#341 | Link |
Other strange things too:
The information for track E-AC3 is ok on the old 2.6.12, but not on the latest version? I tested with several .mkv with an E-AC3 track and there is always the same error. Why? thank you |
#342 | Link |
tsmuxer creating a short black section when joining 2 files
Hey guys,
I'm hoping someone here can help me...I have wasted so much time trying to get this joined properly. So as some of you may know, some long 3D movies (eg:- The Hobbit, Titanic, etc) are in 2 parts. Seems pretty straight forward, you just append them using tsmuxer, and in practice, it does, HOWEVER, after running it thru, if you navigate to the "join point", there is a noticeable approx 1 second of "black", then when the 2nd part starts, the audio is out of sync...the same length as the "black" section that somehow appears when joined. Is there some way that this "black" section doesn't happen ?? |
#344 | Link | |
Edit : seems to be linked to this easysup bug https://forum.doom9.org/showthread.p...13#post1451113 Last edited by a5180007; 3rd February 2020 at 22:37. |
#345 | Link | |
Yes, I've tried both methods, several times, same result ![]() |
#346 | Link | |
tsMuxer Open Source
I posted a way to do this a few years ago. Instead of joining playlists join ssif files. The results are seamless. Only thing I had to do was to fix chapter marks on second half. I’ll see if I can locate it and post link here. It’s post 9 in this thread https://forum.redfox.bz/threads/3d-b...e-disks.70932/ Last edited by Hart2hart; 4th February 2020 at 05:17. |
#347 | Link | |
That is a good find! Thanks! I suspected it could be a bug in easySUP. I'm definitely gonna try bdsup2sub! Code:
What I'm doing is I demux .sup files from a Blu-ray with tsMuxer. Import .sup to Subtitle Edit, do some editing, and save as .srt Opening .srt with easySUP and apply settings like font, size, style, margin, etc. (This .sup plays in sync when playing video (.m2ts or .mpls) in PotPlayer or MPC-HC and then adding .sup.) Then add the Blu-ray in tsMuxer, removing unwanted streams, adding one or two easySUP generated .sup files. This is where it goes wrong. tsMuxer auto reads (wrongly) the .sup as Frame rate: 23.976 so not anything I can control. tsMuxer then tries to auto change the FPS .sup to 24 to match the video wich results in a out off sync .sup. ![]() Best regards, varekai |
#348 | Link | ||
PgcEdit daemon
For the audio sync issue, there is probably a solution with the CLI argument --append-mode: Quote:
Also, if there is a blank at the end of the first part, you can remove it with the option Multiplexer -> Output -> Splitting -> Split mode: After specific timestamps. With some luck, you can cut the blank just at the end of the audio, or a bit before, and the second part will be in sync (with a very small delay due to the different durations of the video and audio frames, but that delay is so short that it should not be noticeable).
#349 | Link | |
![]() So I can't wait to try this process, and hope I have the same success as the OP had. edit:- unfortunately, this did not work for me, still got the black frames at the join, and hence, sync was out, after that ![]() I certainly came to the right place ![]() I have a couple of other 2 part 3D movies, hopefully they will go thru tsmuxer without issue, but Titanic is a problem. Cheers Last edited by Pauly Dunne; 5th February 2020 at 01:39. |
#350 | Link | |
As far as I know, MKVToolnix/MKVmerge doesn't process MVC (SSIF) 3D movies...it leaves out the SSIF/MVC track. The ONLY app that I have found that DOES, IS tsmuxer. I'm pretty sure that there are not any black sections at the end of the 1st part, or the start of the 2nd part. If you watch the movie in question (Titanic), that is NOT a joined non 3D version, and watch it at the 2 part version join point, there are NO "black" frames at all. However, I appreciate your reply & suggestions, that I will give it a try in the future. Cheers |
#351 | Link |
@yannick92 the "secondary" checkbox was already there with 2.6.12. The secondary audio is for PiP (Picture-in-Picture) videos.
Edit : secondary audio is possible only with E-AC3 and DTS Express. Patch has been submitted for fixing the bitrate and channel. Last edited by a5180007; 4th February 2020 at 20:43. |
#352 | Link |
SuperVirus
AT LAST!
![]() In file w64-nightly-2020-02-05--01-09-49.zip the 24-bit DTS Express "bug" in the GUI has been "fixed" (so to speak) ![]() Last edited by filler56789; 5th February 2020 at 06:14. Reason: remove P.S. |
#353 | Link | |
PgcEdit daemon
And, of course, if you want to recreate a 3DBD, tsMuxeR is better.
#355 | Link | |
Try eg dolby-vision-amaze.mp4 (DV Profile 5) or P81_GlassBlowing2.mp4 (DV Profile 8.1) Last edited by a5180007; 5th February 2020 at 20:51. |
#356 | Link | |
Alternatively, open the sup produced by easysup with an hexeditor: - bytes 14-15 are width (0x0780 = 1920) - bytes 16-17 are height (0x0438 = 1080) - first nibble of byte 18 is fps: = (0, 23.976, 24, 25, 29.97, 30, 50, 59.94) => change from "10" to "20" |
#357 | Link | |
Life's clearer in 4K UHD
#359 | Link | |
Links: - https://4kmedia.org/lg-earth-dolby-vision-uhd-4k-demo/ [60.000fps] https://4kmedia.org/lg-dolby-vision-uhd-4k-demo/ [30.000fps] https://4kmedia.org/lg-dolby-comparison-uhd-4k-demo/ [24.000fps] https://4kmedia.org/lg-amaze-dolby-vision-uhd-4k-demo/ [60.000fps]
#360 | Link | |
