#1241 | Link |
Ok I copied the last command into a command prompt to execute it and came up with this..
C:\Users\Wayne Cierkowski\Desktop\Blu-Ray Tools\BD_Rebuilder\Tools>x264.exe "E:\ BLU-RAY WORKING\WORKFILES\VID_00123.AVS" --bitrate 4651 --level 4.1 --sar 1:1 -- aud --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --vbv-maxrate 17500 --filter 0,0 --subme 2 --me hex --bframes 3 --8x8dct --direct auto --weightb --trellis 0 --analyse none --threads auto --thread-input --progress --no-psnr --no-ssim --st ats "E:\BLU-RAY WORKING\WORKFILES\VID_00123.AVS.264.stats" --pass 1 --output NUL avis [info]: 1920x1080 @ 23.98 fps (8409 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.1 [0.1%] 8/8409 frames, 28.17 fps, 0.00 kb/s, eta 0:04:58 C:\Users\Wayne Cierkowski\Desktop\Blu-Ray Tools\BD_Rebuilder\Tools> Hope that helps.....
3 - VMC's - Each has a Quad processor with 8 GB's memory 2 - Dells 1 - Built from scratch Last edited by MR.WaynesWorld; 13th February 2009 at 00:42. Reason: Command was incorrect. |
#1242 | Link |
Never Grow Up !
Succes !
I earlier posted an error report on "Day after tomorrow". I got an error while backing up (find post). Later I saw this post from setarip_old about rebooting and from Atak_Snajpera about using WMV11. I realized I didn't boot after I installed everything neededfor your program. So I finally did. I can tell you now I also succesfully made a back up of my disk !!! Thanks for this great program and succes making it even better ! LOL See next post ! It worked for me ! [20:41:46] BD Rebuilder v0.18.8 (beta) - Source: DAT_F2 - Input BD size: 29,76 GB - Approximate total content: [02:03:40.412] - Target BD size: 4,27 GB - MOVIE-ONLY mode enabled [20:41:48] PHASE ONE, Encoding - [20:58:47] Collecting video information [00001] - Video: 1920x1080, 23,976fps - Bitrate: 3.473 Kbs - [20:58:48] Reencoding: VID_00001, Pass 1 of 2 - [20:58:48] Reencoding: VID_00001, Pass 2 of 2 - [23:38:56] Video Encode complete - [23:38:56] Extracting/reencoding audio tracks - [23:44:46] Multiplexing M2TS [23:49:40]PHASE ONE complete [23:49:40]PHASE TWO - Rebuild Started - [23:49:40] Rebuilding BD file Structure [23:57:07] - Encode and Rebuild complete [23:57:07]JOB: DAT_F2 completed. Thanks. Last edited by SvT; 13th February 2009 at 01:57. |
#1243 | Link |
@jdobbs, @BenieUK, @SvT
Regarding the problems encountered by "BenieUK", please see my post at: http://forum.doom9.org/showpost.php?...49&postcount=1 |
#1244 | Link |
Another successful backup,
![]() No issues on playback for Zack and Miri on my BX1. Used BD-RB v0.18.8 with included .x264, movie only, kept 640kbps AC3, BD-5 size. It could be considered slightly undersized at 4.13GB, but my guess is noone could tell the difference visually. Completed in 5 hours and 3 minutes on i7 920 at 2.67GHz. ![]() Thanks again jdobbs!! P.S. I do hope "shut down after completion" can be implemented soon since I no longer have to wait over night ( or over the next few days ) for my backup to finish, and that humming to shut down sound will greatly improve my sleep pattern.
#1245 | Link | |
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "D:\BDRIP\WORKFILES\VID_00000.AVS.264", fps=23.976, insertSEI, contSPS A_AC3, "D:\BDRIP\WORKFILES\AUD_00000_4352.AC3", lang=eng A_AC3, "D:\BDRIP\WORKFILES\AUD_00000_4354.AC3", lang=eng S_HDMV/PGS, "D:\BDRIP\WORKFILES\00000.track_4608.sup", fps=23.976, lang=eng S_HDMV/PGS, "D:\BDRIP\WORKFILES\00000.track_4609.sup", fps=23.976, lang=fra S_HDMV/PGS, "D:\BDRIP\WORKFILES\00000.track_4610.sup", fps=23.976, lang=spa S_HDMV/PGS, "D:\BDRIP\WORKFILES\00000.track_4611.sup", fps=23.976, lang=fra And here's the terminal output SmartLabs tsMuxeR. Version 1.8.4(b) http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976 0.0% complete H264 bitstream changed: insert pict timing and buffering period SEI units Decoding AC3 stream (track 2): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 6 Decoding AC3 stream (track 3): Bitrate: 448Kbps Sample Rate: 48KHz Channels: 6 Decoding PGS stream (track 4): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 6): Resolution: 1920:1080 Frame rate: 23.976 Decoding PGS stream (track 7): Resolution: 1920:1080 Frame rate: 23.976 H264 bitstream changed: insert SPS/PPS units 99.9% complete Processed 263474 video frames 100.0% complete Creation of Blu-ray playlist Creation of Blu-ray stream info and seek index Bitstream exception. It does not have to be! Plase contact the application support team for more information. update: I have the disc image on HD and it stuttered terribly. The original disc might have been scratched. I'll get another original and see what happens, because that error above looks like it has nothing to do with BD-RB. update 2: stuttering problem was caused by powerdvd, ignore previous update. Last edited by dmancornell; 13th February 2009 at 04:48. |
#1246 | Link |
i don't think of it as a bug more like a early software limitation but here it is: blackhawk down r1 main movie consists of 2 files 1 14gigs and 1 22gigs i can only select one or the other, deja vu r1 comes out so f***ed up don't even know where to start
it starts as a movie then some sort of a interactive menu kicks in then it goes back to main movie then menu and so on
#1248 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#1251 | Link | |
I have had the "Stricter AVCHD compliance for movie-only" checked since about this time |
#1252 | Link |
That's correct for the "High Quality" setting. That variable is set by the selection on the ENCODER SETTINGS menu. But I added a couple of "hidden" settings for testing (mainly to speed things up). I accidentally left one set in the INI I sent out in the v0.18.8 ZIP file.
#1257 | Link |
JDOBBS...I HAVE THIS ERROR:
[07:36:49] BD Rebuilder v0.18.8 (beta) - Source: HI-DEFINITION REFERENCE DISC 2008 BLU-RAY 1080I AVC LPCM7.1 - Input BD size: 16.56 GB - Approximate total content: [00:57:38.955] - Target BD size: 4.27 GB [07:36:50] PHASE ONE, Encoding - [07:36:53] Reencoding: VID_00000 (1 of 64) - [07:39:36] Reencoding: VID_00001 (2 of 64) - [07:40:13] Reencoding: VID_00002 (3 of 64) - [07:44:28] Reencoding: VID_00003 (4 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [07:44:41] Reencoding: VID_00004 (5 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [07:44:52] Reencoding: VID_00005 (6 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [07:45:10] Reencoding: VID_00006 (7 of 64) - [07:46:52] Reencoding: VID_00007 (8 of 64) - [07:50:38] Reencoding: VID_00008 (9 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [07:52:15] Reencoding: VID_00009 (10 of 64) - [07:56:29] Reencoding: VID_00010 (11 of 64) - [07:59:54] Reencoding: VID_00011 (12 of 64) - [08:05:57] Reencoding: VID_00012 (13 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [08:06:41] Reencoding: VID_00013 (14 of 64) - [08:11:04] Reencoding: VID_00014 (15 of 64) - [08:15:05] Reencoding: VID_00015 (16 of 64) - [08:19:33] Reencoding: VID_00016 (17 of 64) - [08:25:43] Reencoding: VID_00017 (18 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [08:26:02] Reencoding: VID_00018 (19 of 64) - [08:27:17] Reencoding: VID_00019 (20 of 64) - [08:38:06] Reencoding: VID_00020 (21 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [08:38:49] Reencoding: VID_00021 (22 of 64) - [08:47:10] Reencoding: VID_00022 (23 of 64) - [08:53:10] Reencoding: VID_00023 (24 of 64) - [08:57:26] Reencoding: VID_00024 (25 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [10:28:38] Reencoding: VID_00025 (26 of 64) - [10:29:52] Reencoding: VID_00026 (27 of 64) - [10:37:26] Reencoding: VID_00027 (28 of 64) - [10:43:22] Reencoding: VID_00028 (29 of 64) - [10:50:24] Reencoding: VID_00029 (30 of 64) - [10:55:23] Reencoding: VID_00030 (31 of 64) - [11:03:09] Reencoding: VID_00031 (32 of 64) - [11:05:01] Reencoding: VID_00032 (33 of 64) - [11:06:13] Reencoding: VID_00033 (34 of 64) - [11:11:41] Reencoding: VID_00034 (35 of 64) - [11:17:48] Reencoding: VID_00035 (36 of 64) - [11:21:48] Reencoding: VID_00036 (37 of 64) - [11:29:45] Reencoding: VID_00037 (38 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [11:30:26] Reencoding: VID_00038 (39 of 64) - [11:34:26] Reencoding: VID_00039 (40 of 64) - [11:41:23] Reencoding: VID_00040 (41 of 64) - [11:43:23] Reencoding: VID_00041 (42 of 64) - [11:48:09] Reencoding: VID_00042 (43 of 64) - [11:50:41] Reencoding: VID_00043 (44 of 64) - [11:54:29] Reencoding: VID_00044 (45 of 64) - [12:01:26] Reencoding: VID_00045 (46 of 64) - [12:05:30] Reencoding: VID_00046 (47 of 64) - [12:12:38] Reencoding: VID_00047 (48 of 64) - [12:15:43] Reencoding: VID_00048 (49 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [12:16:37] Reencoding: VID_00049 (50 of 64) - [12:22:27] Reencoding: VID_00050 (51 of 64) - [12:24:34] Reencoding: VID_00051 (52 of 64) - [12:32:42] Reencoding: VID_00052 (53 of 64) - [12:40:51] Reencoding: VID_00053 (54 of 64) - Reached retry limit. Aborting. - [12:41:50] Reencoding: VID_00054 (55 of 64) - [12:43:22] Reencoding: VID_00055 (56 of 64) - [12:45:36] Reencoding: VID_00056 (57 of 64) - [12:49:03] Reencoding: VID_00057 (58 of 64) - [12:53:35] Reencoding: VID_00058 (59 of 64) - Reached retry limit. Aborting. - [12:57:43] Reencoding: VID_00059 (60 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. - [13:07:27] Reencoding: VID_00060 (61 of 64) - [13:10:27] Reencoding: VID_00061 (62 of 64) - Reached retry limit. Aborting. - [13:12:46] Reencoding: VID_00062 (63 of 64) - [13:13:39] Reencoding: VID_00063 (64 of 64) - Reached retry limit. Aborting. - Reached retry limit. Aborting. [13:14:02]PHASE ONE complete [13:14:02]PHASE TWO - Rebuild Started - [13:14:02] Rebuilding BD file Structure - [13:14:09] CorrectMPLS() 00009 5 [13:14:11] - Aborted at user request ??? |
#1258 | Link |
The 21 times that you got "Reached retry limit. Aborting" is not a good sign... that means that each of those sections of the disc did not finish encoding. That would logically create a problem in the rebuild.
Something is causing X264 to fail in encoding those segments. I would suggest you step back to the previous version of X264.
jdobbs.softworks@gmail.com Last edited by jdobbs; 13th February 2009 at 14:29. |
#1259 | Link | |
Interestingly I have done a number of encodes with this version of X264 and haven't had a crash yet. Is there anything unique about your setup, codecs, configuration? What worries me is that the issue seems to go away by stepping back to X264 r1082... but all I have are reports, no personal experiences -- I guess I'll just change back in the next release, but I was hoping more info would come in that we could pass over to the X264 developers. I hate to lose all those speed improvements that have been implemented.
jdobbs.softworks@gmail.com Last edited by jdobbs; 13th February 2009 at 12:46. |
#1260 | Link |
Just as a test, could one of the folks who is experiencing "crashes" with X264, please download this version (r1112) and see if (by some chance) the issue has resolved itself?
A quick response would be appreciated. I'd like to put out a new BD-RB release. Thanks.
| Thread Tools | Search this Thread |
| Display Modes | |
