#61 | Link |
I know it won't reencode but it will use CCE when it's not necessary.
For example, if I want to backup the main movie and menu without compression aka 'No Compression (100% video)' DVD ReBuilder won't let me do that. It always use CCE even if know that main movie and menu will fit on a DVD5. |
#62 | Link |
Country Member
Are you sure its not just doing a demux of the m2vs and a remux? This is done invisibly when stripping audio and subbie streams in editing packages. The process should be quite fast.
Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
#63 | Link | |
Currently I use an AMD A64 X2 3800+ (2.0GHz stock), overclocked to 2.43GHz & 2GB RAM running at 486MHz DDR @ 1:1 ratio with the motherboard & a RAID setup for faster preperation/rebuilding times. Using this setup & the default sample size, for a 105-120Mins movie takes me anywhere between 9-12 Minutes just to finish redistribution. Faster, Core2Duo or even Core2Quads will finish this substantially faster, no doubt. I'd really appreciate it if you could look into implementing the same threads detection-&-execution that's done on the encoding process, on the distribution as well. Regards, Samuel. |
#64 | Link |
Country Member
I agree. I have a similar setup to Samuel (except for less RAM and striped HDD) and it takes about 1 minute of preparation for every 10 minutes of video for me, too. I have it set to 10% with low threshold of 85%. A dual core preparation would cut time in half (or, better still, enable 20%).
Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 29th October 2007 at 23:25. |
#65 | Link |
old
(my emphasis) . . . what leads you to believe that simultaneously reading from/writing to a striped 'firmware RAID' array of 2x HDDs [if this is what you have] would be faster than reading from one HDD & writing to another, each on separate SATA channels?
#66 | Link |
Location: The Great North (the better half of North America)
DVD-RB first time user here... nice app and thanks. One question though, is it normal for the DVD5 output to be 2.5GB, or are there other options that I am missing?
Thanks again. |
#67 | Link |
![]() Join Date: Oct 2001
Not at all. It should be consistently arount 4.32GB. The exception would be sources that are no full sized. Undersizing usually indicate that the encoder options are not configured properly. If you post your REBUILDER.INI file, I may be able to see what the issue is.
jdobbs.softworks@gmail.com |
#68 | Link |
I this what you're asking for?
Mode=1 OneClick=1 ReduceOpt=0 NoWarn=1 AdditionalOutput=1 LogFile=1 QuEncHQ=1 EncoderMinimized=1 RemoveDTS=1 HC_Quality=1 HC_Matrix=1 SkinVersion=12 AudioDub=1 QuEncodeType=0 iDCT=0 GOP=0 DCPrec=0 MainMatrix=Encoder Default LowMatrix=Same as Main Feature VLowMatrix=Same as Main Feature ExtraMatrix=Same as Main Feature ProCoder_Quality=4 DVD_Label=NO_SELECTION DVD_Name=NO_SELECTION.ISO MovieOnly=0 HalfD1=0 Convert_16_9=0 DisableInterlace=0 ConvertToYUY2=1 CCE=2 [Paths] QuEnc=C:\Program Files\DVD-RB PRO\Encoders\QuEnc\QuEnc.exe ReJig=C:\Program Files\DVD-RB PRO\Encoders\ReJig\ReJig.exe HC=C:\Program Files\DVD-RB PRO\Encoders\HC Encoder\HCbatch.EXE FFMPEG=C:\Program Files\DVD-RB PRO\Encoders\FFMpeg\ffmpeg.exe CMDLINE=C:\Program Files\DVD-RB PRO\Encoders\CMDLINE\mencoder.bat ProCoder=C:\Program Files\DVD-RB PRO\Encoders\EclPro\EclPro.exe DECOMB=C:\Program Files\AviSynth 2.5\plugins\Decomb521.dll NICAUDIO=C:\Program Files\AviSynth 2.5\plugins\nicaudio.dll MPEG2DEC=C:\Program Files\DVD-RB PRO\DGDecode.dll Working=C:\Videos\DVD-RB\WorkFlow\ Output=C:\Videos\DVD-RB\Output\ CCEBasic=C:\Program Files\Custom Technology\Cinema Craft Encoder Basic\cct2.exe [Audio] Selected= [Subpictures] Selected= |
#69 | Link |
Yes. I don't see anything unusual in there... was the source a commercial disc?
#71 | Link |
Just to be sure... you're not using the trial version of CCE Basic are you? It has a limitation on the number of frames it will encode and would cause an undersize.
I've done close to 2000 movies in testing and I've never had an undersize like that...
#73 | Link |
It will do a certain number of frames and then exit as if it had completed it all.
Was the source preprocessed, run through other software, or modified in any way?
#75 | Link |
What do I do with the update zip for DVD Rebuilder Pro?
(I figure if I ask this enough I'll eventually get an answer. I tried searching the forum, but only irrelevant threads pop up, and there's nothing on the so-called "guide" about it, that I can see anyway.) |
#76 | Link | |
#77 | Link | |
Look, I just checked the other thread and you never really answered the question. You just posted some stuff about how the updates weren't intended for noobs like me. I'm getting a little irked at your attitude, sir. I wonder if you'd be willing to refund my money for this product, since you can't even answer a simple question about it without copping an attitude. You have $40 of mine, and I'm the one who deserves to cop an attitude *because I still don't know what to do with the update zip*. It's been less than 30 days (actually less than a week), and I'd prefer to spend the money somewhere else. (By the way, I never really cared who answered the question. Just thought it was odd that you wouldn't at least put a one sentence "readme" file in the zip, indicating what to do with the updates. This thread is supposedly about a FAQ. Well...?) Last edited by freewheeling; 19th July 2010 at 03:06. |
#78 | Link |
The update.zip is meant for experienced users who have the very previous version of RB already installed. It contains only updated files compared to the version before (plus some basic files).
If you're new to RB always use the installer version! This is the author's recommendation. Cu Rippraff Last edited by Guest; 19th July 2010 at 11:35. Reason: remove OT content |
#79 | Link |
Seems to me freewheeling has the previous version installed and he's asking the simple question of HOW to apply the update files from the ZIP. Seems like a reasonable question. jdobbs did say this in the other thread:
"With the zip you can just replace the existing files in the DVD-RB directory." It just means one simply uncompresses the ZIP onto the correct path. Do you know how to do that, freewheeling? It's a common operation with ZIP files. Last edited by Guest; 19th July 2010 at 11:43. |
#80 | Link | |
BTW, part if this was that the default "skin" on the program wasn't playing correctly (with progress indicators overlapping and other elements not visible) and it gave me the impression that something was wrong with the installation. I changed to one of the other skins and it seemed to work better. Last edited by freewheeling; 19th July 2010 at 15:12. |
