Old 15th January 2022, 23:48   #9041  |  Link
wushantao
Originally Posted by Klaus1189 View Post
At first I thought I leave the new "Adapter" since it can be used in german but I reconsidered.
Updated german translation
I have a Ryzen 9 5950x (so no iGPU) and a dedicated RTX 3090. Is it normal that the new line in options dialog "Adapter" is greyed out with this setup? If it is, do you think it would be a good idea to display the name of the one and only GPU in the greyed out box so the user has feedback what GPU is "selected", not much to select when there is only one available but you get the idea. Cosmetic
agree
wushantao is offline   Reply With Quote
Old 16th January 2022, 18:42   #9042  |  Link
v0lt
@wushantao, @Klaus1189
Thanks. Updated in r6795 and r6809.
Old 17th January 2022, 00:28   #9043  |  Link
s0meone_new
Hungarian translation updated:
https://www41.zippyshare.com/v/KLqp4zFL/file.html
Just a little fix.
s0meone_new is offline   Reply With Quote
Old 18th January 2022, 09:13   #9044  |  Link
Megalith
Is there any way to get MPC-BE to play an MKV with Dolby Vision? All of these play fine, but Dolby Vision isn't kicking in:
https://www.makemkv.com/download/dvtest/
Megalith is offline   Reply With Quote
Old 18th January 2022, 12:01   #9045  |  Link
cmhrky
Latest Turkish translation based on r6817.
cmhrky is offline   Reply With Quote
Old 18th January 2022, 12:14   #9046  |  Link
Aleksoid1978
Aleksoid1978's Avatar
No...
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 18th January 2022, 17:22   #9047  |  Link
alex1399
hi guys, might be the one-hundred-and-one question again. Why is the 1.6.0 installer download count less than the 1.5.8 installer one on the web sourceforge.net? I'm grabbing the 1.6.0.6767 one and enjoying it without a hiccup. Thanks.
alex1399 is offline   Reply With Quote
Old 18th January 2022, 17:34   #9048  |  Link
Because its not even a month old, and the older one is half a year old, hence had much more time to collect downloads?
Old 19th January 2022, 15:33   #9049  |  Link
v0lt
Thanks. I set up sourceforge.net and check for updates.
Old 19th January 2022, 15:48   #9050  |  Link
cmhrky
r6810 ?
Old 19th January 2022, 16:07   #9051  |  Link
v0lt
@cmhrky
Thanks. Updated in r6818.
Old 20th January 2022, 22:46   #9052  |  Link
s0meone_new
https://www27.zippyshare.com/v/zG8N9DrI/file.html
Just a little fix.
Old 22nd January 2022, 06:13   #9053  |  Link
v0lt
@s0meone_new
Thanks. Update in r6821.
Originally Posted by cmhrky View Post
I guess for the Recent Files menu, the ability to open with a hotkey is required.
Added in r6824.
Old 22nd January 2022, 07:38   #9054  |  Link
Klaus1189
Updated german translation based on r6824
Thank you for commit r6808
Old 22nd January 2022, 14:31   #9055  |  Link
wushantao
https://anonfiles.com/B8j2P7C4x0/mplayerc.sc.rc_7z
https://files.catbox.moe/hibn23.7z
Update Simplified Chinese:)
Old 23rd January 2022, 08:03   #9056  |  Link
s0meone_new
https://www76.zippyshare.com/v/qqLunFTV/file.html
Old 24th January 2022, 05:40   #9057  |  Link
v0lt
@Klaus1189, @wushantao, @s0meone_new
Thanks. Updated in r6825 and r6827.
Old 24th January 2022, 18:03   #9058  |  Link
alex1399
I'm using a nirsoft software SoundVolumeView to toggle the 'Allow applications to take exclusive control of this device' option for the specified device.
Is it possible to add one hotkey for Audio Exclusive Mode on/off in MPC-BE?
Changing the "DeviceMode" in [HKEY_CURRENT_USER\Software\MPC-BE\Filters\MPC Audio Renderer] via Windows Registry Editor needs administrator privilege. Any alternative suggestion? Thanks.
Old 24th January 2022, 20:44   #9059  |  Link
cmhrky
Latest Turkish translation with some fixes based on r6832.
Old 24th January 2022, 20:44   #9060  |  Link
Ravioli
MPC builds for the last two month or so, do not play AV1 encoded files, such as https://www.elecard.com/storage/vide..._22.7mbps.webm
MPC shows an error Like this if i have LAV Splitter enabled in external filters, or Like this if it is disabled.
Old build 1.6.0.6653 from last october plays them without a hitch Screenshot
Ravioli is offline   Reply With Quote
