Old 1st October 2009, 19:57   #5441  |  Link
Originally Posted by drmih View Post
Has it ever been tried as non-conformant? At present you either keep 'silent' PiP or exclude it. I'm guessing that PCs may well handle non-conformant streams and perhaps even some SAPs. I know it's a bit sloppy but a beta which worked on some systems with AC3 as a second audio would surely be preferable to not at all, particularly if there is unlikely to be any movement on a freeware solution in the near future.
It doesn't matter. I won't write a program that (knowingly) creates non-compliant streams... I'll leave that to the hackers.
My plan is to demux/remux them myself if nothing else comes along soon. But I want to avoid having to do so if possible.
Old 1st October 2009, 19:59   #5442  |  Link
Originally Posted by Nav1 View Post
I have to wait 5 days before I can post. Hi everyone. Jdobbs first I want to say very nice program. Question for you jdobbs. I am using Bd rebuilder 8 month now. Started using older versions 20.03 and upgrading to newer versions. Some way along versions 20.09 to 24.01 not sure which versions everything started working fine. I have 14 blu ray movies which I rebuild to BD5,than burn with Img and than play on Sony blu ray player. It was superb video quality and sound no distortion at all. And each movie took to rebuild about 7 hours (Movie Only).Since I upgrading to newer versions and now I have 30.02.There is a bug.When it finish rebuild I burn with Img and than play on Sony blu ray player somewhere along the movie the video Freeze and audio is running in the background. Never happen with older versions. Is there a way I can download the older versions to test again. Because when I download the older versions and install on my PC it says "This beta has expired. Please upgrade to a newer versions" Any suggestion Jdobbs. Thanks.
Here’s the list of blu ray movies I rebuild to BD5 (Older Versions)
Valkyrie
Pink Panther
The Code
My Bloody Valentine
Push
Underworld
International
Defiance
Wanted
Friday The 13th
Yesman
The Spirit
Seven Pounds
Body Of Lies
I put that timeout in specifically to keep people from using older versions. This is a beta test. It doesn't make a lot of sense to test versions that are months old... if you have a bug, report it. By the way, I have a Sony Player also -- and I've not seen any problems like this. Are you sure your burner is good? Discs?
You haven't really given me anything to work with as far as helping you. Are you doing movie-only? Full? What specific disc is causing the issue? What settings are you using?
I'm sorry, and I really don't want to be rude, but this is a beta test -- I need information so I can fix current versions, not requests for old ones (which, by the way, have Bugs that have since been fixed).
Old 1st October 2009, 20:58   #5443  |  Link
Nav1
Thanks for the quick reply. I'm doing movies only and the burner is Lite-on. The only setting I did in ffdshow is Mpeg2 enable and VC1 disable. The movies I have problem is Crank2 (High Voltage) and Battle of Terra is animation. PS I also disable in ffdshow WMV 1/7 WMV 2/8 WMV 3/9 is that correct. No setting change in BD Rebuilder.
Nav1 is offline   Reply With Quote
Old 1st October 2009, 21:18   #5444  |  Link
turbojet
Hmmm... I meant for it to work that way -- but I missed it. I planned for movie-only to BD-5/9 to be written as AVCHD. Right now it outputs as "--avchd" only when "Strict" is selected" (which is on by default). I'll fix it and put out a quick release.
Thanks for the new version
Are you positive about the players, even with the new settings? The whole purpose of the new setting was to make it compatible across more players.
Ya I've still been keeping up with that database and while the audio formats matter in powerdvd/windvd, empty directories have a lot more to do with playability as weird as it sounds.
A wild guess but could the newly reported freeze problems have something to do with x264's --slices or new --nal-hrd implementation as opposed to tsmuxer's nal-hrd?
Also any news on BDSup2Sub? TSMuxer sub resizing success rate is decresing greatly for me on newer titles.
Old 2nd October 2009, 02:54   #5445  |  Link
DGenerateKane
Former Kanenite
I'm having trouble with Pirates of the Caribbean Dead Man's Chest. It always fails encoding at the same spot. I've ripped it multiple times with the last three stable versions of AnyDVD HD, and have tried two versions of BD-RE. Anyone know what my problem is? I know others have been successful so I'm hoping whatever my problem is can be fixed easily.
[23:10:23] BD Rebuilder v0.30.02 (beta)
  - Source:  PIRATES2
  - Input BD size: 39.87 GB
  - Approximate total content: [03:31:26.089]
  - Target BD size: 22.46 GB
  - Windows Version: 6.1 [7600]
[23:10:26] PHASE ONE, Encoding
 - [23:10:26] Extracting A/V streams [VID_00002]
 - [23:10:26] Reencoding: VID_00002 (1 of 18)
 - [23:10:26] Collecting video information
   - Video: 1920x1080, 23.976fps, 24 frames
   - Bitrate: 500 Kbs
 - [23:10:26] Reencoding: VID_00002, Pass 1 of 2
 - [23:10:27] Reencoding: VID_00002, Pass 2 of 2
 - [23:10:27] Video Encode complete
 - [23:10:27] Reencoding audio tracks (if req'd)
 - [23:10:27] Multiplexing M2TS
 - [23:10:28] Extracting A/V streams [VID_00013]
 - [23:10:29] Reencoding: VID_00013 (2 of 18)
 - [23:10:29] Collecting video information
   - Video: 1920x1080, 23.976fps, 217 frames
 - [23:10:29] Reencoding: VID_00013, Pass 1 of 1
 - [23:10:33] Video Encode complete
 - [23:10:33] Reencoding audio tracks (if req'd)
 - [23:10:33] Multiplexing M2TS
 - [23:10:33] Extracting A/V streams [VID_00019]
 - [23:10:34] Reencoding: VID_00019 (3 of 18)
 - [23:10:34] Collecting video information
   - Video: 1920x1080, 23.976fps, 298 frames
 - [23:10:34] Reencoding: VID_00019, Pass 1 of 1
 - [23:10:41] Video Encode complete
 - [23:10:41] Reencoding audio tracks (if req'd)
 - [23:10:41] Multiplexing M2TS
 - [23:10:41] Extracting A/V streams [VID_00027]
 - [23:10:42] Reencoding: VID_00027 (4 of 18)
 - [23:10:42] Collecting video information
   - Video: 1920x1080, 23.976fps, 393 frames
 - [23:10:42] Reencoding: VID_00027, Pass 1 of 1
 - [23:10:50] Video Encode complete
 - [23:10:50] Reencoding audio tracks (if req'd)
 - [23:10:50] Multiplexing M2TS
 - [23:10:51] Extracting A/V streams [VID_00024]
 - [23:10:53] Reencoding: VID_00024 (5 of 18)
 - [23:10:53] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,689 frames
 - [23:10:53] Reencoding: VID_00024, Pass 1 of 1
 - [23:11:25] Video Encode complete
 - [23:11:25] Reencoding audio tracks (if req'd)
 - [23:11:25] Multiplexing M2TS
 - [23:11:27] Extracting A/V streams [VID_00018]
 - [23:11:29] Reencoding: VID_00018 (6 of 18)
 - [23:11:29] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,176 frames
 - [23:11:29] Reencoding: VID_00018, Pass 1 of 1
 - [23:11:50] Video Encode complete
 - [23:11:50] Reencoding audio tracks (if req'd)
 - [23:11:50] Multiplexing M2TS
 - [23:11:52] Extracting A/V streams [VID_00026]
 - [23:11:54] Reencoding: VID_00026 (7 of 18)
 - [23:11:54] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,537 frames
 - [23:11:54] Reencoding: VID_00026, Pass 1 of 1
 - [23:12:28] Video Encode complete
 - [23:12:28] Reencoding audio tracks (if req'd)
 - [23:12:28] Multiplexing M2TS
 - [23:12:29] Extracting A/V streams [VID_00010]
 - [23:12:32] Reencoding: VID_00010 (8 of 18)
 - [23:12:32] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,057 frames
 - [23:12:32] Reencoding: VID_00010, Pass 1 of 1
 - [23:13:19] Video Encode complete
 - [23:13:19] Reencoding audio tracks (if req'd)
 - [23:13:19] Multiplexing M2TS
 - [23:13:21] Extracting A/V streams [VID_00022]
 - [23:13:24] Reencoding: VID_00022 (9 of 18)
 - [23:13:24] Collecting video information
   - Video: 1920x1080, 23.976fps, 2,160 frames
 - [23:13:24] Reencoding: VID_00022, Pass 1 of 1
 - [23:14:02] Video Encode complete
 - [23:14:02] Reencoding audio tracks (if req'd)
 - [23:14:02] Multiplexing M2TS
 - [23:14:04] Extracting A/V streams [VID_00012]
 - [23:14:07] Reencoding: VID_00012 (10 of 18)
 - [23:14:07] Collecting video information
   - Video: 1920x1080, 23.976fps, 1,824 frames
 - [23:14:07] Reencoding: VID_00012, Pass 1 of 1
 - [23:14:41] Video Encode complete
 - [23:14:41] Reencoding audio tracks (if req'd)
 - [23:14:41] Multiplexing M2TS
 - [23:14:44] Extracting A/V streams [VID_00021]
 - [23:14:48] Reencoding: VID_00021 (11 of 18)
 - [23:14:48] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,599 frames
 - [23:14:48] Reencoding: VID_00021, Pass 1 of 1
 - [23:16:04] Video Encode complete
 - [23:16:04] Reencoding audio tracks (if req'd)
 - [23:16:04] Multiplexing M2TS
 - [23:16:07] Extracting A/V streams [VID_00017]
 - [23:16:13] Reencoding: VID_00017 (12 of 18)
 - [23:16:13] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,697 frames
 - [23:16:13] Reencoding: VID_00017, Pass 1 of 1
 - [23:17:20] Video Encode complete
 - [23:17:20] Reencoding audio tracks (if req'd)
 - [23:17:20] Multiplexing M2TS
 - [23:17:23] Extracting A/V streams [VID_00015]
 - [23:17:31] Reencoding: VID_00015 (13 of 18)
 - [23:17:31] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,586 frames
 - [23:17:31] Reencoding: VID_00015, Pass 1 of 1
 - [23:18:41] Video Encode complete
 - [23:18:41] Reencoding audio tracks (if req'd)
 - [23:18:41] Multiplexing M2TS
 - [23:18:44] Extracting A/V streams [VID_00016]
 - [23:18:52] Reencoding: VID_00016 (14 of 18)
 - [23:18:52] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,612 frames
 - [23:18:52] Reencoding: VID_00016, Pass 1 of 1
 - [23:19:56] Video Encode complete
 - [23:19:56] Reencoding audio tracks (if req'd)
 - [23:19:56] Multiplexing M2TS
 - [23:19:59] Extracting A/V streams [VID_00014]
 - [23:20:07] Reencoding: VID_00014 (15 of 18)
 - [23:20:07] Collecting video information
   - Video: 1920x1080, 23.976fps, 3,683 frames
 - [23:20:07] Reencoding: VID_00014, Pass 1 of 1
 - [23:21:13] Video Encode complete
 - [23:21:13] Reencoding audio tracks (if req'd)
 - [23:21:13] Multiplexing M2TS
 - [23:21:18] Extracting A/V streams [VID_00023]
 - [23:21:35] Reencoding: VID_00023 (16 of 18)
 - [23:21:35] Collecting video information
   - Video: 1920x1080, 23.976fps, 14,173 frames
 - [23:21:35] Reencoding: VID_00023, Pass 1 of 1
 - [23:26:37] Video Encode complete
 - [23:26:37] Reencoding audio tracks (if req'd)
 - [23:26:37] Multiplexing M2TS
 - [23:26:47] Extracting A/V streams [VID_00025]
 - [23:27:38] Reencoding: VID_00025 (17 of 18)
 - [23:27:38] Collecting video information
   - Video: 1920x1080, 23.976fps, 42,717 frames
 - [23:27:38] Reencoding: VID_00025, Pass 1 of 1
 - [23:42:53] Video Encode complete
 - [23:42:53] Reencoding audio tracks (if req'd)
 - [23:42:53] Multiplexing M2TS
 - [23:43:18] Extracting A/V streams [VID_00001]
 - [23:52:14] Reencoding: VID_00001 (18 of 18)
 - [23:52:14] Collecting video information
   - Video: 1920x1080, 23.976fps, 216,720 frames
   - Bitrate: 7,583 Kbs
 - [23:52:14] Reencoding: VID_00001, Pass 1 of 2
 - [23:52:14] Reencoding: VID_00001, Pass 2 of 2
  - Encode failed.  Retrying.
  - Reached retry limit.  Aborting.
[23:55:17] - Failed video encode, aborted
DGenerateKane is offline   Reply With Quote
Old 2nd October 2009, 04:53   #5446  |  Link
I'll check it out.
Old 2nd October 2009, 15:33   #5447  |  Link
marius1
Originally Posted by nelly09 View Post
[22:04:11] BD Rebuilder v0.30.01 (beta)
- Source: LOGICAL_VOLUME_ID
- Input BD size: 20.92 GB
- Approximate total content: [01:43:59.983]
- MOVIE-ONLY mode enabled
[22:04:11] PHASE ONE, Encoding
- [22:04:11] Extracting A/V streams [VID_00009]
- Error in attempt to extract audio/subs.
- AV frame too large (60005 bytes). Increase AV buffer.
[22:08:48] - Failed to retrieve audio, abort
any help with this? the movie is invincible, tried to do a movie only to bd25, highest quality, didnt change any other settings
I'm having the same problem with I Love You Man, except my log is missing the "AV frame too large" line.
marius1 is offline   Reply With Quote
Old 2nd October 2009, 16:46   #5448  |  Link
By-Tor
  - Source:  PIRATES2
   - Bitrate: 500 Kbs
I had this problem doing that film and was advised to use DVDFAB HDDcrypter and it worked for me I had tried like you
doing various rips with no success until i used dvdfab, hope this helps ..... i think the posts where about 219 in forum
By-Tor is offline   Reply With Quote
Old 2nd October 2009, 18:10   #5449  |  Link
GaPony
I put POTC 2 (Dead Man's Chest) in to run before going to bed last night and it completed without any issues.. Final output was 21.4gb.
[02:34:11] BD Rebuilder v0.30.02 (beta)
  - Source:  PIRATES2
  - Windows Version: 5.1 [2600]
  - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[02:34:13] PHASE ONE, Encoding
 - [02:34:13] Extracting A/V streams [VID_00002]
 - [02:34:14] Reencoding: VID_00002 (1 of 18)
 - [02:34:14] Collecting video information
   - Bitrate: 500 Kbs
 - [02:34:14] Reencoding: VID_00002, Pass 1 of 2
 - [02:34:15] Reencoding: VID_00002, Pass 2 of 2
 - [02:34:15] Video Encode complete
 - [02:34:15] Reencoding audio tracks (if req'd)
 - [02:34:15] Multiplexing M2TS
 - [02:34:16] Extracting A/V streams [VID_00013]
 - [02:34:17] Reencoding: VID_00013 (2 of 18)
 - [02:34:17] Collecting video information
 - [02:34:17] Reencoding: VID_00013, Pass 1 of 1
 - [02:34:21] Video Encode complete
 - [02:34:21] Reencoding audio tracks (if req'd)
 - [02:34:21] Multiplexing M2TS
 - [02:34:21] Extracting A/V streams [VID_00019]
 - [02:34:22] Reencoding: VID_00019 (3 of 18)
 - [02:34:22] Collecting video information
 - [02:34:22] Reencoding: VID_00019, Pass 1 of 1
 - [02:34:28] Video Encode complete
 - [02:34:28] Reencoding audio tracks (if req'd)
 - [02:34:28] Multiplexing M2TS
 - [02:34:29] Extracting A/V streams [VID_00027]
 - [02:34:30] Reencoding: VID_00027 (4 of 18)
 - [02:34:30] Collecting video information
 - [02:34:30] Reencoding: VID_00027, Pass 1 of 1
 - [02:34:38] Video Encode complete
 - [02:34:38] Reencoding audio tracks (if req'd)
 - [02:34:38] Multiplexing M2TS
 - [02:34:38] Extracting A/V streams [VID_00024]
 - [02:34:40] Reencoding: VID_00024 (5 of 18)
 - [02:34:40] Collecting video information
 - [02:34:40] Reencoding: VID_00024, Pass 1 of 1
 - [02:35:12] Video Encode complete
 - [02:35:12] Reencoding audio tracks (if req'd)
 - [02:35:12] Multiplexing M2TS
 - [02:35:13] Extracting A/V streams [VID_00018]
 - [02:35:15] Reencoding: VID_00018 (6 of 18)
 - [02:35:15] Collecting video information
 - [02:35:15] Reencoding: VID_00018, Pass 1 of 1
 - [02:35:36] Video Encode complete
 - [02:35:36] Reencoding audio tracks (if req'd)
 - [02:35:36] Multiplexing M2TS
 - [02:35:37] Extracting A/V streams [VID_00026]
 - [02:35:40] Reencoding: VID_00026 (7 of 18)
 - [02:35:40] Collecting video information
 - [02:35:40] Reencoding: VID_00026, Pass 1 of 1
 - [02:36:12] Video Encode complete
 - [02:36:12] Reencoding audio tracks (if req'd)
 - [02:36:12] Multiplexing M2TS
 - [02:36:13] Extracting A/V streams [VID_00010]
 - [02:36:15] Reencoding: VID_00010 (8 of 18)
 - [02:36:15] Collecting video information
 - [02:36:15] Reencoding: VID_00010, Pass 1 of 1
 - [02:37:02] Video Encode complete
 - [02:37:02] Reencoding audio tracks (if req'd)
 - [02:37:02] Multiplexing M2TS
 - [02:37:03] Extracting A/V streams [VID_00022]
 - [02:37:06] Reencoding: VID_00022 (9 of 18)
 - [02:37:06] Collecting video information
 - [02:37:06] Reencoding: VID_00022, Pass 1 of 1
 - [02:37:44] Video Encode complete
 - [02:37:44] Reencoding audio tracks (if req'd)
 - [02:37:44] Multiplexing M2TS
 - [02:37:45] Extracting A/V streams [VID_00012]
 - [02:37:49] Reencoding: VID_00012 (10 of 18)
 - [02:37:49] Collecting video information
 - [02:37:49] Reencoding: VID_00012, Pass 1 of 1
 - [02:38:22] Video Encode complete
 - [02:38:22] Reencoding audio tracks (if req'd)
 - [02:38:22] Multiplexing M2TS
 - [02:38:24] Extracting A/V streams [VID_00021]
 - [02:38:29] Reencoding: VID_00021 (11 of 18)
 - [02:38:29] Collecting video information
 - [02:38:29] Reencoding: VID_00021, Pass 1 of 1
 - [02:39:42] Video Encode complete
 - [02:39:42] Reencoding audio tracks (if req'd)
 - [02:39:42] Multiplexing M2TS
 - [02:39:44] Extracting A/V streams [VID_00017]
 - [02:39:51] Reencoding: VID_00017 (12 of 18)
 - [02:39:51] Collecting video information
 - [02:39:51] Reencoding: VID_00017, Pass 1 of 1
 - [02:40:56] Video Encode complete
 - [02:40:56] Reencoding audio tracks (if req'd)
 - [02:40:56] Multiplexing M2TS
 - [02:40:59] Extracting A/V streams [VID_00015]
 - [02:41:06] Reencoding: VID_00015 (13 of 18)
 - [02:41:06] Collecting video information
 - [02:41:06] Reencoding: VID_00015, Pass 1 of 1
 - [02:42:15] Video Encode complete
 - [02:42:15] Reencoding audio tracks (if req'd)
 - [02:42:15] Multiplexing M2TS
 - [02:42:18] Extracting A/V streams [VID_00016]
 - [02:42:25] Reencoding: VID_00016 (14 of 18)
 - [02:42:25] Collecting video information
 - [02:42:25] Reencoding: VID_00016, Pass 1 of 1
 - [02:43:27] Video Encode complete
 - [02:43:27] Reencoding audio tracks (if req'd)
 - [02:43:27] Multiplexing M2TS
 - [02:43:30] Extracting A/V streams [VID_00014]
 - [02:43:37] Reencoding: VID_00014 (15 of 18)
 - [02:43:37] Collecting video information
 - [02:43:37] Reencoding: VID_00014, Pass 1 of 1
 - [02:44:43] Video Encode complete
 - [02:44:43] Reencoding audio tracks (if req'd)
 - [02:44:43] Multiplexing M2TS
 - [02:44:45] Extracting A/V streams [VID_00023]
 - [02:45:03] Reencoding: VID_00023 (16 of 18)
 - [02:45:03] Collecting video information
 - [02:45:03] Reencoding: VID_00023, Pass 1 of 1
 - [02:49:52] Video Encode complete
 - [02:49:52] Reencoding audio tracks (if req'd)
 - [02:49:52] Multiplexing M2TS
 - [02:49:58] Extracting A/V streams [VID_00025]
 - [02:50:47] Reencoding: VID_00025 (17 of 18)
 - [02:50:47] Collecting video information
 - [02:50:47] Reencoding: VID_00025, Pass 1 of 1
 - [03:05:13] Video Encode complete
 - [03:05:13] Reencoding audio tracks (if req'd)
 - [03:05:13] Multiplexing M2TS
 - [03:05:31] Extracting A/V streams [VID_00001]
 - [03:13:20] Reencoding: VID_00001 (18 of 18)
 - [03:13:20] Collecting video information
   - Bitrate: 8,489 Kbs
 - [03:13:21] Reencoding: VID_00001, Pass 1 of 2
 - [05:26:26] Reencoding: VID_00001, Pass 2 of 2
 - [10:13:18] Video Encode complete
 - [10:13:18] Reencoding audio tracks (if req'd)
 - [10:13:18] Multiplexing M2TS
[10:23:03]PHASE ONE complete
[10:23:03]PHASE TWO - Rebuild Started
 - [10:23:03] Rebuilding BD file Structure
[10:23:29] - Encode and Rebuild complete
 - WORKFILES folder removed.
[10:23:29]JOB: PIRATES2 finished.
GaPony is offline   Reply With Quote
Old 3rd October 2009, 12:05   #5450  |  Link
DGenerateKane
Former Kanenite
Same problem at the same spot, wondering if there is a problem with the disc at this point.
Old 3rd October 2009, 14:04   #5451  |  Link
I ripped it with AnyDVD and it worked fine.
Old 3rd October 2009, 19:05   #5452  |  Link
dragonknight
The audio on the movie is out of sync and does not match up with scenes. i can't even make out what is being said. also the org. rip with anydvdhd plays fine.
[23:33:44] BD Rebuilder v0.30.02 (beta)
  - Source:  OBSERVE_AND_REPORT
  - Input BD size: 20.28 GB
  - Approximate total content: [02:36:10.110]
  - Target BD size: 7.72 GB
  - SHUTDOWN at completion enabled
[23:33:50] PHASE ONE, Encoding
 - [23:33:50] Extracting A/V streams [VID_00011]
 - [23:33:51] Reencoding: VID_00011 (1 of 27)
 - [23:34:01] Extracting A/V streams [VID_00015]
 - [23:34:02] Reencoding: VID_00015 (2 of 27)
 - [23:34:12] Extracting A/V streams [VID_00018]
 - [23:34:13] Reencoding: VID_00018 (3 of 27)
 - [23:34:24] Extracting A/V streams [VID_00010]
 - [23:34:25] Reencoding: VID_00010 (4 of 27)
 - [23:34:30] Extracting A/V streams [VID_00021]
 - [23:34:31] Reencoding: VID_00021 (5 of 27)
 - [23:34:38] Extracting A/V streams [VID_00023]
 - [23:34:39] Reencoding: VID_00023 (6 of 27)
 - [23:34:47] Extracting A/V streams [VID_00020]
 - [23:34:49] Reencoding: VID_00020 (7 of 27)
 - [23:34:58] Extracting A/V streams [VID_00004]
 - [23:34:59] Reencoding: VID_00004 (8 of 27)
 - [23:35:09] Extracting A/V streams [VID_00024]
 - [23:35:10] Reencoding: VID_00024 (9 of 27)
 - [23:35:22] Extracting A/V streams [VID_00008]
 - [23:35:23] Reencoding: VID_00008 (10 of 27)
 - [23:35:35] Extracting A/V streams [VID_00019]
 - [23:35:36] Reencoding: VID_00019 (11 of 27)
 - [23:35:51] Extracting A/V streams [VID_00013]
 - [23:35:52] Reencoding: VID_00013 (12 of 27)
 - [23:36:06] Extracting A/V streams [VID_00017]
 - [23:36:08] Reencoding: VID_00017 (13 of 27)
 - [23:36:24] Extracting A/V streams [VID_00014]
 - [23:36:26] Reencoding: VID_00014 (14 of 27)
 - [23:36:42] Extracting A/V streams [VID_00012]
 - [23:36:44] Reencoding: VID_00012 (15 of 27)
 - [23:37:02] Extracting A/V streams [VID_00005]
 - [23:37:04] Reencoding: VID_00005 (16 of 27)
 - [23:37:28] Extracting A/V streams [VID_00007]
 - [23:37:30] Reencoding: VID_00007 (17 of 27)
 - [23:37:54] Extracting A/V streams [VID_00016]
 - [23:37:57] Reencoding: VID_00016 (18 of 27)
 - [23:38:25] Extracting A/V streams [VID_00022]
 - [23:38:28] Reencoding: VID_00022 (19 of 27)
 - [23:39:00] Extracting A/V streams [VID_00028]
 - [23:39:02] Reencoding: VID_00028 (20 of 27)
 - [23:39:35] Extracting A/V streams [VID_00006]
 - [23:39:38] Reencoding: VID_00006 (21 of 27)
 - [23:40:14] Extracting A/V streams [VID_00029]
 - [23:40:17] Reencoding: VID_00029 (22 of 27)
 - [23:41:05] Extracting A/V streams [VID_00009]
 - [23:41:14] Reencoding: VID_00009 (23 of 27)
 - [23:41:14] Reencoding secondary video [TRK_02]
 - [23:46:08] Extracting A/V streams [VID_00027]
 - [23:46:14] Reencoding: VID_00027 (24 of 27)
 - [23:47:25] Extracting A/V streams [VID_00026]
 - [23:47:31] Reencoding: VID_00026 (25 of 27)
 - [23:48:50] Extracting A/V streams [VID_00025]
 - [23:48:59] Reencoding: VID_00025 (26 of 27)
 - [23:51:03] Extracting A/V streams [VID_00000]
 - [23:56:20] Reencoding: VID_00000 (27 of 27)
 - [23:56:20] Reencoding secondary video [TRK_02]
[03:28:43]PHASE ONE complete
[03:28:43]PHASE TWO - Rebuild Started
 - [03:28:43] Rebuilding BD file Structure
[03:28:56] - Encode and Rebuild complete
dragonknight is offline   Reply With Quote
Old 3rd October 2009, 23:32   #5453  |  Link
DGenerateKane
Former Kanenite
I'm going to get another copy and try again soon.
Old 4th October 2009, 02:24   #5454  |  Link
I'll take a look at it -- but having seen "Observe and Report" I might want to call this a hidden feature. You may end up thanking BD Rebuilder for saving you an hour and a half of your life.
Old 4th October 2009, 02:41   #5455  |  Link
dragonknight
ok thanks and i am guessing that this wasn't a good movie?
Old 4th October 2009, 03:20   #5456  |  Link
chudm
pretty lame! maybe worst seth rogen movie ever made!
anyway sorry for the offstopic!
chudm is offline   Reply With Quote
Old 4th October 2009, 14:58   #5457  |  Link
I'm not going to use it. I don't want a dependency on the java engine built it. I'm in the process of writing my own code to resize the subtitles -- it's almost done.
Old 4th October 2009, 15:00   #5458  |  Link
It's could be called "Paul Blart, Mall Cop II" -- it's hard to believe that two studios could come up with the same terrible idea at almost the same time.
Too bad -- I normally like Seth Rogen.
Old 4th October 2009, 19:01   #5459  |  Link
dragonknight
The org. (NOTORIOUS BIG) rip with anydvdhd plays back fine.sorry for the off topic question but what firmware is your sony bdp s360 running and did you have any playback issues after you update it? i got the following error message:
[00:14:33] BD Rebuilder v0.30.02 (beta)
  - Source:  NOTORIOUS_BIG
  - Input BD size: 41.79 GB
  - Approximate total content: [04:48:58.370]
[00:14:41] PHASE ONE, Encoding
 - [00:14:41] Extracting A/V streams [VID_00157]
 - [00:14:45] Reencoding: VID_00157 (1 of 86)
 - [00:14:53] Extracting A/V streams [VID_00100]
 - [00:14:55] Reencoding: VID_00100 (2 of 86)
 - [00:15:00] Extracting A/V streams [VID_00308]
 - [00:15:03] Reencoding: VID_00308 (3 of 86)
 - [00:15:20] Extracting A/V streams [VID_00306]
 - [00:15:23] Reencoding: VID_00306 (4 of 86)
 - [00:15:43] Extracting A/V streams [VID_00310]
 - [00:15:47] Reencoding: VID_00310 (5 of 86)
 - [00:16:08] Extracting A/V streams [VID_00314]
 - [00:16:12] Reencoding: VID_00314 (6 of 86)
 - [00:16:37] Extracting A/V streams [VID_00352]
 - [00:16:41] Reencoding: VID_00352 (7 of 86)
 - [00:16:41] Reencoding secondary video [TRK_02]
 - [00:17:19] Extracting A/V streams [VID_00001]
 - [00:17:24] Reencoding: VID_00001 (8 of 86)
 - [00:17:37] Extracting A/V streams [VID_00350]
 - [00:17:41] Reencoding: VID_00350 (9 of 86)
 - [00:17:41] Reencoding secondary video [TRK_02]
 - [00:18:41] Extracting A/V streams [VID_00312]
 - [00:18:45] Reencoding: VID_00312 (10 of 86)
 - [00:19:17] Extracting A/V streams [VID_00313]
 - [00:19:22] Reencoding: VID_00313 (11 of 86)
 - [00:19:54] Extracting A/V streams [VID_00398]
 - [00:19:58] Reencoding: VID_00398 (12 of 86)
 - [00:21:12] Extracting A/V streams [VID_00397]
 - [00:21:17] Reencoding: VID_00397 (13 of 86)
 - [00:22:33] Extracting A/V streams [VID_00393]
 - [00:22:37] Reencoding: VID_00393 (14 of 86)
 - [00:23:54] Extracting A/V streams [VID_00370]
 - [00:23:59] Reencoding: VID_00370 (15 of 86)
 - [00:23:59] Reencoding secondary video [TRK_02]
 - [00:24:13] Extracting A/V streams [VID_00394]
 - [00:24:18] Reencoding: VID_00394 (16 of 86)
 - [00:25:44] Extracting A/V streams [VID_00374]
 - [00:25:49] Reencoding: VID_00374 (17 of 86)
 - [00:26:08] Extracting A/V streams [VID_00369]
 - [00:26:14] Reencoding: VID_00369 (18 of 86)
 - [00:26:14] Reencoding secondary video [TRK_02]
 - [00:26:34] Extracting A/V streams [VID_00340]
 - [00:26:41] Reencoding: VID_00340 (19 of 86)
 - [00:26:41] Reencoding secondary video [TRK_02]
 - [00:27:49] Extracting A/V streams [VID_00399]
 - [00:27:56] Reencoding: VID_00399 (20 of 86)
 - [00:29:28] Extracting A/V streams [VID_00328]
 - [00:29:34] Reencoding: VID_00328 (21 of 86)
 - [00:29:34] Reencoding secondary video [TRK_02]
 - [00:30:54] Extracting A/V streams [VID_00307]
 - [00:31:00] Reencoding: VID_00307 (22 of 86)
 - [00:31:44] Extracting A/V streams [VID_00003]
 - [00:31:52] Reencoding: VID_00003 (23 of 86)
 - [00:32:13] Extracting A/V streams [VID_00319]
 - [00:32:19] Reencoding: VID_00319 (24 of 86)
 - [00:32:38] Extracting A/V streams [VID_00309]
 - [00:32:45] Reencoding: VID_00309 (25 of 86)
 - [00:33:29] Extracting A/V streams [VID_00366]
 - [00:33:36] Reencoding: VID_00366 (26 of 86)
 - [00:33:36] Reencoding secondary video [TRK_02]
 - [00:33:59] Extracting A/V streams [VID_00364]
 - [00:34:04] Reencoding: VID_00364 (27 of 86)
 - [00:34:04] Reencoding secondary video [TRK_02]
 - [00:34:26] Extracting A/V streams [VID_00358]
 - [00:34:33] Reencoding: VID_00358 (28 of 86)
 - [00:34:33] Reencoding secondary video [TRK_02]
 - [00:34:57] Extracting A/V streams [VID_00344]
 - [00:35:03] Reencoding: VID_00344 (29 of 86)
 - [00:35:03] Reencoding secondary video [TRK_02]
 - [00:36:32] Extracting A/V streams [VID_00316]
 - [00:36:40] Reencoding: VID_00316 (30 of 86)
 - [00:37:32] Extracting A/V streams [VID_00359]
 - [00:37:38] Reencoding: VID_00359 (31 of 86)
 - [00:37:38] Reencoding secondary video [TRK_02]
 - [00:38:03] Extracting A/V streams [VID_00346]
 - [00:38:10] Reencoding: VID_00346 (32 of 86)
 - [00:38:10] Reencoding secondary video [TRK_02]
 - [00:39:33] Extracting A/V streams [VID_00305]
 - [00:39:41] Reencoding: VID_00305 (33 of 86)
 - [00:40:09] Extracting A/V streams [VID_00311]
 - [00:40:17] Reencoding: VID_00311 (34 of 86)
 - [00:41:14] Extracting A/V streams [VID_00330]
 - [00:41:22] Reencoding: VID_00330 (35 of 86)
 - [00:41:22] Reencoding secondary video [TRK_02]
 - [00:43:00] Extracting A/V streams [VID_00392]
 - [00:43:08] Reencoding: VID_00392 (36 of 86)
 - [00:45:27] Extracting A/V streams [VID_00395]
 - [00:45:37] Reencoding: VID_00395 (37 of 86)
 - [00:48:05] Extracting A/V streams [VID_00322]
 - [00:48:13] Reencoding: VID_00322 (38 of 86)
 - [00:48:13] Reencoding secondary video [TRK_02]
 - [00:50:16] Extracting A/V streams [VID_00355]
 - [00:50:24] Reencoding: VID_00355 (39 of 86)
 - [00:50:24] Reencoding secondary video [TRK_02]
 - [00:50:57] Extracting A/V streams [VID_00342]
 - [00:51:06] Reencoding: VID_00342 (40 of 86)
 - [00:51:06] Reencoding secondary video [TRK_02]
 - [00:53:09] Extracting A/V streams [VID_00332]
 - [00:53:20] Reencoding: VID_00332 (41 of 86)
 - [00:53:20] Reencoding secondary video [TRK_02]
 - [00:55:16] Extracting A/V streams [VID_00360]
 - [00:55:26] Reencoding: VID_00360 (42 of 86)
 - [00:55:26] Reencoding secondary video [TRK_02]
 - [00:56:03] Extracting A/V streams [VID_00338]
 - [00:56:13] Reencoding: VID_00338 (43 of 86)
 - [00:56:13] Reencoding secondary video [TRK_02]
 - [00:58:15] Extracting A/V streams [VID_00365]
 - [00:58:26] Reencoding: VID_00365 (44 of 86)
 - [00:58:26] Reencoding secondary video [TRK_02]
 - [00:59:03] Extracting A/V streams [VID_00337]
 - [00:59:15] Reencoding: VID_00337 (45 of 86)
 - [00:59:15] Reencoding secondary video [TRK_02]
 - [01:01:29] Extracting A/V streams [VID_00327]
 - [01:01:39] Reencoding: VID_00327 (46 of 86)
 - [01:01:39] Reencoding secondary video [TRK_02]
 - [01:04:20] Extracting A/V streams [VID_00367]
 - [01:04:32] Reencoding: VID_00367 (47 of 86)
 - [01:04:32] Reencoding secondary video [TRK_02]
 - [01:05:13] Extracting A/V streams [VID_00336]
 - [01:05:24] Reencoding: VID_00336 (48 of 86)
 - [01:05:24] Reencoding secondary video [TRK_02]
 - [01:08:01] Extracting A/V streams [VID_00341]
 - [01:08:12] Reencoding: VID_00341 (49 of 86)
 - [01:08:12] Reencoding secondary video [TRK_02]
 - [01:11:00] Extracting A/V streams [VID_00372]
 - [01:11:14] Reencoding: VID_00372 (50 of 86)
 - [01:14:27] Extracting A/V streams [VID_00347]
 - [01:14:40] Reencoding: VID_00347 (51 of 86)
 - [01:14:40] Reencoding secondary video [TRK_02]
 - [01:17:36] Extracting A/V streams [VID_00348]
 - [01:17:49] Reencoding: VID_00348 (52 of 86)
 - [01:17:49] Reencoding secondary video [TRK_02]
 - [01:20:50] Extracting A/V streams [VID_00333]
 - [01:21:04] Reencoding: VID_00333 (53 of 86)
 - [01:21:04] Reencoding secondary video [TRK_02]
 - [01:23:50] Extracting A/V streams [VID_00363]
 - [01:24:03] Reencoding: VID_00363 (54 of 86)
 - [01:24:03] Reencoding secondary video [TRK_02]
 - [01:27:07] Extracting A/V streams [VID_00315]
 - [01:27:22] Reencoding: VID_00315 (55 of 86)
 - [01:31:04] Extracting A/V streams [VID_00368]
 - [01:31:20] Reencoding: VID_00368 (56 of 86)
 - [01:31:20] Reencoding secondary video [TRK_02]
 - [01:34:47] Extracting A/V streams [VID_00373]
 - [01:35:02] Reencoding: VID_00373 (57 of 86)
 - [01:38:57] Extracting A/V streams [VID_00371]
 - [01:39:13] Reencoding: VID_00371 (58 of 86)
 - [01:43:07] Extracting A/V streams [VID_00396]
 - [01:43:24] Reencoding: VID_00396 (59 of 86)
 - [01:53:38] Extracting A/V streams [VID_00331]
 - [01:53:59] Reencoding: VID_00331 (60 of 86)
 - [01:53:59] Reencoding secondary video [TRK_02]
 - [01:57:37] Extracting A/V streams [VID_00304]
 - [01:57:57] Reencoding: VID_00304 (61 of 86)
 - [02:05:50] Extracting A/V streams [VID_00343]
 - [02:06:08] Reencoding: VID_00343 (62 of 86)
 - [02:06:08] Reencoding secondary video [TRK_02]
 - [02:10:33] Extracting A/V streams [VID_00324]
 - [02:10:54] Reencoding: VID_00324 (63 of 86)
 - [02:10:54] Reencoding secondary video [TRK_02]
 - [02:15:33] Extracting A/V streams [VID_00362]
 - [02:15:55] Reencoding: VID_00362 (64 of 86)
 - [02:15:55] Reencoding secondary video [TRK_02]
 - [02:20:57] Extracting A/V streams [VID_00356]
 - [02:21:20] Reencoding: VID_00356 (65 of 86)
 - [02:21:20] Reencoding secondary video [TRK_02]
 - [02:26:29] Extracting A/V streams [VID_00303]
 - [02:26:57] Reencoding: VID_00303 (66 of 86)
 - [02:36:57] Extracting A/V streams [VID_00334]
 - [02:37:23] Reencoding: VID_00334 (67 of 86)
 - [02:37:23] Reencoding secondary video [TRK_02]
 - [02:42:51] Extracting A/V streams [VID_00361]
 - [02:43:20] Reencoding: VID_00361 (68 of 86)
 - [02:43:20] Reencoding secondary video [TRK_02]
 - [02:50:21] Extracting A/V streams [VID_00321]
 - [02:50:50] Reencoding: VID_00321 (69 of 86)
 - [02:50:50] Reencoding secondary video [TRK_02]
 - [02:58:11] Extracting A/V streams [VID_00302]
 - [02:58:46] Reencoding: VID_00302 (70 of 86)
 - [03:20:26] Extracting A/V streams [VID_00301]
 - [03:21:04] Reencoding: VID_00301 (71 of 86)
 - [03:43:11] Extracting A/V streams [VID_00349]
 - [03:43:41] Reencoding: VID_00349 (72 of 86)
 - [03:43:41] Reencoding secondary video [TRK_02]
 - [03:51:34] Extracting A/V streams [VID_00339]
 - [03:52:08] Reencoding: VID_00339 (73 of 86)
 - [03:52:08] Reencoding secondary video [TRK_02]
 - [03:59:27] Extracting A/V streams [VID_00325]
 - [04:00:07] Reencoding: VID_00325 (74 of 86)
 - [04:00:07] Reencoding secondary video [TRK_02]
 - [04:08:56] Extracting A/V streams [VID_00351]
 - [04:09:35] Reencoding: VID_00351 (75 of 86)
 - [04:09:35] Reencoding secondary video [TRK_02]
 - [04:19:20] Extracting A/V streams [VID_00381]
 - [04:20:03] Reencoding: VID_00381 (76 of 86)
 - [04:20:03] Reencoding secondary video [TRK_02]
 - [04:31:48] Extracting A/V streams [VID_00383]
 - [04:32:38] Reencoding: VID_00383 (77 of 86)
 - [04:32:38] Reencoding secondary video [TRK_02]
 - [04:45:31] Extracting A/V streams [VID_00323]
 - [04:46:23] Reencoding: VID_00323 (78 of 86)
 - [04:46:23] Reencoding secondary video [TRK_02]
 - [04:59:49] Extracting A/V streams [VID_00354]
 - Error in attempt to MKVMERGE.
[05:00:43] - Failed to retrieve audio, aborted
Old 5th October 2009, 02:09   #5460  |  Link
equad
BD25 re-encode
Hey,
Using a BD25 setting for resizing my blue ray. I have tried BD-25 and Custom size. The encoding is working, but i am getting total movie size of 5-10GB from a 30+GB original file. I feel that it should be a little closer to 22GB... Anyways u have tried encoding full movie and movie only. Also tried highest quality instead of high with same results. Also tried 3 different BD's.
[Status]
LABEL=DRIVE_2
VERSION=v0.30.02 (beta)
SOURCE_SIZE=35409180672
SOURCE_VIDEO_SIZE=35409180672
TARGET_SIZE=24589107200
REDUCTION=.694427454500351
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00000]
AUDIO=1
PGS=10
M2TS_TARGET=24589107200
RATE=19585
NSIZE=5221109760
FLINK=0
MLINK=0
- Target BD size: 22.90 GB
Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[18:57:04] - Encode and Rebuild complete
[18:57:04]JOB: DRIVE_2 finished.
"C:\Users\equad\Desktop\BD_Rebuilder\tools\x264.exe" "C:\USERS\EQUAD\DESKTOP\BD2\WORKFILES\VID_00000.AVS" --preset slow --ref 4 --b-adapt 1 --qpmin=0 --bitrate 19585 --level 4.1 --sar 1:1 --fps 24000/1001 --aud --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "C:\USERS\EQUAD\DESKTOP\BD2\WORKFILES\VID_00000.AVS.MKV.stats" --pass 2 --output "C:\USERS\EQUAD\DESKTOP\BD2\WORKFILES\VID_00000.AVS.MKV"
Total size 8.87GB
equad is offline   Reply With Quote
