#13621 | Link | |
![]() Join Date: Oct 2001
Next time please open another thread. This thread is for bug reports only. Last edited by jdobbs; 21st November 2011 at 23:10. |
#13622 | Link | |
These were BD25 Full movie backups, and I did Cars 2 twice to verify. It doesn't happen on all backups though as I've had others that work fine like Season of the Witch (39.03). Reason I didn't report it is I thought the JVC was starting to fail, but after reading others are experiencing it, now know that's not the case. One other thing I would like to mention is Imgburn updated to 2.5.6.0 around the time I started experiencing this as well, so maybe it's the culprit. I'll downgrade imgburn to 2.5.5.0 and see if that changes anything. Edit: Downgraded Imgburn to 2.5.5.0, recreated and burned the iso and still experiencing the same issue, so Imgburn is not the cause. Edit2: Also confirmed ISO is playing fine in TotalMedia Theatre 5 so it looks like it may just be stand alones that are affected. Update: Just ran the same rip through dvdfab and am experiencing the same issue, so it appears bd rebuilder is not the issue, wish I had a 50gb bdrw to test the original image on, oh well. ![]() Last edited by rippn; 24th November 2011 at 12:36. |
#13625 | Link |
Moviewatcher666 has created a thread for this type of report here:
http://forum.doom9.org/showthread.php?t=162928 |
#13626 | Link | |
#13631 | Link | |
I may change it so they all get listed when you enter "Edit Mode". It depends how much of a pain it is. |
#13633 | Link | |
@omegaman7
My BD25 FULL DISC backup included all extras... (As one of my grandsons pointed out, this is a well-made, serious movie - strongly reminiscent of "The Goonies"). Last edited by setarip_old; 28th November 2011 at 06:28. |
#13635 | Link |
Hi, this is my first post. Sorry for my English.
My inspect: - Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - FFDSHOW VC-1 set "disabled", WMP11, Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.39.0.3, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok One encode: ----------------------- [19:51:10] BD Rebuilder v0.39.03 (beta) - Source: XMEN_FIRST_CLASS - Input BD size: 29,27 GB - Approximate total content: [02:11:42.936] - Target BD size: 4,36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [19:51:11] PHASE ONE, Encoding - [19:51:11] Processing: VID_00800 (1 of 1) - [19:51:11] Extracting A/V streams [VID_00800] - [20:16:44] Reencoding video [VID_00800] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 189.481 frames - Convert: 1280x720, 23,976fps, 189.481 frames - Bitrate: 3.697 Kbs - [20:17:26] Reencoding: VID_00800, Pass 1 of 2 - [21:11:18] Reencoding: VID_00800, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.39.03 (beta) - Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - FFDSHOW VC-1 set "disabled", WMP11, Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [21:11:24] - Failed video encode, aborted Last Encode: ----------------------- [20:54:43] BD Rebuilder v0.39.03 (beta) - Source: XMEN - Input BD size: 27,73 GB - Approximate total content: [01:44:20.295] - Target BD size: 4,36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:54:55] - Aborted per user request ----------------------- [20:55:05] BD Rebuilder v0.39.03 (beta) - Source: XMEN - Input BD size: 27,73 GB - Approximate total content: [01:44:20.295] - Target BD size: 4,36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:55:06] PHASE ONE, Encoding - [20:55:06] Processing: VID_00000 (1 of 1) - [20:55:06] Extracting A/V streams [VID_00000] - [21:32:56] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 150.097 frames - Convert: 1280x720, 23,976fps, 150.097 frames - Bitrate: 4.854 Kbs - [21:32:57] Reencoding: VID_00000, Pass 1 of 2 - [22:20:29] Reencoding: VID_00000, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.39.03 (beta) - Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - FFDSHOW VC-1 set "disabled", WMP11, Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [22:20:36] - Failed video encode, aborted I tried to encode with all the qualities (Good, Better, High, Highest) and always gives errors in the second pass. I installed the version of the post and I have configured the components following the post (http://forum.doom9.org/showthread.php?t=143716) http://www.jdobbs.net/freeware/ffdsh...0613_clsid.exe http://www.jdobbs.net/freeware/Matro....11.96.14).exe http://www.jdobbs.net/freeware/Avisynth_258.exe I tried to change the version of MatroskaSplitter03032011_(1.11.96.14) for this one http://www.jdobbs.net/freeware/MatroskaSplitter.exe. I did not get it to work the second pass. It has only worked with One pass CRF and One pass ABR. any idea? |
#13639 | Link | |
This afternoon I will try one encoding to 3.3GHz. For encoding I use linux with windows xp virtual machine to which I have assigned 4 cores. Does this affect? Thank you. |
