Old 6th October 2023, 15:16   #161  |  Link
ReinerSchweinlin
Sorry, I canīt help, thats beyond my capabilities
But I just wanted to say "thanks" for all you do !!
Old 20th October 2023, 21:08   #162  |  Link
Selur
Selur's Avatar
btw. did anyone test NNVISR ? (https://github.com/tongyuantongyu/vs-NNVISR)
Old 21st October 2023, 02:50   #163  |  Link
lansing
I couldn't get it working on vsedit2 or vd2 or vsedit_mod. I manual install the plugin and its dependencies. Somehow the plugin won't auto load when I put it in my roaming folder, so I'll have to put everything in Vapoursynth's installation plugin folder. But everything just crashed after some loading time.
import vapoursynth as vs
core = vs.core
clip = core.bs.VideoSource(r'E:\video samples\hand wave.mkv')
model_config = {'scale_factor': 2, 'input_count': 2, 'feature_count': 64, 'extraction_layers': 4, 'interpolation': True, 'extra_frame': True, 'double_frame': True, 'model': 'cycmunet/vimeo90k-deblur'}
clip = core.nnvisr.Super(clip,
                         model_path=r"C:\Program Files\VapourSynth\plugins",  **model_config)
clip.set_output()
Old 21st October 2023, 06:33   #164  |  Link
Selur
Selur's Avatar
When I first tested this, I used this file structure
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cublas64_12.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cublasLt64_12.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudart64_12.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_adv_infer64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_adv_train64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_cnn_infer64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_cnn_train64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_ops_infer64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\cudnn_ops_train64_8.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvblas64_12.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_builder_resource.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_dispatch.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_lean.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_plugin.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvinfer_vc_plugin.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvonnxparser.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvrtc-builtins64_121.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\nvrtc64_120_0.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\test_1.vpy
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\timing.cache
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\vs-nnvisr.dll
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\cycmunet
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\cycmunet
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\timing.cache
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\cycmunet\vimeo90k-deblur
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\cycmunet\vimeo90k-deblur\yuv_1_1_1
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\cycmunet\vimeo90k-deblur\yuv_1_1_1\fe_640x352_2x2_b1_l4_yuv1-1.engine
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\8601\NVIDIA GeForce RTX 4080\cycmunet\vimeo90k-deblur\yuv_1_1_1\ff_n2a+_640x352_2x2_b1_l4_yuv1-1.engine
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\cycmunet\vimeo90k-deblur
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\cycmunet\vimeo90k-deblur\yuv_1_1_1
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\cycmunet\vimeo90k-deblur\yuv_1_1_1\fe_640x352_2x2_b1_l4_yuv1-1.engine
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\engines\cycmunet\vimeo90k-deblur\yuv_1_1_1\ff_n2a+_640x352_2x2_b1_l4_yuv1-1.engine
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\cycmunet
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\yogo
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\cycmunet\vimeo90k-deblur
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\cycmunet\vimeo90k-deblur\yuv_1_1_1
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\cycmunet\vimeo90k-deblur\yuv_1_1_1\fe_n2_2x2_l4_yuv1-1.onnx
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\cycmunet\vimeo90k-deblur\yuv_1_1_1\ff_n2_2x2_l4_yuv1-1.onnx
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\yogo\vimeo90k
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\yogo\vimeo90k\rgb_1_1
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\yogo\vimeo90k\rgb_1_1\fe_n4_4x4_l1.onnx
F:\Hybrid\64bit\vsfilters\ResizeFilter\NNVISR\models\yogo\vimeo90k\rgb_1_1\ff_n4_4x4_l1.onnx
and the following script:
# Imports
# getting Vapoursynth core
core = vs.core
import site
import os
import ctypes
# Adding torch dependencies to PATH
path = site.getsitepackages()[0]+'/../vsfilters/ResizeFilter/NNVISR'
ctypes.windll.kernel32.SetDllDirectoryW(path)
path = path.replace('\\', '/')
os.environ["PATH"] = path + os.pathsep + os.environ["PATH"]
# Loading Plugins
core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/vslsmashsource.dll")
core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR/vs-nnvisr.dll")
# source: 'G:\TestClips&Co\files\test.avi'
# current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive
# Loading G:\TestClips&Co\files\test.avi using LWLibavSource
clip = core.lsmas.LWLibavSource(source="G:/TestClips&Co/files/test.avi", format="YUV420P8", stream_index=0, cache=0, prefer_hw=0)
# Setting detected color matrix (470bg).
clip = core.std.SetFrameProps(clip, _Matrix=5)
# Setting color transfer info (470bg), when it is not set
clip = clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip, _Transfer=5)
# Setting color primaries info (), when it is not set
clip = clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip, _Primaries=5)
# Setting color range to TV (limited) range.
clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1)
# making sure frame rate is set to 25
clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1)
clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=0) # progressive
clip = core.resize.Bicubic(clip=clip, matrix_in_s="470bg", matrix_s="709", range_in=0, range=0) # converting to bt709 for NNVISR
clip = core.std.SetFrameProps(clip, _Transfer=1)
clip = core.std.SetFrameProps(clip, _Primaries=1)
clip = core.nnvisr.Super(clip, model_path="F:/Hybrid/64bit/vsfilters/ResizeFilter/NNVISR", **model_config)
# Output
clip.set_output()
in a portable Vapoursynth setup. But I had my struggles too (https://github.com/tongyuantongyu/vs-NNVISR/issues/2).
Maybe this helps you getting it working.
Cu Selur
Ps.: iirc. it took ages to get engine files created on my setup when I tested it.
Old 26th November 2023, 10:01   #165  |  Link
julius666
julius666's Avatar
Does anyone know what happened to vs-femasr? The github repository is not available anymore.
julius666 is offline   Reply With Quote
Old 26th November 2023, 11:00   #166  |  Link
kedautinh12
HolyWu was deleted it (maybe)
Old 26th November 2023, 14:06   #167  |  Link
Selur
Selur's Avatar
Yup, like a few other repos HolyWu deleted it. (or set it private)
Old 1st December 2023, 17:52   #168  |  Link
julius666
julius666's Avatar
I thought so but do we have any information regarding why he did that? It was one of the best (if not THE best) upscalers in vapoursynth.
Old 1st December 2023, 18:25   #169  |  Link
Selur
Selur's Avatar
No (at least not that I know of), you would have to ask him (maybe by posting an issue in one of this other projects https://github.com/HolyWu/).
Probably because there hasn't been an update to it, not much feedback and keeping it working with latest pytorch&co was too much trouble.
Old 2nd December 2023, 15:55   #170  |  Link
Selur
Selur's Avatar
btw. for those who need colorization of b&w content https://github.com/HolyWu/vs-ddcolor might be worth a try:
did some small tests which do seem good so far.
Cu Selur
Old 2nd December 2023, 17:51   #171  |  Link
kedautinh12
Wow, respect HolyWu
Old 2nd December 2023, 19:54   #172  |  Link
Selur
Selur's Avatar
https://github.com/piddnad/DDColor should get the main respect, HolyWu 'just' wrote a Vapoursynth Wrapper for it.
Old 3rd December 2023, 01:57   #173  |  Link
kedautinh12
Ok, piddnad too
Old 17th January 2024, 20:43   #174  |  Link
Selur
Selur's Avatar
Anyone has an idea how to stabilize the colorization output of ddcolor? (see: https://forum.selur.net/thread-3532.html)
