Old 21st October 2012, 10:40   #241  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by suanm View Post
Aleksoid1978,add the double frame function into MPC-BE player please,now potplayer has the double frame function.
What you mean - "double frame" ?
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 21st October 2012, 10:46   #242  |  Link
wanezhiling
Then you needn't collect all the IDs of vp5 and IVB cards, not only for gtx660ti.
Old 21st October 2012, 10:52   #243  |  Link
wanezhiling
He referred to this, methods of s/w deinterlacing, maybe.
But I think its needless.
Old 22nd October 2012, 12:19   #244  |  Link
Mercury_22
Subtitles are broken in latest versions (e.g. version 1427) = some letters like , , ş ţ .... are incorrect displayed as squares or some kind of Chinese letters
Test file: any sub from http://www.addic7ed.com with such letters (e.g. Spanish)
P.S. Version 1364 it's working correct
Windows 10 19042.508 x64, HD7790 Adrenalin 2020 Edition 20.9.1, HDMI Full RGB 4:4:4
Mercury_22 is offline   Reply With Quote
Old 22nd October 2012, 12:45   #245  |  Link
kasper93
MPC-HC Developer
I guess they had ported this change 7cb86ad but have not port this 6d1472b yet. Just wait for newer build...
kasper93 is offline   Reply With Quote
Old 22nd October 2012, 12:49   #246  |  Link
Aleksoid1978
Better - upload example and say the number of sub and text. At http://www.addic7ed.com/ i don't find subtitle with letters like , , ş ţ.
P.S. - find. all ok - be testing.
Old 22nd October 2012, 12:51   #247  |  Link
Aleksoid1978
Originally Posted by kasper93 View Post
I guess they had ported this change 7cb86ad but has not port this 6d1472b yet. Just wait for newer build...
No - we don't ported you commit, relax
P.S. I ported only you idea .
Old 22nd October 2012, 12:59   #248  |  Link
Mercury_22
Try the Spanish
Or
Old 22nd October 2012, 13:29   #249  |  Link
Aleksoid1978
Try the Spanish
Or
Try this - http://rghost.ru/41087966
Old 22nd October 2012, 13:38   #250  |  Link
Mercury_22
Fixed !
Спасибо !
Edit: Any chance you can upload a x64 version too ?
Old 22nd October 2012, 14:10   #251  |  Link
Aleksoid1978
Fixed !
Спасибо !
Here - http://rghost.ru/41088860
also fix this bug - https://sourceforge.net/apps/trac/mpc-hc/ticket/2671 when with internal MPEGSplitter do not show PGS subtitle.
Old 22nd October 2012, 14:17   #252  |  Link
Mercury_22
Big Спасибо !
Now I have to ask ... can you upload ver 1428 for x86 too ? пожалуйста !
EDIT: Now "Prefer external subtitles over embedded subtitles" doesn't work with some files when "Default track preference" is not check
Sample
Also there still are some minor problems displaying correctly the subs but only at the beginning for 2-3 seconds
Old 22nd October 2012, 21:20   #253  |  Link
VipZ
Thanks for updated version and found a bug.
There is flickering in the video when you move the window around either playing or paused. This was with EVR-CP
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 23rd October 2012, 02:22   #254  |  Link
Aleksoid1978
Fixed.
Old 23rd October 2012, 03:31   #255  |  Link
suanm
yes,if you can build built-in double frame 2x function in mpc-be,i will thank you
suanm is offline   Reply With Quote
Old 23rd October 2012, 05:10   #256  |  Link
Aleksoid1978
There is no software deinterlace support in MPC video decoder/renderer.
Old 23rd October 2012, 05:37   #257  |  Link
Aleksoid1978
Big Спасибо !
Sample
Test - Test build
Try fix both bug - incorrect display sub at you sample and "Prefer external subtitles over embedded subtitles" doesn't work with some files when "Default track preference" is not check
Old 23rd October 2012, 07:30   #258  |  Link
Mercury_22
Test - Test build
They are both fixed and VipZ's flickering (which I had too)
Old 23rd October 2012, 07:33   #259  |  Link
suanm
uh,i mean mpc-be can play 720p or 1080p video back smoothly with 47.95 frames or 48 frames .these 720p or 1080p videoes have original 23.97 frames or 24 frames
Old 23rd October 2012, 07:38   #260  |  Link
Aleksoid1978
ok - i think.
