Old 3rd September 2012, 03:24   #15621  |  Link
@jdobbs
Am I correct that each of the following examples would result in NO processing for DTSExpress audio?:
1) No entry in .INI file for DTSX_ENABLE=
2) Entry in .INI file ;DTSX_ENABLE=1
3) Entry in .INI file DTSX_ENABLE=0
Correct. In fact any value other than DTSX_ENABLE=1 would result in no DTS Express processing. I usaully put a leader "#" when I want it disabled (#DTSX_ENABLE=1).
Old 3rd September 2012, 03:28   #15622  |  Link
Originally Posted by omegaman7 View Post
Been a while since I've posted here
I seem to have a selective memory. I apologize for asking something which has likely been answered at least once before. But at least asking it, I'm 10X more likely to remember it LOL!
I'm dealing with a disc/s that has a video commentary track with a secondary DTS(express) track. No matter what I seem to do to the settings, it removes it regardless. '
It's "The Pacific" if that holds any relevance
Is it because BD rebuilder believes it to be an exact duplicate track? Thereby not needing it?
You need to add DTSX_ENABLE=1 to the [Options] area of your config/ini file. It's disabled by default because the remuxing of the DTSX track is experimental and still doesn't work on some players. Wish I knew why... with a little luck maybe there is some smart person out there who can find what I can't. I've done a considerable amount of banging my head against that one.
Old 3rd September 2012, 03:29   #15623  |  Link
omegaman7
omegaman7's Avatar
I figured it was something like that. I just started looking for the option :S
Thanks!
Old 3rd September 2012, 14:27   #15624  |  Link
bassnut
That's a different error... the other one was an "overflow error" (00006) and yours is a "subscript out of range" error (00009). I believe that can only happen if the original is corrupt and one of the internal MPLS's indexes is wrong, but I'll double check. Hmm... odd that these are popping up all at once. That code is executed for every full backup... and it is a small section of code.
I wouldn't trust an MPLS that got an error. That means it was never updated with new information (like a change in video type, audio type, etc). If BD-RB is updating it, that means it shouldn't match the original after updating... BD-RB doesn't attempt to update MPLSs that don't require changes in the rebuild. You'd have to be extremely lucky for everything to "fall into place".
Yup played the disk on Sat and it hangs .... Black screen right before the play menue comes on (LG BD551). I did test this on my PC and the disk did work, menue and all chapters(TMT3), never had a chance to test it on my Sony S360 before leaving home Friday but will try when I get home.
bassnut is offline   Reply With Quote
Old 3rd September 2012, 16:28   #15625  |  Link
dfsooner
IGS stream in menus problem resurfaced
Originally Posted by dfsooner View Post
I have a number of selections I have authored with TMPgenc Authoring Works 4 (football games, actually) where I have created menus to select by quarters. When I compress them with BD_Rebuilder the menus no longer function. The m2ts files are compressed fine, however, (along with the menu file which is also m2ts).
TMPgenc reencodes all the original video to AVC.
The original plays fine with TMT3, but the reduced copy does not.
Is it your intention to make bd_rb work with selections not authored by the movie houses? If not, I understand.
One thing I did notice when comparing the before and after with BDedit is that the .clpi file for the BD-RB output is missing the IG stream. I believe this has the menu items.
JDobbs,
I believe you put a workaround in 37.04 for this but I have encountered it again. I have a BD authored with TMPGenc Authoring Works 5 that contains 5 m2ts files one of which is the menu. It is 302MB and the menus did not work after BDRB processing. I noticed the MIN_M2TS_SIZE parameter in Hidden Opts has a default of 100MB, so I figure if I changed it to 400 it would bypass processing of the menu. It didn't. Could something have changed to effectively ignore that option? When I enter it into BDREBUILDER.INI, should it have shown up in the .inf file? It doesn't.
dfsooner is offline   Reply With Quote
Old 3rd September 2012, 16:37   #15626  |  Link
JDobbs,
If you have DTSX_ENABLE=1 in your INI, try setting it to "0". That flag also instructs BD-RB to attempt to demux/remux IGS streams.
Old 3rd September 2012, 16:52   #15627  |  Link
dfsooner
I don't use that option (see below).
FYI. When I replaced the .m2ts, .clpi, and .mpls files with the originals, everything plays fine.
[Options]
VERSION=0.41.0.1
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=8032
PRIORITY_CLASS=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;fra;ger;spa;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
AUTO_BLANK=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
QUICK_EXTRAS=0
UNMASK_CHAPTER=1
COMPLETION_BEEP=1
DGDECNV=0
MIN_M2TS_SIZE=400
[Paths]
WORKING_PATH=D:\BD_REBUILDER WORKFILES\
SOURCE_PATH=F:\OU FOOTBALL\GAMES\2012\01 UTEP\
Old 3rd September 2012, 17:15   #15628  |  Link
greslogo
I seem to be having issues with Battleship_DOM, using current BDR and the previous version (I just upgraded, yesterday. Movie Only.
Ripped using the latest AnyDVDV.
[09/03/12] BD Rebuilder v0.41.01 (beta)
[11:12:06] Source: BATTLESHIP_DOM_PLAYLIST_00800
- Input BD size: 25.85 GB
- Approximate total content: [02:11:21.915]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Decoding/Frame serving: DGDecNV [2-way]
- Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640
- Resuming from previously started job.
[11:12:09] PHASE ONE, Encoding
- [11:12:09] Processing: VID_00131 (8 of 47)
- [11:12:09] Reencoding video [VID_00131]
- Rate/Length: 23.976fps, 17,414 frames
- Bitrate: 19,358 Kbs
- [11:12:09] Reencoding: VID_00131, Pass 1 of 1
- [11:25:18] Video Encode complete
- [11:25:18] Processing: VID_00110 (9 of 47)
- [11:25:18] Extracting A/V streams [VID_00110]
- [11:25:28] Reencoding video [VID_00110]
- Rate/Length: 23.976fps, 2,803 frames
- Bitrate: 22,326 Kbs
- [11:25:28] Reencoding: VID_00110, Pass 1 of 1
- [11:27:35] Video Encode complete
- [11:27:35] Processing: VID_00132 (10 of 47)
- [11:27:35] Extracting A/V streams [VID_00132]
- [11:27:44] Reencoding video [VID_00132]
- Rate/Length: 23.976fps, 2,522 frames
- Bitrate: 18,791 Kbs
- [11:27:44] Reencoding: VID_00132, Pass 1 of 1
- [11:29:33] Video Encode complete
- [11:29:33] Processing: VID_00111 (11 of 47)
- [11:29:33] Extracting A/V streams [VID_00111]
- [11:29:39] Reencoding video [VID_00111]
- Rate/Length: 23.976fps, 601 frames
- Bitrate: 20,685 Kbs
- [11:29:39] Reencoding: VID_00111, Pass 1 of 1
- [11:30:06] Video Encode complete
- [11:30:06] Processing: VID_00133 (12 of 47)
- [11:30:06] Extracting A/V streams [VID_00133]
- [11:30:27] Reencoding video [VID_00133]
- Rate/Length: 23.976fps, 9,239 frames
- Bitrate: 18,997 Kbs
- [11:30:27] Reencoding: VID_00133, Pass 1 of 1
- [11:37:08] Video Encode complete
- [11:37:08] Processing: VID_00112 (13 of 47)
- [11:37:08] Extracting A/V streams [VID_00112]
- [11:37:16] Reencoding video [VID_00112]
- Rate/Length: 23.976fps, 1,708 frames
- Bitrate: 19,072 Kbs
- [11:37:16] Reencoding: VID_00112, Pass 1 of 1
- [11:38:30] Video Encode complete
- [11:38:30] Processing: VID_00134 (14 of 47)
- [11:38:30] Extracting A/V streams [VID_00134]
- [11:38:45] Reencoding video [VID_00134]
- Rate/Length: 23.976fps, 5,286 frames
- [11:38:45] Reencoding: VID_00134, Pass 1 of 1
- [11:42:34] Video Encode complete
- [11:42:34] Processing: VID_00113 (15 of 47)
- [11:42:34] Extracting A/V streams [VID_00113]
- [11:42:43] Reencoding video [VID_00113]
- Rate/Length: 23.976fps, 2,241 frames
- Bitrate: 18,933 Kbs
- [11:42:43] Reencoding: VID_00113, Pass 1 of 1
- [11:44:20] Video Encode complete
- [11:44:20] Processing: VID_00135 (16 of 47)
- [11:44:20] Extracting A/V streams [VID_00135]
- [11:44:58] Reencoding video [VID_00135]
- Rate/Length: 23.976fps, 18,450 frames
- Bitrate: 19,432 Kbs
- [11:44:58] Reencoding: VID_00135, Pass 1 of 1
- [11:58:58] Video Encode complete
- [11:58:58] Processing: VID_00114 (17 of 47)
- [11:58:58] Extracting A/V streams [VID_00114]
- [11:59:04] Reencoding video [VID_00114]
- Rate/Length: 23.976fps, 496 frames
- Bitrate: 19,791 Kbs
- [11:59:04] Reencoding: VID_00114, Pass 1 of 1
- [11:59:28] Video Encode complete
- [11:59:28] Processing: VID_00136 (18 of 47)
- [11:59:28] Extracting A/V streams [VID_00136]
- [11:59:37] Reencoding video [VID_00136]
- Rate/Length: 23.976fps, 2,166 frames
- Bitrate: 19,805 Kbs
- [11:59:37] Reencoding: VID_00136, Pass 1 of 1
- [12:01:07] Video Encode complete
- [12:01:07] Processing: VID_00115 (19 of 47)
- [12:01:07] Extracting A/V streams [VID_00115]
- [12:01:14] Reencoding video [VID_00115]
- Rate/Length: 23.976fps, 1,275 frames
- Bitrate: 20,214 Kbs
- [12:01:14] Reencoding: VID_00115, Pass 1 of 1
- [12:02:09] Video Encode complete
- [12:02:09] Processing: VID_00034 (20 of 47)
- [12:02:09] Extracting A/V streams [VID_00034]
- [12:02:36] Reencoding video [VID_00034]
- Rate/Length: 23.976fps, 12,227 frames
- Bitrate: 19,000 Kbs
- [12:02:36] Reencoding: VID_00034, Pass 1 of 1
- [12:11:26] Video Encode complete
- [12:11:26] Processing: VID_00116 (21 of 47)
- [12:11:26] Extracting A/V streams [VID_00116]
- Error in attempt to extract audio/subs.
- SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
[12:11:35] - Failed to retrieve audio, aborted
I get 2 popups
tsmuxer.exe has stopped working
MPEG1 not supported
greslogo is offline   Reply With Quote
Old 3rd September 2012, 18:12   #15629  |  Link
Ch3vr0n
- Target BD size: 22.95GB
I get 2 popups
MPEG1 not supported
I hotly doubt that is an original disc. The volume name is not one studios would use, the source size also isn't right. Mine is 35GB + while yours is barely 25GB, combine that with that mpeg1 error and your looking at a downloaded movie most likely. Blurays don't use the MPEG1codec but among others MPEG2!!!
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
Old 3rd September 2012, 18:16   #15630  |  Link
greslogo
This was a rental disc. I am rebuilding the Movie only. It was also restarted.
Old 3rd September 2012, 18:39   #15631  |  Link
Ch3vr0n
Rental discs don't use discnames like that either, i don't believe that it an original disc. Rental or storebought neither use a discname like that. Restarting a job won't give an error like that either.
Old 3rd September 2012, 18:41   #15632  |  Link
omegaman7
omegaman7's Avatar
Indeed. I've never seen PLAYLIST in the disc title. I'd probably never rename it to that either. Unless to remind myself of a good working playlist.
Old 3rd September 2012, 18:46   #15633  |  Link
DVD Maniac
Is it possible you have set a large value for MIN_PLAYLIST_MINS (minimum playlist minutes) in the config file? Normally any playlist with over 15 minutes of content will be listed as a choice.
Assuming the config file is "BDREBUILDER.INI" (Sorry to sound like the div kid @ school but I have yet to play around with these settings) then no I haven't changed the default. Other episode discs with run times per episode of 50 mins or abouts always seem to be OK - this is the first time I have had this issue.
BTW, can you confirm this is the correct config file with which to set my own custom settings for each job?
DVD Maniac is offline   Reply With Quote
Old 3rd September 2012, 19:22   #15634  |  Link
greslogo
I have no reason to lie. I rent and rip Blue-Rays to hard drive using AnyDVD. Then BDR, Movie Only.
Folder Structure on a hard drive
THE_HUNGER_GAMES
-BDMW
-CERIFICATE
I'm currently running The Hunger Games through BDR
[12:40:40] Source: THE_HUNGER_GAMES_PLAYLIST_00800
- Input BD size: 36.92 GB
- Approximate total content: [02:22:33.378]
[12:40:43] PHASE ONE, Encoding
- [12:40:43] Processing: VID_00450 (1 of 1)
- [12:40:43] Extracting A/V streams [VID_00450]
- [12:48:53] Reencoding video [VID_00450]
- Rate/Length: 23.976fps, 205,076 frames
- Bitrate: 19,939 Kbs
- [12:48:54] Reencoding: VID_00450, Pass 1 of 1
Old 3rd September 2012, 19:26   #15635  |  Link
omegaman7
omegaman7's Avatar
I find it curious that the playlist is the same number. Though it is a common number I've noticed.
Old 3rd September 2012, 19:28   #15636  |  Link
Adbear
What settings are you using in AnyDVD, as your disc titles are definitely wrong
Adbear is offline   Reply With Quote
Old 3rd September 2012, 19:29   #15637  |  Link
Ch3vr0n
THE_HUNGER_GAMES
-BDMW
-CERIFICATE
Oh please you ain't fooling me. That's not an original discname for that either. And again the correct playlist for hunger games ain't 800. The only way ill believe that volume name is with a print screen of windows explorer with the disc inside the drive and not mounted in a virtual one. Combine that with what you're doing ripping rentals without owning the original yourself is pure movie piracy. I doubt you'll get any further "help" by anyone.
Old 3rd September 2012, 20:49   #15638  |  Link
greslogo
CH3vr0n... If you can't find an explanation, then please refrain from commenting. The discs are ripped and have been returned days ago (rental for new movies is 1 day, here, at Videotron). I do own some Blue Rays. Curious what I will get with those, as far as BDR is showing as name/playlist.
To Omegaman7/Adbear... I don't recall every seeing the playlist as part of the name withing BDR. before. The last time I ripped/BDR'd was at the end of June (very little worth renting these days).
If you look at the video file that it aborted on, it's no even part of the playlist which is more baffling.
AnyDVD is setup with the defaults. 7.8.0
Enable Blue Ray Support
Remove proh.....
Remove annoying.....
Disable BD Live
Remove Blue Ray region code-Automatic
Speedmenu is off.
Remove CD Digital Audio protection.
Old 3rd September 2012, 20:58   #15639  |  Link
greslogo
I just put Spaceballs into my drive and I am getting the same type of name/playlist in BDR
Old 3rd September 2012, 21:17   #15640  |  Link
Adbear
Well AnyDVD HD gets the name from the disc, so it's not AnyDVD HD that's putting it in.
If you try to play the original rips do they play back with full disc structure. Do they play the menu, then when you choose an option in the menu does the disc then play?
It appears to be BD rebuilder putting in the playlist text. I just tested making a 'movie only' on my system and the source comes up as 'A_TEAM_PLAYLIST_00801'
I don't normally do 'movie only' backups so I've never seen this before
You might want to check the file that's causing the encode to fail to see if it really is Mpeg1 or if the file is corrupt
