Old 24th August 2014, 08:04   #2241  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by max wyty View Post
Ive been using the mpc-be internal source / decoders , and no problem in general, but, most of tutorials strongly suggest unselect internal filters and install LAV filters.
My questions for the experts...how good are the BE internal source / decoders ? LAv increases something else in the quality / performance ?
thanks
Internal source/decoder is good, there is not necessary to use LAV
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is online now   Reply With Quote
Old 24th August 2014, 13:32   #2242  |  Link
wanezhiling
Internal splitters/decoders are most compatible with the player, that's the truth.
And since Internal ones have almost all functions of LAV, you'd better stick to them.
Old 25th August 2014, 01:31   #2243  |  Link
octal9
octal9's Avatar
i noticed that sometimes when i double click on a media file that the seek bar will appear below the player controls rather than above them (normally its' always the other way around) - why is this, and is there a way change this behavior? secondly, are mpc-be's filters based directly off of lav or ffdshow or elsewhere? and lastly, love the player - you folks always make my day much better - best program around - thanks kindly for the continuing hard work........
octal9 is offline   Reply With Quote
Old 25th August 2014, 11:54   #2244  |  Link
xiringu
Is it possible to add a keyboard shortcut to turn the OSD on/off?
I've seen this:
Options->Player->Other->Show OSD
but no keyboard shortcut.
my problem is the following:
I turn the OSD off because I watch sports and I skip forward a lot, but I don't want to see how much time there's left (the default behaviour).
Then, if I need to see something, like the system time, I have to go all the way to the menu to turn the OSD on again.
xiringu is offline   Reply With Quote
Old 25th August 2014, 14:06   #2245  |  Link
JohnLai
Guys, how do I disable the built-in 'audio switcher'?
Normal MPC-HC has the option to disable it, but I can't seem to find it at MPC-BE
JohnLai is offline   Reply With Quote
Old 25th August 2014, 14:09   #2246  |  Link
You can't disable it anymore.
Old 25th August 2014, 14:32   #2247  |  Link
JohnLai
Why?
Old 25th August 2014, 14:41   #2248  |  Link
detmek
Because that option is removed recently. Audio switcher is always active now.
detmek is offline   Reply With Quote
Old 25th August 2014, 14:46   #2249  |  Link
JohnLai
Since I am not sure how many pages needed to be looked back, I just ask here.
Any justification on why the audio switcher must be active now?
Old 25th August 2014, 15:11   #2250  |  Link
detmek
Check 2 pages back, from page 111.
Old 25th August 2014, 15:30   #2251  |  Link
JohnLai
I kinda feel like an idiot for not reading few previous pages... ^.^;;
Well, after reading it, these should be something that I can live with.
Old 25th August 2014, 21:33   #2252  |  Link
arrgh
Internal Audio-Decoder forgets settings
hi
I'm using only the internal Decoders.
Most of the time I'm playing mkv files with aac Audio, which I let convert on the fly to ac3 and stream through spdif to my Receiver. DD and DTS streams, I also let funnel directly to spdif....
I have now observed that this settings are lost when I Play in between e.g. a "real" DVD...somehow MPC-BE forgets what I have selected in the settings of the internal Audio-Decoder...
arrgh is offline   Reply With Quote
Old 25th August 2014, 21:39   #2253  |  Link
arrgh
a different Topic:
Stereoscopic Player, which I have payed for, is now able also to display subtitles of interlaced 3D-mkv (like produced by MakeMKV)...I'm wondering of it would not be possible to use this Decoder to implement this function into MPC-BE for those who have payed for StereoscopicPlayer...
Old 26th August 2014, 02:55   #2254  |  Link
Aleksoid1978
Originally Posted by arrgh View Post
a different Topic:
Upload a sample of this "interlaced 3D-mkv" file with subtitles.
Old 26th August 2014, 22:15   #2255  |  Link
xiringu
Is it possible to add Gamma to Color controls?
Now there's Brightness, Contrast, Hue and Saturation.
Old 27th August 2014, 03:31   #2256  |  Link
v0lt
There are standard renderer capabilities. Gamma is not supported.
http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
v0lt is online now   Reply With Quote
Old 27th August 2014, 09:51   #2257  |  Link
xiringu
3 questions
1) I've seen that mpc-be can't remember the position where I paused some of my files. Is there a limitation on the number of files that remember this? Is it the same as the recent files?
2) Are there any plans on adding Color Controls to the OSD?
3) And any plans on being able to make and save shader (and color controls) presets?
Old 27th August 2014, 15:49   #2258  |  Link
v0lt
Yes. No.
No. (see View->Options...->Interface->OSD)
No.
Old 28th August 2014, 17:00   #2259  |  Link
xiringu
Now,if you change values on color controls (inside the menu) while the video is paused, nothing happens. You can't see the changes until you start playing again.
I've seen that you can change shaders while paused and see the results immediately. Is it possible to do the same with color controls?
Old 28th August 2014, 22:20   #2260  |  Link
arrgh
...you have a PM...
