Old 16th June 2013, 10:09   #1221  |  Link
ontherocks
Some more files having issues (I have bitstreaming enabled)
1. http://www.mediafire.com/watch/smqnuhjgxaf1841/test.m4a - Pauses automatically
2. http://www.hifistatement.info/downlo...heme_24-96.wav - Doesn't play
3. aif files don't play. I am not sure if they are supported. Example https://dl.dropboxusercontent.com/u/...parkly_48k.aif
4. Any file with sampling rate greater than 48kHz, is displayed in my AVR as 48kHz. I am not sure if I am missing any settings. Example http://www.rarewares.org/rja/Yes-Rou...96kHz_5.1.flac
5. 2 Channel files with sampling rate greater than 48kHz are displayed as Multichannel PCM 5.1 in my AVR. Example files could be obtained from here http://www.unipheyemusic.com/filetest.cfm
6. This file produces static noise sometimes, sometimes there is no audio and sometimes it plays fine. It produces issues normally when it is after another file in playlist and it starts to play after the first one has ended playing. http://trailers.apple.com/movies/ind...ion_h1080p.mov
ontherocks is offline   Reply With Quote
Old 16th June 2013, 11:56   #1222  |  Link
Aleksoid1978
Aleksoid1978's Avatar
What audio renderer you use. See Filters list on playback.
P.S.
http://www.mediafire.com/watch/smqnuhjgxaf1841/test.m4a - LAV also failed.
for .aif - need install LAV. http://www.hifistatement.info/download_petrocca/Deborahs_Theme_24-96.wav - also. MPC-BE don't have internal splitter for aif/wav files.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 18th June 2013, 15:29   #1223  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic - BE 1.2.0.3 Win32 (Stable release):
Media Player Classic - BE 1.2.0.3 x86 (with installer)
Media Player Classic - BE 1.2.0.3 x86 (portable)
Standalone Filters Media Player Classic - BE 1.2.0.3 x86
Media Player Classic - BE 1.2.0.3 x64 (Stable release):
Media Player Classic - BE 1.2.0.3 x64 (with installer)
Media Player Classic - BE 1.2.0.3. x64 (portable)
Standalone Filters Media Player Classic - BE 1.2.0.3 x64
Source Code:
Media Player Classic - BE 1.2.0.3 Source Code
ChangeLog
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 18th June 2013, 15:56   #1224  |  Link
wanezhiling
stable version
Old 18th June 2013, 17:30   #1225  |  Link
ontherocks
I am using System Default for Audio Renderer
4. http://www.rarewares.org/rja/Yes-Rou...96kHz_5.1.flac
5. 2 Channel high resolution files that show up as Multichannel PCM 5.1
(a). Sampling rate 96kHz, bit depth 24bit
(b). Sampling rate 192kHz, bit depth 24bit
Old 18th June 2013, 22:04   #1226  |  Link
filler56789
SuperVirus
filler56789's Avatar
VC1-I decoding without DXVA;
Interlaced VC-1 decoded thru software, finally?
Old 18th June 2013, 22:28   #1227  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Yes!
Old 18th June 2013, 22:54   #1228  |  Link
filler56789
SuperVirus
Originally Posted by alexins View Post
Yes!
Thanks for confirming
Congratulations, and again.
Old 19th June 2013, 02:13   #1229  |  Link
Aleksoid1978
Because Windows mix in format, that you set in Sound Settings. I think you settings is 5.1
Old 19th June 2013, 06:51   #1230  |  Link
Aleksoid1978
Hi fellas.
Please, test MPC Audio Renderer in WASAPI Exclusive mode.
What's done: in this test build, MPC Audio Renderer trying transmit data as is, without any changes (also it ignore system settings), in case if selected modes are supported in system.
For example:
we have: 5.1 24bit 48000
Decoder's output: 2.0 32bit 96000
Renderer's output: 2.0 32bit 96000
In this case we will have stereo only. And vice-versa:
we have: 2.0 24bit 96000
Decoder's output: 5.1 32bit 44100
Renderer's output: 5.1 32bit 44100
And again, only in case if your system is support such modes, if not - sound mixer will catch this up and you will see default behavior.
In case of success, bit-exact output will be performed from audio decoder to device.
P.S. - If something doesn't work - show me the screenshot of "Status" tab in MPC Audio Renderer preferences window.
http://aleksoid.voserver.net/MPC-BE/...I_EXCLUSIVE.7z
Old 19th June 2013, 06:52   #1231  |  Link
ontherocks
Yes you are right.
Which one should I choose then?
Old 19th June 2013, 07:05   #1232  |  Link
Aleksoid1978
Yes you are right.
Test this build http://aleksoid.voserver.net/MPC-BE/...I_EXCLUSIVE.7z
First step - select MPC Audio Renderer on Options->Output->Audio Renderer. in MPC Audio Renderer select WASAPI Exclusive mode.
Old 19th June 2013, 07:09   #1233  |  Link
You should congratulate and thank the good people at ffmpeg for implementing it.
Old 19th June 2013, 07:17   #1234  |  Link
madshi
How's performance, compared to the MS VC-1 decoder?
Old 19th June 2013, 08:02   #1235  |  Link
bozek
Originally Posted by wanezhiling View Post
stable version
Finally, thx guys!
bozek is offline   Reply With Quote
Old 19th June 2013, 08:30   #1236  |  Link
Its faster on some samples, slower on others. Frame-Interlaced and Progressive samples are slightly faster (~10%), field-interlaced are same speed or even slightly slower.
However its not bit-exact because some loop filtering is still missing, and there are some VC1 samples that don't work yet.
You can turn off the WMV9 DMO in LAV for a direct comparison.
Old 19th June 2013, 12:43   #1237  |  Link
SamKook
It doesn't output to the same format for me:
My audio card support up to 192KHz(I tried setting it at 48KHz instead and it dindn't change anything) and 24bit from what I understand: http://ca.asus.com/en/Multimedia/Aud...specifications
i7 2600K@4.7 watercooled and 2x EVGA GTX 760 in SLI with Corsair 16Gb 1600 (2 4x2 kit) on Asrock P67 Extreme4 Gen 3 with Intel 530 240Gb SSD running Win7 x64 on 3x ASUS VS239H-P 23"
SamKook is offline   Reply With Quote
Old 19th June 2013, 12:45   #1238  |  Link
Aleksoid1978
You use my test build ?
Old 19th June 2013, 12:50   #1239  |  Link
SamKook
I did
Old 19th June 2013, 22:04   #1240  |  Link
ontherocks
With the settings as mentioned in this post, I am able to obtain bit-exact playback with wav files. But the issue remains the same with hi resolution lossless wma files.
Example wma files could be obtained from here
ftp://www.unipheyemusic.com/audio/TestPageSamples
here
http://www.gimell.com/recording-free...wnloads-1.aspx
and here
http://www.gimell.com/recording-free...wnloads-2.aspx
