21st July 2024, 02:58 | #31884 | Link |
@jdobbs
I want to check your requirements to test the encoding to check its compatibility with VCEEnc. I have a Ryzen 5 5600G APU and a Radeon RX 7600 GPU for testing. Maybe not in the planning, but it might be an add-on for the future. Thank you. |
21st July 2024, 14:20 | #31885 | Link | |
21st July 2024, 21:22 | #31887 | Link | |
The resulting file will be a TruHD+AC3 file which will show in TSMuxer so that you can mux it back into a BDMV folder format for BDRB to import and process. (It's nice to be able to help somebody ELSE sometimes! ) |
22nd July 2024, 14:27 | #31888 | Link | |
Another limitation is that I don't personally have a system with the AMD GPU -- so I'd rely completely on someone else to test it. Last edited by jdobbs; 22nd July 2024 at 20:28. |
23rd July 2024, 10:30 | #31889 | Link | |
Thank you, I will try that out. One problem I can tell is that each generation if AMD GPUs and APUs has different options that may not work in the next or the previous one. Example B-frames are not supported by all AMD cards, unfortunately. As for QSVEnc the only option I found to further fine tune CQP is Code:
--qp-offset <int>[:<int>][:<int>]... Set qp offset of each pyramid reference layers. (default = 0) |
23rd July 2024, 16:05 | #31890 | Link | |
Would you mind running the following commands from a CMD window and post the output here? \pathto\VCEEncC.exe --check-hw \pathto\VCEEncC.exe --check-features |
23rd July 2024, 23:19 | #31892 | Link | |
I'll run the commands once I'm back at one of the machines. Might take a while. |
23rd July 2024, 23:32 | #31893 | Link |
I did extensive testing using SSIM and PSNR comparisons (to reduce subjectivity). Both scored with roughly equal quality at approximately the same output size. You just have remember to use different constant quality settings (the values aren't 1:1).
24th July 2024, 09:15 | #31894 | Link | |
For the RX 7600. Please find below: --check-hw Code:
VCEEnc (x64) 8.23 (r1710) by rigaya, Jul 18 2024 12:57:57 (VC 1940/Win) AMF Version 1.4.34 reader: raw, avs, vpy, avsw, avhw VCE available device #0: AMD Radeon RX 7600 Supported Codecs: H.264/AVC H.265/HEVC AV1 Code:
device #0: AMD Radeon RX 7600 H.264/AVC encode features acceleration: Hardware-accelerated max profile: High max level: unknown max bitrate: 1000000 kbps ref frames: 1-16 Bframe support: yes HW instances: 1 pre analysis: yes max streams: 16 timeout support: yes smart access: no H.264/AVC input: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.264/AVC output: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: NV12[1](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.265/HEVC encode features 10bit depth: yes acceleration: Hardware-accelerated max profile: main10 max level: unknown max bitrate: 1000000 kbps ref frames: 1-16 pre analysis: yes max streams: 16 timeout support: yes smart access: no H.265/HEVC input: Width: 128 - 8192 Height: 128 - 4352 alignment: 32 Interlace: no pix format: YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.265/HEVC output: Width: 128 - 8192 Height: 128 - 4352 alignment: 32 Interlace: no pix format: NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST AV1 encode features 10bit depth: yes acceleration: Hardware-accelerated max profile: main max level: unknown max bitrate: 1000000 kbps Temporal layers: 4 pre analysis: yes max streams: 1 timeout support: no smart access: no AV1 input: Width: 128 - 8192 Height: 128 - 4352 alignment: 32 Interlace: no pix format: YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST AV1 output: Width: 128 - 8192 Height: 128 - 4352 alignment: 32 Interlace: no pix format: NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST device #0: AMD Radeon RX 7600 H.264/AVC decode features 10bit depth: no acceleration: Hardware-accelerated max streams: 16 smart access: no H.264/AVC output: Width: 32 - 4096 Height: 32 - 4096 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) H.265/HEVC decode features 10bit depth: yes acceleration: Hardware-accelerated max streams: 0 smart access: no H.265/HEVC output: Width: 32 - 7680 Height: 32 - 4320 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) VP9 decode features 10bit depth: yes acceleration: Hardware-accelerated max streams: 16 smart access: no VP9 output: Width: 32 - 7680 Height: 32 - 4320 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) device #0: AMD Radeon RX 7600 AMFVideoConverter features acceleration: GPU-accelerated input: Width: 32 - 2147483647 Height: 32 - 2147483647 alignment: 2 Interlace: no pix format: NV12[1](native), YV12[2](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), YUV420P[7](native), YUY2[9](native), UYVY[12](native) memory type: DX11(native), OPENCL(native), OPENGL(native), HOST output: Width: 32 - 2147483647 Height: 32 - 2147483647 alignment: 2 Interlace: no pix format: NV12[1](native), YV12[2](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), YUV420P[7](native) memory type: DX11(native), OPENCL(native), OPENGL(native), HOST AMFHQScaler features acceleration: GPU-accelerated input: Width: 32 - 8192 Height: 32 - 4096 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) output: Width: 32 - 16384 Height: 32 - 8192 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) AMFVQEnhancer features acceleration: GPU-accelerated input: Width: 32 - 8192 Height: 32 - 4096 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) output: Width: 32 - 16384 Height: 32 - 8192 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) Please find below results for the Ryzen 5 5600g APU (Vega 7 if I am not mistaken) --check-hw Code:
VCEEnc (x64) 8.23 (r1710) by rigaya, Jul 18 2024 12:57:57 (VC 1940/Win) AMF Version 1.4.34 reader: raw, avs, vpy, avsw, avhw VCE available device #0: AMD Radeon Supported Codecs: H.264/AVC H.265/HEVC Code:
device #0: AMD Radeon H.264/AVC encode features acceleration: Hardware-accelerated max profile: High max level: unknown max bitrate: 1000000 kbps ref frames: 1-16 Bframe support: no HW instances: 1 pre analysis: yes max streams: 16 timeout support: yes smart access: no H.264/AVC input: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.264/AVC output: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: NV12[1](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.265/HEVC encode features 10bit depth: yes acceleration: Hardware-accelerated max profile: main max level: unknown max bitrate: 1000000 kbps ref frames: 1-16 pre analysis: yes max streams: 16 timeout support: yes smart access: no H.265/HEVC input: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: YUV420P[7], YV12[2], BGRA[3], RGBA[5], ARGB[4], NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST H.265/HEVC output: Width: 128 - 4096 Height: 128 - 4096 alignment: 32 Interlace: no pix format: NV12[1](native), P010[10](native) memory type: DX11(native), OPENCL, OPENGL, HOST device #0: AMD Radeon H.264/AVC decode features 10bit depth: no acceleration: Hardware-accelerated max streams: 16 smart access: no H.264/AVC output: Width: 32 - 4096 Height: 32 - 2160 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) H.265/HEVC decode features 10bit depth: yes acceleration: Hardware-accelerated max streams: 0 smart access: no H.265/HEVC output: Width: 32 - 7680 Height: 32 - 4320 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) MPEG2 decode features 10bit depth: no acceleration: Hardware-accelerated max streams: 16 smart access: no MPEG2 output: Width: 32 - 1920 Height: 32 - 1080 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) VP9 decode features 10bit depth: yes acceleration: Hardware-accelerated max streams: 16 smart access: no VP9 output: Width: 32 - 7680 Height: 32 - 4320 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) VC-1 decode features 10bit depth: no acceleration: Hardware-accelerated max streams: 16 smart access: no VC-1 output: Width: 32 - 1920 Height: 32 - 1080 alignment: 32 Interlace: yes pix format: NV12[1](native), P010[10](native), P012[19](native), BGRA[3], RGBA[5] memory type: DX11(native) device #0: AMD Radeon AMFVideoConverter features acceleration: GPU-accelerated input: Width: 32 - 2147483647 Height: 32 - 2147483647 alignment: 2 Interlace: no pix format: NV12[1](native), YV12[2](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), YUV420P[7](native), YUY2[9](native), UYVY[12](native) memory type: DX11(native), OPENCL(native), OPENGL(native), HOST output: Width: 32 - 2147483647 Height: 32 - 2147483647 alignment: 2 Interlace: no pix format: NV12[1](native), YV12[2](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), YUV420P[7](native) memory type: DX11(native), OPENCL(native), OPENGL(native), HOST AMFHQScaler features acceleration: GPU-accelerated input: Width: 32 - 8192 Height: 32 - 4096 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) output: Width: 32 - 16384 Height: 32 - 8192 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) AMFVQEnhancer features acceleration: GPU-accelerated input: Width: 32 - 8192 Height: 32 - 4096 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) output: Width: 32 - 16384 Height: 32 - 8192 alignment: 2 Interlace: no pix format: NV12[1](native), BGRA[3](native), ARGB[4](native), RGBA[5](native), P010[10](native), RGBA_F16[11](native), R10G10B10A2[13](native) memory type: DX11(native), OPENCL(native) Last edited by dietachi; 24th July 2024 at 12:17. Reason: UPDATE |
25th July 2024, 21:12 | #31897 | Link |
New Release of BD-Rebuilder (v0.62.06)
I have updated the first post of this thread with a link to the most recent release (v0.62.06) of BD-RB. Changes for this release:
- Added code to correct resizing when using Intel GPU on imported sources that are not standard resolutions to make up for its unusual resize-before-padding behavior. - Added similar resizing adjustments to GPUENCC for when padding and resizing are required. - Corrected an issue in which resizing an SD 4:3 source to 1080p or 720p source while forcing UHD output could result in output with an incorrect aspect ratio. - Corrected an issue in which non-UHD HEVC files that are imported cause the pseudo BD Structure to be flagged as UHD-BD, and results in reencoding to HEVC and the creation of a UHD-BD structure when performing a rebuild. - Removed QSYNC_TEST requirement to enable Intel Quick Sync testing/usage. It is now available by default -- but, of course, it only works for those with appropriate GPUs. - Other minor corrections and cosmetic fixes. |
25th July 2024, 23:25 | #31898 | Link | |
26th July 2024, 01:57 | #31899 | Link |
Hmmm... I know I'm forgetting something, but I'm trying to convert an HEVC MKV file into an x264 archive file (AVC/AC3) but, I keep getting errors. I tried first using alternate output 1920x1080 keep intact audio, and then I tried the archive backup that I mention above. Both failed... I've attached the MediaInfo txt file of the original MKV file.
Oh, I see that attachments need to be 'Approved', so please forgive me, but I'll just add the file information below then. ***EDIT Okay, I tried reinstalling AVS from your #1 page here. I had installed the newest version because everyone said it would work, but with BDRB it did not. But, it still failed. I'll include the failed information below the MediaInfo of the original file. Here are the logs: [Status] LABEL=IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737 VERSION=v0.62.01 SOURCE_SIZE=3290222716 SOURCE_VIDEO_SIZE=3290204160 TARGET_SIZE=24851251200 REDUCTION=7.55309744791034 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=1 ENCODE_STEP=1.5 [00000] AUDIO=111 PGS=11 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=24851232644 SPLITS=1 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ---------------------- [17:47:08] Importing MKV: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737 - Preparing MKV for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [17:47:49] Video import completed successfully. ---------------------- ---------------------- [07/25/24] BD Rebuilder v0.62.01 [17:50:24] Source: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737 - Input BD size: 3.06 GB - Approximate total content: [01:28:20.420] - Windows Version: 6.2 [9200] - Archive Backup (AVC/AC3) mode enabled - Quality: High Quality (Default) - X264 Tweak(s) enabled - UHD-BD source detected. - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [17:50:26] PHASE ONE, Encoding - [17:50:26] Processing: VID_00000 (1 of 1) - [17:50:26] Reencoding video [VID_00000] - Source Video: HEVC, 1920x1080 - Rate/Length: 23.976fps, 127,083 frames - [17:50:26] Reencoding: VID_00000, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.62.01 - Windows Version: 6.2 [9200] - Working Path Free Space: 184.86GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [17:50:28] - Failed video encode, aborted ---------------------- [17:51:08] Importing MKV: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737 - Preparing MKV for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [17:51:46] Video import completed successfully. ---------------------- [07/25/24] BD Rebuilder v0.62.01 [17:51:54] Source: IL.SORRISO.DELLA.IENA.1972.1080P.BLURAY.DUAL.DDP.1.0.X265-SM737 - Input BD size: 3.06 GB - Approximate total content: [01:28:20.420] - Windows Version: 6.2 [9200] - Archive Backup (AVC/AC3) mode enabled - Quality: High Quality (Default) - X264 Tweak(s) enabled - UHD-BD source detected. - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [17:51:55] PHASE ONE, Encoding - [17:51:55] Processing: VID_00000 (1 of 1) - [17:51:55] Extracting A/V streams [VID_00000] - [17:52:08] Reencoding video [VID_00000] - Source Video: HEVC, 1920x1080 - Rate/Length: 23.976fps, 127,083 frames - [17:52:08] Reencoding: VID_00000, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.62.01 - Windows Version: 6.2 [9200] - Working Path Free Space: 184.86GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [17:52:09] - Failed video encode, aborted ~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Original HEVC MediaInfo file: General Unique ID : 67595281969964806923358460752008863402 (0x32DA60B52D0A1DC136A0CDC9BAB45EAA) Complete name : D:\__MKVMerge\Il.sorriso.della.iena.1972.1080p.BluRay.DUAL.DDP.1.0.x265-SM737.mkv Format : Matroska Format version : Version 4 File size : 2.84 GiB Duration : 1 h 28 min Overall bit rate : 4 600 kb/s Frame rate : 23.976 FPS Encoded date : 2024-07-26 00:44:55 UTC Writing application : mkvmerge v86.0 ('Winter') 64-bit Writing library : libebml v1.4.5 + libmatroska v1.7.1 / Lavf60.16.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 28 min Bit rate : 3 501 kb/s Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 0) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.095 Stream size : 2.16 GiB (76%) Writing library : x265 3.5+1-f0c1022b6:[Linux][GCC 13.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x800 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-eob / no-eos / no-hrd / info / hash=0 / temporal-layers=0 / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / no-weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=3500 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=4 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=1 / chromaloc-top=0 / chromaloc-bottom=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 28 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 1 s 600 ms Stream size : 121 MiB (4%) Title : Commentary with Author Troy Howarth and Film Maker Nathaniel Thompson Language : English Service kind : Complete Main Default : No Forced : No Dialog Normalization : -31 dB dialnorm_Average : -31 dB dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dB Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 28 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 1 s 600 ms Stream size : 283 MiB (10%) Language : Italian Service kind : Complete Main Default : No Forced : No Dialog Normalization : -31 dB dialnorm_Average : -31 dB dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dB Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 28 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 1 channel Channel layout : M Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 1 s 600 ms Stream size : 283 MiB (10%) Language : English Service kind : Complete Main Default : Yes Forced : No Dialog Normalization : -31 dB dialnorm_Average : -31 dB dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dB Text #1 ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 28 min Bit rate : 16.8 kb/s Frame rate : 0.215 FPS Count of elements : 1138 Stream size : 10.6 MiB (0%) Title : SDH Language : English Default : Yes Forced : No Text #2 ID : 6 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 27 min Bit rate : 14.7 kb/s Frame rate : 0.186 FPS Count of elements : 978 Stream size : 9.24 MiB (0%) Language : English Default : No Forced : No ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Last attempt: ---------------------- [18:20:28] Importing MKV: 00000 - Preparing MKV for processing... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [18:21:17] Video import completed successfully. ---------------------- [07/25/24] BD Rebuilder v0.62.01 [18:21:22] Source: 00000 - Input BD size: 3.06 GB - Approximate total content: [01:28:20.420] - Windows Version: 6.2 [9200] - Archive Backup (AVC/AC3) mode enabled - Quality: High Quality (Default) - X264 Tweak(s) enabled - UHD-BD source detected. - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:21:22] PHASE ONE, Encoding - [18:21:22] Processing: VID_00000 (1 of 1) - [18:21:22] Extracting A/V streams [VID_00000] - [18:21:40] Reencoding video [VID_00000] - Source Video: HEVC, 1920x1080 - Rate/Length: 23.976fps, 127,083 frames - [18:21:40] Reencoding: VID_00000, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.62.01 - Windows Version: 6.2 [9200] - Working Path Free Space: 182.02GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [18:21:41] - Failed video encode, aborted Last edited by Lathe; 26th July 2024 at 02:26. Reason: Adding MediaInfo txt file of original MKV file... |
