#20081 | Link |
![]() Join Date: Oct 2001
Yeah. But I don't want to populate a huge window with options that are rarely used -- when there are others more important. If I added everything to that window -- it would require two monitors to see them.
If someone likes to disable the loop... they just have to set it in the INI and forget it. How often do you think someone with that preference is going to change it? So why have it taking up space in an area that is meant for common SETUP changes? |
#20082 | Link | |
#20085 | Link | |
#20087 | Link |
Monsters, inc - 480i
Is it possible, when using SmoothDeinterlace on a soft-telecined 480i source with the IVTC check box unchecked in the setup dialoge, that the result of the encode will be inverse telecined finally? It seems so, because the playback of the resulted m2ts in powerdvd 14 was so stuttering (due to codec "issues" of the player) as if it was one of my inverse telecined results of the past. With the other deinterlacers available I have no such an issue on a soft telecined source.
Please find enclosed my BDREBUILDER.INI. Thank you for the help in advance! |
#20088 | Link | |
#20089 | Link |
Please check my avs regarding the issue above. I have checked it also, but nothing seems unproper to me in the avs. Unfortunately, the result is stalling so much in Powerdvd as it were inverse telecined. I hope you can recommend something to find the reason.
#20091 | Link |
Just completed a full disc backup to BD5 of the Blu-ray Walking With Dinosaurs. This is a multi-m2ts disc type Blu-ray. (5 m2ts's for the main movie)
I chose to keep only 2 of the 11 subtitle tracks for the main movie, blanking 3 to 11. When I check the "WORKFILES" folder, only the first m2ts file of the movies .mpls file has the subtitles blanked, represented by a 1KB .sup file for the blanked ones. But when I check the other 4 m2ts files that are part of the main movie, they all have their .sup files with sizes ranging from 500KB up to 32,712KB. So it appears BD-RB is not blanking all the .sup files for each .m2ts files associated with a given .mpls file. |
#20092 | Link | |
#20093 | Link | |
I agree that some people would want it to loop, especially for promo/marketing stuff. But for the average user, wanting to simply pare down a BD disc to just the movie itself, I would imagine that they just want to watch the movie once at a time.
It's not a big deal; I'll just have to remember to reset that in the ini with each new version. I'm just surprised that the default is ON, not OFF. Quote:
#20094 | Link | |
The reason looping is the default is because it is the default in TSMUXER (and always has been). BD-RB has to make changes to the TSMUXER output (in the MovieObject.bdmv file) in order to stop it. That ability to stop it is a feature I added to BD-RB (a look at the changelog shows it added in July of 2010). I've found it easiest to simply keep your old INI file than to go back through the settings and hidden opts with every version. Since the INI isn't included in the new-release ZIP, you can simply extract the ZIP into the same folder as the older version -- and overwrite the contents. Your settings will remain unchanged. I've edited my INI into a structured format, keeping similar settings together, so I can easily find them for testing. It contains every possible hidden and SETUP-controlled setting. So I certainly don't want to have to edit it every time I make a new release. Last edited by jdobbs; 24th April 2014 at 14:10. |
#20095 | Link |
Well, I haven't gotten much feedback on the use of FRIMEncode for 2D (other than Shylock, and it isn't working for him). Since it appears to have no useful purpose I guess I'll remove it from the next release. There's no sense complicating the interface with a feature that nobody cares about.
#20096 | Link | |
![]() Maybe as more CPUs that support it come online more users will have some interest, and then it might be worth a good long look. Cheers. |
#20097 | Link | |
No big deal. |
#20099 | Link | |
It's the only choice for MVC though. Last edited by jdobbs; 24th April 2014 at 19:42. |
#20100 | Link |
Tried a 2D back up using FRIM. With QuickSync the framerate hovered around 200 fps however, when playing the resulting backup the movie picture kept twiching every few seconds throughout the movie. I had similar results with 3D back up using QuickSync (InMux enabled) - the back up was heavily pixelated.
![]() [04/24/14] BD Rebuilder v0.47.05 (beta) [19:37:21] Source: HUNGER_GAMES_2_CATCHING_FIRE_00000 - Input BD size: 20.16 GB - Approximate total content: [02:27:31.808] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 - Resuming from previously started job. [19:37:26] PHASE ONE, Encoding - [19:37:26] Processing: VID_00000 (1 of 1) - [19:37:26] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 212,231 frames - Bitrate: 3,408 Kbs - Using FRIMEncoder for AVC encoding - [19:37:26] Reencoding: VID_00000, Pass 1 of 1 - [19:59:24] Video Encode complete - [19:59:24] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [20:00:29]PHASE ONE complete [20:00:29]PHASE TWO - Rebuild Started - [20:00:29] Rebuilding AVCHD file Structure [20:01:40] - Encode and Rebuild complete [20:01:40] JOB: HUNGER_GAMES_2_CATCHING_FIRE finished. [Status] LABEL=HUNGER_GAMES_2_CATCHING_FIRE VERSION=v0.47.05 (beta) SOURCE_SIZE=21650927616 SOURCE_VIDEO_SIZE=21650927616 TARGET_SIZE=4686086144 REDUCTION=.216438123442664 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 REBUILD_COMPLETE=1 COMPLETED=1 [00000] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4686086144 RATE=3408 NSIZE=0 FLINK=0 MLINK=0 Last edited by Yordan5; 24th April 2014 at 21:28. |
