Old 22nd December 2012, 13:33   #421  |  Link
wanezhiling
Originally Posted by Aleksoid1978 View Post
Much better, still a slight delay.
Old 22nd December 2012, 13:44   #422  |  Link
Aleksoid1978
Aleksoid1978's Avatar
I compare with LAV splitter - identically.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 22nd December 2012, 14:13   #423  |  Link
wanezhiling
http://forum.doom9.org/showpost.php?...1&postcount=94
Any suggestion?
Old 23rd December 2012, 02:00   #424  |  Link
Aleksoid1978
I do not understand what you mean.
Old 24th December 2012, 04:11   #425  |  Link
boyumeow
boyumeow's Avatar
If running MPC-BE and you proceed to uninstall MPC-HC the uninstaller says MPC-HC is running, HC & BE should be able to be distinguished from each other.
This is a BE problem, MPC-HC has its own frame names, GUIDs and everything, MPC-BE just never changed those after forking, so the installer doesn't know any better.
In this case, its the application mutex which is created somewhere.
Just some info to take note off, can it be resolved to avoid conflict.
boyumeow is offline   Reply With Quote
Old 24th December 2012, 04:34   #426  |  Link
Aleksoid1978
Already fixed
Old 24th December 2012, 06:53   #427  |  Link
wanezhiling
That issue also happens on BE before, do you remember?
And you fixed it.
So I think maybe you can give some help for MPC-HC.
Old 24th December 2012, 07:46   #428  |  Link
Aleksoid1978
And you fixed it.
Why - in their team is full of wonderful and knowledgeable developers. They thought that I did not want on their team.
Post about this bug in MPC-HC forums - see what happened.
Old 24th December 2012, 09:39   #429  |  Link
wanezhiling
http://forum.doom9.org/showpost.php?...ostcount=13546
@Aleksoid1978, BE failed too.
Old 24th December 2012, 10:32   #430  |  Link
Aleksoid1978
Fixed - http://aleksoid.voserver.net/MPC-BE/..._3VID_Fixed.7z
Old 24th December 2012, 10:38   #431  |  Link
wanezhiling
Great, works now.
Old 24th December 2012, 17:39   #432  |  Link
wanezhiling
http://forum.doom9.org/showpost.php?...&postcount=330
Build 1716 still crashed..
Old 24th December 2012, 21:58   #433  |  Link
Aleksoid1978
I know.
Old 25th December 2012, 00:07   #434  |  Link
phoenix_fr
hello, with galley to setup 'mpc-be' like my 'mpc-hc be mod'
I think it would be nice to turn some packages in the next preset correctly by default
ex:
"touch window from inside"
"keep aspect ratio"
phoenix_fr is offline   Reply With Quote
Old 25th December 2012, 06:39   #435  |  Link
robpdotcom
I noticed that pressing the hot-key for "Remaining Time" (Ctrl+I) now actually shows the remaining time. Is there any way to show the elapsed time?
In other words:
it used to show "00:30:00/02:00:00"
now it shows "-01:30:00/02:00:00"
Any way to show the old style?
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline   Reply With Quote
Old 25th December 2012, 13:35   #436  |  Link
judelaw
In other words:
judelaw is offline   Reply With Quote
Old 25th December 2012, 14:22   #437  |  Link
robpdotcom
Windows 7 x64
i7 870
16GB RAM
AMD 6870
Old 26th December 2012, 15:36   #438  |  Link
wanezhiling
@Aleksoid1978, http://forum.doom9.org/showpost.php?...ostcount=13565
BE does not do the deinterlacing job.
Old 27th December 2012, 07:43   #439  |  Link
Aleksoid1978
It seems that the file is encoded incorrectly.
Old 27th December 2012, 07:52   #440  |  Link
wanezhiling
No field order can be determined?
