Old 10th March 2011, 16:28   #11481  |  Link
bassnut
Originally Posted by HatchetMan View Post
Same error occurring here with same title. Tried 2 different original copies ripped with AnyDVD HD and DVDFab HD Decrypter, BD-RB does not like!
Had a bit of time on my hands and thought I would give HP5 a go ....
I can confirm the 2 errors Movie only shows error"Selected source is not BD format"
Full disk shoes .......
[10:27:35] BD Rebuilder v0.37.05 (beta)
- Source: HP5_PHOENIX
- Input BD size: 44.42 GB
- Approximate total content: [05:03:47.266]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- Auto Quality: Good (Very Fast), Two Pass
- Target too small. Encode stopped.
I get the same errors wether i try encoding from the ripped files from my hard drive, AnyDVD HD 6.7.9.0 or directly from the disk.
bassnut is offline   Reply With Quote
Old 10th March 2011, 16:36   #11482  |  Link
rysktkr
blocking
Anybody experience the issue of blocking (see enclosed picture)? I am seeing this on most if not all encoding on bd rebuilder. I am using version 0.37.04 on windows xp. I followed recommendation 8. which will allow WMV11 codec to be used. That did not improve the situation. My encode settings are high quality, one pass abr, targeted to a BD-25.
rysktkr is offline   Reply With Quote
Old 10th March 2011, 17:06   #11483  |  Link
If you are getting blocking with output to BD-25, it is most likely a problem with the decoding. The bitrates involved in BD-25 are unlikely to ever result in blocking unless the source is super large (like 6 hours or more).
Run INSPECT.EXE -- I suspect that somehow the CODEC is a problem in the frame serving. It's possible that some other program you have installed in intercepting and using an inferior CODEC.
Old 10th March 2011, 17:52   #11484  |  Link
rysktkr
- Windows Version: 5.1 [2600]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3703, not recommended version
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- BD Rebuilder v0.37.0.4, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Could it be the version FFDSHOW?
Here is hopefully a still of the blocking.
Old 10th March 2011, 18:35   #11485  |  Link
setarip_old
setarip_old's Avatar
@rysktkr
Hi!
Yes.
Use the version linked to in Post #1 of this thread...
Old 10th March 2011, 22:52   #11486  |  Link
No, it has not been set.
But probably "Resize - 1080p to 720p" has been set. I don't think this would have interfered with the Alternate Mode backup because it has always worked with other sources before.
Tab CLIPINF: AVC, 1080i, 25, 16:9
Tab PLAYLIST: AVC, 1080i, 25
I think I'm getting close on this. Could you try this again without "Resize - 1080p to 720p" set and let me know how it behaves?
Old 11th March 2011, 14:56   #11487  |  Link
torque2k
I'll make a stupid comment here, see if it applies to your situ. I had run the anime 'Akira' through BD-RB, and was getting really bad blocking issues in the playback, even though it was to a BD-25. I went back through the settings, and found that the primary track was Japanese, and both the English and Japanese tracks were being kept as full quality DTS-HD, which was pushing the video down to something ridiculous like 150Kbps.
I decided to drop the Japanese track completely as a test, and that did the trick; the video came through at around 8000Kbps.
torque2k is offline   Reply With Quote
Old 11th March 2011, 15:17   #11488  |  Link
Elvis Gratton
Interlaced material
How can i encode interlaced source to obtain a file type MBAFF (interlaced result) ?
Or insert --interlaced to x264 cmd line...
DVD Rebuilder user
Elvis Gratton is offline   Reply With Quote
Old 11th March 2011, 16:06   #11489  |  Link
rysktkr
Well I now have the correct version of FFDSHOW and unfortuantely the blocking issue still exists. Not sure what to try next. Maybe, give one pass CRF encodeing a try?
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Old 11th March 2011, 16:52   #11490  |  Link
Originally Posted by Elvis Gratton View Post
???? If the source is interlaced the output will be interlaced unless you have set deinterlacing on.
If it doesn't have "--tff", "--bff", or "--fake-interlaced" in it already -- it shouldn't be there.
Old 11th March 2011, 17:01   #11491  |  Link
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Post your log and INF file from the encode. If you're keeping multiple HD audio tracks, its possible (as mentioned earlier) that there isn't any space left for the video.
Old 11th March 2011, 18:04   #11492  |  Link
rysktkr
I will have to get back to you tomorrow for that. As the log file was deleted. I will need to reencode.
Old 11th March 2011, 20:18   #11493  |  Link
larrsz
Bitter Old Geek
larrsz's Avatar
No Audio on some BDs
I am recording some movies from my tivo (1080i, 384kbps DD) which I remove commercials from and then use tsMuxer to convert them to BDs which works fine. This gives me a BD file of about 16GB for a 2 hr movie that plays fine when burned with imgburn to a BD disc.
Due to cost and since these are from TV channels (most have station ID's etc in the lower corners), I decided to use BDRB to reencode most of these to fit on BD-9 discs. However, I am getting no audio when using BDRB on these files. When I open the file in BDRB, I see the video and the audio, but the audio has a red "x" beside it and says AUD_001 AC3 Multi-Ch. Unknown. I can double click the "x" and it changes to a Windows Media player icon. However, no matter what I do I get a file out of BD-RB with no audio at all. Here is the MediaInfo results from the file I am trying to reencode. Suggestions?
General
Complete name : V:\tsMuxer\BD\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 13.0 GiB
Duration : 1h 38mn
Overall bit rate : 18.8 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 1h 38mn
Bit rate mode : Variable
Bit rate : 17.7 Mbps
Nominal bit rate : 65.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.285
Stream size : 12.2 GiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 270 MiB (2%)
larrsz is offline   Reply With Quote
Old 11th March 2011, 20:48   #11494  |  Link
Sharc
It doesn't help. It's enoded progressive 1080p/25.
Old 11th March 2011, 21:20   #11495  |  Link
hungryhorse
Audio Error Message
Ive just started to get an audio error(pic attached)
BD Rebuilder experienced an error 1801 [20:17:46] ReencodeAudio() 00075 1801
Can you please tell me what it is because Ive never had it before come up?
hungryhorse is offline   Reply With Quote
Old 11th March 2011, 22:07   #11496  |  Link
General
Format : BDAV
Duration : 1h 38mn
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 1h 38mn
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 1h 38mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Try going to the SETUP menu and click/add "und" to your audio selection list (undeterminted).
Old 11th March 2011, 23:15   #11497  |  Link
Sharc
Isn't this the same as I observed in my case? Interlaced sources are encoded progressive ....
Old 12th March 2011, 01:02   #11498  |  Link
I really can't tell -- all I got was a question about adding "--interlaced" to the command line.
Old 12th March 2011, 01:06   #11499  |  Link
Stereodude
FWIW, I found the same thing you did with v 0.37.03 (haven't tried any newer versions). Interlaced BD's are encoded as progressive. However, since my source was not untouched (already run through Clown BD to make it movie only) I did not post anything here. I eventually did the whole process manually instead of using BD Rebuilder.
Old 12th March 2011, 01:48   #11500  |  Link
I don't get it. I've done hundreds of interlaced sources... especially 720x480i and they all encode as interlaced.
I haven't had much opportunity to work on BD-RB the last few days. I'll run a 1080i/25fps source through tomorrow. If it encodes incorrectly I will fix it and hopefully get a version out either late tomorrow or Sunday.
