Old 17th December 2016, 17:46   #2721  |  Link
pinterf
Originally Posted by Myrsloik View Post
Why u use offset float 4 uv? Whyyyyyy?
To tell the truth I didnt know. I had no experience or prejudice about these expert formats. That's why I mentioned 'now' because you guys who have the knowledge, can propose the right way, it's not too late.
pinterf is offline
Old 17th December 2016, 18:29   #2722  |  Link
jpsdr
@feisty2
I'm doing the 16bits for now, i'll see for the floats latter.
@pinterf
I don't understand. I thought you said all the planes in floats were 0.0-1.0, so the U/V planes are also the same, or have i missed something (because of some english part i may have misunderstood) ?
jpsdr is offline
Old 17th December 2016, 19:06   #2723  |  Link
pinterf
Yes. All planes are 0-1.0 at the moment. But it seems that this is unusual.
pinterf is offline
Old 18th December 2016, 01:13   #2724  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Use -0.5 to 0.5 for UV and it'll match VS. Will make compatibility so much easier...
Myrsloik is offline
Old 18th December 2016, 13:00   #2725  |  Link
jpsdr
@feisty2
I have a question, just to ask if it's normal :
In evalFunc_0 you use prescreener >=2 only if pixelsize=1, wich is normal, but the way the tests are made, if you ask prescreener=2 with pixelsize>1, you fall in "no prescreener". Isn't better to go back to "original" instead ? I mean, somehow you have asked for a prescreener. But in that case, the constructor/Init would have to be adjusted according to this.
jpsdr is offline
Old 19th December 2016, 08:33   #2726  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by jpsdr View Post
@feisty2
didn't quite get what you were saying... (not sure what you meant by "go back to original")
anyways, pscrn could only be 0 or 1 for high bitdepth samples (as new prescreeners were trained for byte inputs). 2 is illegal for them.
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline
Old 19th December 2016, 09:35   #2727  |  Link
pinterf
I note that GScriptClip is incompatible with avs+ mt, with mode 2 not work at all and with mode 3 gave random scriptcilp errors
This was not forgotten, but I cannot help with it right now, could you post a test script and a hint what is special in GScriptClip (I have read some info about it but it is still not clear for me, never used)
pinterf is offline
Old 19th December 2016, 10:15   #2728  |  Link
jpsdr
@pinterf
Let me know what you think you'll be doing in final, and if you're doing -0.5/+0.5 for UV, confirm that a PlaneToY will still produce 0.0/1.0.
@feisty2
Ok.
I mean, actualy in the code, from what i've understood, if you've set a value of 2 for the prescrener with high bitdepth, it switches to 0. Maybe it may switche to 1. Just a little thought.
jpsdr is offline
Old 19th December 2016, 10:34   #2729  |  Link
feisty2
I'm Siri
feisty2's Avatar
@feisty2
Ok.
it should pop out an error message, not silently switch to another mode without notifying the user
feisty2 is offline
Old 19th December 2016, 11:25   #2730  |  Link
pinterf
@pinterf
Good catch, I was thinking about the same theoretical problem. I wonder if VS has special treatments for this in ShufflePlanes, but I don't think so.
pinterf is offline
Old 19th December 2016, 11:58   #2731  |  Link
Myrsloik
Myrsloik's Avatar
Any float value is always valid (except nan and inf) so no special handling at all. If the user wants weird luma they can have it.
There's also no guarantee that the luma channel stays in the 0-1 range so it doesn't matter.
Myrsloik is offline
Old 19th December 2016, 12:22   #2732  |  Link
real.finder
ColorBars(width=640, height=480, pixel_type="yv12")
srestore
Prefetch(6)
it used in Srestore and others
See My Avisynth Stuff
real.finder is offline
Old 19th December 2016, 13:24   #2733  |  Link
jpsdr
Well, let me know the final result of float decision, it will decide if i work or not to use float format in nnedi3.
The luma (or grey) plane in nnedi3 is clipped to 0.0-1.0 (and chroma planes are clipped to -0.5/+0.5). So, if you split an YUV format in 3 Y,U,V planes, and feed them separately in nnedi3, and the splitted plane U,V are in -0.5/+0.5 instead of 0.0-1.0 usual grey plane, your result will be messed up. So, if a splitted/extracted planar chroma plane is not shifted to match an usual Y/grey plane, you can't properly use nnedi3 in float format without adding a parameter to specify the the range of the float of the "grey" planar.
For now, even with the code of vapoursynth, i'm still unable to make it work with 16 bits....
jpsdr is offline
Old 19th December 2016, 13:35   #2734  |  Link
feisty2
I'm Siri
feisty2's Avatar
NO!!!
WHYYYYYYYYYYYY DID YOU DO THAT???
overflow is practically nonexistent to floating points, the MAIN reason to use floating point samples is to avoid clipping to have a more mathematically correct result.
CLIPPING IS TOXIC
feisty2 is offline
Old 19th December 2016, 14:18   #2735  |  Link
pinterf
srestore
Prefetch(6)
Could you try this one?
GRunT-1.0.2 (avisynth+ and 2.6, x86 and x64)
I suppose I only made it self register as a NICE_FILTER for Avisynth+.
That means that it doesn't run under avs 2.5x.
And if I had work with it, I made a 64bit version also.
pinterf is offline
Old 19th December 2016, 14:32   #2736  |  Link
jpsdr
Originally Posted by feisty2 View Post
NO!!!
Heu... Sorry, i've done nothing yet, take a look at your nnedi3.cpp lines 338, 641.
Did i misunderstood something ?
jpsdr is offline
Old 19th December 2016, 14:39   #2737  |  Link
feisty2
I'm Siri
feisty2's Avatar
https://github.com/dubhater/vapoursy...src/nnedi3.cpp
correct link
feisty2 is offline
Old 19th December 2016, 14:46   #2738  |  Link
jpsdr
Ok, thanks. But i'm still struggling with integer for now...
Edit :
If you have any idea/comment about the potentiel issue i've posted in the nnedi3 thread.
jpsdr is offline
Old 19th December 2016, 23:13   #2739  |  Link
real.finder
it show random things in the top of frame
Old 21st December 2016, 20:01   #2740  |  Link
pinterf
Yes, there is garbage. I was blind or I don't know. But it seems to be a very hard problem, at least haven't seen those avisynth internal parts that I have to debug now. First I'm struggling with the source of those hieroglyphs, which show: "ERROR: I don't know what 'current_frame' means." (Put this line at the beginning of the script: SetLogParams("log.txt", LOG_DEBUG))
And why it appears: ScriptClip errors (exception text with source module and line number) are overlayed on the current frame.
For some reason when formatting the error message, the C++ variadic parameter list (va_list) becomes corrupt between calls or after using vsnprintf. But only in this case. Now I'm reinstalling my VS2015.
But that is only the problem of the weird error message rendering. The real problem is the scope of variables, this plugin sets global paramers run-time, and this is somehow different in AVS+ than is classic AVS.
pinterf is offline
