2nd November 2011, 19:42 | #13481 | Link | |
Programmer
What are the options to avoid that? That is, is there a way to just copy some files from the original source to get it working? For me, I tried the stream and its clipinf file, but not sure if I am missing something else. |
2nd November 2011, 19:45 | #13482 | Link | |
I'm a little disappointed. My hope would be that the folks who decided to test it would "help out" by reporting their experiences -- but have a little patience, as this isn't an easy task in blu-ray. You typically can't just "copy files" because there can be interconnections between CLPI/M2TS sets via MPLS references. All three have to be updated accordingly. Last edited by jdobbs; 2nd November 2011 at 19:53. |
2nd November 2011, 20:02 | #13483 | Link | |
I do understand the complexities of a BD structure and i know how hard it must be to navigate, and you are doing a cracker job with no complaints from me. Last edited by MILLZY; 2nd November 2011 at 20:20. |
2nd November 2011, 20:20 | #13484 | Link | |
Programmer
In fact I wanted to dig deeper to see if I could assist more but I lack understanding of how bluray handles first play and menus. I do know this feature is not ready for prime time and if a file copy workaround is available I have no problem doing that when issues occur until its resolved. But it looks like this is alot more complex then I thought so that would not be an option. I would like to dig into the internals more to see how its all interconnected, but it seems BDInfo is not a tool that would be able to aid in this. Are there other tools I can look at for exploring a bluray discs structure and organization? If there is anymore info I can provide to aid in diagnosing the issue then please let me know. I am one of those who also donates multiple times, so I don't take your work for granted and I think while the blanking and movies and menu is not ready for primetime, its working pretty darn good already. |
2nd November 2011, 22:10 | #13486 | Link |
I think you need a holiday mate or a good old old fashioned drinking bender to clear your head and chill for a while.
I think you need a break from all this, its not going to be the end of the world if you take a break for a while.... Not trying to be full of it by the way. Just a little bit of concern thats all..... Last edited by MILLZY; 4th November 2011 at 18:09. |
3rd November 2011, 06:49 | #13488 | Link | |
Programmer
Perhaps that's the issue is that BD-Java static streams with just a still image are not caught. Not sure if this is going to be something BD-Rebuilder would be able to catch. Perhaps this means if we see a bd-java title to make sure to check all the extremely short streams via edit mode. But, I think we cannot go by filesize. While this file was bigger then most short streams in size, its video duration was only 750ms. So perhaps it might also be useful in Bd-Rebuilder to list the duration of the video stream. MILLZY- prehaps you can list the info on that stream that held the static background image for your backup Here is some info on the stream: Code:
General ID : 0 Complete name : T:\BD_Rips\ROB_ROY\BDMV\STREAM\00941.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 3.98 MiB Duration : 1s 440ms Overall bit rate : 21.7 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, BVOP : No Format settings, Matrix : Default Format settings, GOP : N=1 Duration : 750ms Bit rate mode : Constant Bit rate : 40.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.805 Stream size : 3.58 MiB (90%) |
3rd November 2011, 15:42 | #13489 | Link |
@jdobbs;
I have not had much success with using the blank feature to blank warnings. For me, they don't show up in BD-RB. As jfcarbel states, some streams are not shown. Alternately, if I open the original Blu-ray or the BD-RB backup with multiAVCHD in re-author mode, every mpls/m2ts is visible. Of course with this option to blank anything does bring about potentially more problems, but with a little practice I have had success. |
4th November 2011, 00:14 | #13490 | Link |
PredictAndEncode() 0006 2803 error
I've seen several comments in various posts on PredictAndEncode errors, but not the one I'm getting.
I have a captured mpg file that plays fine and is clean by TSDoctor, but when I try to shrink it with BD-RB I get the above error as soon as Reencoding starts. I've tested two RB versions (0.39.01 and 0.39.02) and get the same error. I've successfully used BD-RB with similar files in the past so why it's happening now is a mystery (at least to me). Thoughts? Here's the INF file: [Status] LABEL=AVCHD VERSION=v0.39.02 (beta) SOURCE_SIZE=4469588616 SOURCE_VIDEO_SIZE=4469495808 TARGET_SIZE=1258291200 REDUCTION=.281507902915568 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=1.5 [00000] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 ------------------------------------- Here's the log file: [14:34:29] BD Rebuilder v0.39.02 (beta) - Source: AVCHD - Input BD size: 4.16 GB - Approximate total content: [00:42:26.725] - Target BD size: 1.17 GB - Windows Version: 5.1 [2600] - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640 [14:34:30] PHASE ONE, Encoding - [14:34:30] Processing: VID_00000 (1 of 1) - [14:34:30] Extracting A/V streams [VID_00000] - Extracting video streams [VID_00000] - Extracting audio streams [VID_00000] - [14:38:10] Reencoding video [VID_00000] - [14:38:10] PredictAndEncode() 00006 2803 [14:52:27] - Aborted by user request |
4th November 2011, 15:45 | #13491 | Link |
hi jdobbs,
hope you can help, I have started to have problems playing bd25 full back ups of the last 5 films i've backed up using v0.39.02. In that proir to using this version i've had no trouble playing my back ups, but since using this update none of my back ups play on my LG bd370 ? but will play on my samsung bd1400 and my panasonic portable player I'm using same settings as always and same media, this media from same packet works no problem on the LG bd370 using v0.39.01, any idea's as the LG is my main unit i use films backed up are salt fantastic mr fox knowing and battlestar galactica disc's 1 and 2 of the complete series all data looks fine but LG does not like any more ? Last edited by By-Tor; 4th November 2011 at 15:46. Reason: missed some data |
4th November 2011, 16:07 | #13493 | Link | |
4th November 2011, 18:14 | #13494 | Link | |
thanx for quick reply will check later when encode finishes |
5th November 2011, 17:14 | #13495 | Link |
posible bug 0.39.02?
with version 0.39.02 just started noticing the following as well.
My last 2 Blu ray rip are slightly larger than a standard single layer BD disc. So I use BD rebuilder to resize ( I have changed the name of the label). This film had only one video and one audio DTS MA 5.1 and no subtitles after my rip. I have my BD-RB audio setting boxes first 2 and the last one checked in BD rebulder (in short BD rebuilder is to leave audio alone ?) So if the video was not reencoded and the audio was not renecode. How did the move shrink 1.3 gb. and notuse the X264 encoder? I have seen this now twice with this version, but I have not watched them yet. [Status] LABEL=XXXXXXXXX VERSION=v0.39.02 (beta) SOURCE_SIZE=25546303488 SOURCE_VIDEO_SIZE=25546303488 TARGET_SIZE=24222105600 REDUCTION=.948164794620011 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24222105600 USE_ORIGINAL=1 NSTART=27000000 NEND=281749920 NSIZE=22730188800 FLINK=0 MLINK=0 [20:46:12] BD Rebuilder v0.39.02 (beta) - Source: xxxxxxx - Input BD size: 23.79 GB - Approximate total content: [01:34:21.109] - Target BD size: 22.56 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:46:13] PHASE ONE, Encoding - [20:46:13] Processing: VID_00000 (1 of 1) - [20:46:13] Extracting A/V streams [VID_00000] - [21:01:57] Reencoding video [VID_00000] - [21:01:57] Keeping original video (no reencode) - [21:01:57] Reencoding audio tracks (if req'd) - [21:01:57] Multiplexing M2TS [21:16:40]PHASE ONE complete [21:16:40]PHASE TWO - Rebuild Started - [21:16:40] Rebuilding BD file Structure [21:31:47] - Encode and Rebuild complete - WORKFILES folder removed. [21:31:47]JOB: xxxxxx finished. My answer is probably going to come from demuxing both the video and then audio track on the orginal file and the completed BD rebuilder file, as something became smaller. |
5th November 2011, 17:32 | #13496 | Link |
I guess I don't see the issue. The log shows that the video and audio both were kept intact. So the process happened as it should. It's likely there was something else in the source M2TS other than just the audio/video you saw. It's easy to put in NUL packets or an unreferenced audio track (for example) if someone wanted to make the M2TS a little larger and force dual layer.
Bottom line: The log shows BD-RB did exactly as it should. After it demuxed what was requested it saw that no reencoding was necessary, and it didn't reencode. Last edited by jdobbs; 5th November 2011 at 17:34. |
5th November 2011, 17:48 | #13497 | Link | |
5th November 2011, 17:54 | #13499 | Link |
BD Rebuilder v0.39.03 (beta)
I've updated the first post of this thread with links to a new version of BD-RB (v0.39.03). Changes for this release:
- Corrected an issue in which under certain rare circumstances a main feature could be seen as a menu -- and the feature may not be listed in the streams list on BD-25 or unwanted audio may not be removable. - Corrected an error in experimental DTSX code that could cause M2TS files to not fall on proper aligned unit boundaries. - Updated CLPI correction routine to modify the TS_recording_rate value after updates to the M2TS by experimental DTSX code. - Fixed an issue related to arrival_time_stamp rollover that incorreclty set permission bits in packet headers (DTSX experimental code). - Added a SETUP option to cause an audible "beep" when a job is complete. - Added a feature in which batch mode will not overwrite existing output folders, but instead add a suffix to the output title. - Added a new AUTO_TWOPASSONLY hidden option. By setting this value to "1" you can prevent the automatic quality selector from ever doing one pass ABR encoding. - Regressed the included version of X264.EXE to a previous release (r2085) due to reported LAVF decoding issues. - Regressed the included version of X264-64.EXE to a previous release (r2085) due to reported LAVF decoding issues. - Other minor corrections and cosmetic fixes. |
5th November 2011, 19:17 | #13500 | Link |
Sweet to see my "audio tune" request to be implemented ^^
** Edit ** wanted to test the new version so i ran the Mamma Mia disc (that was previously rebuilt with the glitchy x264). When previewing stream 00124 (that was auto selected to be blanked) the following error occured Is it because the source file is mpeg2 Last edited by Ch3vr0n; 5th November 2011 at 20:10. |
