Old 6th September 2012, 12:48   #15661  |  Link
xterminater
oh ok thanks rippn, yes my friend send me that from hong kong.
for reference... http://www.yesasia.com/global/the-four-2012-blu-ray-hong-kong-version/1031343283-0-0-0-en/info.html
xterminater is offline   Reply With Quote
Old 6th September 2012, 13:32   #15662  |  Link
Originally Posted by xterminater View Post
jdobbs, was that question to me or rippn?
rippn. I asked because the filename looked like it was something created with multiAVCHD.
Old 6th September 2012, 13:36   #15663  |  Link
Originally Posted by AmigaFuture View Post
Braveheart Update:
Using the Movie and Menus (Auto-blank Extras) then selectively unchecking the extras I want produces my desired backup. It's the only mode that showed what I couldn't select to blank. Are you able to change that in the other modes? I checked with BD-25, encode High Speed. Now I'll use Highest, for quality.
Thank ~a lot~ for FORCE_NOENCODE=n!! I'm going to test more with that.
May I also suggest, when a SubProgram crashes that BD-RB _ makes _Sure_ that "tsmuxer.exe" is exited checking the process better? Even when the Info checker says all is good... I restarted a later than midnight process twice, that...come to find in other moemnts what the challenge was...I killed it, and got a good result when I was....more awake. :-D
What I noticed is that TsMuxer had locked a file in use even though BD-RB showed everything had quit. So the 2nd attempt, was futile because of that. I hadn't cleaned the trash, so the "locked" file (over a Gig) remained for 2 reset (sleepy) attempts...
When BD-RB runs a TSMUXER task, it waits for TSMUXER to close before it will continue (or exit). If it looks like TSMUXER is hung, BD-RB will tell the O/S to terminate it. The only exception to that would be if BD-RB completely crashed (not a BD-RB error screen -- just an O/S memory dump or BSOD).
Old 7th September 2012, 08:13   #15664  |  Link
Archer_Jonathan
now I have trouble, two BDs that won't work:
[20:51:44] PROCESSING BATCH FILE [4]
[09.05.12] BD Rebuilder v0.41.01 (beta)
[20:51:53] Source: HIDE_AND_SEEK
- Input BD size: 34,20 GB
- Approximate total content: [02:33:11.914]
- Target BD size: 22,95 GB
- Windows Version: 6.0 [6002]
[20:51:54] PHASE ONE, Encoding
- [20:51:54] Processing: VID_00800 (1 of 26)
- [20:51:54] Extracting A/V streams [VID_00800]
- [21:23:19] Reencoding video [VID_00800]
- Rate/Length: 23,976fps, 145.106 frames
- Bitrate: 23.195 Kbs
- [21:23:20] Reencoding: VID_00800, Pass 1 of 1
- [23:01:56] Video Encode complete
- [23:01:57] Processing audio tracks
- Track 4356 (deu): Keeping original audio
- [23:01:57] Multiplexing M2TS
[08:28:46] BD Rebuilder v0.41.01 (beta)
[08:28:46] BEGIN - BATCH SEQUENCE
[08:28:46] PROCESSING BATCH FILE [4]
[09.06.12] BD Rebuilder v0.41.01 (beta)
[08:28:55] Source: HIDE_AND_SEEK
- Resuming from previously started job.
[08:29:00] PHASE ONE, Encoding
- [08:29:00] Processing: VID_00800 (1 of 26)
- [08:29:00] Multiplexing M2TS
- [08:29:00] DoEncoding() 00061 2004
[08:29:02] - Failed to complete.
[08:29:02] BATCH ABORTED...
[08:29:02] END - BATCH SEQUENCE
[08:29:05] BD Rebuilder v0.41.01 (beta)
[08:29:05] BEGIN - BATCH SEQUENCE
[08:29:05] PROCESSING BATCH FILE [4]
[08:29:06] Source: HIDE_AND_SEEK
[08:29:08] PHASE ONE, Encoding
- [08:29:08] Processing: VID_00800 (1 of 26)
- [08:29:08] Extracting A/V streams [VID_00800]
- [08:29:08] DoEncoding() 00061 1603
[08:47:02] - Failed to complete.
[08:47:02] BATCH ABORTED...
[08:47:02] END - BATCH SEQUENCE
[09:12:06] BD Rebuilder v0.41.01 (beta)
[09:12:06] BEGIN - BATCH SEQUENCE
[09:12:06] PROCESSING BATCH FILE [4]
[09:12:15] Source: HIDE_AND_SEEK
[09:12:15] PHASE ONE, Encoding
- [09:12:15] Processing: VID_00800 (1 of 26)
- [09:12:15] Extracting A/V streams [VID_00800]
- [09:42:55] Reencoding video [VID_00800]
- [09:42:56] Reencoding: VID_00800, Pass 1 of 1
- [11:09:47] Video Encode complete
- [11:09:47] Processing audio tracks
- [11:09:47] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00800.meta
- Can't create file G:\ZZ REBUILDERWORKS\WORKFILES\TMP\BDMV\STREAM\00000.m2ts
[11:09:56] - Failed to build structure, aborted
[11:09:57] PROCESSING BATCH FILE [5]
[11:10:06] Source: CONTRABAND_G51
- Input BD size: 36,57 GB
- Approximate total content: [02:38:08.770]
[11:10:07] PHASE ONE, Encoding
- [11:10:07] Processing: VID_00023 (1 of 30)
- [11:10:07] Extracting A/V streams [VID_00023]
- [11:45:24] Reencoding video [VID_00023]
- [11:45:24] Reencoding secondary video [TRK_02]
- Rate/Length: 23,976fps, 157.725 frames
- Bitrate: 20.158 Kbs
- [11:53:06] Reencoding: VID_00023, Pass 1 of 1
- [13:32:23] Video Encode complete
- [13:32:23] Processing audio tracks
- Track 4353 (deu): Keeping original audio
- [13:32:23] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00023.meta
[13:32:31] - Failed to build structure, aborted
[13:32:32] END - BATCH SEQUENCE
[23:38:16] BD Rebuilder v0.41.01 (beta)
[23:38:17] BEGIN - BATCH SEQUENCE
[23:38:20] END - BATCH SEQUENCE
[23:40:42] BD Rebuilder v0.41.01 (beta)
[23:40:42] BEGIN - BATCH SEQUENCE
[23:40:43] PROCESSING BATCH FILE [1]
[23:41:00] Source: HIDE_AND_SEEK
[23:41:10] PHASE ONE, Encoding
- [23:41:11] Processing: VID_00800 (1 of 26)
- [23:41:11] Multiplexing M2TS
[23:41:25] - Failed to build structure, aborted
[23:41:25] PROCESSING BATCH FILE [2]
[23:41:26] Source: CONTRABAND_G51
[23:41:29] PHASE ONE, Encoding
- [23:41:29] Processing: VID_00023 (1 of 30)
- [23:41:29] Extracting A/V streams [VID_00023]
[23:43:27]PHASE ONE aborted by user request
[23:43:27] BATCH ABORTED...
[23:43:30] END - BATCH SEQUENCE
[23:44:46] BD Rebuilder v0.41.01 (beta)
[23:44:46] BEGIN - BATCH SEQUENCE
[23:44:46] PROCESSING BATCH FILE [1]
[23:44:57] Source: HIDE_AND_SEEK
[23:44:58] PHASE ONE, Encoding
- [23:44:58] Processing: VID_00800 (1 of 26)
- [23:44:58] Extracting A/V streams [VID_00800]
- [00:16:50] Reencoding video [VID_00800]
- [00:16:50] Reencoding: VID_00800, Pass 1 of 1
- [01:40:24] Video Encode complete
- [01:40:24] Processing audio tracks
- [01:40:24] Multiplexing M2TS
[01:40:32] - Failed to build structure, aborted
[01:40:32] PROCESSING BATCH FILE [2]
[09.07.12] BD Rebuilder v0.41.01 (beta)
[01:40:41] Source: CONTRABAND_G51
[01:40:41] PHASE ONE, Encoding
- [01:40:41] Processing: VID_00023 (1 of 30)
- [01:40:41] Extracting A/V streams [VID_00023]
- [02:17:09] Reencoding video [VID_00023]
- [02:17:09] Reencoding secondary video [TRK_02]
- [02:24:53] Reencoding: VID_00023, Pass 1 of 1
- [04:03:23] Video Encode complete
- [04:03:23] Processing audio tracks
- [04:03:23] Multiplexing M2TS
[04:03:32] - Failed to build structure, aborted
[04:03:32] END - BATCH SEQUENCE
[06:54:15] Source: HIDE_AND_SEEK
[06:54:16] PHASE ONE, Encoding
- [06:54:16] Processing: VID_00800 (1 of 26)
- [06:54:17] Multiplexing M2TS
[06:54:24] - Failed to build structure, aborted
any idea what I can do?
Archer_Jonathan is offline   Reply With Quote
Old 7th September 2012, 12:52   #15665  |  Link
RobertM
To start with the easy stuff... are you sure that you haven't filled up your HDD again? It happens quickly with BD work.
Old 7th September 2012, 13:27   #15666  |  Link
Error 00061 means your disc is full.
Clear up your hard drive, or add on more disc space.
Yep.
Old 7th September 2012, 15:56   #15667  |  Link
omegaman7
omegaman7's Avatar
I'll be receiving that message soon enough, If I don't get to burning LOL! Nah, I watch my drives like a hawk!
Old 7th September 2012, 22:33   #15668  |  Link
BD Rebuilder v0.42.01 (beta)
I've updated the first post of this thread with links to a new release of BD Rebuilder (v0.42.01). Changes for this version:
- Added an IMPORT function to the FILE menu.  This
  will allow you to import a movie from DVD, an MKV
  sources, or an MP4 source.  Handy for those who
  want to make BD backups from their alternative
  sources.  I've found that using H.264's superior
  encoding allows me to make perfect BD backups of
  my DVD-9 sources to BD-5 or create MKV or MP4
  material from a DVD source. It also allows me to
  upconvert to 720p or 1080p using AVISYNTH rather
  than the (sometimes) inferior upscaling of TVs or
  standalone players. Note: MP4 & MKV importing will
  require a source using H.264, MPEG, or VC-1.
- Added a new hidden setting, IMPORT_FOLDER, which
  allows you to select a location where any interim
  imported items are kept.  The default location is
  in the WORKING folder.  Note:  Items in the IMPORT
  folder are meant to only be used as a source for
  encoding via BD-RB since they may not necessarily
  be fully compliant with BD standards at that point.
- Enhanced the audio selection process so that when
  "Keep only one language" is enabled, BD-RB will
  select the track having the better likely potential
  quality (e.g. True-HD is selected over AC3).
- Corrected an issue in which very large timestamp
  values could result in failure and the error
  "CorrectMPLS() 00006  2403" during rebuild.
- Corrected an error in which resizing SD to 720p or
  1080p in a full backup would not properly update
  the MPLS.
- Corrected an issue in which 480p or 576p video
  used as a primary might be mishandled.  Note that
  this configuration is illegal per BD standards but
  is generally supported by players and can be found
  occasionally in reauthored sources.
- Corrected an issue in which sources with pulldown
  that were iVTC'd or those that were resized could
  under certain circumstances result in subtitles
  that were out of sync.
- Changed MKV output so no PGS subtitle is selected
  by default at playback.
- Updated WAVI.EXE to a newer version.  This should
  fix possible exceptions when reencoding WAV files.
Old 7th September 2012, 22:51   #15669  |  Link
omegaman7
omegaman7's Avatar
You're incredible Jdobbs! I may just love the new import function
Old 7th September 2012, 22:57   #15670  |  Link
Ch3vr0n
does this mean that with the import option i could simply import the VIDEO_TS folder and turn it into a blu-ray? Will the menu be kept or will it just pick the main movie & turn it into a BD? The output structure will be BD?
** edit ** Nvm the second question the menu option indicates movie only JFYI, don't see the proper command for the new hidden option IMPORT_FOLDER or wich variables are possible
Old 7th September 2012, 22:58   #15671  |  Link
Thanks! I kinda' like that one myself.
Old 7th September 2012, 23:03   #15672  |  Link
No menu... but I'm looking into that, not sure whether it is completely possible, though. I'm also looking at an option that can import multiple sources into a single disc and another that uses some simple authoring modes to create menus for the output.
Old 7th September 2012, 23:07   #15673  |  Link
Ch3vr0n
lol was modifying my post when you replied. take a look at the edit part (last part in specific)
Old 7th September 2012, 23:08   #15674  |  Link
soneca
+1
Thanks Jdobbs!
Old 7th September 2012, 23:09   #15675  |  Link
Example (in the config/ini file):
[Options]
IMPORT_FOLDER=C:\MYIMPORTS
You can get some speed increases by putting the import folder on a different drive than the working folder.
Old 7th September 2012, 23:19   #15676  |  Link
Ch3vr0n
If i read the changes.txt file correctly and your post that hidden command isnt tied to the new import function but is kind of a 2nd working folder?
Say i want to import a DVD movie that resides on my D:\ drive, BDRB is "installed on C:\ with the working folder C:\Temp. For best possible speed should i use D:\Temp or even better a 3rd (external) drive?
Just wanna make sure before i try this, cause if i read it correctly it will use the IMPORT_FOLDER as a read only source and the actual encoding happens in the working folder?
** edit ** just dit a test encode. Audio totally out of sync & subs didn't show up at all. Looks like i'll need to play arround a little ^^
Old 8th September 2012, 03:12   #15677  |  Link
thegame
thegame's Avatar
Thanks a lot jdobbs for this great update, now we just need PAL to NTSC conversion lol, but I was wondering is anyone having a problem getting BD-RB set to use DGIndexNV? I had it going on the last version and now I keep getting a run time error.
Edit, this is what I get and then it closes everything.
Run-Time error '5':
Invalid procedure call or argument
but like I said, the last version was working and using it.
thegame is offline   Reply With Quote
Old 8th September 2012, 03:16   #15678  |  Link
No, it isn't a second working folder. It is tied directly to the IMPORT function and is used specifically for it. It is better for the IMPORT folder to be on a different disc than your WORKING folder. But it isn't necessary. By default (no IMPORT_FOLDER specified) the IMPORT folder is called "IMPORTS" and will be created in the working folder on demand.
When the DVD is converted to BD format it's stored in the IMPORT folder. Then when you run BD-RB against it, the source is the folder under IMPORT. Importing usually takes only a few minutes (on my system it is usually 5 minutes, but it can depend on how many subtitles have to be converted).
I've done somewhere in the neighborhood of 30 or so DVDs in testing, and I haven't had any issues with audio sync or subtitles yet. But it is new, so there's always a chance there's something that needs tweaking. I added the necessary code to handle PAL sources -- but I haven't done any PAL testing.
Old 8th September 2012, 03:23   #15679  |  Link
Run-Time error '5':
I use DGDecNV it all the time. In fact I have it executing (doing a job) right now on my other computer. Error 5 indicates an invalid procedure call or argument. I'd need more information as to how & when you are getting it to identify what's causing it.
Old 8th September 2012, 04:24   #15680  |  Link
AmigaFuture
AmigaFuture's Avatar
TSMUXER task was still active and BD-RB's GUI was still there, only the info about everything being "Ok" was the last bit of the log. I should have displayed the log, ah...well. TSMUXER hasn't crashed in a while with my machine. I was able to kill the Nonfunctional TSMUXER and have BD-RB, without exiting, resume...once I could delete the locked large file.
If it happens again, I'll share the log and more.
