Old 6th October 2014, 23:50   #21461  |  Link
Sharc
BD-RB doesn't use the audio decoders of LAVFilters except for previewing. It uses nicaudio via AVISYNTH.
That brings up a possibility. Remove LAVFilters, and then reinstall. But when it comes up, uncheck the "LAV Audio" from the components list. Maybe it is hosing up the PCM audio-serving when nicaudio is decoding AC3 or DTS and presenting it to the encoder.
I found that ArcSoft filters interfere with LAV audio. After removing ArcSoft filters, the preview works fine.
Old 7th October 2014, 00:12   #21462  |  Link
gonca
Do you mean the ones in the codec folder?
Old 7th October 2014, 00:22   #21463  |  Link
gonca
@Ch3vr0n
To clarify, if your intention is to re-encode Transformers Age Of Extinction and keep the HD Audio BD_RB can handle it, I've done it.
If you wish to re-encode the audio, BD_RB can also do it
Old 7th October 2014, 00:24   #21464  |  Link
Ch3vr0n
Intention is the same as always. Full disc backup to bd25, intact audio. So good to know it can handle it.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 7th October 2014, 00:29   #21465  |  Link
gonca
Sorry, didn't know your back up habits, seems they are are the same as mine. Bear in mind that the movie is 2:45 long and the HD audio track alone is about 5.5 GB. The down conversion was for a tablet, no point keeping the HD audio for that
Old 7th October 2014, 01:24   #21466  |  Link
gonca
test 1
frame serving >> LAV >> out of sync
test 2 (Sharc's findings)
go to codec folder
create a new sub folder called New Folder
move the two filters Sharc mentioned into it
test 3
Make sure that Bit stream DTS HD is unchecked in LAV Audio settings since that brings up the filters mention by Sharc
out of sync
Old 7th October 2014, 03:07   #21467  |  Link
gonca
Tried changing every setting in LAVSplitter and LAVAudio that I thought might affect sync. No luck.
Right about now I'm happy I use DGDecNV.
Old 7th October 2014, 03:15   #21468  |  Link
gonca
@jdobbs
which decoder have you selected in LAV Video?
Old 7th October 2014, 04:41   #21469  |  Link
MajorEvent
Passed Newbie Inquisition
MajorEvent's Avatar
It seems that ArcSoft filters interfere with LAV filters.
Removing (disabling) dtsdecoderdll.dll and ASAudioHD.ax (both from ArcSoft) solved my preview problems.
Maybe it will solve your out-of-sync issues as well.
Renamed, rebooted, re-encoded. No change. Confirming gonca's result.
MajorEvent is offline   Reply With Quote
Old 7th October 2014, 06:14   #21470  |  Link
omegaman7
omegaman7's Avatar
Tried the newest version 0.63 LAV. No luck. Still out of sync.
@ all others testing LAV. How many source BD's have you tried? I've only tried one. I shall try another, that has significantly different audio streams.
Old 7th October 2014, 07:16   #21471  |  Link
Sharc
I don't have a "codec" folder (?). But these filters got installed/copied into the \WINDOWS\sysWOW64\ folder in my case. They are probably a leftover of some trial SW and didn't get uninstalled. Deleting these filters solved my issue, and I can reproduce the effect. The culprit seems to be the "dtsdecoderdll.dll".
For indexing I am always using DGIndexNV. Never tried anything else. Moreover, even on BD25 I usually convert the dts(-HD) to ac3 and don't keep the original dts.
Old 7th October 2014, 09:59   #21472  |  Link
gonca
@all
Those having issues with Lav and video/audio sync
Do you have TMT6 installed?
Do you have PDVD installed?
Old 7th October 2014, 10:21   #21473  |  Link
gonca
@Sharc
TMT has a subfolder called codecs
Old 7th October 2014, 12:06   #21474  |  Link
worknstiff
@ Ch3vr0n RE: Full disc backup to bd25, intact audio.
The Transformers: Age of Extinction 3D/2D both have Dolby Atmos audio and by keeping only the English tracks you will end up with 3 .AC3 tracks. The first one (which I think is the 7.1 mix) is 5.79 GB's and the other 2 are both 755 MB's (which I think has the extra Atmos directional data). You will end up with a total of 7.27 GB's which only leaves you with about 15.5 GB for the 2:45 minutes of video. I am really thinking of using up one of my BD25 DL's for this one because I can't see how to keep only the 7.1 track.
Old 7th October 2014, 12:17   #21475  |  Link
Mark_Venture
After trying to make an mkv container using x264 I have got the following message from BD-RB right after extracting the streams. Please find my log file, alternate and lastcmd test file below. The used profile is [00037].
I didn't see a reply to your post, but I had similar issue, and same failure message when trying to backup to Alt Movie Only MKV (1920x1080 intact audio) with The Monuments Men and both the 2D and 3D of Transformers: Age of Extinction (to Half SBS MKV). Yet I found that King Kong worked just fine.
I thought it might be because I update BD-Rebuilder on my PC by unzipping to the existing folder, overwriting any files. So I made a new folder and unzipped only 49.04. Nope. Still failed.
Looking closer, if it was reported that Source Video: MPEG-4 (AVC), I got that error. King Kong and others that worked were Source Video: VC-1. So I checked FFDShows settings per the notes in the OP. They were set right, but it still failed.
I ended up uninstalling FFDShow, Haali Matroska Splitter, AVISYNTH, and LAV Directshow Filters.
After rebooting, I installed them again, following the OP of this thread, and its working again. 2D Age of Extinction finished last night, and the 3D Age of Extinction (to half SBS mkv) is still running.
Not sure what messed things up on my system, but at least its working again.
Old 7th October 2014, 15:14   #21476  |  Link
omegaman7
omegaman7's Avatar
No TMT installed here yet. I wanted a very clean installation to work with
Old 7th October 2014, 15:18   #21477  |  Link
MajorEvent
MajorEvent's Avatar
@all
I have both, TMT 6 and PDVD 11.
Old 7th October 2014, 15:33   #21478  |  Link
I've removed LAV instructions from the first post. They will also be removed from the README.TXT of the next release. Too bad... it was a much more complete solution than FFDSHOW/HAALI.
Old 7th October 2014, 15:42   #21479  |  Link
omegaman7
omegaman7's Avatar
Jdobbs, I ran "The Postman" last night, and the audio is in complete sync :S
Old 7th October 2014, 15:52   #21480  |  Link
That was with LAV? How did it differ from other ones you've tried?
