8th April 2022, 21:36 | #101 | Link | ||
And all actual encoders than I know read wav input ChannelMask and create the equivalent internal channel order if is available (if not show a error). If wav input have a simple header (without ChannelMask) assign a default channel map for each number of channels. For instance for qaac encoder: In addition to mono/stereo, following channel layouts are supported for AAC and ALAC with slight variations. When channel layout is unknown, one of the layouts indicated by asterisk is assumed as default. Code:
# chn input layout output layout codec ----------- --- --------------------------------- ----------------------- ------------ 3ch* 3 FL FR FC C L R LC, ALAC 4ch 4 FL FR FC BC C L R Cs LC, ALAC 4ch * 4 FL FR BL BR (SL SR) L R Ls Rs LC, HE 5ch * 5 FL FR FC BL BR (SL SR) C L R Ls Rs LC, ALAC 5.1ch * 6 FL FR FC LF BL BR (SL SR) C L R Ls Rs LFE LC, HE, ALAC 6ch 6 FL FR FC BL BR BC (SL SR) C L R Ls Rs Cs LC 6.1ch * 7 FL FR FC LF BL BR BC (SL SR) C L R Ls Rs Cs LFE LC, ALAC 7ch 7 FL FR FC BL BR SL SR C L R Ls Rs Rls Rrs LC 7.1ch front 8 FL FR FC LF BL BR FLC FRC (SL SR) C Lc Rc L R Ls Rs LFE LC, HE, ALAC 7.1ch rear* 8 FL FR FC LF BL BR SL SR C L R Ls Rs Rls Rrs LFE LC, HE 8ch 8 FL FR FC BL BR BC SL SR C L R Ls Rs Rls Rrs Cs LC Rls Rrs is here MediaInfo Lb Rb (or wav BL BR or EAC3 Lrs Rrs) Like you see the order and name aren't the same but the encoder do the job atomatically.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 8th April 2022 at 21:56. |
11th April 2022, 14:52 | #102 | Link |
I make a test also with TotalCode Studio.
We can configure it like with Audition with some differences: 1) For big files like movie tracks we need rf64 input files (without support for .w64). And need remap or use the internal remap showed in the image. We can use eac3to: eac3to 8v341.dtshd 8v341_R.rf64 -0,1,2,3,6,7,4,5 2) The max bitrate is also 1024 Kb/s but there are different channel layouts (see the images). Without the (L R C LFE Ls Rs Vhl Vhr) than work fine with my audio system 3D 5.2.1. 3) Is fast than Audition. In my previous old PC (Intel i5-3550 3.30GHz, DDR3 2+2 GB PC3-10700 (667 MHz), SATA ST2000DL003-9VT166 2TB) a source file (Jurasic Park 2h 6m 37s) converted previously to rf64 take 10m 36s to be converted to .ec3. Audition take 4m to load the .w64 and after 14m to convert it to ec3.
12th April 2022, 14:59 | #103 | Link | |
Acid fr0g
Would you please try to use it and tell me if I need channel remapping? I currently have 2.0 HT here, so I encode to DD+ for archive purpose only and can't directly test.
@turment on Telegram |
12th April 2022, 15:34 | #104 | Link | |||
-filter_complex "pan=7.1|c0=c0|c1=c1|c2=c2|c3=c3|c4=c6|c5=c7|c6=c4|c7=c5"
12th April 2022, 20:47 | #106 | Link |
I tried with a small file and just output a wav with RIFF header.
Seems need to be a big file (>4 GB) to create a RF64 header. No problem, if TotalCode Studio accept .wav with RF64 header, instead the .rf64 extension.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 12th April 2022 at 20:51. |
12th April 2022, 21:00 | #107 | Link | |
Acid fr0g
Unfortunately EAC3TO development is frozen, that is why I suggest to use ffmpeg, at least for the decoding part. The command line that you gave me was for ffmpeg or EAC3TO? And for TotalCode or Audition?
13th April 2022, 10:39 | #108 | Link |
With ffmpeg:
ffmpeg.exe -i whatever.thd -filter_complex "pan=7.1|c0=c0|c1=c1|c2=c2|c3=c3|c4=c6|c5=c7|c6=c4|c7=c5" -rf64 auto -acodec pcm_s24le whatever.wav Needed for both, TotalCode or Audition, when the source is a standard 7.1 and the output is remapped to FL FR FC LFE SL SR BL BR in the order to obtain the EAC3 L R C LFE Ls Rs Lrs Rrs With TotalCode you can do the remap inside the dialog 'Channels' window.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 13th April 2022 at 11:17. Reason: Add -acodec pcm_s24le, see next post |
13th April 2022, 11:16 | #109 | Link | ||
WARNING:
By default the ffmpeg output is downsize to 16 bitdepth, no mather the source bitdepth: Quote:
With ffmpeg you must know the source bitdepth or add always -acodec pcm_s24le. Now: Quote:
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 13th April 2022 at 13:26. |
13th April 2022, 13:11 | #110 | Link |
How I do the job (see the image):
1) Load the input file in UsEac3to, and let use the eac3to bitdepth detection 2-4) Select (or write yourself) the desired parameters for ffmpeg 5-6) Click 'A/V Recode' and Replace the decoder by the ffmpeg parameters 7) Select output file 'WAV' UsEac3to select like encoder "-acodec pcm_s16le" for 16 bit DTSMA or "-acodec pcm_s24le" for 24 bit DTSMA or THD by default. Many THD are marked as 24 even when are only 16 (detected by eac3to) but if after is recoded to eac3 it is not a problem. The command line generated is like (without paths to input and output folders): ffmpeg -i "INPUT" -filter_complex "pan=7.1|c0=c0|c1=c1|c2=c2|c3=c3|c4=c6|c5=c7|c6=c4|c7=c5" -rf64 auto -acodec pcm_s24le "INPUT_.wav"
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 13th April 2022 at 13:21. |
13th April 2022, 15:14 | #111 | Link | |
Acid fr0g
Do we need the same remap for 7.1 DTS, 5.1 THD and 5.1 DTS?
13th April 2022, 15:22 | #112 | Link |
Is a encoder fault than ignore the channelmap stored in the wav header, writed correctly by ffmpeg.
AAC, FLAC and OPUS encoders don't need remap at all. 5.1 don't need remap, 7.1 standard always with these encoders. The 5.1.2 in Audition don't need remap.
15th April 2022, 14:07 | #113 | Link | |
Acid fr0g
Please explain me how to check if a encoder loses channel configuration and how to understand the proper channel "wiring" to be done.
15th April 2022, 18:54 | #114 | Link | |
Acid fr0g
Let us say I want to lower bitrate from 896 to 640. Would it use 24 or 16 bits? Does it need channel remap when 7.1 or is it in the right order as wav from eac3?
16th April 2022, 09:58 | #115 | Link | |||
Lossy encodes don't have bitdepth. Decoders work internally in float format, eac3to can output until 64 bits float, but it is enough 24 bits int (human ear can difference only to 20 bits). Quote:
If you don't have a 7.1 system to listen you always can "see" the order, the first image is the correct the second is a wrong order:
16th April 2022, 20:03 | #117 | Link |
Audo editors only work with uncompressed audio.
Decode anything to wav/w64 before edit. I work with Goldwave from longtime ago, but you can use Audacity also.
30th May 2022, 17:38 | #120 | Link |
Acid fr0g
I have found a (I think) strange 6.1 (7?) audio DTS from Ghost in the shell 2.0 BD.
mediainfo: Code:
Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS ES XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 23 min Bit rate mode : Variable / Constant / Constant Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s Channel(s) : 7 channels / 7 channels / 6 channels Channel layout : C L R Ls Rs LFE Cb / C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless / Lossy / Lossy Language : Italian Source : 00009.m2ts Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : DTS ES XXCH XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 1 h 23 min Bit rate mode : Variable / Constant / Constant Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s Channel(s) : 7 channels / 7 channels / 6 channels Channel layout : C L R Ls Rs LFE Cb / C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy / Lossy Language : Japanese Source : 00009.m2ts Code:
DTS Master Audio, 5.1 channels, 24 bits, 48kHz (core: DTS-ES, 5.1 channels, 1509kbps, 48kHz) DTS Master Audio, 6.1 channels, 16 bits, 48kHz (core: DTS-ES, 6.1 channels, 1509kbps, 48kHz)
@turment on Telegram Last edited by tormento; 30th May 2022 at 17:42. |
eac3 |
