Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Thread Tools Display Modes
Old 31st July 2009, 01:29   #4241  |  Link
Furiousflea
Originally Posted by chudm View Post
did iron maiden with highest quality settings and trellis to bd 25 full backup (total content its around 3:30) but i get some blockiness sometimes only happens this with the newest beta, cause even on movies like matrix with high speed to bd25 never saw any blockiness (at least until beta 25.01), its this only hapenning to me?
Trouble with your posts on this "blocking" issue is that there are variables other than the different version of BDRB at play. Do a backup with version X, then do the SAME backup with version Y and let us know the results.
It's no good comparing different discs with different versions, doesn't give any concrete information. Blocking is common on the highspeed BD25 mode from what I can tell although your not using that now so thats one thing out the way. The "Iron Maiden" disc may well have the blocking on the original and so on.
Furiousflea is offline   Reply With Quote
Old 31st July 2009, 01:34   #4242  |  Link
chudm
yep ill redo the discs on the weekeng with severals versions and will let you know
chudm is offline   Reply With Quote
Old 31st July 2009, 02:10   #4243  |  Link
chudm
got this error with full backup to bd25 v25.04: with madagascar 2
[20:25:33] PHASE ONE, Encoding
- Error in attempt to multiplex: MUX_00003.meta
- Matroska parser: read error at pos 1161519104
[20:26:49] - Failed to build structure, aborted
Old 31st July 2009, 04:00   #4244  |  Link
Jake802
Hey guys! I recently installed the latest version of BDRebuilder. I can't get it to work. I am trying to backup Watchmen, the first thing I noticed it wont let me add the 3rd Audio Track It says...
XAUD_003 (2nd) DTS-HD, Stereo, English
Then when I goto run i get nothing it just sits there....
[22:55:51] BD Rebuilder v0.25.04 (beta)
- Source: WATCHMEN
- Input BD size: 39.79 GB
- Approximate total content: [04:30:56.990]
- Target BD size: 22.90 GB
- Resuming from previously started job.
[22:55:53] PHASE ONE, Encoding
- [22:55:53] Reencoding: VID_00524 (1 of 50)
- Encode failed. Retrying.
[22:57:14]PHASE ONE aborted by user request
[22:59:26] BD Rebuilder v0.25.04 (beta)
- Source: WATCHMEN
[22:59:27] PHASE ONE, Encoding
- [22:59:27] Reencoding: VID_00524 (1 of 50)
Ive never had these issues what the heck am I doing wrong?
Jake
SORRY GUYS forgot to mention I am trying Full Backup Custom Size,I did just notice when I do movie only I dont have any issues at all? Any ideas why?
I take that back that failed too....
[23:06:19] BD Rebuilder v0.25.04 (beta)
- Source: WATCHMEN
- Input BD size: 30.97 GB
- Approximate total content: [03:08:01.770]
- MOVIE-ONLY mode enabled
[23:06:20] PHASE ONE, Encoding
- [23:06:20] Extracting A/V streams [VID_00500]
- [23:16:18] Reencoding: VID_00500 (1 of 25)
- Reached retry limit. Aborting.
[23:19:28] - Failed video encode, aborted
Jake802 is offline   Reply With Quote
Old 31st July 2009, 04:22   #4245  |  Link
setarip_old
setarip_old's Avatar
Hi!
- Source: WATCHMEN
Whe you say, "It just sits there", it's quite likely that it's simply processing a large video - perhaps the main movie. Did you look at the bottom of the window to see if the number of frames was changing (as well as the "ETA")?
Old 31st July 2009, 04:25   #4246  |  Link
Jake802
Yea nothing changes it literally just sits there one of the times it came up encoding failed. But for the most part it just sits there.
Old 31st July 2009, 04:45   #4247  |  Link
Capsbackup
@Jake802;
The reason the 3rd audio track can't be added is you need to enable the PiP option with "PROCESS_SECONDARY=1" set in the INI. It is the secondary audio track for the PiP video track.( see the changes log ) BD-RB cannot decode DTS Express though.
This is not the issue though. The Watchman is VC-1, so you need to have Windows Media Player 11 and/or ffdshow decoder set correctly, I think VC-1 to wmv9.( worked for me )
Old 31st July 2009, 05:59   #4248  |  Link
Jake802
I tried like you said I got nothing! Thanks!
Old 31st July 2009, 06:18   #4249  |  Link
Sharc
@Jake802:
Is your video in VC-1 format?
If so, it may be field based interlaced for which there is still no free decoder available. Or worse even when VC-1 has some hybrid content of progressive and interlaced mix. I am not sure if DB-RB would copy intact (BD25) or blank (BD5,9) hybrid VC-1 content. If not, x264 may just abort.
Old 31st July 2009, 06:29   #4250  |  Link
Jake802
Thanks! I am thinking it is something to do with the disc itself. I just tried Green Lantern and that appears to be working I stopped it but got this far....
[01:26:15] BD Rebuilder v0.25.04 (beta)
- Source: GREEN_LANTERN_FIRST_FLIGHT
- Input BD size: 16.61 GB
- Approximate total content: [04:52:05.124]
[01:26:15] PHASE ONE, Encoding
- [01:26:15] Extracting A/V streams [VID_00021]
- [01:26:19] Keeping original video (no reencode)
- [01:26:40] Extracting A/V streams [VID_00020]
- [01:26:43] Keeping original video (no reencode)
- [01:26:47] Extracting A/V streams [VID_00023]
- [01:26:53] Keeping original video (no reencode)
- [01:26:59] Extracting A/V streams [VID_00017]
[01:27:00]PHASE ONE aborted by user request
Old 31st July 2009, 08:50   #4251  |  Link
apophis906
I found something interesting I would like to share. I was trying to make an SD back up of 'Dr Who Planet of the Dead'. All normal ways for decoding would cause the encoder to crash after a few seconds. I found that if I take the m2ts and extract the video and output it as mvk that I can then decode and encode that mkv fine.
apophis906 is offline   Reply With Quote
Old 31st July 2009, 15:22   #4252  |  Link
drmih
SD backup?? If you mean dvd resolution then it seems a bit pointless as it is released as a dvd as well.
Old 31st July 2009, 15:37   #4253  |  Link
Capsbackup
I have tested Transformers, region A, NTSC, full backup to BD-25, with keep PiP, burned to BD-RE for playback on Sony BX1. Video freezes after just a few seconds while the counter keeps going when playing the PiP track. If playing the regular movie track, the playback is fine. I do not have any other movies with a Dolby Digital Plus secondary audio track, the rest have DTS Express.
So I was successful with Batman Begins ( except audio is out of sync for the main movie, but PiP video and audio works fine ).
Unsuccessful with Beowulf and Transformers. ( both experience video freezing )
Old 31st July 2009, 16:10   #4254  |  Link
Kakashi Sensei
Your Green Lantern First Flight bluray doesn't need to be re-encoded the source is smaller then a BD-25 so BD-RB wont do anything with the Video.
Kakashi Sensei is offline   Reply With Quote
Old 31st July 2009, 16:12   #4255  |  Link
Kakashi Sensei
Make sure you have the right FFDshow version installed. I was pulling my hair out and had freezing/stuttering video and couldn't figure it out. Found out i wasn't using Ver 2661 of FFDShow. Changed to that version and fixed all my problems.
Old 31st July 2009, 17:07   #4256  |  Link
apophis906
Yes I know,but I am not going to buy the DVD when I already bought the Blu-ray. My point was in that I had a way to deal with the interlaced VC-1 that worked for me and thought it might help others in some way.
My main point was that I was having trouble with the same title dealing with the interlaced VC-1 and I found a way that I was able to decode it and not have a problem. All I know is that as long as the VC-1 was muxed as an m2ts that it would not work, once it was demuxed into an mkv on its own it decoded just fine.
Old 31st July 2009, 17:44   #4257  |  Link
Capsbackup
I do not have freezing video on any movies except PiP ones with PiP enabled. All other backups, movie only to BD-5 and full backups to BD-25 are fine. These same backups that don't work with PiP enabled do work properly without PiP enabled. So, for me, I don't believe that this is the issue.
Old 31st July 2009, 18:14   #4258  |  Link
drmih
But I think that this would only work if you are doing the movie only - I may be wrong. You can happily handle the discs using MakeMKV which will extract all of the tracks to mkv to process as you like but it was really the ability to make a blu-ray copy of the disc in entirety that is problemetic without switching codecs.
I still haven't got a clue why you're going to SD as the logic is that you could re-encode to a dvd-5 HD version.
Old 31st July 2009, 18:19   #4259  |  Link
drmih
@jdobbs
Is it possible to change the programme so that the message 'Audio and / or PGS size too large...' just records a warning? I am finding plenty of discs, particularly BBC ones, where there are lots of small files (~5Mb) which trigger this but still give a disc under the capacity if ignored. However, the programme just sits there waiting for you to click 'Yes' or 'No' which is a real pain if you set something going overnight.
Old 31st July 2009, 20:11   #4260  |  Link
@jdobbs
But it isn't just a warning. It is telling you that with the audio/sub selections you have made there is no room for the video...
I think you are saying that you are getting this on small files only. If so, I would suggest you select "Quicker Encode for Extras" -- as it uses a CRF value to encode and the smaller encodes aren't tied to the required size. It is adjusted with the main movie is encoded.
jdobbs.softworks@gmail.com
Thread Tools
