Old 9th August 2009, 17:47   #4481  |  Link
Adbear
Originally Posted by Kakashi Sensei View Post
I have a quick question. Trying to do a backup of Golden Compass RA North American BD. Problem is there are 2 vid sets. One 24GB that has just the main movie, the second has the main movie with a hard coded PiP. Is there a way i can just blank out the second m2ts so BD-RB will just take the main movie and keep the menus?
Thanks!
You could just move that file out of the folders completely then see if the original disc structure still works, if it does then you could just re-encode with it removed from the folders
Adbear is offline   Reply With Quote
Old 9th August 2009, 18:05   #4482  |  Link
chudm
Thanks!
that would be great if we can choose what to keep on the bluray or not, we will have to wait
chudm is offline   Reply With Quote
Old 9th August 2009, 18:29   #4483  |  Link
Thanks!
This is a "Bug Reports Only" thread. If you have a feature request, please put it in the "Feature Requests" thread. It's getting really hard to find bug reports here with all the extraneous discussions.
Old 9th August 2009, 19:38   #4484  |  Link
BD-Rebuilder v0.28.02 (beta)
Updated the first post of this thread with a new version of BD-RB (v0.28.02). Changes:
[v0.28.02]
- Updated the one-pass CRF routine to prevent a rare
  but possible "forever loop".
- Fixed an error introduced in v0.28.01 that could
  cause timing issues on some very small sources.
[v0.28.01]
- Added a Batch processing feature.  This allows you
  to queue up multiple jobs, especially useful when
  you decide to let BD-RB run overnight. Right-click
  in the batch area to see action options.
- Rewrote the MPLS update routines to better handle
  SubPath() updates related to remuxing of secondary
  audio and video streams. Also fixed the updating
  of pip_metadata() tables. This should correct the
  remaining issues with PiP video processing with
  the exception of DTS audio demuxing/muxing.
- Added a "hidden" option to force encoding (helpful
  when using filters) even when the source would fit
  in the output.  You can set it by adding the line
  "FORCE_ENCODING=1" to the "[Options]" area of the
  config file (INI).
- Updated some encode settings to ensure Blu-ray/4.1
  compliance for the "Highest Quality" mode.
- Upgraded the included X264 executable to r1198. This
  version includes "Macroblock Tree Rate Control". It
  should produce higher quality if you are using the
  "Better, High Quality, or Highest" encoding settings.
  Note: This is really cool -- Dark Shikari rules.
- Corrected an error in which the "Remove WORKFILES"
  option was not being correctly set at dialog startup.
Old 9th August 2009, 20:12   #4485  |  Link
Sharc
[v0.28.01]
  config file (INI).
Cool. Together with the .mkv intermediate step it helps a lot with difficult interlaced vc-1 sources.
Added:
v0.28.02:
But unfortunately the FORCE_ENCODING=1 in the [Options] section seems to have no effect. The small source is still skipped.
I can only force the encoding by setting the target size low ...
Old 9th August 2009, 20:56   #4486  |  Link
Added:
v0.28.02:
I guess I misunderstood. I didn't configure it to do the ones that weren't in the streams list.
Old 9th August 2009, 21:14   #4487  |  Link
Capsbackup
A big congrats jdobbs, PiP backup of Beowulf with BD-RBv2801 was a success!! No more freezing picture. Play back on my BX1 is absolutely perfect.
Your efforts and time spent to accomplish this is appreciated.
EDIT:
Very fast too! Approx. 2:08:00 for BD-RB to reencode, 5:00 to build image and 45:00 to burn with IMGBurn. Awesome!!
Old 9th August 2009, 22:38   #4488  |  Link
EDIT:
Good news. I've been burning the midnight oil trying to get it right...
Old 9th August 2009, 23:38   #4489  |  Link
dianasta
I'm working on full backup X_FILES_2 and getting the following error with v0.28.02
[18:22:37] BD Rebuilder v0.28.02 (beta)
  - Source:  X_FILES_2_US
  - Input BD size: 43.06 GB
  - Approximate total content: [04:33:28.683]
  - Target BD size: 22.46 GB
- Resuming from previously started job.
[18:22:40] PHASE ONE, Encoding
 - [18:22:40] Extracting A/V streams [VID_00012]
 - Error in attempt to extract audio/subs.
 - Reading buffer overflow. Possible container streams are not syncronized.
   Please, verify stream fps. File name: I:\BDMV\STREAM\00012.m2ts
[18:22:49] - Failed to retrieve audio, aborted
[18:23:11] BD Rebuilder v0.28.02 (beta)
[18:23:16] PHASE ONE, Encoding
 - [18:23:16] Extracting A/V streams [VID_00041]
 - [18:23:17] Reencoding: VID_00041 (1 of 38)
 - [18:23:17] Collecting video information
   - Video: 720x480, 29.970fps, 30 frames
 - [18:23:17] Reencoding: VID_00041, Pass 1 of 1
 - [18:23:20] Video Encode complete
 - [18:23:20] Reencoding audio tracks (if req'd)
 - [18:23:20] Multiplexing M2TS
 - [18:23:20] Extracting A/V streams [VID_00017]
 - [18:23:22] Reencoding: VID_00017 (2 of 38)
 - [18:23:22] Reencoding secondary video [TRK_02]
 - [18:23:24] Collecting video information
   - Video: 1920x1080, 23.976fps, 120 frames
 - [18:23:24] Reencoding: VID_00017, Pass 1 of 1
 - [18:23:30] Video Encode complete
 - [18:23:30] Reencoding audio tracks (if req'd)
 - [18:23:30] Multiplexing M2TS
 - [18:23:30] Extracting A/V streams [VID_00030]
 - [18:23:33] Reencoding: VID_00030 (3 of 38)
 - [18:23:33] Collecting video information
   - Video: 1920x1080, 23.976fps, 24 frames
 - [18:23:33] Reencoding: VID_00030, Pass 1 of 1
 - [18:23:35] Video Encode complete
 - [18:23:35] Reencoding audio tracks (if req'd)
 - [18:23:35] Multiplexing M2TS
 - [18:23:36] Extracting A/V streams [VID_00028]
 - [18:23:38] Reencoding: VID_00028 (4 of 38)
 - [18:23:38] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,515 frames
 - [18:23:38] Reencoding: VID_00028, Pass 1 of 1
 - [18:24:44] Video Encode complete
 - [18:24:44] Reencoding audio tracks (if req'd)
 - [18:24:45] Multiplexing M2TS
 - [18:24:46] Extracting A/V streams [VID_00031]
 - [18:24:50] Reencoding: VID_00031 (5 of 38)
 - [18:24:50] Collecting video information
   - Video: 1920x1080, 23.976fps, 2,088 frames
 - [18:24:50] Reencoding: VID_00031, Pass 1 of 1
 - [18:26:34] Video Encode complete
 - [18:26:34] Reencoding audio tracks (if req'd)
 - [18:26:34] Multiplexing M2TS
 - [18:26:35] Extracting A/V streams [VID_00034]
 - [18:26:39] Reencoding: VID_00034 (6 of 38)
 - [18:26:39] Collecting video information
   - Video: 720x480, 29.970fps, 11,285 frames
 - [18:26:39] Reencoding: VID_00034, Pass 1 of 1
 - [18:28:51] Video Encode complete
 - [18:28:51] Reencoding audio tracks (if req'd)
 - [18:28:51] Multiplexing M2TS
 - [18:28:53] Extracting A/V streams [VID_00004]
 - [18:29:15] Reencoding: VID_00004 (7 of 38)
 - [18:29:15] Reencoding secondary video [TRK_02]
 - [18:29:24] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,866 frames
 - [18:29:24] Reencoding: VID_00004, Pass 1 of 1
 - [18:30:47] Video Encode complete
 - [18:30:47] Reencoding audio tracks (if req'd)
 - [18:30:47] Multiplexing M2TS
 - [18:30:51] Extracting A/V streams [VID_00032]
 - [18:30:55] Reencoding: VID_00032 (8 of 38)
 - [18:30:55] Collecting video information
   - Video: 1920x1080, 23.976fps, 2,736 frames
 - [18:30:55] Reencoding: VID_00032, Pass 1 of 1
 - [18:32:54] Video Encode complete
 - [18:32:54] Reencoding audio tracks (if req'd)
 - [18:32:54] Multiplexing M2TS
 - [18:32:57] Extracting A/V streams [VID_00029]
 - [18:33:01] Reencoding: VID_00029 (9 of 38)
 - [18:33:01] Collecting video information
   - Video: 1920x1080, 23.976fps, 2,823 frames
 - [18:33:02] Reencoding: VID_00029, Pass 1 of 1
 - [18:35:11] Video Encode complete
 - [18:35:11] Reencoding audio tracks (if req'd)
 - [18:35:11] Multiplexing M2TS
 - [18:35:14] Extracting A/V streams [VID_00012]
[18:35:23] - Failed to retrieve audio, aborted
dianasta is offline   Reply With Quote
Old 10th August 2009, 00:00   #4490  |  Link
leChameleon
It looks like the last M2TS file in the list (of SLINGBLADE example you posted) massively undersized... by about 13GB. Are you sure it completed? Does is playback end-to-end?
Sometimes (especially when you use "Quick Encode for Extras") you may get to the largest of the files and find that there is way too much space available -- and the encoder "saturates". That means it hits its highest level of quality (QP=10) and refuses to use all the available space (as it would be wasted). I've see that happen before, but never to that level...
One way to check is to open up the .stats file and look at the values for Q for each frame. If you see a lot of "10s" in there -- you are saturating.
Here are the results from the same exact run, same settings, same machine, etc... with BD Rebuilder v0.26.03.
SLING_BLADE.INF BD Rebuilder v0.26.03
[Status]
LABEL=SLING_BLADE
VERSION=v0.26.03 (beta)
SOURCE_SIZE=49329246396
SOURCE_VIDEO_SIZE=48674899968
TARGET_SIZE=24117248000
REDUCTION=.482032866784011
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=49
REBUILD_COMPLETE=1
[00613]
AUDIO=1000
PGS=10111111111100000000000
M2TS_TARGET=15806352106
RATE=10385
NSIZE=15301140480
FLINK=0
MLINK=0
[00616]
AUDIO=1
PGS=111111111
M2TS_TARGET=123232589
RATE=2603
NSIZE=123113472
FLINK=-1
MLINK=0
[00630]
AUDIO=1
PGS=111111111
M2TS_TARGET=1058609701
RATE=2624
NSIZE=1058211840
FLINK=0
MLINK=0
[00631]
AUDIO=1
PGS=111111111
M2TS_TARGET=192892617
RATE=2613
NSIZE=192565248
FLINK=-1
MLINK=0
[00643]
AUDIO=1
PGS=111111111
M2TS_TARGET=208929734
RATE=2610
NSIZE=208637952
FLINK=0
MLINK=0
[00644]
AUDIO=1
PGS=111111111
M2TS_TARGET=181905044
RATE=2594
NSIZE=181721088
FLINK=0
MLINK=0
[00645]
AUDIO=1
PGS=111111111
M2TS_TARGET=554428188
RATE=2636
NSIZE=553758720
FLINK=0
MLINK=0
[00651]
AUDIO=1
PGS=111111111
M2TS_TARGET=85169978
RATE=2561
NSIZE=85112832
FLINK=0
MLINK=0
[00652]
AUDIO=1
PGS=111111111
M2TS_TARGET=111235107
RATE=2656
NSIZE=111095808
FLINK=0
MLINK=0
[00655]
AUDIO=1
PGS=111111111
M2TS_TARGET=105077920
RATE=2634
NSIZE=104792064
FLINK=0
MLINK=0
[00656]
AUDIO=1
PGS=
M2TS_TARGET=7904537
RATE=7902
NSIZE=7335936
FLINK=0
MLINK=0
[00658]
AUDIO=10
PGS=111
M2TS_TARGET=7883806
RATE=8159
NSIZE=7643136
FLINK=0
MLINK=0
[00659]
AUDIO=1
PGS=
M2TS_TARGET=172297581
RATE=12988
NSIZE=166877184
FLINK=0
MLINK=0
[00660]
AUDIO=1
PGS=
M2TS_TARGET=249089165
RATE=11360
NSIZE=241784832
FLINK=0
MLINK=0
[00661]
AUDIO=1
PGS=
M2TS_TARGET=111069257
RATE=12823
NSIZE=107464704
FLINK=0
MLINK=0
[00662]
AUDIO=1
PGS=
M2TS_TARGET=220672518
RATE=12952
NSIZE=213688320
FLINK=0
MLINK=0
[00663]
AUDIO=1
PGS=
M2TS_TARGET=182307823
RATE=12291
NSIZE=176750592
FLINK=0
MLINK=0
[00696]
AUDIO=10
PGS=111
M2TS_TARGET=8100003
RATE=8109
NSIZE=7796736
FLINK=0
MLINK=0
[00697]
AUDIO=10
PGS=111
M2TS_TARGET=8088157
RATE=8097
NSIZE=7882752
FLINK=0
MLINK=0
[00698]
AUDIO=10
PGS=111
M2TS_TARGET=8058541
RATE=8065
NSIZE=7858176
FLINK=0
MLINK=0
[00700]
AUDIO=1
PGS=
M2TS_TARGET=187404753
RATE=12648
NSIZE=181721088
FLINK=0
MLINK=0
[00701]
AUDIO=10
PGS=111
M2TS_TARGET=170724966
RATE=8210
NSIZE=165758976
FLINK=0
MLINK=0
[00702]
AUDIO=10
PGS=111
M2TS_TARGET=164185731
RATE=7656
NSIZE=159197184
FLINK=0
MLINK=0
[00703]
AUDIO=10
PGS=111
M2TS_TARGET=73353155
RATE=8126
NSIZE=71055360
FLINK=0
MLINK=0
[00706]
AUDIO=10
PGS=111
M2TS_TARGET=122145678
RATE=8039
NSIZE=118536192
FLINK=0
MLINK=0
[00722]
AUDIO=1
PGS=
M2TS_TARGET=7895652
RATE=7893
NSIZE=7311360
FLINK=0
MLINK=0
[00723]
AUDIO=1
PGS=
RATE=12648
NSIZE=181702656
FLINK=0
MLINK=0
[00728]
AUDIO=1
PGS=111111111
M2TS_TARGET=55162947
RATE=2595
NSIZE=55025664
FLINK=-1
MLINK=0
[00729]
AUDIO=1
PGS=111111111
M2TS_TARGET=89502814
RATE=2597
NSIZE=89149440
FLINK=-1
MLINK=0
[00730]
AUDIO=1
PGS=111111111
M2TS_TARGET=166540211
RATE=2611
NSIZE=166275072
FLINK=-1
MLINK=0
[00731]
AUDIO=1
PGS=111111111
M2TS_TARGET=100049107
RATE=2607
NSIZE=99944448
FLINK=-1
MLINK=0
[00732]
AUDIO=1
PGS=111111111
M2TS_TARGET=131371093
RATE=2620
NSIZE=131217408
FLINK=-1
MLINK=0
[00733]
AUDIO=1
PGS=111111111
M2TS_TARGET=189797734
RATE=2623
NSIZE=189566976
FLINK=-1
MLINK=0
[00734]
AUDIO=1
PGS=111111111
M2TS_TARGET=98953311
RATE=2614
NSIZE=98936832
FLINK=-1
MLINK=0
[00735]
AUDIO=1
PGS=111111111
M2TS_TARGET=157362182
RATE=2542
NSIZE=157132800
FLINK=-1
MLINK=0
[00736]
AUDIO=1
PGS=111111111
M2TS_TARGET=135348536
RATE=2603
NSIZE=135192576
FLINK=-1
MLINK=0
[00737]
AUDIO=1
PGS=111111111
M2TS_TARGET=60025910
RATE=2595
NSIZE=59412480
FLINK=-1
MLINK=0
[00738]
AUDIO=1
PGS=111111111
M2TS_TARGET=228772521
RATE=2551
NSIZE=228710400
FLINK=-1
MLINK=0
[00739]
AUDIO=1
PGS=111111111
M2TS_TARGET=83905371
RATE=2574
NSIZE=83767296
FLINK=0
MLINK=0
[00741]
AUDIO=1
PGS=111111111
M2TS_TARGET=298349623
RATE=2626
NSIZE=297940992
FLINK=-1
MLINK=0
[00742]
AUDIO=1
PGS=111111111
M2TS_TARGET=176651148
RATE=2612
NSIZE=176351232
FLINK=-1
MLINK=0
[00743]
AUDIO=1
PGS=111111111
M2TS_TARGET=147591831
RATE=2635
NSIZE=147320832
FLINK=-1
MLINK=0
[00744]
AUDIO=1
PGS=111111111
M2TS_TARGET=329304370
RATE=2618
NSIZE=328765440
FLINK=-1
MLINK=0
[00745]
AUDIO=1
PGS=111111111
M2TS_TARGET=169247123
RATE=2614
NSIZE=168990720
FLINK=-1
MLINK=0
[00746]
AUDIO=1
PGS=111111111
M2TS_TARGET=118603593
RATE=2614
NSIZE=118327296
FLINK=-1
MLINK=0
[00747]
AUDIO=1
PGS=111111111
M2TS_TARGET=82581531
RATE=2633
NSIZE=82397184
FLINK=-1
MLINK=0
[00748]
AUDIO=1
PGS=111111111
M2TS_TARGET=198318286
RATE=2615
NSIZE=197984256
FLINK=-1
MLINK=0
[00749]
AUDIO=1
PGS=111111111
M2TS_TARGET=49064992
RATE=2591
NSIZE=48918528
FLINK=-1
MLINK=0
[00750]
AUDIO=1
PGS=111111111
M2TS_TARGET=79978276
RATE=2581
NSIZE=79804416
FLINK=0
MLINK=0
BD-REBUILDER.LOG
[01:43:03] BD Rebuilder v0.26.03 (beta)
- Source: SLING_BLADE
- Input BD size: 45.94 GB
- Approximate total content: [06:33:04.986]
[01:43:03] PHASE ONE, Encoding
[13:15:47]PHASE ONE complete
[13:15:47]PHASE TWO - Rebuild Started
- [13:15:47] Rebuilding BD file Structure
[13:15:56] - Encode and Rebuild complete
- WORKFILES folder removed.
[13:15:57]JOB: SLING_BLADE finished.
Final size is 23.6 GB. What gives between v0.26.03 and v0.27.01?
leChameleon is offline   Reply With Quote
Old 10th August 2009, 00:12   #4491  |  Link
BD-REBUILDER.LOG
I don't know. You didn't post the information for Slingblade in your earlier posts.
I can tell you, though, that 0.27.1 uses a newer version of X264 and it is the first version where PRESETS are used. That means the the "--ultrafast" option was used for your encoding. I've done a lot of encoding with that setting, though, and have never seen undersizing anywhere near the extent that you're seeing -- and yours is the only report of it.
Old 10th August 2009, 01:12   #4492  |  Link
leChameleon
Oh sorry... it was the same run as Valkyrie showing a very reduced data size. I'm rerunning Valkyrie now with v0.28.2 to see what it does.
I figured there was some change between *26 and *27 since the results were so different.
I completely uninstalled all required software for BD-RB and reinstalled it fresh after rebooting with *28.2. We'll see what this run yields... fingers crossed.
Thanks for letting me know the differences in *26 and *27.
Old 10th August 2009, 10:15   #4493  |  Link
Adbear
That just means the second pass couldn't be done becuase the first pass crashed at 75 frames. Try running both the first and second passes without "--thread-input" set (just change where it says "--pass 2" to "--pass 1").
I ran the first pass as requested with hyper-threading on and it only encodes 75 frames then stops, doesn't come up with any error, just finishes as if it thinks that's the whole file. Turn hyper-threading back off and it goes through fine.
The same discs work fine on a standard i7 with hyper-threading, just not on a Dual Xeon i7 system
Old 10th August 2009, 10:30   #4494  |  Link
Furiousflea
I'm getting this error
08/10/09 [00:47:32] RebuildBDFiles() 00075 2202
08/10/09 [09:02:43] CorrectMPLS() 00063 2408
With...
Pinnochio
Resident Evil Degeneration
Cheers for nailing the PiP problems...This i assume is just some final teething problem.
Furiousflea is offline   Reply With Quote
Old 10th August 2009, 15:10   #4495  |  Link
With...
Pinnochio
Did you get both errors on each source? Also, were you using v0.28.01 or v0.28.02?
The first one is in the routine that copies files from the original to the destination directory. It says that the path was bad... odd because there haven't been any changes in that section for a long time. Any chance the source path was unmounted or corrupted in some way?
The second one is in an area of new code I added for the PiP processing where it updates the pip tables in the extension area, so it's likely I've made some kind of mistake there. I'll probably have to find one of those two titles to fix it (I don't own either).
It may be possible that that first error cause the second one -- but I don't know until I do some testing.
[Edit] I think I've found the source of the second one. I made a classic mistake by concentrating only on the PiP when testing -- I check the extension area of the MPLS for PiP without first checking whether extension data even exists! I'll see if I can find anything on the first error and post a fix early today.
Old 10th August 2009, 17:32   #4496  |  Link
leChameleon
[*] Valkyrie (2008) Region A: BD-RBV02603
BD-RBV02603 VALKYRIE.INF
[Status]
LABEL=VALKYRIE
SOURCE_SIZE=42911885717
SOURCE_VIDEO_SIZE=42544183296
REDUCTION=.55823249476346
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=10
REBUILD_COMPLETE=1
[00074]
AUDIO=10000
PGS=11111010
M2TS_TARGET=13775500522
RATE=10005
NSIZE=13321525248
FLINK=0
MLINK=0
[00172]
AUDIO=1
PGS=
M2TS_TARGET=493466521
RATE=6451
NSIZE=481892352
FLINK=0
MLINK=0
[00175]
AUDIO=1
PGS=
M2TS_TARGET=407406470
RATE=6451
NSIZE=398475264
FLINK=0
MLINK=0
[00176]
AUDIO=1
PGS=
M2TS_TARGET=860912620
RATE=6451
NSIZE=841138176
FLINK=0
MLINK=0
[00177]
AUDIO=1
PGS=
M2TS_TARGET=370272238
RATE=6449
NSIZE=361598976
FLINK=0
MLINK=0
[00178]
AUDIO=1
PGS=
M2TS_TARGET=379302850
RATE=6450
NSIZE=370563072
FLINK=0
MLINK=0
[00181]
AUDIO=1
PGS=
M2TS_TARGET=161535800
RATE=9577
NSIZE=156776448
FLINK=0
MLINK=0
[00182]
AUDIO=1
PGS=
M2TS_TARGET=192287211
RATE=9624
NSIZE=186691584
FLINK=0
MLINK=0
[00183]
AUDIO=1
PGS=
M2TS_TARGET=914677858
RATE=2667
NSIZE=902025216
FLINK=0
MLINK=0
[00184]
AUDIO=1
PGS=
M2TS_TARGET=6194183489
RATE=6476
NSIZE=6046654464
FLINK=0
MLINK=0
BD-RBV02603 BD-REBUILDER.LOG
[18:51:40] BD Rebuilder v0.26.03 (beta)
- Source: VALKYRIE
- Input BD size: 39.96 GB
- Approximate total content: [05:24:24.653]
[18:51:40] PHASE ONE, Encoding
- [18:51:40] Extracting A/V streams [VID_00074]
- [18:57:13] Collecting video information [00074]
- Video: 1920x1080, 23.976fps, 173,130 frames
- Bitrate: 10,005 Kbs
- [18:57:13] Reencoding: VID_00074, Pass 1 of 2
- [20:16:51] Reencoding: VID_00074, Pass 2 of 2
- [00:58:23] Video Encode complete
[09:04:35]PHASE ONE complete
[09:04:35]PHASE TWO - Rebuild Started
- [09:04:35] Rebuilding BD file Structure
[09:04:41] - Encode and Rebuild complete
[09:04:41]JOB: VALKYRIE finished.
Final size = 23.4 GB as expected.
[*] Valkyrie (2008) Region A: BD-RBV02701
The information for BD-RBV02701 has already been posted.
[*] Valkyrie (2008) Region A: BD-RBV02802
BD-RBV02802 VALKYRIE.INF
[Status]
LABEL=VALKYRIE
VERSION=v0.28.02 (beta)
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=2
COMPLETED=1
[00074]
AUDIO=10000
PGS=11111010
RATE=10005
NSIZE=3916130304
FLINK=0
MLINK=0
[00172]
AUDIO=1
PGS=
RATE=6451
BD-RBV02802 BD-REBUILDER.LOG
[16:59:13] BD Rebuilder v0.28.02 (beta)
- Source: VALKYRIE
[16:59:13] PHASE ONE, Encoding
- [16:59:13] Extracting A/V streams [VID_00074]
- [17:04:47] Reencoding: VID_00074 (1 of 10)
- [17:04:47] Collecting video information
- [17:04:47] Reencoding: VID_00074, Pass 1 of 2
- [18:00:51] Reencoding: VID_00074, Pass 2 of 2
- [18:18:33] Video Encode complete
- [18:18:33] Reencoding audio tracks (if req'd)
- [18:18:33] Multiplexing M2TS
- [18:20:17] Extracting A/V streams [VID_00172]
- [18:20:27] Reencoding: VID_00172 (2 of 10)
- [18:20:27] Collecting video information
- Video: 1920x1080, 29.970fps, 16,429 frames
- Bitrate: 6,451 Kbs
- [18:20:27] Reencoding: VID_00172, Pass 1 of 2
- [18:20:31] Reencoding: VID_00172, Pass 2 of 2
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[18:20:33] - Failed video encode, aborted
BD-RBV02802 LASTCMD.TXT
"D:\Downloads\BD-RB\BD-RBV02802\BD_Rebuilder\tools\x264.exe"
"J:\BD25 4\VALKYRIE (2008)\WORKFILES\VID_00172.AVS" --preset slow
--ref 4 --b-adapt 1 --bitrate 6451 --level 4.1 --sar 1:1 --fps 30000/1001
--aud --vbv-bufsize 25000 --keyint 24 --min-keyint 1 --ipratio 1.1
--pbratio 1.1 --vbv-maxrate 35000 --threads auto --thread-input
--stats "J:\BD25 4\VALKYRIE (2008)\WORKFILES\VID_00172.AVS.MKV.stats"
--pass 2 --output "J:\BD25 4\VALKYRIE (2008)\WORKFILES\VID_00172.AVS.MKV"
CMD: LASTCMD.TXT
x264 [error]: can't open output file `J:\BD25 4\VALKYRIE (2008)\WORKFILES\VID_00172.AVS.MKV'
Correct since the file does not exist.
There is obviously something going on between these three builds.
Old 10th August 2009, 17:56   #4497  |  Link
Not really. It should overwrite it or at least prompt to overwrite it. Does something else have the file open?
I'm confused. What happened to all the other M2TS files that were in your original post (the order is different now)?
Old 10th August 2009, 19:39   #4498  |  Link
Chefkoch_ico
[v0.28.01]- Rewrote the MPLS update routines to better handle
the exception of DTS audio demuxing/muxing.[/code]
O my god, you did it, I tried Kung Fu Panda (PiP title previously not playable with PowerDVD). What can I say, PowerDVD plays it. THX.
It is one of the titles with AC3+. I can watch the PiP track normally. However I do not hear the PiP audio, but thats not a big issue for me. Previously the complete movie did not play.
I just tested, I do not even hear the PiP audio on the original disc with PowerDVD.
best regards.
Chefkoch_ico is offline   Reply With Quote
Old 10th August 2009, 22:00   #4499  |  Link
leChameleon
This is the directory listing of the files that reside on disk after the application was closed.
Version BD-RBV02802
J:\Bd25 4\Valkyrie (2008)\WORKFILES>dir /b
00074.track_4113.264
00074.track_4352.dts
00074.track_4608.sup
00074.track_4609.sup
00074.track_4610.sup
00074.track_4611.sup
00074.track_4612.sup
00074.track_4614.sup
Perhaps since [x] Remove WORKFILES... was selected it deleted them afterward before I closed the application. Is this the expected behavior of the product? If so perhaps it may be a benefit to only Remove WORKFILES if successful.
[EDIT] I'm rerunning the full job yet again without Remove WORKFILES...
Old 10th August 2009, 22:08   #4500  |  Link
Shuttle99
Is there a thread on here for people that are using BD-RB that are having problems like the disc won't play and the player says incompatible disc, it only says this on full back, movie only works great. Thanks.
Shuttle99 is offline   Reply With Quote
