Old 27th December 2012, 09:42   #441  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by wanezhiling View Post
No field order can be determined?
I do not look at file, but think you are right
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 27th December 2012, 18:59   #442  |  Link
VipZ
[pic removed]
Is the above correct?
I would assume the button None to only become visible once Modify is selected.
Windows 10 Pro x64 (1809), CPU: Core i7 6700K, GPU: GeForce GTX 980 /w 417.71, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 27th December 2012, 23:09   #443  |  Link
Aleksoid1978
Fixed - thanks.
Old 27th December 2012, 23:43   #444  |  Link
dlind87
Pixelshader don't seem to work anymore when using madVR.
Edit: redownloaded, works now
dlind87 is offline   Reply With Quote
Old 27th December 2012, 23:46   #445  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic - BE 1.1.3.0 Win32 (Stable release):
Media Player Classic - BE 1.1.3.0 x86 (with installer)
Media Player Classic - BE 1.1.3.0 x86 (portable)
Standalone Filters Media Player Classic - BE 1.1.3.0 x86
Media Player Classic - BE 1.1.3.0 x64 (Stable release):
Media Player Classic - BE 1.1.3.0 x64 (with installer)
Media Player Classic - BE 1.1.3.0. x64 (portable)
Standalone Filters Media Player Classic - BE 1.1.3.0 x64
Source Code:
Media Player Classic - BE 1.1.3.0 Source Code
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 28th December 2012, 01:11   #446  |  Link
Anleck
Thanks BE team.
Seeking is very responsive - smooth video.
Anleck is offline   Reply With Quote
Old 28th December 2012, 07:50   #447  |  Link
wanezhiling
Oh stable build released, has been forwarded to China.
Old 28th December 2012, 10:53   #448  |  Link
ZoNi
ZoNi's Avatar
Is there any way to see flybar with madVR?
ZoNi is offline   Reply With Quote
Old 28th December 2012, 14:45   #449  |  Link
wanezhiling
http://samples.mplayerhq.hu/sub/DivX+Subtitles.divx
BE can not show the divx subtitle.
Old 28th December 2012, 15:56   #450  |  Link
jos99
Thankyou for this Alexins, seems very stable with MPC filters/codecs or LAV. I am experimenting with logos using these masks, you can paste as a new layer on any image to use as MPC-BE logoscreen, use fill to change colours:
http://dl.dropbox.com/u/35202345/mpcbelogomask3a.png
http://dl.dropbox.com/u/35202345/mpcbelogomask3b.png
http://dl.dropbox.com/u/35202345/mpcbelogomask3c.png
http://dl.dropbox.com/u/35202345/mpcbelogomask3d.png
http://dl.dropbox.com/u/35202345/mpcbelogomask3e.png
http://dl.dropbox.com/u/35202345/mpcbelogomask3f.png
One problem though is that MPC-BE always seems to add a black border when opening
http://dl.dropbox.com/u/35202345/mpcbecap12a.PNG
this is how I want it to look with no borders (manually resized), so it wraps to the logo, whatever the dimensions, as MPC-HC does
http://dl.dropbox.com/u/35202345/mpcbecap12c.PNG
jos99 is offline   Reply With Quote
Old 28th December 2012, 19:00   #451  |  Link
wanezhiling
1.) Could BE add an option "restore default window size when playback is over or stopped" ? Because I checked auto-zoom 100%.
2.) http://pan.baidu.com/share/link?shar...&uk=3558042035
internal mpeg2 video decoder(software), DI failed, DXVA mode is fine.
3.) What's the difference, Fast seek(on keyframe) in Tweaks tab and Fast(inaccurate) seek in MPEG Splitter configuration?
4.) About DXVA compatibility check.
Did BE do a limit to a "L5.1 & Ref5" file on AMD/Intel cards? why? No limit on Nvidia
Old 28th December 2012, 19:03   #452  |  Link
VipZ
Thanks for the stable release and source.
Do you have any ETA for opening up SVN read access?
Old 28th December 2012, 20:42   #453  |  Link
alexins
MPC-BE DEV
alexins's Avatar
I will soon open access to our svn repository.
Old 28th December 2012, 22:01   #454  |  Link
olymind1
Possible bugs:
I'm using win7 with turned off automatic windows resizing, BE setting: View -> Presets... -> Normal (3), when i maximalized/stretched the window to full (not fullscreen), if i click on the screen (main media area while playing only) then drag it, it moves, it doesn't stick. If it is not a bug, then i would like to request an option to turn it off in all Presets seperately.
BE setting: View -> Presets... -> Compact (2), FlyBar's Maximize button doesn't consider Taskbar, it overlaps it completly, acts like it is fullscreen. If it is not a bug, then i would like to request an option to turn it off.
Feature/option request: Always start media with Maximized screen.
Basicly if i open a media, i would like to see my taskbar with a maxmized BE window, and without the worrying of accidental window moving. So once it is maximized, make it stay/stick to the frame of my monitor, preferably in Compact Preset.
Keep up the good work, i like BE over HC a lot. And thanks for developing it!
olymind1 is offline   Reply With Quote
Old 29th December 2012, 00:14   #455  |  Link
VipZ
Old 29th December 2012, 00:49   #456  |  Link
phoenix_fr
with 1.0.3.1.1239.x64 the cover of the folder containing my music files are displayed. this is not the case with the version 1.1.3.0.1737.x64
this is related to what option ?
phoenix_fr is offline   Reply With Quote
Old 29th December 2012, 00:55   #457  |  Link
Aleksoid1978
3) - Fast(inaccurate) seek - it's only for MPEG. MPEG files do not have keyframe.
4) - L5.1 & Ref5 use for ATI with Catalyst above 10.4. after this - ATI support high ref frames & level.
About Intel - i do not have device to test high level & ref frames support.
Old 29th December 2012, 00:56   #458  |  Link
Aleksoid1978
There is no options for this - cover file show automatically for music files, if present in folder/subfolder.
If you do not see image - show the contents of your folders with music and where files with Cover
Old 29th December 2012, 02:07   #459  |  Link
Anleck
phoenix_fr - Picture shows fine for me, as long as it is named folder.
Old 29th December 2012, 06:12   #460  |  Link
wanezhiling
http://samples.mplayerhq.hu/sub/small.divx
This file is ok.
I collected this type of files.
M HD4650 with Catalyst_12.6_Legacy, no limit on MPC-HC even I set "full check", DXVA works just fine on MPC-HC, but there is a limit on BE.
Ivb 2500/4000 work fine with a L5.1 & Ref16 file.
http://forum.doom9.org/showthread.ph...74#post1607874
BE and HC failed too.
