#1241 | Link |
I see - LAV Audio Decoder set "incorrect" channel mask. It must 0x06f instead 0x3f for 5.1 output.
P.S. Update. Now work fine with LAV Audio - http://aleksoid.voserver.net/MPC-BE/...EXCLUSIVE_2.7z
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 19th June 2013 at 23:03. |
#1242 | Link | |
2 - what's wrong with .wmv playback ??
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#1243 | Link | |
I tested v2 and nothing's changed: ![]() If the input is limited to 16bit, it will play at 48KHz with both LAV and MPC, but anything higher and it drops to 44.1KHz. The output is always 16bit.
i7 2600K@4.7 watercooled and 2x EVGA GTX 760 in SLI with Corsair 16Gb 1600 (2 4x2 kit) on Asrock P67 Extreme4 Gen 3 with Intel 530 240Gb SSD running Win7 x64 on 3x ASUS VS239H-P 23" Last edited by SamKook; 19th June 2013 at 23:46. |
#1244 | Link | |
#1245 | Link |
The default format for shared mode in the advanced tab was the culprit, changing it will change the output bit and KHz. I was only changing it in the audio driver software.
But that seems like pretty odd behavior. Shouldn't the renderer use the highest settings supported by the hardware instead of using the default set in windows? And shouldn't exclusive mode ignore windows settings(especially when they specify it's for shared mode and is a default value, not a fixed one) and use the hardware directly or am I missing something here.
i7 2600K@4.7 watercooled and 2x EVGA GTX 760 in SLI with Corsair 16Gb 1600 (2 4x2 kit) on Asrock P67 Extreme4 Gen 3 with Intel 530 240Gb SSD running Win7 x64 on 3x ASUS VS239H-P 23" |
#1246 | Link |
Here 3 test build. Must work with 24bit/32bit output
http://aleksoid.voserver.net/MPC-BE/...EXCLUSIVE_3.7z P.S. Before test - check "Allow bit-exact output" in MPC Audio Renderer settings.
#1247 | Link |
v3 will use the closest supported settings from the input when "Allow bit-exact output" is checked which is very nice.
So I now get 24bit and 48KHz for 32bit 48KHz sources regardless of what setting is set for the default shared mode. A quick unrelated question: Is there a way to only launch the player in fullscreen when you open the player, like mpchc does instead of going to fullscreen every time a new file is opened? When I decide to exit fullscreen after loading something directly or if I launch the player without loading a video or audio file, I'd really like it to not switch to fullscreen automatically if I load a new video or audio file. mpchc behaves like that and I love it since if I'm not already in fullscreen after the player is launched the first time, I most likely want to stay in windowed mode.
#1248 | Link | |
#1249 | Link | |
I want the player to zoom to 100% for every video when not in fullscreen(I have that enabled) and switching from HD to SD video will move the player default position to the left which really annoys me(I wish it could remember the position from the right side instead of the left). So I'm not sure those will have the desired effect.
i7 2600K@4.7 watercooled and 2x EVGA GTX 760 in SLI with Corsair 16Gb 1600 (2 4x2 kit) on Asrock P67 Extreme4 Gen 3 with Intel 530 240Gb SSD running Win7 x64 on 3x ASUS VS239H-P 23" Last edited by SamKook; 20th June 2013 at 02:59. |
#1250 | Link |
It still goes to fullscreen with those 2 options enabled.
To make sure you understand what I mean, here's the 2 way I use the player 99% of the time. 1- Double-click on a video or use XBMC to launch mpcbe, the video goes into fullscreen, I watch it and the player exit automatically. Then I start the process again to watch another video. This is my main use of it and it works as intended in both mpc be and mpc hc. 2- a) Open the player directly without loading anything so it opens in windowed mode(so far both mpc be and mpc hc act the same). b) Then open a video so I can watch it and do some other stuff on my computer at the same time. This is the step where mpc be and mpc hc differ. Mpc hc won't go to fullscreen and this is exactly what I want since I'll continue to work on other things. Mpc be on the other hand will always switch to fullscreen every time you open a video, regardless of the current state the player is in so I have to switch out of fullscreen for every video I watch. c) Open another video without closing the player. Here mpc be will once again switch to fullscreen which will force me to switch back to windowed mode manually while mpc hc will stay in windowed mode. So what I want is for it to only switch to fullscreen when the player gets started unless no video is loaded and for it to stay in windowed mode once it's started, even if I open a new video.
#1251 | Link | |
I use MPC-BE in the same way as you in XBMC Code:
<playercorefactory> <players> <player name="MPC-BE" type="ExternalPlayer" audio="true" video="true"> <filename>C:\Program Files (x86)\MPC-BE\mpc-be.exe</filename> <args>"{1}" /fullscreen /close</args> <hidexbmc>true</hidexbmc> <hideconsole>false</hideconsole> <warpcursor>none</warpcursor> </player> </players> </playercorefactory> So you should try reset your settings (at least disable "Lunch files in full screen" option if selected) and see what happens
Windows 10 19042.508 x64, HD7790 Adrenalin 2020 Edition 20.9.1, HDMI Full RGB 4:4:4 Last edited by Mercury_22; 20th June 2013 at 05:21. |
#1252 | Link |
Not .wmv, it's .wma files that still have the problem. The issue is, any wma file with sampling rate greater than 48kHz, is displayed in my AVR as 48kHz. and 2 Channel files with sampling rate greater than 48kHz are displayed as Multichannel PCM 5.1 in my AVR.
It is the same issue that was present with .wav files, which you fixed that in the previous wasapi fix for bit-exact playback. So now, .wma files remain to be fixed. |
#1253 | Link | |
set the checkbox as shown in screen: ![]()
#1255 | Link |
Both 0x60f and 0x3f are correct for 5.1, it just depends which standard you read. The opinions on this have changed back and forth over the years.
#1256 | Link |
For WASAPI output mode 5.1 need set 0x60f channel mask. if set 0x3f - device initialization failed.
#1257 | Link | |
http://msdn.microsoft.com/en-us/windows/hardware/gg463023
According to the Microsoft doc linked to above, XP and Windows 2003 might need 0x3f, if the latest Service Packs are not installed yet. Maybe you should first try to use 0x60f for WASAPI and if that fails, as plan B try 0x3f, too? |
#1258 | Link |
MPC-BE DEV
MPC-BE v1.2.1.0 -dev build 2961 (Nightly Builds) (sourceforge)
MPC-BE v1.2.1.0 -dev build 2961 (Nightly Builds) (Dev. MPC-BE)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
#1259 | Link |
I remade - generating channels layout depending on the number of channels. For 5.1 - 0x60f
#1260 | Link | |
