Old 14th May 2021, 13:15   #641  |  Link
hubblec4
Matroska find' ich toll
Originally Posted by darksen View Post
Hey, yes, I use the dark theme in Windows and in all the apps I can. I think that these two parts (and in reality all the white parts) should be darker:
https://i.imgur.com/FPadhU2.png
Wow, so different in different OS's. Like I said all this section are grey here.
I don't know if I can fix this easily. It seems to me I have to add ever a Panel first, which can change the color independent from the OS.
But this would be make a lot of work. I have also started to read about Dark-mode in the Lazarus apps.
I will try to do something but I can't promise it.
EDIT: Also, could you please expand a little on this:
When a box is in grey? I'm asking because there are two states when I check the box, the first is that it's checked with a square and the other is a check but in none of them the box is in grey.
Thank you.
A checkbox has normally 2 states: checked and unchecked. But there is a third state, called gray-state.
The gray-state is like undetermined -> not checked and not unchecked.
The word "gray" has nothing to do with the color of the checkbox.
On my Win7 looks the gray-state of the checkbox indeed grey. On Linux it is also a bit grey, but looks totally different to Windows 7 and also Windows 10.
That is/was also the reason why I have insert my own checkbox icons at some places, to simulate a checkbox which looks ever the same on the OS's.
chapterEditor || Matroska-Playback || hSplit || DiscShare
Old 19th May 2021, 11:38   #642  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by hubblec4 View Post
Yes. The OGM specs says the chapter number starts with 0.
I did not know, thank you!
Another question: is it possible to join 2 chapter files? Zack Snyder's Justice league comes as 2 BDs but I want to join the encode in a single file. No problem for video and audio but how can I join the 2 separate chapter files?
@turment on Telegram
Old 19th May 2021, 11:59   #643  |  Link
hubblec4
Hi tormento
You can load the first chapter file and append the second one. Then select the first chapter of the second chapter file and adjust the timestamps with the Time-Edit-Tool.
Choose for the Action Range "All chapters from the selected ...." and as time shift set the play duration of the first video.
Old 19th May 2021, 12:19   #644  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks, will try!
Old 28th May 2021, 10:12   #645  |  Link
hubblec4
@darksen
I have tested the Dark-Mode in my Win7, and cE is using the dark colors from the OS.
It seems it should work when you change colors in the OS for your Theme.
But I have no idea how and where this settings are in the OS.
Old 4th June 2021, 13:22   #646  |  Link
hubblec4
update rev 1.29
chapterEditor(cE) rev1.29 is available.
Windows
Linux
An important bug fix for parsing Matroska files and Matroska chapter XML files.
Change chapterEditor
added    &
fixed    *
improved #
changed  %
rev1.29 2021-06-04
// chapterEditor
* Matroska Parser + Matroska Chapter-XML Parser
  The default value for the "ChapLanguage Element" is now "eng" and no longer "und"
// Time adjustments
& Frames as input (move and cut)
  - add an "f" to the end of the frame number
  - the source FPS from the FPS section is used
  - Source and Target FPS should be the same (but do not have to be)
  - the FPS must be set before entering the frame number,
    otherwise the entries in the edit fields must be renewed
// DVD2mkv
& added opening/editing of external subtitles
Old 16th July 2021, 12:39   #647  |  Link
an3k
an3k's Avatar
chapterEditor]chapterEditor(cE) rev1.29 is available.
Thank you so much for your tool. I have some MPLS that combine multiple episodes (individual m2ts files) and I wanted chapters for these individual episodes but needed something that allows me to remove preceding and following chapter entries but with automatic timecode adjusting.
I may only need it for this one project but do you have a donation thing?
an3k is offline   Reply With Quote
Old 16th July 2021, 19:16   #648  |  Link
hubblec4
Hi an3k
Originally Posted by an3k View Post
...something that allows me to remove preceding and following chapter entries but with automatic timecode adjusting.
Such a feature exists, called "Split Chapters".
In the GUI you will find it in the Feature-Bar or you can use the CLI of cE.
https://forum.doom9.org/showthread.p...12#post1902412
...do you have a donation thing?
No, not at the moment.
Old 20th December 2021, 01:51   #649  |  Link
darksen
Hey, I'm trying to upload a chapter file and I'm getting this error:
The following error occurred:
TMySQL56Connection : Error executing query: Field 'm_langietf' doesn't have a default value
darksen is offline   Reply With Quote
Old 20th December 2021, 15:04   #650  |  Link
hubblec4
mmh that's bad.
I'm currently change all to the IETF language and this takes a lot of time because it is a lot of work.
I will set a default value for this field, so that the current cE versions work again.
Old 20th December 2021, 17:58   #651  |  Link
hubblec4
Hi darksen
Can you try to upload chapters, and tell if everything works?
Old 21st December 2021, 02:46   #652  |  Link
darksen
Hey, thank you! It now works well like usual.
Old 21st December 2021, 11:56   #653  |  Link
hubblec4
Wonderful. Thanks for your feedback.
Old 3rd January 2022, 23:39   #654  |  Link
hubblec4
update rev1.30
chapterEditor(cE) rev1.30 is available.
Windows
Linux
After a while there is an update again.
BCP 47 IETF language-tags are now available after the new Matroska Standard
and replace the old language and country codes.
The processing of the language-tags works similarly to MKVToolNix(MTX).
So you have to get used to no new input mask.
However, I did not want to open this extra form to set a language.
The goal was to maintain the "old input" for the languages.
For this you can predefine in the settings("often used") IETF language favorites,
which are then available in the selection lists and can thus be used directly.
New language-tags can be added individually at any time to the selection lists.
The input mask:
There are a few differences to the input mask of MTX.
My Laz_BCP47 Package supports the complete IANA code list for all subtags.
So there is also the "Grandfathered" option
and for the Extensions there is a selection list of the possible ones (there are only two) permissible values.
MTX supports about 8000 languages but in the IANA code list there are 8213 (cE supports all).
Therefore, it can happen that MTX does not recognize a language code from cE.
added    &
fixed    *
improved #
changed  %
rev1.30 2022-01-03
// chapterEditor
& BCP 47 IETF language-tags
  - own Lazarus Package -> Laz_BCP47 (https://gitlab.com/hubblec4/laz_bcp47)
& IETF language favorites (settings)
  - Predefined BCP 47 language-tags for the selection lists
// Matroska Chapters
% "Disable the multi-language and country system" removed
% Country selection for chapter names removed
// Chapternaming
& Chapter names from Favorites: Language-tag parsing for BCP 47 IETF
  - The obsolete language and country codes continue to work
% Matroska: Country selection removed
// Tab management
% "Compare tabs": Countries for Matroska tabs removed
  - New comparison code for Matroska tabs <0,0,0,0>
// Chapter database
% Old languages: Data column removed
  - older cE versions no longer compatible
Old 31st January 2022, 09:27   #655  |  Link
Lirk
Hi. Is there way to select certain chapters in DVD2MKV, export them in MKV and to select all titles/chapters at once? Also, if open .IFO file through "Chapter Editors" tab, then DVD angles does not appears, even if uncheck all "Hide IFO-Title" filters, unlike DVD2MKV tab.
Lirk is offline   Reply With Quote
Old 31st January 2022, 13:48   #656  |  Link
hubblec4
Hi and welcome to cE.
Export chapters from the DVD2MKV editor is not possible. The chapters will be created automatically for each title and can be loaded into the chapter-editor.
Yes that's true, the Angles of a title there not present because the chapters are always identical for Angle-Titles.
Old 11th February 2022, 21:45   #657  |  Link
Masutin
How do I choose a file to use Upload chapters? It looks like I have an account.
Masutin is offline   Reply With Quote
Old 12th February 2022, 12:57   #658  |  Link
hubblec4
Load your chapter file to the chapter editor tab(Matroska). Then you can upload it.
Old 14th February 2022, 17:24   #659  |  Link
Masutin
Alles klar! I got an error as I opened in the OGG section.
Old 9th March 2022, 01:47   #660  |  Link
hubblec4
update rev1.31
chapterEditor(cE) rev1.31 is available.
Windows
Linux
In this update there are a few improvements and new features for mass paste of chapters.
added    &
fixed    *
improved #
changed  %
rev1.31 2022-03-09
// Text-Favorites (chapter names)
# multiple IETF Language-Tags for a chapter name (comma separated)
   - Example: Chapter||de,en,de-CH or Chapter||ger,eng,de-CH
   - support for the old language-country-code formatting removed
& use predefined IETF languages of chapter names from the Text-Favorites
// Multi Chapters
& delete existing chapters
& All tabs
* two values were not loaded from the INI file
// Chapter naming
& all values are now stored in the INI file
// Disc2mkv
* Disc Title Profiles now use IETF language tags
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
