Old 30th September 2012, 16:51   #181  |  Link
ney2x
Originally Posted by iwod View Post
Why is it every player of this sort requires DirectX 9.0c update? Aren't it already included inside Windows 7 and Windows 8? Do Newer Direct X not compatible with previous version? And can we not get rid of this dependencies?
@Aleksoid1978
Does adding or copying D3DCompiler_43.dll and d3dx9_43.dll to MPC-BE program directory fixed or doesn't require Directx 9, just like with MPC-HC?
ney2x is offline   Reply With Quote
Old 1st October 2012, 00:49   #182  |  Link
Originally Posted by jos99 View Post
I see slightly different version is on latest screenshot on the project page
That background used for that image along with many others can be picked up in a zip file over here Preview of all the images contacted in the zip here.
Old 1st October 2012, 04:50   #183  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
BE failed, lav was fine.
Old 1st October 2012, 05:09   #184  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by wanezhiling View Post
MPC-BE don't have own splitter/source for BIK video. Use LAV for this.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 1st October 2012, 05:51   #185  |  Link
wanezhiling
I mean LAV S + BE V/A failed.
Old 1st October 2012, 07:11   #186  |  Link
Aleksoid1978
Yes - fail, but only audio, video is ok. Audio - fix later.
Old 1st October 2012, 14:01   #187  |  Link
ZoNi
ZoNi's Avatar
Few toolbar skins (by ZoNi):
Android
Android Dark
Carpelinx
Farm-Fresh
Icons source: http://findicons.com/
Just save any of those PNG "skins" to MPC-BE folder and restart it.
ZoNi is offline   Reply With Quote
Old 1st October 2012, 14:24   #188  |  Link
z_mashine
z_mashine's Avatar
Toolbars with icons from mpc-hc be mod.
z_mashine is offline   Reply With Quote
Old 1st October 2012, 19:21   #189  |  Link
mark0077
There is a 0.1% of user can/be managed to work DVD with MadVR. Other 99.9% - give a error/hang while try watch DVD+MadVR.
How do I do in this situation ?
I think - i make options to replace or not MadVR for DVD playback.
Hi guys, is this functionality to switch from madVR to EVR for DVD playback optional, or planned to be?
mark0077 is offline   Reply With Quote
Old 2nd October 2012, 08:26   #190  |  Link
ZoNi
ZoNi's Avatar
z_mashine, can you do the same with icons from HC? http://www.sendspace.com/file/mw7nis
Old 2nd October 2012, 08:32   #191  |  Link
z_mashine
z_mashine's Avatar
Which is the same?
Old 2nd October 2012, 11:34   #192  |  Link
ZoNi
ZoNi's Avatar
Sorry - I meant: can you make MPC-BE icon library with icons from MPC-HC? http://www.sendspace.com/file/mw7nis
Old 2nd October 2012, 14:18   #193  |  Link
Aleksoid1978
http://aleksoid.tosei.ru/Test/mpc-be/mpc-be.exe.1282.7z
See - DVD/OGM options. Will be in next release.
Old 2nd October 2012, 14:41   #194  |  Link
z_mashine
z_mashine's Avatar
Maybe later.
Old 2nd October 2012, 18:28   #195  |  Link
ZoNi
ZoNi's Avatar
Then: maybe thanks
Old 6th October 2012, 14:48   #196  |  Link
naoan
Since madvr now able to take screenshot can you guys remove the restriction? I tried using older version of MPC and screenshot work just fine with madvr 0.84.0.
naoan is offline   Reply With Quote
Old 7th October 2012, 11:29   #197  |  Link
Aleksoid1978
Already done.
Old 7th October 2012, 23:56   #198  |  Link
jinsk8r
"Auto-load Subtitles" sometimes don't work. Have to LOAD manually.
x64 build. Both external and internal, srt and ass.
This. x86 too.
In some movies it loads, in some others, it doesn't. MPC-HC loads properly.
(And I'm 100% sure subtitle/movies names are match)
You need to check this problem.
jinsk8r is offline   Reply With Quote
Old 7th October 2012, 23:57   #199  |  Link
jinsk8r
Use mine:
http://archangelx2.deviantart.com/art/MPC-HC-Icon-Library-v-2-2-265250286
@z_mashine: U should post ur preview img so ppl can see
Old 8th October 2012, 00:23   #200  |  Link
z_mashine
z_mashine's Avatar
New Icon Set MPC-BE Monochrome Icon Library v1.0
