0, frequency=440, samplerate=44100, channels=CHANNELS, type="Noise", level=1.0)
V1=AudioDub(V,A1).Trim(0,-1000)
V2=AudioDub(V,A2).Trim(0,-1000)
#S=StackHorizontal(V1,V2)  # Seems OK
S=StackVertical(V1,V2)     # Wrong, CHANNELS=(2)=Audio from bottom clip, CHANNELS=(1)= maybe some mix of audio from both clips
#V1
#V2
S
EDIT: Does not occur in v2.60/2.61 std.
EDIT: DOES OCCUR in avs+ v0.1 r2772.
Old 31st March 2021, 00:16   #897  |  Link
zorr
How much support is there for array variables? My tests indicate that currently you can
  • create an array variable: arr = [0.1, 0.2]
  • read from an array: a = arr[0]
  • loop through an array: for (i = 0, ArraySize(arr)-1, 1) { ... }
However I wasn't able to update a value to a specific index: arr[0] = 0.1
Is there a way to create an array with a specific size without listing all the values, something like arr = float_array[10]?
Thanks!
zorr is offline   Reply With Quote
Old 31st March 2021, 07:30   #898  |  Link
pinterf
#V1
#V2
S
I suppose it happens only for packed RGB? Because this format has its lines upside down order, so input clip order is reversed as well. But then it has this side effect.
Old 31st March 2021, 12:56   #899  |  Link
StainlessS
StainlessS's Avatar
Well wadya know, I did not even think to try with non RGB interleaved when prob was audio, nice one P.
Old 31st March 2021, 16:16   #900  |  Link
pinterf
Fixed, anyway.
